  4. seltsames Verhalten meines Sonoff 4CH pro
iobroker sonoff
29 Beiträge 7 Kommentatoren 7.2k Aufrufe 3 Beobachtet
  • Ralla66R Offline
    Ralla66R Offline
    Ralla66
    Schau mal in die Tasmota Console.
    Dort müsstest du ja sehen ob geschaltet wird.
    Beim reboot des ESP sind einige Pins high.
    Bedeutet wenn an dem Pin ein Relay hängt wird dieses beim reboot geschaltet.
    Geht so in die Richtung.
    Schau mal ob der ESP sich versucht öfters ins Wlan einzuloggen.
    Tasmota 6.4.1 ist gut aber welcher Core ?
    Da gabs welche mit Wlanfehler.
    Versuch mal mit 6.5.0 mit 2.3.0.
    http://thehackbox.org/tasmota/release/
    • docadamsD Offline
      docadamsD Offline
      docadams
      schrieb am zuletzt editiert von docadams
      Es sind immer nur POWER2 und POWER4, die da schalten.
      Das sieht dann so aus:
      12:47:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T12:47:15","Uptime":"0T18:40:16","Vcc":3.461,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      12:52:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T12:52:15","Uptime":"0T18:45:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      12:54:02 MQT: stat/sonoff/RESULT = {"POWER4":"ON"}
      12:54:02 MQT: stat/sonoff/POWER4 = ON
      12:57:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T12:57:15","Uptime":"0T18:50:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      12:57:42 MQT: stat/sonoff/RESULT = {"POWER2":"OFF"}
      12:57:42 MQT: stat/sonoff/POWER2 = OFF
      13:02:00 MQT: tele/sonoff/UPTIME = {"Time":"2019-04-18T13:02:00","Uptime":"0T18:55:01"}
      13:02:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:02:15","Uptime":"0T18:55:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:07:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:07:15","Uptime":"0T19:00:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:12:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:12:15","Uptime":"0T19:05:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxxA1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:17:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:17:15","Uptime":"0T19:10:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:22:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:22:15","Uptime":"0T19:15:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:27:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:27:15","Uptime":"0T19:20:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:32:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:32:15","Uptime":"0T19:25:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:37:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:37:15","Uptime":"0T19:30:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      13:39:07 MQT: stat/sonoff/RESULT = {"POWER4":"OFF"}
      13:39:07 MQT: stat/sonoff/POWER4 = OFF
      13:42:15 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T13:42:15","Uptime":"0T19:35:16","Vcc":3.462,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":13,"Downtime":"0T00:00:23"}}
      Mit Consolen-Befehlen muss ich erst mal sehen, da kenne ich mich überhaupt nicht aus.
      • docadamsD Offline
        docadamsD Offline
        docadams
        Habe das Teil aktualisiert:
        Program Version	6.5.0(release-sonoff)
        Build Date & Time	2019-03-19T12:24:10
        Core/SDK Version	2_3_0/1.5.3(aec24ac9)
        Uptime	0T01:49:02
        Flash write Count	2843 at 0xF4000
        Boot Count	35
        Restart Reason	Software/System restart
        Leider schaltet er munter weiter:
        17:00:24 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:00:24","Uptime":"0T01:20:22","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xxxxxxA1","Channel":13,"RSSI":100,"LinkCount":2,"Downtime":"0T00:00:11"}}
        17:02:00 MQT: tele/sonoff/UPTIME = {"Time":"2019-04-18T17:02:00","Uptime":"0T01:21:58"}
        17:05:24 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:05:24","Uptime":"0T01:25:22","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":2,"Downtime":"0T00:00:11"}}
        17:10:24 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:10:24","Uptime":"0T01:30:22","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxx:A1","Channel":13,"RSSI":100,"LinkCount":2,"Downtime":"0T00:00:11"}}
        17:15:24 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:15:24","Uptime":"0T01:35:22","Vcc":3.182,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":2,"Downtime":"0T00:00:11"}}
        17:20:24 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:20:24","Uptime":"0T01:40:22","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"ON","Wifi":{"AP":1,"SSId":"xxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":2,"Downtime":"0T00:00:11"}}
        17:23:49 MQT: stat/sonoff/RESULT = {"POWER4":"OFF"}
        17:23:49 MQT: stat/sonoff/POWER4 = OFF
        17:24:10 MQT: Attempting connection...
        17:24:10 MQT: Connected
        17:24:10 MQT: tele/sonoff/LWT = Online (retained)
        17:24:10 MQT: cmnd/sonoff/POWER =
        17:25:26 MQT: tele/sonoff/STATE = {"Time":"2019-04-18T17:25:26","Uptime":"0T01:45:24","Vcc":3.182,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xxxxxx:A1","Channel":13,"RSSI":100,"LinkCount":3,"Downtime":"0T00:00:13"}}
        17:26:15 MQT: stat/sonoff/RESULT = {"POWER2":"OFF"}
        17:26:15 MQT: stat/sonoff/POWER2 = OFF
        Was mir jetzt auffällt, es wird die Zeit ist die UTC+1, nicht unsere Sommerzeit. Aber daran wird es wohl kaum liegen.
        Das Relais meldet sich so alle 5 Minuten (+/-) an und nach ca. 2 Sekunden wieder an. Ich habe noch einen Sonoff BASIC, der macht das noch öfters. Ich weiß nicht, ist das normal?
        Alle Geräte, Router, RasPi, Sonoffs, befinden sich z.Z. im gleichen Raum. Fremde WLANs sind wenige und schwach.
        • Ralla66R Offline
          Ralla66R Offline
          Ralla66
          Normal ist das nicht.
          5 Minuten ist der default Wert der Telemetry period (300).
          Zeig mal deine Blockly vom Basic und 4 CH.
          Das hatte ich auch einmal.
          Wenn die Werte im Sonoff Adapter alle 5 min aktualisiert werden , werden die Werte überschrieben.
          Hast du den Trigger im Blockly auf aktualisiert löst dieser eventuell aus.
          Das alle 5 Minuten.
          Schalte mal die Blocklys aus zum testen.
          Stecker der Sonoff mal ziehen und wieder einstecken.
          Was macht das Relay alle 5 min ?
          • docadamsD Offline
            docadamsD Offline
            docadams
            Die Blocklys sind heute schon den ganzen Tag deaktiviert. Zumindest die, die etwas mit den Sonoffs zu tun haben.
            Und sie sind es auch nicht Wert, gezeigt zu werden. Es sind aller erste Versuche. Wie gesagt, die sind alle deaktiviert.
            Aber könnte ich die Loglevel mal ändern, eventuell zeigt sich da etwas?
            Aber welche wie?
            • Ralla66R Offline
              Ralla66R Offline
              Ralla66
              Mein RF also Basic mit 433 MHZ Modul steht das Relay auf GPIO 2 Switch1 (9).
              Wie sind deine Relays beim Basic und CH 4 definiert ?
              Tasmota Mqtt steht Full Topic auf default Werte also %prefix%/%topic%/ ?
              Spannungsversorgung ist groß genug ausgelegt ?
              • docadamsD Offline
                docadamsD Offline
                docadams
                Hallo und schon mal schöne Feiertage an alle.
                Bevor ich auf meine Einstellungen eingehe ist mir Folgendes Aufgefallen.
                Ich habe sowohl das Sonoff-Modul als auch das MQTT-Modul und bei beiden habe ich den gleichen Port eingestellt. An den Modulen selbst als auch im ioBroker. Allerdings ist das MQTT-Modul die ganze Zeit deaktiviert.
                Aber ich denke, es liegt an den Sonoff selbst, zumal nur immer zwei der 4 Relais schalten. Kann man nicht hieraus irgendwie erkennen, warum gerade geschaltet wurde:
                11:03:00 MQT: Attempting connection...
                11:03:00 MQT: Connect failed to 192.168.178.xx:1888, rc -2. Retry in 10 sec
                11:03:13 MQT: Attempting connection...
                11:03:13 MQT: Connected
                11:03:13 MQT: tele/sonoff/LWT = Online (retained)
                11:03:13 MQT: cmnd/sonoff/POWER =
                11:03:13 MQT: Subscribe to cmnd/sonoff/#
                11:03:13 MQT: Subscribe to cmnd/sonoffs/#
                11:03:13 MQT: Subscribe to cmnd/Relais-3_fb/#
                11:04:34 HTP: Main Menu
                11:05:17 MQT: tele/sonoff/STATE = {"Time":"2019-04-19T11:05:17","Uptime":"0T17:21:04","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":xxxxxxx","Channel":13,"RSSI":100,"LinkCount":147,"Downtime":"0T00:05:08"}}
                11:10:17 MQT: tele/sonoff/STATE = {"Time":"2019-04-19T11:10:17","Uptime":"0T17:26:04","Vcc":3.183,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xx:xx:A1:26:2C:A1","Channel":13,"RSSI":100,"LinkCount":147,"Downtime":"0T00:05:08"}}
                11:15:17 MQT: tele/sonoff/STATE = {"Time":"2019-04-19T11:15:17","Uptime":"0T17:31:04","Vcc":3.174,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxxx","BSSId":"xx:xx:A1:26:2C:A1","Channel":13,"RSSI":96,"LinkCount":147,"Downtime":"0T00:05:08"}}
                11:20:17 MQT: tele/sonoff/STATE = {"Time":"2019-04-19T11:20:17","Uptime":"0T17:36:04","Vcc":3.182,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"xxxxx","BSSId":"xx:xx:A1:26:2C:A1","Channel":13,"RSSI":100,"LinkCount":147,"Downtime":"0T00:05:08"}}
                11:20:47 APP: Button2 level 1-0
                11:20:47 SRC: Button
                11:20:47 MQT: stat/sonoff/RESULT = {"POWER2":"OFF"}
                11:20:47 MQT: stat/sonoff/POWER2 = OFF
                11:20:47 APP: Button2 level 0-1
                11:20:47 CFG: Saved to flash at F8, Count 2887, Bytes 3584
                11:21:54 HTP: Console
                Das BASIC-Modul ist bei mir so konfiguriert. Dazu muss ich aber sagen, dass er die ganze Zeit jetzt vom Strom genommen wurde und im ioBroker zwar erfasst, aber noch nicht mit Blockly irgendwie angesteuert wurde.
                Typ: Sonoff BASIC (1) keine GPIOs definiert
                FullTopic: %prefix%/%topic%/
                Was meinst du mit "wie die Relais definiert sind"?
                Typ: Sonoff 4CH Pro (23) keine GPIOs definiert
                Beim 4CH finde ich kein MQTT
                Wäre vielleicht ein Reset Configuration sinnvoll?
                Was ist der Unterschied zu Restore? Wird da die Originalfirmware wieder aufgespielt?
                • Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  Mqtt Adapter ist bei mir Port 1883.
                  Sonoff Adapter 1885.
                  Die Ports müssen verschieden sein !!!
                  Du mußt bei dem Basic in Tasmota sagen das er ein Basic ist, haste ja.
                  Damit Tasmota Basic weiß wo das Relay angeschlossen ist muß du das einstellen.
                  Relay auf GPIO 2 Switch1 (9) beim Basic.
                  CH 4 geht das Automatisch wenn CH 4 gewählt ist.
                  • P Offline
                    paul.honka
                    schrieb am zuletzt editiert von paul.honka
                    Wie weit ist den Sonoff 4CH pro vom Router weg?
                    Beim mir ist der Router unter dem Schreibtisch an der Wand,
                    da spielte der Sonoff auf dem Schreitisch auch verrückt. Er schaltete auch wahrlos. Jetzt mit 5 m Entfernung geht es .
                    Beste Grüsse paul
                    • docadamsD Offline
                      docadamsD Offline
                      docadams
                      Das ist eine Idee. Das Relais ist ca. 3m vom Router entfernt, ohne Hinternisse.
                      Ich werde das Relais in einen anderen Raum verfrachten. Muss mir aber dann etwas einfallen lassen, wie ich das verfolge.
                      Auf alle Fälle liegt es nicht am ioBroker direkt, der RasPi ist aus und trotzdem schaltet das Gerät munter vor sich hin.
                      Danke für den Hinweis, dass es unbedinget unterschiedliche Ports sein müssen.
                      Das MQTT habe ich perspektivisch für die Sonoff-Bridge. Deshalb hatte ich das Modul noch nicht aktiviert.
                      Brauche ich für das Sonoff-Modul trotzdem die MQTT-Einstellungen an den Relais?
                      • Ralla66R Offline
                        Ralla66R Offline
                        Ralla66
                        Im IO Broker ist der Sonoff Adapter dein Mqtt Broker ( nenne das mal Verwaltungszentrale ).
                        Der Sonoff Basic verbindet sich mit dem Sonoff Adapter über den Mqtt Broker mit IO.
                        Das dient nur dazu aus IO Broker den Basic schalten zu können.
                        Brauchst du nicht unbedingt.
                        Der Basic sollte auch aus einem Browser schaltbar sein.
                        Wenn du gar nicht weiter kommst flashe den Basic neu mit Core 2.3.0.
                        Binde diesen nicht in dein Netzwerk ein.
                        Taucht dann auf über verfügbare Netzwerke anzeigen.
                        Ist dann glaube ich über 192.168.4.1 zu erreichen.
                        Schaltet das Relais immer noch liegt es am Basic.
                        Bevor du die Tasmota flasht ist es ratsam den Flash mit einer Blank zu überschreiben
                        um reste im Flash zu löschen.
                        Anleitung findest du hier :
                        https://forum.creationx.de/lexicon/index.php?entry/36-bei-problemen-esp8266-85-flash-speicher-löschen/
                        • docadamsD Offline
                          docadamsD Offline
                          docadams
                          Im anderen Raum hat er noch nicht wieder geschaltet. Zumindest bei den Stichproben nicht.
                          Vielleicht war es das.
                          Aber der Hinweis, den BASIC nicht in das normale WLAN einzubinden, ist mir neu. Soll das bei allen Sonoff-Relais so geschehen?
                          Wie ist dann die Reichweite?
                          • Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            Das ist nur zu Testzwecken.
                            Wenn er nicht in deinem Netzwerk steht kommt der Schaltbefehl Relay eindeutig vom Basic selbst.
                            Meine Sonoff sind alle in meinem Netzwerk verbunden.
                            Selbst 1 Meter neben dem Router laufen diese ohne Probleme.
                            Sonoff Bridge erkennt bei mir nur wenige Fernbedienungen.
                            Selbst nach flashen mit Tasmota und flashen des 433 Mhz Chip.
                            Meine Intertechno FB sind damit nicht schaltbar.
                            Nach Umbau auf Infrarot Sender geht das auch nur bedingt.
                            Linux Sat Boxen schalten nicht.
                            Daher war meine Wahl der Broadlink.
                            Zwar etwas teuerer aber dieser schaltet bei mir alles per 433 Mhz und IR.
                            • docadamsD Offline
                              docadamsD Offline
                              docadams
                              Doch zu früh gefeut. Es sind immer nur Relais2 und Relais4, die Schalten.
                              Aber er scheit zumindest seltener zu schalten.
                              Wenn ich per GUI schalte, sieht das so aus:
                              16:33:01 SRC: WebGui from 192.168.178.xx
                              16:33:01 RSL: RESULT = {"POWER4":"OFF"}
                              16:33:01 RSL: POWER4 = OFF
                              16:33:01 CFG: Saved to flash at FB, Count 2916, Bytes 3584
                              Und wenn es fremdgeschaltet wird, so:
                              15:46:34 APP: Button4 level 1-0
                              15:46:34 SRC: Button
                              15:46:34 RSL: RESULT = {"POWER4":"ON"}
                              15:46:34 RSL: POWER4 = ON
                              15:46:34 APP: Button4 level 0-1
                              15:46:34 CFG: Saved to flash at F5, Count 2914, Bytes 3584
                              Als wenn einer den Button drückt....
                              Ich werde wohl mal alles neu machen. Danke für den Link von Creationx.
                              • Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                Würde das zuerst mit dem Basic probieren.
                                Blank flashen und danach Tasmota drauf.
                                CH 4 habe ich nicht.
                                Bei CH4 gabs wohl die R1 und R2 die teilweise zicken machen.
                                Erst einmal den Basic ans laufen bekommen.
                                Dann weißt du mehr.
                                • docadamsD Offline
                                  docadamsD Offline
                                  docadams
                                  Danke erst mal. Aber jetzt ist Ostern, sonst ist Ärger in Anmarsch ;-)
                                  • E Offline
                                    Einstein67
                                    Hatte auch mal solche Geisterschaltungen auf 2 Kanälen.
                                    Lösch einfach mal den RF-Empfänger, danach war bei mir absolute Ruhe!
                                    • docadamsD Offline
                                      docadamsD Offline
                                      docadams
                                      Meinst du den RF-Code löschen?
                                      Ich habe allerdings keine FR-Fernbedienung.
                                      Ich hab jetzt 2 Quellen gefunden, wo gesagt wird "3 kurze Tastendrücke zum Löschen und 2x zum Anlernen".
                                      Ich habe es mit allen 4 Tasten auf dem Sonoff 4CH probiert. Welche Taste ist gemeint, vielleicht ist nur mein "kurz" zu lang oder zu kurz ;-)
                                      • docadamsD Offline
                                        docadamsD Offline
                                        docadams
                                        ich hatte jetzt endlich wieder etwas Zeit, mich dem Problem zu widmen.
                                        Ich habe inzwischen das 4CH blank und danach mit der Tasmota 6.5.0 und dem ESP-Tool völlig neu geflasht und neu eingerichtet. Dann habe ich es in einen anderen Raum verbracht (wo es in Zukunft eingesetzt werden soll) und in Ruhe gelassen. Also wir waren nicht zu Hause.
                                        Trotzdem schalten hin und wieder die Kanäle 2 und 4. Irgendeine Systematik kann ich nicht erkennen. Einen Einfluss aus der Nachbarschaft kann ich nicht gänzlich ausschalten, ist aber äußerst unwahrscheinlich.
                                        Bleibt eigentlich nur der RF-Empfänger. Ich habe leider nicht gefunden, wie man den RF-Empfänger löschen kann. Ich habe zwar auf der Platine einen Taster "433 clearing button" gefunden, hat aber keine Wirkung.
                                        Ich brauche die 433-Funktionalität nicht. Kann ich das irgendwie mittels (Consolen-?)-Befehl gänzlich deaktivieren?
                                        • Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          Systematik testen.
                                          Neu flashen ohne Netzwerkanbindung und keine Einstellungen bei Mqtt.
                                          Verhalten beobachten.
                                          Wenn gleich anderen Standort wählen, Freund Eltern oder so.
                                          Wenn der woanders immer noch schaltet liegt das am 4 CH selbst.
                                          Auf der Platine sind ja Schalter und K usw .
                                          So wie ich gelesen habe sind die bei Tasmota außer Betrieb.
                                          Einfach mal testen.
                                          Zur Not schneide die 433 MHZ Antenne ab dann hat der kein Empfang mehr.
                                          Kannste ja später wieder anlöten bei Bedarf.
