  5. Stoppuhr
Stoppuhr
130 Beiträge 4 Kommentatoren 22.2k Aufrufe 11 Beobachtet
    Schlagschatten
    Tag
    <variables>
    <variable type="undefined" id="Intervall33">Intervall33</variable>
    <variable type="" id="RJX#bCFN/lLc{/ML$d(C">counter33</variable>
    </variables>
    <block type="on_ext" id="nlX!8rCV~k.;9Xm#$t0S" x="-1112" y="-1337">
    <value name="OID0">
    <shadow type="field_oid" id="ES``F{uHqW8J+/Y,X@P,">
    <field name="oid">vis.0.HansNOTAUS.Wasserzaehler2</field>
    </shadow>
    </value>
    <value name="OID1">
    <shadow type="field_oid" id="c1dm,W4lL4F/SCN/JXE[">
    <field name="oid">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field>
    </shadow>
    </value>
    <statement name="STATEMENT">
    <block type="controls_if" id="CjOQv-/z9yZw|+5]9~Ey">
    <value name="IF0">
    <block type="logic_compare" id="mbvd~(W_.g}5*}=^oO~v">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="jMiE]hV^DT%]ElNF/Ms">
    <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="_zD5z^Eg?Mp/(ND7]U/1">
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="timeouts_setinterval" id="@4#gh8ib?30YN]phECu"> <field name="NAME">Intervall33</field> <field name="INTERVAL">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"> <block type="math_change" id="ISrC8BYmAH[I|pL+%xZ">
    <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field>
    <value name="DELTA">
    <shadow type="math_number" id="fRCT)TN8g
    |+PyckhQDs">
    <field name="NUM">1</field>
    </shadow>
    </value>
    <next>
    <block type="controls_if" id="e02eDw4RhcrUIFhfdw_.">
    <value name="IF0">
    <block type="logic_compare" id=";GfrwfY$+9p-)fDhUb$^">
    <value name="A">
    <block type="variables_get" id="]b(I5apIK{$dpqaHjv3">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="eKpd|+UN.Vum}MTuDzQ">
    <field name="NUM">1440</field>
    </block>
    </value>
    </block>
    </value>
    <block type="update" id="bMO;21Gt^nL/r2CY@1
    t">
    <mutation delay_input="false"></mutation>
    <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field>
    <value name="VALUE">
    <block type="math_arithmetic" id="Vp#pAhCa-z%KT|(U:K+"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="j1N0n8@)2iYs00z3u#fB"> <field name="NUM">1</field> </shadow> <block type="get_value" id="+nhPP|Y:/v3J51YI:~1a"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field> </block> </value> <value name="B"> <shadow type="math_number" id="(/_[7S|b%eWw1_/$Wu;m"> <field name="NUM">1</field> </shadow> </value> </block> </value> <next> <block type="timeouts_clearinterval" id="tB5ooe#rUd?S;~;+GFti"> <field name="NAME">Intervall33</field> <next> <block type="variables_set" id="Y3Rl?EUO8%)_wC#VErw">
    <block type="math_number" id="[kE?RAf~_i@=IdcO3N]Z">
    <field name="NUM">0</field>
    </block>
    </value>
    <next>
    <block type="controls_if" id="?mjZfBT8Xecb![V:#If#">
    <value name="IF0">
    <block type="logic_compare" id="IlY(^7|L^PL{#$Ef:0K7">
    <value name="A">
    <block type="get_value" id="XG{iq+Iq:-PioU+|NIg8">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="y
    #0BBv2lF3l1eRR|TB$">
    <field name="NUM">150</field>
    </block>
    </value>
    </block>
    </value>
    <block type="update" id="Ra[sDyz:[v~THw17*OB6">
    <block type="math_number" id=",W@U]?C~uk+N7:Z~H~Z"> <field name="NUM">0</field> </block> </value> <next> <block type="timeouts_clearinterval" id="+U[%E4VpEBy)9mDc,FtW"> <field name="NAME">Intervall33</field> <next> <block type="variables_set" id="2qecrhsfgE-R5[MWB5by"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field> <value name="VALUE"> <block type="math_number" id="F8X}B-:T~5)nxFSE/69N"> <field name="NUM">0</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <value name="IF1"> <block type="logic_compare" id="HZ*d)FAmc$T/gmUyaATz"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Bgj{aa~3Rhl-J_{J,JEj"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2</field> </block> </value> <value name="B"> <block type="logic_boolean" id="z=?N^mXE=#b:f;PI7M@c"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="variables_set" id="P2H;X!(CVbMKDLqv34hT"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field> <value name="VALUE"> <block type="math_number" id="l3z)Gn0Uy?}=Te48Ai[">
    </block>
    </value>
    <next>
    <block type="timeouts_clearinterval" id="TQ;:O)dZR;9m`8)[Ubq8">
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </xml>
      Schlagschatten
      Kann auch alles in ein Script
      • rantanplanR rantanplan
        Wie schon gesagt. Da sind sehr viele Verzögerungen und Timeouts. Wenn da mehrere von laufen, kann es haarig werden. Und wenn man ne Kleinigkeit verändert hat, ist es nicht mehr zu überblicken.
        @liv-in-sky Lass das anlegen der Datenpunke erstmal liegen und pass das Script an. Sonst hast Du hier Support ohne Ende.
        liv-in-skyL Offline
        liv-in-skyL Offline
        @rantanplan
        hättest du mal lust, mein (mit datenpunkten anlegen) script zu testen - im script ist auch ein testmodus der alle paar minuten läuft und die stoppuhr immer wieder startet - bei mir geht es - du müßtest also nicht mal start ode stopp drücken, da dies schon im test script vorhanden ist - nur die datenpunkte überwachen und evt. ein paar performance sachen feststellen.
        stoppuhr-mit-daternanlegen.txt
        • liv-in-skyL liv-in-sky
          @rantanplan
          danke dir - bin schon dabei
          ich habe nicht damit gerechnet, dass es gleich in die massenverarbeitung geht :-)
          rantanplanR Online
          rantanplanR Online
          rantanplan
          @liv-in-sky sagte in Stoppuhr:
          Wer die Geister ruft.....☺
          Hier mal ein kleines Beispiel wie ich das mit dem Initialieseren meine.
          Ich mache das z.B. bei meiner Heizungssteuerung so.
          Da ich jeden Raum einzeln steuer, hat das noch den Vorteil das ich die Scripte kopieren kann und nur an einer Stelle die Daten anpassen muss.
          Du brauchst dann noch eine Funktion, die am Ende die Werte der lokalen Variablen in die Datenpunkte schreibt.
          Rantanplan
            liv-in-skyL Offline
            liv-in-skyL Offline
            @rantanplan
            habe das mit dem berechnen teil so gemacht - nkannst ja mal kucken - bitte - aber ich denke, ich habe es verstanden
            • S Schlagschatten
              liv-in-skyL Offline
              liv-in-skyL Offline
              @Schlagschatten
              zwischen unseren scripten, gibt es einen wichtigen unterschied
              du zählst die sekunden oder minuten die ganze zeit und verbraucht die ganze zeit performance
              meine scripte berechnen die sekunden alle z.b 30 sekunden - das spart die performance !!!!!!
                Schlagschatten
                Das Script ist wesentlich einfacher augebaut, es Zählt eigentlich nur und damit bibt es Problem. In deinem Script z.b. wandels du Datum in Rechenwerte um und halt wieder zurück. Wenn ich das richtig verstanden habe. Und wofür braucht du das Objekt Momentan?
                  Schlagschatten
                  Ein Zähler der nach 45min nicht mehr richtig zählt.
                  • S Schlagschatten
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @Schlagschatten
                    dein problem im script - was ist bei einem ausfall oder neustart des iobrokers - dann ist vorbei mit zählen oder du speicherst alle deine sekunden und minuten plus ob script aktiv ist - sonst geht das nicht
                    da du keine sekunden brauchst, kannst du meine scripte auch minütlich ausführen
                      Schlagschatten
                      #66
                      Können die Bausteine mit Sekunden im Script gelöscht werden?
                      • S Schlagschatten
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #67
                        @Schlagschatten
                        macht keinen sinn, da die grundlage in millisekunden ist - die sog. linuxzeit - würde nicht wirklich was bringen - ich mach jetzt noch mal einen längeren test
                        momentan laufen schon 3 scripte von mir - ich sehe absolut keine laufzeitdifferenz von 45 minuten - manchmal habe ich eine (EINS) sekunden abweichung
                        vielleicht hast du noch eine alte version - des scripts
                        rantanplanR 1 Antwort Letzte Antwort
                          Schlagschatten
                          #68
                          Zum Thema Neustart ist da keine Lösung vorhanden.
                          Die Frage die sich stellt, wie kommt der Pi mit all den Scripten und was man sonst noch läuft klar.
                          • S Schlagschatten
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #69
                            @Schlagschatten ich glaube nicht, das der pi bei 8 scripten die nur alle minute oder so rechnen ein großes problem hat -
                              Schlagschatten
                              #70
                              Missverständnis. Bei meinem Script läuft die Zeit nach 45min weg. Bei Deinen läuft die Zeit korrekt, die Zeit startet nur 10 sek später. Nimm eine Stopuhr und dein Script und starte es gleichzeitig. Der Punkt ist unwichtig, sind nur 10 sek. danach läuft es.
                                @Schlagschatten
                                rantanplanR Online
                                rantanplanR Online
                                rantanplan
                                #71
                                Deshalb sollte man immer den ersten Beitrag aktualisieren. Und nicht irgendwo mittendrin.
                                Rantanplan
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #72
                                  @rantanplan ich weiß
                                  ich wollte nach der richtigen funktion einen eigenen thread mit dem script machen
                                    Schlagschatten
                                    #73
                                    Habe gerade mal nachgeschaut, die geplante Anzahl an Scripten geht auf die 30 zu. Und was man sonst noch angeschlossen hat. Was an Performance nötig ist, kann ich nicht sagen, habe mir gestern abend den RPI-Monitor-Adapter installiert und die Werte sehen noch gut aus.
                                    Auch wieviel Leistung das Script von liv-in-sky braucht, keine Vorstellung, es sieht halt nur sehr umfangreich aus. Kann halt auch letztlich weniger Rechenleistung nutzten.
                                      rantanplanR Online
                                      rantanplanR Online
                                      rantanplan
                                      #74
                                      Guter Plan!
                                      Dein Anlegen von Datenpunkten scheint nicht richtig zu sein.
                                      Vom Script angelegt
                                        "from": "system.adapter.javascript.0",
                                        "user": "system.user.admin",
                                        "ts": 1558013055132,
                                        "common": {
                                          "name": "Reset",
                                          "desc": "Reset",
                                          "type": "boolean",
                                          "role": "state"
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "owner": "system.user.admin",
                                          "state": 1636
                                        "_id": "javascript.0.STOPPUHR.Steuerung.Reset",
                                        "type": "state"
                                      Manuell angelegt
                                        "ts": 1558013264754,
                                        "common": {
                                          "name": "Test Objekt",
                                          "role": "",
                                          "type": "boolean",
                                          "desc": "Manuell erzeugt",
                                          "read": true,
                                          "write": true,
                                          "def": false
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636
                                        "_id": "javascript.0.STOPPUHR.Steuerung.Test_Objekt",
                                        "type": "state"
                                      Rantanplan
                                        Guter Plan!
                                        Vom Script angelegt
                                          "common": {
                                            "name": "Reset",
                                            "desc": "Reset",
                                            "type": "boolean",
                                            "role": "state"
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636
                                          "type": "state"
                                        Manuell angelegt
                                          "common": {
                                            "role": "",
                                            "type": "boolean",
                                            "read": true,
                                            "write": true,
                                            "def": false
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636
                                          "type": "state"
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #75
                                        @rantanplan
                                        ja habe ich geseh - sollte aber kein thema sein - ich werd aber noch versuchen, die restlichen werte hinzuzufügen - ich habe das von jmd anderem aus dessen script kopiert - dises script legt die punkte auch so an,und läuft schon über ein jahr bei mir
                                        vielleicht probleme lönnten kommen, wenn man mit sowas wie aufzählungen arbeitet - weil man dann die punkte im "raw-tab" ändern müßte
                                          Schlagschatten
                                          #76
                                          Das ist eine gute Idee mit dem Threat. Falls du mal langeweile hast und damit ich dein Script verstehe,
                                          liv-in-skyL rantanplanR 3 Antworten Letzte Antwort
