  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 528.6k Aufrufe 93 Beobachtet
  • integer63I integer63
    Ich muss noch eine Frage stellen, solange ich nur einen Unifi AP im Netz hatte, lief der Adapter ohne Probleme. Jetzt habe ich ein USG (Gateway) mit in Betrieb genommen und kann den Adapter nicht mehr starten:
    host.ioBrokerVM1	2019-04-13 18:25:00.670	error	instance system.adapter.unifi.0 terminated with code 0 (OK)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at Array.every (<anonymous>)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    Caught	2019-04-13 18:25:00.670	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
    Caught	2019-04-13 18:25:00.669	error	by controller[0]: TypeError: Cannot read property 'subsystem' of null
    unifi.0	2019-04-13 18:25:00.665	info	terminating
    unifi.0	2019-04-13 18:25:00.658	info	cleaned everything up...
    unifi.0	2019-04-13 18:25:00.658	error	at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
    unifi.0	2019-04-13 18:25:00.658	error	at Array.every (<anonymous>)
    unifi.0	2019-04-13 18:25:00.658	error	at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
    unifi.0	2019-04-13 18:25:00.658	error	at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
    unifi.0	2019-04-13 18:25:00.658	error	at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
    unifi.0	2019-04-13 18:25:00.658	error	at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
    unifi.0	2019-04-13 18:25:00.658	error	at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
    unifi.0	2019-04-13 18:25:00.658	error	at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
    unifi.0	2019-04-13 18:25:00.658	error	at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
    unifi.0	2019-04-13 18:25:00.658	error	TypeError: Cannot read property 'subsystem' of null
    unifi.0	2019-04-13 18:25:00.658	error	uncaught exception: Cannot read property 'subsystem' of null
    unifi.0	2019-04-13 18:25:00.655	info	getSitesStats: default
    unifi.0	2019-04-13 18:25:00.196	info	controller = 192.168.11.163:8443
    unifi.0	2019-04-13 18:25:00.196	info	update_interval = 60
    unifi.0	2019-04-13 18:25:00.196	info	Starting UniFi-Controller query
    unifi.0	2019-04-13 18:25:00.188	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v8.15.1
    unifi.0	2019-04-13 18:25:00.178	info	States connected to redis: 192.168.11.31:6379
    host.ioBrokerVM1	2019-04-13 18:24:59.922	info	instance system.adapter.unifi.0 started with pid 1107
    host.ioBrokerVM1	2019-04-13 18:24:59.916	info	"system.adapter.unifi.0" enabled
    Was kann ich da machen?
    BBTownB Offline
    BBTownB Offline
    BBTown
    #248
    @integer63 die USG hat ja zunächst eigentlich nichts mit dem Unifi-Controller zu tun, das dürfte ja im Grunde nur ein weiteres Device sein was aus dem Controller ausgelesen wird.
    Hast Du ggf. in der USG Firewall Regeln agelegt die einen Zugriff verhiindern?
    integer63I 1 Antwort Letzte Antwort
    • BBTownB BBTown
      integer63I Offline
      integer63I Offline
      integer63
      #249
      @BBTown Ja, das war auch meine Erwartung und es wurde sogar ein neues Device und diverse Datenpunkte angelegt. Aber dann kamen die Fehlermeldungen. Ich habe keine zusätzlichen Firewall Regeln angelegt - aber in den letzten zwei Tagen so einiges im Controller konfiguriert.
      Heute habe ich die unifi.0 Instanz wieder aktiviert und siehe da - es funktioniert!
      Darüber freue ich mich natürlich :-) , aber ich hasse es, wenn man nicht weiß, woran es gelegen hat :-(
        Thaibodo
        #250
        Ich benutze den Unifi-Adapter und bin ganz glücklich damit. Daher an dieser Stelle erst einmal vielen Dank an den Entwickler.
        Ich habe aber ein Problem. Wenn der Controller mal, warum auch immer, nicht läuft, funktioniert der Adapter natürlich nicht. Wenn der Controller dann aber wieder läuft, merkt es der Adapter anscheinend nicht. Ich muss dann immer den Adapter aktualisieren.
        Falls das nicht geändert werden kann, gibt es eine Möglichkeit, den Adapter per Script (am liebsten Blocky) zu aktualisieren?
        ioBroker auf Raspi 4
        • T Thaibodo
          sigi234S Online
          sigi234S Online
          #251
          @Thaibodo
          Hallo, warum legst du nicht einen Neustart mit Cron an..........
          Instanzen - Expertenmodus........
            Thaibodo
            #252
            Danke für den Tip, das werde ich gleich mal ausprobieren.
            • T Thaibodo
              Thaibodo
              #253
              @Thaibodo Hat Geklappt. Danke nochmals.
              • N Offline
                N Offline
                nevermind
                #254
                Hallo Zusammen,
                der Adapter hat bei mir immer problemlos funktioniert. Seit heute habe ich neben den AP´s auch ein USG, welches meinen bisherigen Router ersetzen soll. Leider läuft seitdem der Adapter nicht mehr:
                host.pm-100	2019-04-20 15:41:40.906	error	instance system.adapter.unifi.0 terminated with code 0 (OK)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at Array.every (<anonymous>)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
                host.pm-100	2019-04-20 15:41:40.906	error	Caught by controller[0]: TypeError: Cannot read property 'subsystem' of null
                Irgendjemand ne Idee? :(
                Jens
                • N Offline
                  N Offline
                  nevermind
                  schrieb am zuletzt editiert von nevermind
                  #255
                  also, der fehler muss, wie aus dem log ja ersichtlich, irgendwo hier
                  traverse(value, name + '.' + value.subsystem, 0, 0, function(name, value, depth)
                    //adapter.log.info('__(' + depth + '): ' + name + ' = ' + value + ' type: ' + typeof(value));
                    if(typeof(value) === 'object')
                  	createChannel(name, 'Subsystem ' + value.subsystem);
                    else
                  	createState(name, value);
                  in der main.js liegen.
                  Ich habe es für mich jetzt wiefolgt gefixt:
                  if(value.subsystem == "wlan"){
                  	  else
                  (if-Abfrage nach "Typ" wlan)
                  Das ist natürlich keine finale Lösung aber damit funktioniert erst mal alles wieder wie vorher.
                  vg
                  Jens
                  • N Offline
                    N Offline
                    nevermind
                    #256
                    So, heute wollte ich mir das noch mal genauer ansehen. Als erstes also meine Änderung Rückgängig gemacht und siehe da, ging trotzdem noch?! 😐
                    Seit dem letztens der Fehler aufgetreten ist, habe ich den UniFi Controller auf Version 5.10.21 geupdated. Ich vermute daher, dass der Fehler mit dieser Version des Controllers nicht mehr auftritt. Anders kann ich mir es gerade nicht erklären.
                    Vg
                    Jens
                    • C Offline
                      ChrisXY
                      schrieb am zuletzt editiert von ChrisXY
                      #257
                      hmm mein iobroker lauft als macvlan. Hab nun bridge hinzugefügt. Hab somit auch ein Ping zu der unifi controler. Hab es in der Docker Console vom IOB getestet. Anpingen geht. Aber bekomme nur fehler
                      host.iobroker	2019-05-14 20:52:36.188	info	Restart adapter system.adapter.unifi.0 because enabled
                      host.iobroker	2019-05-14 20:52:36.188	error	instance system.adapter.unifi.0 terminated with code 0 (OK)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at traverseArray (/opt/iobroker/node_modules/iobroker.unifi/main.js:165:7)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at Array.every (<anonymous>)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:168:7
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:155:5)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:178:27)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:288:13
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at traverseObject (/opt/iobroker/node_modules/iobroker.unifi/main.js:184:7)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at traverse (/opt/iobroker/node_modules/iobroker.unifi/main.js:156:32)
                      Caught	2019-05-14 20:52:36.188	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:292:58
                      Caught	2019-05-14 20:52:36.187	error	by controller[0]: TypeError: Cannot read property 'subsystem' of null
                      EDIT: wohl der fehler wie oben. Fhem Modul klappt weiterhin ohne Probleme
                      • N Offline
                        N Offline
                        nevermind
                        #258
                        Welche Version hat dein Controller?
                        C 1 Antwort Letzte Antwort
                        • N nevermind
                          ChrisXY
                          #259
                          @nevermind 5.10.23
                            TorbenNW
                            #260
                            Hi, erst einmal vielen Dank für den Adapter, Daten werden an sich so ausgewertet wie ich es brauche.
                            Allerdings verursacht der Adapter bei mir in dem ioBroker lxc einen erhöhten CPU Verbrauch. Ohne den aktiven Adapter dümpelt die Installation bei 0,5-1% im Idle rum, mit dem aktiven Adapter zwischen 5-6%.
                            Ist das bei euch auch der Fall?
                            Ja, so viel ist es nicht aber es macht sich schon bemerkbar das ein einzelner Adapter so viel CPU Last auslöst.
                            Ich habe keine Ahnung von programmieren aber ist es möglich evtl einzelne Abfragen auszuschließen? Ich brauche eigentlich nur die WLAN Geräte und keine Daten von meinen ganzen Unifi Geräten etc.
                            • HiltexH Offline
                              HiltexH Offline
                              Hiltex
                              #261
                              Das ist mir kürzlich auch mal aufgefallen. Nach dem js-Controller war unifi der, der am meisten CPU-Zeit verbraucht hat. Allerdings ist das jetzt nicht mehr so, da sind andere Adapter weiter vorn.
                              Blog: indibit.de
                                dos1973
                                #262
                                ich habe mich auch zu Unifi entschlossen da meine Fritzbox nur noch genervt hat. Für den Anfang habe ich einen AP nanonHD gekauft, der Controller läuft auf der Nas im Docker Image. (v5.10.24). Das ganze Unifi schreit nach mehr, denke ich werde mir noch das USG zulegen :-)
                                Der Adapter läuft ... liefert aber Unmengen an Daten und Informationen.
                                Hat einer von euch ggfs. schon etwas in VIS gebaut und würde das teilen.
                                was ich bereits gefunden habe ist
                                unifi.0.default.devices.MAC-des-AP.vap_table.ra0.satisfaction
                                das zeigt die aktuelle "Zufriedenheit" des Netzwerks an.
                                @jens-maus
                                kurze Frage, wird der Adapter noch weiter entwickelt? Eingangs hattest du ja viele Ideen geäussert, die ggfs. noch umsetzbar wären.
                                • D dos1973
                                  @jens-maus
                                  Kuddel
                                  #263
                                  @dos1973
                                    dos1973
                                    #264
                                    Danke, st ein Anfang ...
                                    Was sind denn die 20%/ 13% bei den beiden Accesspoints?
                                    • D dos1973
                                      Kuddel
                                      #265
                                      @dos1973 Auslastung vom 2,4 Ghz Netz
                                        dos1973
                                        #266
                                        meinst du das was im controller unter "Utilized" dargestellt wird?
                                        sagt du mir welche DP du dafür verwendest, bzw. was du da kalkulierst.
                                        • D dos1973
                                          dos1973
                                          #267
                                          @dos1973 habs gefunden...
