  4. CacheSelector findet nicht alle Datenpunkte bzw. States
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
cacheselector javascript
21 Beiträge 5 Kommentatoren 2.4k Aufrufe 6 Beobachtet
    mark77
    also:
    var dps = $('[state.id=sonoff.0.*.alive]');
    dps.each(function(id, i) {
        var val = getObject(id);
        log("Sonoff: " + id);
    Ergebinis Version 4.1.12:
    18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-163.alive
    18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-166.alive
    18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.WiFi-RPi-POE.alive
    Ergebins Version 3.6.4:
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.3D-Drucker.alive
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.DunstAbzgHaube.alive
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.EnergyPow1.alive
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.GasStrom.alive
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Kompressor.alive
    18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Luefter-1.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Luefter-2.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.NachtlichtJohanna.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.NachtlichtPaulina.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-1.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-2.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-3.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-163.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-166.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-167.alive
    18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Bohrmaschine.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Kodi-Johanna.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Kodi-Schlafz.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Messgeraete.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Nextion.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Printserver.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-RPi-Server.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Schleifmaschinen.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.TuerKlingel.alive
    18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.WiFi-RPi-POE.alive
    Meinst du so?
    • M mark77
      also:
      Meinst du so?
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @mark77 Ja sieht gut aus. Kannst du mir noch je von einem der Objekte die gefunden werden und einem, die nicht mehr gefunden werden, die Objektdefinition zeigen? (Objekte -> Bearbeiten-Pfeil -> Reiter "Raw")
        mark77
        Geht:
          "_id": "sonoff.0.Sonoff-163.alive",
          "common": {
            "name": "Sonoff-163 alive",
            "type": "boolean",
            "role": "indicator.connected",
            "read": true,
            "write": true
          "type": "state",
          "from": "system.adapter.sonoff.0",
          "user": "system.user.admin",
          "ts": 1539845127231,
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
            "state": 1636
          "native": {}
        Geht nicht:
          "_id": "sonoff.0.Sonoff-167.alive",
          "common": {
            "type": "boolean",
            "read": true,
            "write": false,
            "name": "Sonoff-167 alive"
          "type": "state",
          "ts": 1539845147409,
          "acl": {
            "object": 1636,
            "state": 1636,
          "native": {}
        • M mark77
          Geht:
            "common": {
              "type": "boolean",
              "read": true,
              "write": true
            "type": "state",
            "acl": {
              "object": 1636,
              "state": 1636
            "native": {}
          Geht nicht:
            "common": {
              "type": "boolean",
              "read": true,
              "write": false,
            "type": "state",
            "acl": {
              "object": 1636,
              "state": 1636,
            "native": {}
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @mark77 Danke. Das find ich schon sehr seltsam. Nur um sicher zu gehen, dass das kein bekannter Bug ist:
          Die Datenpunkte existieren schon vor dem Start des Skript-Adapters, und werden nicht erst während der Laufzeit durch einen anderen Adapter angelegt - richtig?
            mark77
            @AlCalzone Ja, ist richtig, alles wurde vom Adapter selber angelegt.
            Hilft es, wenn ich das gleich mit dem ZigBee Adapter mache?
            Da gibt es die gleichen Probleme.
            • M mark77
              arteckA Offline
              arteckA Offline
              arteck
              @mark77 jo mach bitte
              • AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @AlCalzone sagte in CacheSelector findet nicht alle Datenpunkte bzw. States:
                @mark77 Das ist der entscheidende Punkt. Der Sonoff-Adapter lief, die Objekte waren da, und dann hast du den Skript-Adapter gestartet?
                  mark77
                  @AlCalzone ja, korrekt
                    mark77
                    Der geht:
                      "from": "system.adapter.zigbee.0",
                      "ts": 1557846957200,
                      "common": {
                        "name": "Battery percent",
                        "type": "number",
                        "unit": "%",
                        "role": "battery.percent",
                        "min": 0,
                        "max": 100,
                        "read": true,
                        "write": false,
                        "icon": "img/battery_p.png",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "changesOnly": true,
                            "debounce": "10000",
                            "maxLength": "960",
                            "retention": "63072000",
                            "changesRelogInterval": 0,
                            "changesMinDelta": 0,
                            "aliasId": ""
                          "sql.1": {
                            "enabled": true,
                            "storageType": "",
                            "aliasId": ""
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636
                      "_id": "zigbee.0.HierStehtDieId.battery",
                      "type": "state",
                    Der geht nicht:
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "%",
                        "read": true,
                        "write": false,
                        "min": 0,
                        "max": 100,
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "maxLength": "960",
                            "retention": "31536000",
                            "aliasId": ""
                      "ts": 1557846957223,
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "native": {}
                      mark77
                      Gibt es eigentlich einen Grund, dass sich der Aufbau der Objekte, bei eigentlich gleichen Typen, unterscheidet?
                      R 1 Antwort Letzte Antwort
                      • M mark77
                        rtamas
                        schrieb am zuletzt editiert von rtamas
                        @mark77 Hallo! Ich habe die selben Probleme mit Sonoff. Hast du es irgendwie gelöst?
                        ScriptEngine 4.1.12
                        sonoff 2.2.2
                        js-controller 1.5.14
                        • R rtamas
                          ScriptEngine 4.1.12
                          sonoff 2.2.2
                          @rtamas sagte:
                          ScriptEngine 4.1.12
                          Hast Du es mal mit einer neueren Version (4.3.x) versucht ?
                            mark77
                            Moin,
                            habe gerade die Tage wieder damit experimentiert.
                            Irgendwo hatte ich auch noch Probleme damit, weiß nur leider nicht mehr genau, welche Datenpunkte es genau waren.
                            Sie ließen sich nur dann auslesen, wenn das Logging über History/SQL aktiviert war.
                            Habe vor 5 Minuten mal die Versionen 4.1.14 und 4.3.1 probiert und da, wo ich es benötige, nichts auffälliges festgestellt.
                            Für mich scheint es zu laufen.
                            Am einfachsten ließ sich das testen, mit einem Slave (z.B. RPi), auf dem eine andere Version installiert ist, dann kann man immer zwischen den Instanzen wechseln.
                            Gruß,
                            Mark
                              @rtamas sagte:
                              ScriptEngine 4.1.12
                              rtamas
                              @paul53 Hab ich noch nicht, danke Dir fürs Tipp!
                              @mark77 Danke für die weitere Info!
                              Es war mein Fehler mit dem Code, läuft schon problemlos. :)
                              Gruß,
                              Tamas
