  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.8k Aufrufe 2 Beobachtet
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
    EACCES
    Was sagt ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib ?
      AlCalzoneA Offline
      AlCalzone
      Kann es sein, dass ioBroker nach der Installation bereits läuft?
      • AlCalzoneA AlCalzone
        EACCES
        mrMuppet
        @AlCalzone sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
        Läuft noch nicht.
        root@iobroker_v2:~ # ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib
        total 382
        drwxr-xr-x  9 root  wheel      28 May 21 18:05 .
        drwxr-xr-x  6 root  wheel      17 May 21 18:06 ..
        -rw-r--r--  1 root  wheel  225379 Oct 26  1985 adapter.js
        -rw-r--r--  1 root  wheel    2012 Oct 26  1985 dbdump.js
        -rw-r--r--  1 root  wheel    1828 Oct 26  1985 defaultObjs.js
        drwxr-xr-x  2 root  wheel       3 May 21 18:05 img
        -rw-r--r--  1 root  wheel    9114 Oct 26  1985 letsencrypt.js
        -rw-r--r--  1 root  wheel   26624 Oct 26  1985 letsencryptStore.js
        -rw-r--r--  1 root  wheel   11236 Oct 26  1985 logger.js
        -rw-r--r--  1 root  wheel    7177 Oct 26  1985 multihostClient.js
        -rw-r--r--  1 root  wheel    9174 Oct 26  1985 multihostServer.js
        drwxr-xr-x  2 root  wheel       5 May 21 18:05 objects
        -rw-r--r--  1 root  wheel     531 Oct 26  1985 objects.js
        -rw-r--r--  1 root  wheel    2644 Oct 26  1985 password.js
        -rw-r--r--  1 root  wheel    4544 Oct 26  1985 preinstall_check.js
        -rw-r--r--  1 root  wheel    1755 Oct 26  1985 renewal.conf.tpl
        -rw-r--r--  1 root  wheel    6026 Oct 26  1985 restart.js
        drwxr-xr-x  2 root  wheel       3 May 21 18:05 scripts
        -rw-r--r--  1 root  wheel    1809 Oct 26  1985 session.js
        drwxr-xr-x  2 root  wheel      14 May 21 18:05 setup
        -rw-r--r--  1 root  wheel  154618 Oct 26  1985 setup.js
        drwxr-xr-x  2 root  wheel       5 May 21 18:05 states
        -rw-r--r--  1 root  wheel     523 Oct 26  1985 states.js
        -rw-r--r--  1 root  wheel   47344 Oct 26  1985 tools.js
        -rw-r--r--  1 root  wheel    3808 Oct 26  1985 uploadFiles.js
        drwxr-xr-x  2 root  wheel       3 May 21 18:05 vis
        drwxr-xr-x  3 root  wheel       3 May 21 18:05 www
        -rw-r--r--  1 root  wheel   13190 Oct 26  1985 zipFiles.js
        ioBroker auf NUC (Celeron mit Ubuntu-Server)
        Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
          AlCalzoneA Offline
          AlCalzone
          Hmm, da werden die Berechtigungen nicht richtig gesetzt... Evtl hat das mit der Meldung oben zu tun "unknown variable platform". Ich hab mal den Debug-Mode aktiviert, um (hoffentlich) zu sehen was los ist, bitte nochmal installieren (ohne System neu aufsetzen):
          rm -rf /opt/iobroker
          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
            mrMuppet
            root@iobroker_v2:~ # curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
            + INSTALLER_VERSION=2019-05-21
            + [[ 0 -eq 0 ]]
            + IS_ROOT=true
            + ROOT_GROUP=root
            ++ uname
            + unamestr=FreeBSD
            + '[' FreeBSD = Linux ']'
            + '[' FreeBSD = Darwin ']'
            + '[' FreeBSD = FreeBSD ']'
            + platform=freebsd
            + ROOT_GROUP=wheel
            + IOB_DIR=/opt/iobroker
            + '[' freebsd = osx ']'
            + CONTROLLER_DIR=/opt/iobroker/node_modules/iobroker.js-controller
            + INSTALLER_INFO_FILE=/opt/iobroker/INSTALLER_INFO.txt
            + INSTALL_TARGET=iobroker
            + IOB_USER=iobroker
            + test -t 1
            ++ which tput
            ++ tput colors
            + ncolors=94
            + test -n 94
            + test 94 -ge 8
            ++ tput cols
            + termcols=94
            ++ tput bold
            + bold=
            ++ tput smul
            + underline=
            ++ tput smso
            + standout=
            ++ tput sgr0
            + normal=
            ++ tput setaf 0
            + black=''
            ++ tput setaf 1
            + red=''
            ++ tput setaf 2
            + green=''
            ++ tput setaf 3
            + yellow=''
            ++ tput setaf 4
            + blue=''
            ++ tput setaf 5
            + magenta=''
            ++ tput setaf 6
            + cyan=''
            ++ tput setaf 7
            + white=''
            + HLINE===========================================================================
            + print_bold 'Welcome to the ioBroker installer!' 'Installer version: 2019-05-21' '' 'You might need to enter your password a couple of times.'
            + title='Welcome to the ioBroker installer!'
            + echo
            + echo ==========================================================================
            + echo
            + echo '    Welcome to the ioBroker installer!'
            + for text in "${@:2}"
            + echo '    Installer version: 2019-05-21'
            + echo '    '
            + echo '    You might need to enter your password a couple of times.'
            + echo
            + echo
            + export AUTOMATED_INSTALLER=true
            + AUTOMATED_INSTALLER=true
            + NUM_STEPS=4
            + print_step 'Installing prerequisites' 1 4
            + stepname='Installing prerequisites'
            + stepnr=1
            + steptotal=4
            + echo
            + echo '    Installing prerequisites (1/4)'
            + echo
            + case "$platform" in
            + packages=("sudo" "git" "curl" "bash" "unzip" "avahi-libdns" "dbus" "nss_mdns" "gcc" "python")
            + declare -a packages
            + for pkg in "${packages[@]}"
            + install_package_freebsd sudo
            + package=sudo
            + pkg info sudo
            + install_package_freebsd git
            + package=git
            + pkg info git
            + install_package_freebsd curl
            + package=curl
            + pkg info curl
            + install_package_freebsd bash
            + package=bash
            + pkg info bash
            + install_package_freebsd unzip
            + package=unzip
            + pkg info unzip
            + install_package_freebsd avahi-libdns
            + package=avahi-libdns
            + pkg info avahi-libdns
            + install_package_freebsd dbus
            + package=dbus
            + pkg info dbus
            + install_package_freebsd nss_mdns
            + package=nss_mdns
            + pkg info nss_mdns
            + install_package_freebsd gcc
            + package=gcc
            + pkg info gcc
            + install_package_freebsd python
            + package=python
            + pkg info python
            + ln -s /usr/local/include/avahi-compat-libdns_sd/dns_sd.h /usr/include/dns_sd.h
            ln: /usr/include/dns_sd.h: File exists
            + sed -i -e s/#enable-dbus/enable-dbus/ /usr/local/etc/avahi/avahi-daemon.conf
            + sed -i -e 's/hosts: file dns/hosts: file dns mdns/' /etc/nsswitch.conf
            + sysrc -f /etc/rc.conf dbus_enable=YES
            dbus_enable: YES -> YES
            + sysrc -f /etc/rc.conf avahi_daemon_enable=YES
            avahi_daemon_enable: YES -> YES
            + service dbus start
            dbus already running?  (pid=55380).
            + service avahi-daemon start
            avahi_daemon already running?  (pid=55387).
            + print_step 'Creating ioBroker user and directory' 2 4
            + stepname='Creating ioBroker user and directory'
            + stepnr=2
            + steptotal=4
            + echo
            + echo '    Creating ioBroker user and directory (2/4)'
            + echo
            + '[' freebsd = linux ']'
            + '[' freebsd = freebsd ']'
            + create_user_freebsd iobroker
            + username=iobroker
            + id iobroker
            + '[' 0 -ne 0 ']'
            + groups=(audio bluetooth dialout gpio i2c redis tty)
            + declare -a groups
            + for grp in "${groups[@]}"
            + '[' true = true ']'
            + getent group audio
            + getent group bluetooth
            + getent group dialout
            + getent group gpio
            + getent group i2c
            + getent group redis
            + getent group tty
            tty:*:4:iobroker
            + pw group mod tty -m iobroker
            + mkdir -p /opt/iobroker
            + cd /opt/iobroker
            + echo 'Directory /opt/iobroker created'
            + touch /opt/iobroker/INSTALLER_INFO.txt
            + chmod 777 /opt/iobroker/INSTALLER_INFO.txt
            + echo 'Installer version: 2019-05-21'
            ++ date +%F
            + echo 'Installation date 2019-05-21'
            + echo 'Platform: freebsd'
            + print_step 'Installing ioBroker' 3 4
            + stepname='Installing ioBroker'
            + stepnr=3
            + steptotal=4
            + echo
            + echo '    Installing ioBroker (3/4)'
            + echo
            + echo 'Installed as root'
            + npm i iobroker --loglevel error --unsafe-perm
            + npm i --production --loglevel error --unsafe-perm
            ../src/unix_dgram.cc:53:13: warning: unused function 'SetNonBlock' [-Wunused-function]
            inline void SetNonBlock(int fd) {
            ../src/unix_dgram.cc:65:13: warning: unused function 'SetCloExec' [-Wunused-function]
            inline void SetCloExec(int fd) {
            2 warnings generated.
            ../src/serialport.cpp:95:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
              data->callback.Call(2, argv);
            ../../nan/nan.h:1739:3: note: 'Call' has been explicitly marked deprecated here
              NAN_DEPRECATED inline v8::Local<v8::Value>
            ../../nan/nan.h:104:40: note: expanded from macro 'NAN_DEPRECATED'
            # define NAN_DEPRECATED __attribute__((deprecated))
            ../src/serialport.cpp:150:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
              data->callback.Call(1, argv);
            ../src/serialport.cpp:188:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:231:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:285:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:336:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:383:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:424:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
            8 warnings generated.
            ../src/serialport_unix.cpp:384:20: warning: variable 'outbaud' is uninitialized when used here
                  [-Wuninitialized]
              data->baudRate = outbaud;
            ../src/serialport_unix.cpp:369:14: note: initialize the variable 'outbaud' to silence this
                  warning
              int outbaud;
                          = 0
            1 warning generated.
            ../src/poller.cpp:69:17: warning: 'Call' is deprecated [-Wdeprecated-declarations]
              obj->callback.Call(2, argv);
            + print_step 'Finalizing installation' 4 4
            + stepname='Finalizing installation'
            + stepnr=4
            + steptotal=4
            + echo
            + echo '    Finalizing installation (4/4)'
            + echo
            + INITSYSTEM=unknown
            + [[ freebsd = \f\r\e\e\b\s\d ]]
            + [[ -d /usr/local/etc/rc.d ]]
            + INITSYSTEM=rc.d
            + [[ -n '' ]]
            + echo 'init system: rc.d'
            + IOB_NODE_CMDLINE=node
            ++ which bash
            + BASH_CMDLINE=/usr/local/bin/bash
            + '[' iobroker '!=' root ']'
            + IOB_NODE_CMDLINE='sudo -H -u iobroker node'
            + '[' rc.d = systemd ']'
            + '[' rc.d = launchctl ']'
            ++ cat
            + IOB_EXECUTABLE='#!/usr/local/bin/bash
            sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $@'
            + IOB_BIN_PATH=/usr/local/bin
            + ln -sfn /opt/iobroker/iobroker /usr/local/bin/iobroker
            + ln -sfn /opt/iobroker/iobroker /opt/iobroker/iob
            + echo '#!/usr/local/bin/bash
            + make_executable /opt/iobroker/iobroker
            + file=/opt/iobroker/iobroker
            + chmod 755 /opt/iobroker/iobroker
            + [[ rc.d = \i\n\i\t\.\d ]]
            + '[' rc.d = rc.d ']'
            + echo 'Enabling autostart...'
            ++ cat
            + RCD_FILE='#!/bin/sh
            # PROVIDE: iobroker
            # REQUIRE: DAEMON
            # KEYWORD: shutdown
            . /etc/rc.subr
            name="iobroker"
            rcvar="iobroker_enable"
            load_rc_config $name
            iobroker_enable=${iobroker_enable-"NO"}
            iobroker_pidfile=${iobroker_pidfile-"/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid"}
            PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
            NODECMD=$(which node)
            iobroker_start ()
            su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
            iobroker_stop ()
            su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
            iobroker_status ()
            su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status"
            PATH="${PATH}:/usr/local/bin"
            pidfile="${iobroker_pidfile}"
            start_cmd=iobroker_start
            stop_cmd=iobroker_stop
            status_cmd=iobroker_status
            run_rc_command "$1"'
            + SERVICE_FILENAME=/usr/local/etc/rc.d/iobroker
            + echo '#!/bin/sh
            # PROVIDE: iobroker
            # REQUIRE: DAEMON
            # KEYWORD: shutdown
            . /etc/rc.subr
            name="iobroker"
            iobroker_start ()
            iobroker_stop ()
            iobroker_status ()
            + set_root_permissions /usr/local/etc/rc.d/iobroker
            + file=/usr/local/etc/rc.d/iobroker
            + chown root:wheel /usr/local/etc/rc.d/iobroker
            + chmod 755 /usr/local/etc/rc.d/iobroker
            + sysrc iobroker_enable=YES
            iobroker_enable: YES -> YES
            + service iobroker start
            Before fixing dir permissions...
            platform: Undefined variable.
            + echo 'Autostart enabled!'
            Autostart enabled!
            + echo 'Autostart: rc.d'
            AlCalzoneA HomoranH 4 Antworten Letzte Antwort
            • M mrMuppet
              + [[ 0 -eq 0 ]]
              + IS_ROOT=true
              + ROOT_GROUP=root
              ++ uname
              + unamestr=FreeBSD
              + platform=freebsd
              + ROOT_GROUP=wheel
              + IOB_USER=iobroker
              + test -t 1
              ++ which tput
              ++ tput colors
              + ncolors=94
              + test -n 94
              + test 94 -ge 8
              ++ tput cols
              + termcols=94
              ++ tput bold
              + bold=
              ++ tput smul
              + underline=
              ++ tput smso
              + standout=
              ++ tput sgr0
              + normal=
              ++ tput setaf 0
              + black=''
              ++ tput setaf 1
              + red=''
              ++ tput setaf 2
              + green=''
              ++ tput setaf 3
              + yellow=''
              ++ tput setaf 4
              + blue=''
              ++ tput setaf 5
              + magenta=''
              ++ tput setaf 6
              + cyan=''
              ++ tput setaf 7
              + white=''
              + echo
              + echo
              + echo '    '
              + echo
              + echo
              + NUM_STEPS=4
              + stepnr=1
              + steptotal=4
              + echo
              + echo
              + package=sudo
              + pkg info sudo
              + package=git
              + pkg info git
              + package=curl
              + pkg info curl
              + package=bash
              + pkg info bash
              + package=unzip
              + pkg info unzip
              + package=dbus
              + pkg info dbus
              + package=nss_mdns
              + pkg info nss_mdns
              + package=gcc
              + pkg info gcc
              + package=python
              + pkg info python
              + stepnr=2
              + steptotal=4
              + echo
              + echo
              + username=iobroker
              + id iobroker
              + '[' 0 -ne 0 ']'
              + declare -a groups
              + getent group gpio
              + getent group i2c
              + getent group tty
              tty:*:4:iobroker
              + cd /opt/iobroker
              ++ date +%F
              + stepnr=3
              + steptotal=4
              + echo
              + echo
                    [-Wuninitialized]
                    warning
                int outbaud;
                            = 0
              + stepnr=4
              + steptotal=4
              + echo
              + echo
              + INITSYSTEM=rc.d
              + [[ -n '' ]]
              ++ which bash
              ++ cat
              ++ cat
              # PROVIDE: iobroker
              # REQUIRE: DAEMON
              # KEYWORD: shutdown
              . /etc/rc.subr
              name="iobroker"
              iobroker_start ()
              iobroker_stop ()
              iobroker_status ()
              + echo '#!/bin/sh
              # PROVIDE: iobroker
              # REQUIRE: DAEMON
              # KEYWORD: shutdown
              . /etc/rc.subr
              name="iobroker"
              iobroker_start ()
              iobroker_stop ()
              iobroker_status ()
              Autostart enabled!
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @mrMuppet Danke, schau ich mir später an
              • M mrMuppet
                + [[ 0 -eq 0 ]]
                + IS_ROOT=true
                + ROOT_GROUP=root
                ++ uname
                + unamestr=FreeBSD
                + platform=freebsd
                + ROOT_GROUP=wheel
                + IOB_USER=iobroker
                + test -t 1
                ++ which tput
                ++ tput colors
                + ncolors=94
                + test -n 94
                + test 94 -ge 8
                ++ tput cols
                + termcols=94
                ++ tput bold
                + bold=
                ++ tput smul
                + underline=
                ++ tput smso
                + standout=
                ++ tput sgr0
                + normal=
                ++ tput setaf 0
                + black=''
                ++ tput setaf 1
                + red=''
                ++ tput setaf 2
                + green=''
                ++ tput setaf 3
                + yellow=''
                ++ tput setaf 4
                + blue=''
                ++ tput setaf 5
                + magenta=''
                ++ tput setaf 6
                + cyan=''
                ++ tput setaf 7
                + white=''
                + echo
                + echo
                + echo '    '
                + echo
                + echo
                + NUM_STEPS=4
                + stepnr=1
                + steptotal=4
                + echo
                + echo
                + package=sudo
                + pkg info sudo
                + package=git
                + pkg info git
                + package=curl
                + pkg info curl
                + package=bash
                + pkg info bash
                + package=unzip
                + pkg info unzip
                + package=dbus
                + pkg info dbus
                + package=nss_mdns
                + pkg info nss_mdns
                + package=gcc
                + pkg info gcc
                + package=python
                + pkg info python
                + stepnr=2
                + steptotal=4
                + echo
                + echo
                + username=iobroker
                + id iobroker
                + '[' 0 -ne 0 ']'
                + declare -a groups
                + getent group gpio
                + getent group i2c
                + getent group tty
                tty:*:4:iobroker
                + cd /opt/iobroker
                ++ date +%F
                + stepnr=3
                + steptotal=4
                + echo
                + echo
                      [-Wuninitialized]
                      warning
                  int outbaud;
                              = 0
                + stepnr=4
                + steptotal=4
                + echo
                + echo
                + INITSYSTEM=rc.d
                + [[ -n '' ]]
                ++ which bash
                ++ cat
                ++ cat
                # PROVIDE: iobroker
                # REQUIRE: DAEMON
                # KEYWORD: shutdown
                . /etc/rc.subr
                name="iobroker"
                iobroker_start ()
                iobroker_stop ()
                iobroker_status ()
                + echo '#!/bin/sh
                # PROVIDE: iobroker
                # REQUIRE: DAEMON
                # KEYWORD: shutdown
                . /etc/rc.subr
                name="iobroker"
                iobroker_start ()
                iobroker_stop ()
                iobroker_status ()
                Autostart enabled!
                platform=freebsd
                Und später
                  platform=freebsd
                  Und später
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @Homoran Genau das verwirrt mich. Da scheint FreeBSD etwas anders zu machen als alle anderen Betriebssysteme. Muss ich morgen mal lesen. Heute Abend musste ich erst mal Blues Brothers schauen 😁
                  • M mrMuppet
                    + [[ 0 -eq 0 ]]
                    + IS_ROOT=true
                    + ROOT_GROUP=root
                    ++ uname
                    + unamestr=FreeBSD
                    + platform=freebsd
                    + ROOT_GROUP=wheel
                    + IOB_USER=iobroker
                    + test -t 1
                    ++ which tput
                    ++ tput colors
                    + ncolors=94
                    + test -n 94
                    + test 94 -ge 8
                    ++ tput cols
                    + termcols=94
                    ++ tput bold
                    + bold=
                    ++ tput smul
                    + underline=
                    ++ tput smso
                    + standout=
                    ++ tput sgr0
                    + normal=
                    ++ tput setaf 0
                    + black=''
                    ++ tput setaf 1
                    + red=''
                    ++ tput setaf 2
                    + green=''
                    ++ tput setaf 3
                    + yellow=''
                    ++ tput setaf 4
                    + blue=''
                    ++ tput setaf 5
                    + magenta=''
                    ++ tput setaf 6
                    + cyan=''
                    ++ tput setaf 7
                    + white=''
                    + echo
                    + echo
                    + echo '    '
                    + echo
                    + echo
                    + NUM_STEPS=4
                    + stepnr=1
                    + steptotal=4
                    + echo
                    + echo
                    + package=sudo
                    + pkg info sudo
                    + package=git
                    + pkg info git
                    + package=curl
                    + pkg info curl
                    + package=bash
                    + pkg info bash
                    + package=unzip
                    + pkg info unzip
                    + package=dbus
                    + pkg info dbus
                    + package=nss_mdns
                    + pkg info nss_mdns
                    + package=gcc
                    + pkg info gcc
                    + package=python
                    + pkg info python
                    + stepnr=2
                    + steptotal=4
                    + echo
                    + echo
                    + username=iobroker
                    + id iobroker
                    + '[' 0 -ne 0 ']'
                    + declare -a groups
                    + getent group gpio
                    + getent group i2c
                    + getent group tty
                    tty:*:4:iobroker
                    + cd /opt/iobroker
                    ++ date +%F
                    + stepnr=3
                    + steptotal=4
                    + echo
                    + echo
                          [-Wuninitialized]
                          warning
                      int outbaud;
                                  = 0
                    + stepnr=4
                    + steptotal=4
                    + echo
                    + echo
                    + INITSYSTEM=rc.d
                    + [[ -n '' ]]
                    ++ which bash
                    ++ cat
                    ++ cat
                    # PROVIDE: iobroker
                    # REQUIRE: DAEMON
                    # KEYWORD: shutdown
                    . /etc/rc.subr
                    name="iobroker"
                    iobroker_start ()
                    iobroker_stop ()
                    iobroker_status ()
                    + echo '#!/bin/sh
                    # PROVIDE: iobroker
                    # REQUIRE: DAEMON
                    # KEYWORD: shutdown
                    . /etc/rc.subr
                    name="iobroker"
                    iobroker_start ()
                    iobroker_stop ()
                    iobroker_status ()
                    Autostart enabled!
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    • service iobroker start
                    • echo 'Autostart enabled!'
                      Autostart enabled!
                    • echo 'Autostart: rc.d'
                    Und auch das läuft in einer Reihenfolge ab, die eigentlich nicht sein kann 🤔
                    • M mrMuppet
                      + [[ 0 -eq 0 ]]
                      + IS_ROOT=true
                      + ROOT_GROUP=root
                      ++ uname
                      + unamestr=FreeBSD
                      + platform=freebsd
                      + ROOT_GROUP=wheel
                      + IOB_USER=iobroker
                      + test -t 1
                      ++ which tput
                      ++ tput colors
                      + ncolors=94
                      + test -n 94
                      + test 94 -ge 8
                      ++ tput cols
                      + termcols=94
                      ++ tput bold
                      + bold=
                      ++ tput smul
                      + underline=
                      ++ tput smso
                      + standout=
                      ++ tput sgr0
                      + normal=
                      ++ tput setaf 0
                      + black=''
                      ++ tput setaf 1
                      + red=''
                      ++ tput setaf 2
                      + green=''
                      ++ tput setaf 3
                      + yellow=''
                      ++ tput setaf 4
                      + blue=''
                      ++ tput setaf 5
                      + magenta=''
                      ++ tput setaf 6
                      + cyan=''
                      ++ tput setaf 7
                      + white=''
                      + echo
                      + echo
                      + echo '    '
                      + echo
                      + echo
                      + NUM_STEPS=4
                      + stepnr=1
                      + steptotal=4
                      + echo
                      + echo
                      + package=sudo
                      + pkg info sudo
                      + package=git
                      + pkg info git
                      + package=curl
                      + pkg info curl
                      + package=bash
                      + pkg info bash
                      + package=unzip
                      + pkg info unzip
                      + package=dbus
                      + pkg info dbus
                      + package=nss_mdns
                      + pkg info nss_mdns
                      + package=gcc
                      + pkg info gcc
                      + package=python
                      + pkg info python
                      + stepnr=2
                      + steptotal=4
                      + echo
                      + echo
                      + username=iobroker
                      + id iobroker
                      + '[' 0 -ne 0 ']'
                      + declare -a groups
                      + getent group gpio
                      + getent group i2c
                      + getent group tty
                      tty:*:4:iobroker
                      + cd /opt/iobroker
                      ++ date +%F
                      + stepnr=3
                      + steptotal=4
                      + echo
                      + echo
                            [-Wuninitialized]
                            warning
                        int outbaud;
                                    = 0
                      + stepnr=4
                      + steptotal=4
                      + echo
                      + echo
                      + INITSYSTEM=rc.d
                      + [[ -n '' ]]
                      ++ which bash
                      ++ cat
                      ++ cat
                      # PROVIDE: iobroker
                      # REQUIRE: DAEMON
                      # KEYWORD: shutdown
                      . /etc/rc.subr
                      name="iobroker"
                      iobroker_start ()
                      iobroker_stop ()
                      iobroker_status ()
                      + echo '#!/bin/sh
                      # PROVIDE: iobroker
                      # REQUIRE: DAEMON
                      # KEYWORD: shutdown
                      . /etc/rc.subr
                      name="iobroker"
                      iobroker_start ()
                      iobroker_stop ()
                      iobroker_status ()
                      Autostart enabled!
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @mrMuppet Ich habe nochmal einen Versuch gestartet. Probierst du bitte nochmal:
                        mrMuppet
                        schrieb am zuletzt editiert von mrMuppet
                        @AlCalzone komme gerade nur über's Smartphone dran, aber versucht hab ichs trotzdem Mal:
                        root@iobroker_v2:~ # rm -rf /opt/iobroker
                        + [[ 0 -eq 0 ]]
                        + IS_ROOT=true
                        + ROOT_GROUP=root
                        ++ get_platform
                        +++ uname
                        ++ unamestr=FreeBSD
                        ++ local platform=
                        ++ '[' FreeBSD = Linux ']'
                        ++ '[' FreeBSD = Darwin ']'
                        ++ '[' FreeBSD = FreeBSD ']'
                        ++ platform=freebsd
                        ++ ROOT_GROUP=wheel
                        ++ echo freebsd
                        + platform=freebsd
                        + '[' freebsd = '' ']'
                        + IOB_USER=iobroker
                        + test -t 1
                        ++ which tput
                        ++ tput colors
                        + ncolors=83
                        + test -n 83
                        + test 83 -ge 8
                        ++ tput cols
                        + termcols=83
                        ++ tput bold
                        + bold=
                        ++ tput smul
                        + underline=
                        ++ tput smso
                        + standout=
                        ++ tput sgr0
                        + normal=
                        ++ tput setaf 0
                        + black=''
                        ++ tput setaf 1
                        + red=''
                        ++ tput setaf 2
                        + green=''
                        ++ tput setaf 3
                        + yellow=''
                        ++ tput setaf 4
                        + blue=''
                        ++ tput setaf 5
                        + magenta=''
                        ++ tput setaf 6
                        + cyan=''
                        ++ tput setaf 7
                        + white=''
                        + echo
                        + echo
                        + echo '    '
                        + echo
                        + echo
                        + NUM_STEPS=4
                        + stepnr=1
                        + steptotal=4
                        + echo
                        + echo
                        + package=sudo
                        + pkg info sudo
                        + package=git
                        + pkg info git
                        + package=curl
                        + pkg info curl
                        + package=bash
                        + pkg info bash
                        + package=unzip
                        + pkg info unzip
                        + package=dbus
                        + pkg info dbus
                        + package=nss_mdns
                        + pkg info nss_mdns
                        + package=gcc
                        + pkg info gcc
                        + package=python
                        + pkg info python
                        Starting dbus.
                        Starting avahi-daemon.
                        + stepnr=2
                        + steptotal=4
                        + echo
                        + echo
                        + username=iobroker
                        + id iobroker
                        + '[' 0 -ne 0 ']'
                        + declare -a groups
                        + getent group gpio
                        + getent group i2c
                        + getent group tty
                        tty:*:4:iobroker
                        + cd /opt/iobroker
                        ++ date +%F
                        + echo 'Installation date 2019-05-22'
                        + stepnr=3
                        + steptotal=4
                        + echo
                        + echo
                              [-Wunused-function]
                              [-Wunused-function]
                              when used here [-Wuninitialized]
                              silence this warning
                          int outbaud;
                                      = 0
                        + stepnr=4
                        + steptotal=4
                        + echo
                        + echo
                        + INITSYSTEM=rc.d
                        + [[ -n '' ]]
                        ++ which bash
                        ++ cat
                        ++ cat
                        # PROVIDE: iobroker
                        # REQUIRE: DAEMON
                        # KEYWORD: shutdown
                        . /etc/rc.subr
                        name="iobroker"
                        iobroker_start ()
                        iobroker_stop ()
                        iobroker_status ()
                        + echo '#!/bin/sh
                        # PROVIDE: iobroker
                        # REQUIRE: DAEMON
                        # KEYWORD: shutdown
                        . /etc/rc.subr
                        name="iobroker"
                        iobroker_start ()
                        iobroker_stop ()
                        iobroker_status ()
                        + chown root:root /usr/local/etc/rc.d/iobroker
                        chown: root: illegal group name
                        Illegal variable name.
                        Autostart enabled!
                        Edit:
                        root@iobroker_v2:~ # iobroker start
                        Starting iobroker controller daemon...
                        iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                        Error: Failed to write pidfile (EACCES)
                        • M mrMuppet
                          + [[ 0 -eq 0 ]]
                          + IS_ROOT=true
                          + ROOT_GROUP=root
                          ++ get_platform
                          +++ uname
                          ++ unamestr=FreeBSD
                          ++ local platform=
                          ++ platform=freebsd
                          ++ ROOT_GROUP=wheel
                          ++ echo freebsd
                          + platform=freebsd
                          + IOB_USER=iobroker
                          + test -t 1
                          ++ which tput
                          ++ tput colors
                          + ncolors=83
                          + test -n 83
                          + test 83 -ge 8
                          ++ tput cols
                          + termcols=83
                          ++ tput bold
                          + bold=
                          ++ tput smul
                          + underline=
                          ++ tput smso
                          + standout=
                          ++ tput sgr0
                          + normal=
                          ++ tput setaf 0
                          + black=''
                          ++ tput setaf 1
                          + red=''
                          ++ tput setaf 2
                          + green=''
                          ++ tput setaf 3
                          + yellow=''
                          ++ tput setaf 4
                          + blue=''
                          ++ tput setaf 5
                          + magenta=''
                          ++ tput setaf 6
                          + cyan=''
                          ++ tput setaf 7
                          + white=''
                          + echo
                          + echo
                          + echo '    '
                          + echo
                          + echo
                          + NUM_STEPS=4
                          + stepnr=1
                          + steptotal=4
                          + echo
                          + echo
                          + package=sudo
                          + pkg info sudo
                          + package=git
                          + pkg info git
                          + package=curl
                          + pkg info curl
                          + package=bash
                          + pkg info bash
                          + package=unzip
                          + pkg info unzip
                          + package=dbus
                          + pkg info dbus
                          + package=nss_mdns
                          + pkg info nss_mdns
                          + package=gcc
                          + pkg info gcc
                          + package=python
                          + pkg info python
                          Starting dbus.
                          + stepnr=2
                          + steptotal=4
                          + echo
                          + echo
                          + username=iobroker
                          + id iobroker
                          + '[' 0 -ne 0 ']'
                          + declare -a groups
                          + getent group gpio
                          + getent group i2c
                          + getent group tty
                          tty:*:4:iobroker
                          + cd /opt/iobroker
                          ++ date +%F
                          + stepnr=3
                          + steptotal=4
                          + echo
                          + echo
                                [-Wunused-function]
                                [-Wunused-function]
                            int outbaud;
                                        = 0
                          + stepnr=4
                          + steptotal=4
                          + echo
                          + echo
                          + INITSYSTEM=rc.d
                          + [[ -n '' ]]
                          ++ which bash
                          ++ cat
                          ++ cat
                          # PROVIDE: iobroker
                          # REQUIRE: DAEMON
                          # KEYWORD: shutdown
                          . /etc/rc.subr
                          name="iobroker"
                          iobroker_start ()
                          iobroker_stop ()
                          iobroker_status ()
                          + echo '#!/bin/sh
                          # PROVIDE: iobroker
                          # REQUIRE: DAEMON
                          # KEYWORD: shutdown
                          . /etc/rc.subr
                          name="iobroker"
                          iobroker_start ()
                          iobroker_stop ()
                          iobroker_status ()
                          Autostart enabled!
                          Edit:
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Das ist was neues - ich schaue später nochmal rein.
                            AlCalzoneA Offline
                            AlCalzone
                            Ich habe nochmal was geändert. Magst du bitte nochmal testen?
                              mrMuppet
                              @AlCalzone Hier der nächste Versuch:
                              + [[ 0 -eq 0 ]]
                              + IS_ROOT=true
                              + ROOT_GROUP=root
                              ++ uname
                              + unamestr=FreeBSD
                              + HOST_PLATFORM=freebsd
                              + ROOT_GROUP=wheel
                              + IOB_USER=iobroker
                              + test -t 1
                              ++ which tput
                              ++ tput colors
                              + ncolors=80
                              + test -n 80
                              + test 80 -ge 8
                              ++ tput cols
                              + termcols=80
                              ++ tput bold
                              + bold=
                              ++ tput smul
                              + underline=
                              ++ tput smso
                              + standout=
                              ++ tput sgr0
                              + normal=
                              ++ tput setaf 0
                              + black=''
                              ++ tput setaf 1
                              + red=''
                              ++ tput setaf 2
                              + green=''
                              ++ tput setaf 3
                              + yellow=''
                              ++ tput setaf 4
                              + blue=''
                              ++ tput setaf 5
                              + magenta=''
                              ++ tput setaf 6
                              + cyan=''
                              ++ tput setaf 7
                              + white=''
                              + echo
                              + echo
                              + echo '    '
                              + echo
                              + echo
                              + NUM_STEPS=4
                              + stepnr=1
                              + steptotal=4
                              + echo
                              + echo
                              + case "$HOST_PLATFORM" in
                              + package=sudo
                              + pkg info sudo
                              + package=git
                              + pkg info git
                              + package=curl
                              + pkg info curl
                              + package=bash
                              + pkg info bash
                              + package=unzip
                              + pkg info unzip
                              + package=dbus
                              + pkg info dbus
                              + package=nss_mdns
                              + pkg info nss_mdns
                              + package=gcc
                              + pkg info gcc
                              + package=python
                              + pkg info python
                              dbus already running?  (pid=66501).
                              avahi_daemon already running?  (pid=66508).
                              + stepnr=2
                              + steptotal=4
                              + echo
                              + echo
                              + username=iobroker
                              + id iobroker
                              + '[' 0 -ne 0 ']'
                              + declare -a groups
                              + getent group gpio
                              + getent group i2c
                              + getent group tty
                              tty:*:4:iobroker
                              + cd /opt/iobroker
                              ++ date +%F
                              + echo 'Installation date 2019-05-23'
                              + stepnr=3
                              + steptotal=4
                              + echo
                              + echo
                                    [-Wunused-function]
                                    [-Wunused-function]
                                int outbaud;
                                            = 0
                              + stepnr=4
                              + steptotal=4
                              + echo
                              + echo
                              + INITSYSTEM=rc.d
                              + [[ -n '' ]]
                              ++ which bash
                              ++ cat
                              ++ cat
                              # PROVIDE: iobroker
                              # REQUIRE: DAEMON
                              # KEYWORD: shutdown
                              . /etc/rc.subr
                              name="iobroker"
                              iobroker_start ()
                              iobroker_stop ()
                              iobroker_status ()
                              + echo '#!/bin/sh
                              # PROVIDE: iobroker
                              # REQUIRE: DAEMON
                              # KEYWORD: shutdown
                              . /etc/rc.subr
                              name="iobroker"
                              iobroker_start ()
                              iobroker_stop ()
                              iobroker_status ()
                              HOST_PLATFORM: Undefined variable.
                              Autostart enabled!
                              • M mrMuppet
                                + [[ 0 -eq 0 ]]
                                + IS_ROOT=true
                                + ROOT_GROUP=root
                                ++ uname
                                + unamestr=FreeBSD
                                + ROOT_GROUP=wheel
                                + IOB_USER=iobroker
                                + test -t 1
                                ++ which tput
                                ++ tput colors
                                + ncolors=80
                                + test -n 80
                                + test 80 -ge 8
                                ++ tput cols
                                + termcols=80
                                ++ tput bold
                                + bold=
                                ++ tput smul
                                + underline=
                                ++ tput smso
                                + standout=
                                ++ tput sgr0
                                + normal=
                                ++ tput setaf 0
                                + black=''
                                ++ tput setaf 1
                                + red=''
                                ++ tput setaf 2
                                + green=''
                                ++ tput setaf 3
                                + yellow=''
                                ++ tput setaf 4
                                + blue=''
                                ++ tput setaf 5
                                + magenta=''
                                ++ tput setaf 6
                                + cyan=''
                                ++ tput setaf 7
                                + white=''
                                + echo
                                + echo
                                + echo '    '
                                + echo
                                + echo
                                + NUM_STEPS=4
                                + stepnr=1
                                + steptotal=4
                                + echo
                                + echo
                                + package=sudo
                                + pkg info sudo
                                + package=git
                                + pkg info git
                                + package=curl
                                + pkg info curl
                                + package=bash
                                + pkg info bash
                                + package=unzip
                                + pkg info unzip
                                + package=dbus
                                + pkg info dbus
                                + package=nss_mdns
                                + pkg info nss_mdns
                                + package=gcc
                                + pkg info gcc
                                + package=python
                                + pkg info python
                                + stepnr=2
                                + steptotal=4
                                + echo
                                + echo
                                + username=iobroker
                                + id iobroker
                                + '[' 0 -ne 0 ']'
                                + declare -a groups
                                + getent group gpio
                                + getent group i2c
                                + getent group tty
                                tty:*:4:iobroker
                                + cd /opt/iobroker
                                ++ date +%F
                                + stepnr=3
                                + steptotal=4
                                + echo
                                + echo
                                      [-Wunused-function]
                                      [-Wunused-function]
                                  int outbaud;
                                              = 0
                                + stepnr=4
                                + steptotal=4
                                + echo
                                + echo
                                + INITSYSTEM=rc.d
                                + [[ -n '' ]]
                                ++ which bash
                                ++ cat
                                ++ cat
                                # PROVIDE: iobroker
                                # REQUIRE: DAEMON
                                # KEYWORD: shutdown
                                . /etc/rc.subr
                                name="iobroker"
                                iobroker_start ()
                                iobroker_stop ()
                                iobroker_status ()
                                + echo '#!/bin/sh
                                # PROVIDE: iobroker
                                # REQUIRE: DAEMON
                                # KEYWORD: shutdown
                                . /etc/rc.subr
                                name="iobroker"
                                iobroker_start ()
                                iobroker_stop ()
                                iobroker_status ()
                                Autostart enabled!
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @mrMuppet 😕
                                Irgendwas macht FreeBSD da komisch mit den variablen. Zum nächsten versuch komme ich erst am Wochenende.
                                  @mrMuppet 😕
                                  mrMuppet
                                  @AlCalzone Gibt es schon eine neue "beta"?
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Ich wusste doch, da war was... 😓
                                      mrMuppet
                                      @AlCalzone kannst du bei gelegenheit noch mal reinschauen? 😁
                                      AlCalzoneA 2 Antworten Letzte Antwort
                                      • M mrMuppet
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @mrMuppet Sorry, meine Abende und Wochenenden sind derzeit komplett verplant :( Ggf. Montag.
                                        • M mrMuppet
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          @mrMuppet Was lange währt... Ich habe gerade nochmal einen potentiellen Fix gepusht.
                                          Hast du noch Zeit und Lust den zu testen?
                                          M 2 Antworten Letzte Antwort
