  4. [Aufruf] Adapter: Snips - Offline Speak2Text
    1.0k
snips
635 Beiträge 43 Kommentatoren 209.0k Aufrufe 22 Beobachtet
  • R Offline
    rascal
    #558
    Bei Sprachbefehlen reagiert er ganz komisch, auch erkennt er sie im Moment überhaupt nicht.
    Hey snips -> 2x ping -> 1x "nicht erkannt Ping" -> 2-5x ! ping
    watch am Main:
    [12:38:33] Watching on localhost:1883 (MQTT)
    [12:38:35] [Hotword] detected on site default, for model hey_snips
    [12:38:35] [Asr] was asked to stop listening on site default
    [12:38:35] [Hotword] was asked to toggle itself 'off' on site default
    [12:38:35] [Dialogue] session with id '92a8dce2-d34c-4793-a2ed-33799610d394' was started on site default
    [12:38:35] [AudioServer] was asked to play a wav of 41.1 kB with id 'e18b94f7-9a33-4a2f-a466-2f418c171eee' on site default
    [12:38:35] [Dialogue] session with id 'b4dc7a3c-4bc0-4e79-924d-9bd2ac2cea49' was started on site default
    [12:38:35] [AudioServer] was asked to play a wav of 41.1 kB with id '1bb16720-fbef-482c-ba12-cc1a1fad21c9' on site default
    [12:38:36] [AudioServer] finished playing wav with id 'e18b94f7-9a33-4a2f-a466-2f418c171eee'
    [12:38:36] [Asr] was asked to listen on site default
    [12:38:36] [AudioServer] finished playing wav with id '1bb16720-fbef-482c-ba12-cc1a1fad21c9'
    [12:38:39] [Asr] captured text "an" in 3.0s
    [12:38:39] [Asr] was asked to stop listening on site default
    [12:38:39] [AudioServer] was asked to play a wav of 93.1 kB with id 'f2bab4c5-6adf-4dc8-be6a-e7b65d941635' on site default
    [12:38:40] [Asr] captured text "licht an" in 3.0s
    [12:38:40] [AudioServer] was asked to play a wav of 61.1 kB with id 'a37913d8-7489-48d1-a902-730c26d28fbe' on site default
    [12:38:41] [AudioServer] finished playing wav with id 'f2bab4c5-6adf-4dc8-be6a-e7b65d941635'
    [12:38:41] [AudioServer] finished playing wav with id 'a37913d8-7489-48d1-a902-730c26d28fbe'
    [12:38:41] [Dialogue] session with id '92a8dce2-d34c-4793-a2ed-33799610d394' was ended on site default. The session was ended because an error happened: Event not supported: Response { waiting: AudioFinishedPayload  }, with response: AsrCapture(AsrPayload { text: "licht an", tokens: Some([AsrTokenPayload { value: "licht", confidence: 0.7844479, range_start: 0, range_end: 5, time: AsrDecodingDurationPayload { start: 0.0, end: 1.57888 } }, AsrTokenPayload { value: "an", confidence: 0.8506282, range_start: 6, range_end: 8, time: AsrDecodingDurationPayload { start: 1.57888, end: 3.1499999 } }]), likelihood: 0.8168681, seconds: 3.0 })
    [12:38:41] [Asr] was asked to stop listening on site default
    [12:38:41] [Hotword] was asked to toggle itself 'on' on site default
    [12:38:52] [Dialogue] session with id 'b4dc7a3c-4bc0-4e79-924d-9bd2ac2cea49' was ended on site default. The session was ended because one of the component didn't respond in a timely manner
    [12:38:52] [Asr] was asked to stop listening on site default
    [12:38:52] [Hotword] was asked to toggle itself 'on' on site default
    [12:41:12] [Asr] captured text "schalte das nicht an" in 4.0s
    [12:41:12] [Asr] was asked to stop listening on site default
    [12:41:12] [AudioServer] was asked to play a wav of 93.1 kB with id 'abc3e691-c4bb-44a2-b8e7-276380be0d83' on site default
    [12:41:12] [Asr] captured text "schalte das licht an" in 4.0s
    [12:41:12] [AudioServer] was asked to play a wav of 61.1 kB with id 'fe6cd879-5366-464d-94e5-4dca113be55c' on site default
    [12:41:13] [AudioServer] finished playing wav with id 'abc3e691-c4bb-44a2-b8e7-276380be0d83'
    [12:41:14] [AudioServer] finished playing wav with id 'fe6cd879-5366-464d-94e5-4dca113be55c'
    [12:41:14] [Dialogue] session with id '1b1cbd31-6f78-4691-a257-1f86dadd3719' was ended on site default. The session was ended because an error happened: Event not supported: Response { waiting: AudioFinishedPayload  }, with response: AsrCapture(AsrPayload { text: "schalte das licht an", tokens: Some([AsrTokenPayload { value: "schalte", confidence: 1.0, range_start: 0, range_end: 7, time: AsrDecodingDurationPayload { start: 0.0, end: 2.34 } }, AsrTokenPayload { value: "das", confidence: 1.0, range_start: 8, range_end: 11, time: AsrDecodingDurationPayload { start: 2.34, end: 2.79 } }, AsrTokenPayload { value: "licht", confidence: 1.0, range_start: 12, range_end: 17, time: AsrDecodingDurationPayload { start: 2.79, end: 2.97 } }, AsrTokenPayload { value: "an", confidence: 1.0, range_start: 18, range_end: 20, time: AsrDecodingDurationPayload { start: 2.97, end: 3.99 } }]), likelihood: 1.0, seconds: 4.0 })
    [12:41:14] [Asr] was asked to stop listening on site default
    [12:41:14] [Hotword] was asked to toggle itself 'on' on site default
    • R Offline
      rascal
      #559
      @unltdnetworx sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
      A oder B
      Ich habe das Script verwendet und bis vor 2 Tagen hat auch alles ganz gut funktioniert:
      https://github.com/Psychokiller1888/satConnect
      unltdnetworxU 1 Antwort Letzte Antwort
      • R rascal
        A oder B
        unltdnetworxU Offline
        unltdnetworx
        #560
        @rascal
        Okay, dazu kann ich persönlich nichts sagen. Evtl. schilderst du dein Problem mal im Snips-Forum.
        Einen eigenen Namen (nicht default) hat der Satellit aber schon?
        Gruß, Michael
        Weitere Infos im Profil.
        Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
        • R Offline
          rascal
          #561
          dein letzter Tipp hat geholfen: snips über sam am Satelliten ausgeschaltet, Main neu gestartet und siehe da, der Main funkt ganz normal
          • R rascal
            unltdnetworx
            #562
            @rascal
            Dann passt die Konfiguration nicht. Schau dir mal die Anleitung zum Satellitenbetrieb oder die Posts dazu weiter oben an. Evtl. kannst du was nachbessern. Es brauchen auf dem Satelliten nur wenige Dienste von Snips laufen.
            Gruß, Michael
            • unltdnetworxU Offline
              unltdnetworx
              schrieb am zuletzt editiert von unltdnetworx
              #563
              Neue Funktion in der Adapter-Version 1.1.6:
              Bei allen Satelliten kann jetzt das Hotword/Wakeword (de)aktiviert werden.
              Gruß, Michael
              • V Offline
                V Offline
                vore
                schrieb am zuletzt editiert von vore
                #564
                Hallo! Ich habe jetzt die Hardware für einen Snips Satelliten (Raspi-Zero und 2Hat Mic Array). Es gibt eine Anleitung bei Snips, wie ich einen Satelliten hinzufüge Satellites. Muss ich diese nutzen? Oder hilft mit der Punkt "Create Satellite" im Adpater? Und wenn ja, was muss ich da eintragen? Die IP?
                Vore
                • V vore
                  Vore
                  unltdnetworx
                  #565
                  @vore
                  Ja, du kannst diese nutzen. Alternativ gibt es auch Skript, das die Anbindung durchführt.
                  Was zum Anbinden nicht funktioniert, ist der Punkt "create Satellite". Dieser Punkt legt, nach Eingabe des zuvor definierten Namens des Satelliten-Gerätes, die Datenpunkte in ioBroker an. Das ist allerdings auch nur nötig, falls man kein Mikrophon am Gerät hat. Ansonsten werden die Datenpunkte bei der ersten Spracheingabe automatisch generiert.
                  Gruß, Michael
                  V 1 Antwort Letzte Antwort
                  • unltdnetworxU unltdnetworx
                    @vore
                    V Offline
                    V Offline
                    vore
                    #566
                    Dieses Script macht das alles von alleine. 2Min und der Satellite ist angemeldet: https://github.com/Psychokiller1888/satConnect
                    • F Offline
                      Findus
                      schrieb am zuletzt editiert von Findus
                      #567
                      Kurze Frage: Wollte den Adapter installieren bekomme aber folgende Message beim Installieren.
                      l@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                      iobroker 2019-05-13 10:38:23.033 info WARN
                      iobroker 2019-05-13 10:38:23.030 info npm
                      iobroker 2019-05-13 10:37:03.193 info npm install https://github.com/unltdnetworx/ioBroker.snips/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                      iobroker 2019-05-13 10:37:00.894 info install https://github.com/unltdnetworx/ioBroker.snips/tarball/master
                      iobroker 2019-05-13 10:36:58.974 info url "https://github.com/unltdnetworx/ioBroker.snips/tarball/master" snips
                      Kann mir da jemand einen Tipp geben was ich genau machen muss?
                      Node.js: v8.15.1
                      NPM: 6.4.1
                      Danke und Gruesse
                      Findus
                        unltdnetworx
                        #568
                        @Findus sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                        Hallo Findus,
                        versuch es mal über die Github-Katze zu installieren. Das ist momentan die gleiche Version. Jetzt fehlen komischerweise Abhängigkeiten, ich habe aber nichts geändert. Somit hat sich vermutlich eine andere Abhängkeit geändert. Wenn noch mehrere das Problem haben, muss ich wohl diese Abhängigkeit einfügen. Obwohl das nicht Sinn der Sache wäre.
                        Gruß, Michael
                          unltdnetworx
                          #569
                          Mit meiner npm-Version läuft es einwandfrei. 8.13.*
                          Gruß, Michael
                          • F Offline
                            Findus
                            #570
                            @unltdnetworx Danke fuer die schnelle Antwort.
                            Die Installation über die Katze habe ich schon probiert. Leider gleiches Problem. :-(
                            Viele Gruesse
                            Findus
                            • F Offline
                              Findus
                              #571
                              Der Adpater liegt jetzt unter /opt/iobroker/node_modules/iobroker.snips
                              er taucht aber im UI nicht auf. Gibt es eine Moeglichkeit den Adapter manuell zu starten?
                              Oder ein Tipp was ich noch machen kann?
                              Viele Gruesse
                              Findus
                              • F Offline
                                Findus
                                #572
                                Kurzer update: Habe nachdem ich den Adapter über Katze installiert hatte ( mit Fehlermeldung) diesen nun mit der Console "iobroker add snips" installiert. Dies hat funktioniert und er ist jetzt auch im Admin sichtbar. Werde nun mit den Test beginnen.
                                • F Findus
                                  unltdnetworx
                                  #573
                                  @Findus
                                  Super. Immerhin.
                                  Wollte gerade vorschlagen heute Abend eine Testversion für dein Problem zu basteln. Habe nämlich heute eine Meldung erhalten, dass eine Abhängigkeit eine Sicherheitslücke hat. Möglicherweise hat da ein Entwickler gerade essentielle Änderungen eingebaut. Denke, dass das viele andere Anwendungen betrifft und bald behoben sein wird.
                                  Gruß, Michael
                                  • F Offline
                                    Findus
                                    #574
                                    Wo finde ich die Einstellungen von Text2Command Adapter um die Antwort Id "snips.0.send.say.text einzutragen? Die Text2Command Konfiguration ist bei mir ausgegraut?
                                    • F Findus
                                      unltdnetworx
                                      #575
                                      @Findus
                                      Im text2command Adapter (neuer Eintrag im Menü links) ist rechts oben ein Zahnrad für erweiterte Einstellungen.
                                      Gruß, Michael
                                      • F Offline
                                        Findus
                                        #576
                                        @unltdnetworx 👍 👍 👍
                                        • Daniel BeiderwiedenD Offline
                                          Daniel Beiderwieden
                                          schrieb am zuletzt editiert von Daniel Beiderwieden
                                          #577
                                          Moin,
                                          ich bin jetzt schon 2 Tage dran Snips zu installieren bzw. zum laufen zu bringen.
                                          IoBroker hat den Snips und den Command Adapter wie beschrieben installiert. Er wurde auch entsprechend in der Sinps Console hinzugefügt.
                                          Der Snips Server läuft in Proxmox in einer Debian VM.
                                          Das Hotword wird erkannt und per sam watch bekomme ich folgende Informationen:
                                          sam watch
                                          [17:31:25] Watching on localhost:1883 (MQTT)
                                          [17:31:27] [Hotword] detected on site room1, for model hey_snips
                                          [17:31:27] [Asr] was asked to stop listening on site room1
                                          [17:31:27] [Hotword] was asked to toggle itself 'off' on site room1
                                          [17:31:27] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was started on site room1
                                          [17:31:27] [AudioServer] was asked to play a wav of 41.1 kB with id '61c42146-84bc-4820-a907-0a59dc623e5d' on site room1
                                          [17:31:42] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was ended on site room1. The session was ended because one of the component didn't respond in a timely manner
                                          [17:31:42] [Asr] was asked to stop listening on site room1
                                          [17:31:42] [Hotword] was asked to toggle itself 'on' on site room1
                                          der Satellite wurde mit dem git Script hinzugefügt von Psychokiller..
                                          Sam Status gibt mir folgendes aus:
                                          sam status
                                          Connected to device localhost
                                          OS version ................... Debian GNU/Linux 9 (stretch)
                                          Installed assistant .......... MainSnips
                                          Language ..................... de
                                          Hotword ...................... hey_snips
                                          ASR engine ................... snips
                                          Status ....................... Live
                                          Service status:
                                          snips-analytics .............. (not running)
                                          snips-asr .................... 0.63.2 (running)
                                          snips-audio-server ........... 0.63.2 (running)
                                          snips-dialogue ............... 0.63.2 (running)
                                          snips-hotword ................ 0.63.2 (running)
                                          snips-nlu .................... 0.63.2 (running)
                                          snips-skill-server ........... 0.63.2 (running)
                                          snips-tts .................... 0.63.2 (running)
                                          Den Audio Server habe ich zum laufen gebracht indem ich die Soundkarte durchgeschliffen habe.
                                          Auf dem Satellite habe ich wie in auf dem git reposetory die entsprechen packte installiert.
                                          Ich verwende ein Rasb. mit ReSpeaker ohne lautsprecher derzeit.
                                          Daher die Frage, was läuft hier falsch? was muss ich tun, ich finde einfach keine Lösung.
                                          Und muss auf der VM der Skill-server laufen?
