  4. "npm ERR! pna.nextTick is not a function" bei Adapter Installation
    3.1k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
npm na.nexttick adapter
12 Beiträge 4 Kommentatoren 697 Aufrufe 1 Beobachtet
    mawin
    ich habe ein problem mit meiner iobroker Installation, besser gesagt mit NPM. Bei einer Adpater-Installation (egal welche) erscheint der Fehler :
    *******$ ./iobroker add bring  --host ioBroker-02
    NPM version: 6.4.1
    npm install iobroker.bring --production --save --prefix "/opt/iobroker" (System call)
    npm ERR! asyncWrite is not a function
    npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_01_614Z-debug.log
    host.ioBroker-02 install adapter bring
    NPM version: 6.4.1
    npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_09_415Z-debug.log
    NPM version: 6.4.1
    npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_17_043Z-debug.log
    ERROR: host.ioBroker-02 Cannot install bring
    ERROR: process exited with code 13*******
    Ein 'npm cache verify' bringt ein ähnliches Problem:
    Unhandled rejection TypeError: pna.nextTick is not a function
        at emitReadable (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:498:25)
        at onEofChunk (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:486:3)
        at readableAddChunk (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:257:5)
        at Class.Readable.push (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:245:10)
        at readdirOrEmpty.map.then (/usr/local/lib/node_modules/npm/node_modules/cacache/lib/entry-index.js:135:12)
        at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
        at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:512:31)
        at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:569:18)
        at Promise._settlePromise0 (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
        at Promise._settlePromises (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
        at Promise._fulfill (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
        at MappingPromiseArray.PromiseArray._resolve (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise_array.js:126:19)
        at MappingPromiseArray.init (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise_array.js:74:18)
        at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
    npm ERR!     /root/.npm/_logs/2019-03-27T10_18_31_266Z-debug.log
    Das Problem kann erst seit ein paar Tagen bestehen. Ein npm, node oder nodejs Update habe ich nicht durchgeführt. Meine Versionen wie folgt :
    npm 6.4.1
    nodejs v8.15.1
    node v8.15.1
    Das Letzte an was ich mich erinnern kann, ich habe die Anleitung des radar-Adapters befolgt. Befehle darin sind :
    sudo apt-get install fping arp-scan
    sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
    sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
    Ob der Fehler damit zu tun hat kann ich aber nicht sagen.
    Vielen Dank für Eure Hilfe!
      mawin
      Problem wurde wie folgt behoben :
      cd /usr/local/lib/node_modules
      sudo mv npm npmold
      sudo -H npm install -g npm@6
      Das soweit als Info, ohne Gewähr.
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        @mawin sagte in "npm ERR! pna.nextTick is not a function" bei Adapter Installation:
        iobroker add bring
        ich kan den Fehler nicht reproduzieren, adapter mal komplett gelöscht und neu installiert ?
        iobroker add bring
        NPM version: 6.9.0
        npm install iobroker.bring@1.3.4 --production --save --prefix "/usr/local/iobroker" (System call)
        host.MacBook-Pro-van-Rafal.local install adapter bring
        npm install --production (System call) in "/usr/local/iobroker/node_modules/iobroker.bring"
        npm notice created a lockfile as package-lock.json. You should commit this file.
        got /usr/local/iobroker/node_modules/iobroker.bring/admin
        upload [2] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/words.js words.js application/javascript
        upload [1] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/index_m.html index_m.html text/html
        upload [0] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/bring.png bring.png image/png
        Adapter "system.adapter.vis.0" restarted.
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring created
        host.MacBook-Pro-van-Rafal.local create instance bring
        host.MacBook-Pro-van-Rafal.local object bring.0.info.user created
        host.MacBook-Pro-van-Rafal.local object bring.0.info.connection created
        host.MacBook-Pro-van-Rafal.local object bring.0.info created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.outputCount created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.inputCount created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.uptime created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memRss created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memHeapTotal created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memHeapUsed created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.cputime created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.cpu created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.connected created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.alive created
        host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0 created
        MacBook-Pro:iobroker rafal$ npm -v
        6.9.0
        MacBook-Pro:iobroker rafal$ node -v
        v8.15.0
          mawin
          Fehler tritt bei jeder Adapter Installation auf. Auch 'npm cache verify' bringt diesen Fehler.
          Ich denke die NPM-Installation ist zerschossen, tue mich aber schwer diese neu zu installieren. Ich kann NPM nicht über sich selbst updaten :
          mw@ioBroker-02:~$ sudo npm install -g npm@6
          npm ERR!     /root/.npm/_logs/2019-03-29T11_50_38_715Z-debug.log
          Da NPM eine Komponente von NodeJS ist, ich hoffe da liege ich richtig, könnte ein Update/Reinstall von NodeJS helfen? Ich möchte aber nur ungern eine Neukonfiguration meiner iobroker Installation durchführen müssen, im Moment läuft sie recht stabil und eigentlich ohne Fehler....bis auf diesen hier.
          Danke!
          • M mawin
            Danke!
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            Dürfte helfen. Wenn du bei der selben Major-Version bleibst (6/8/10), sollte keine Änderung an ioBroker nötig sein.
              mawin
              Leider hat der folgende Aufruf keine Besserung gebracht :
              sudo apt-get install --reinstall nodejs
              Also, nur um sicher zu sein und nicht am Wochenende im Keller sitzen zu müssen zwecks kompletter Neuinstallation :-), ich würde jetzt Folgendes ausführen :
              sudo apt-get --purge remove node
              sudo apt-get --purge remove nodejs
              sudo apt-get autoremove
              sudo reboot
              curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
              sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
              sudo reboot
              Gute Idee?
              • M mawin
                sudo reboot
                sudo reboot
                Gute Idee?
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                sollten nicht nötig sein - der Rest sieht für mich sinnvoll aus.
                Mal abgesehen davon: Ich finde bei Google Hinweise, dass das möglicherweise mit dem Versionsmanager n zu tun hat, hast du den zufällig im Einsatz?
                  mawin
                  Einen Versions-Manager, z.B. n, habe ich nicht im Einsatz.
                  Ich führe dann mal die Befehle aus....am Sonntag, da wird das Wetter schlechter.
                  Danke schonmal für die Hilfe!
                    mawin
                    So regnerisches Wetter, wollte nun die Gelegenheit nutzen und node/nodejs neu installieren. Erster Befehl bringt mich aber zum Grübeln :
                    $sudo apt-get --purge remove node
                    Paket »node« ist nicht installiert, wird also auch nicht entfernt.
                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    $ node -v
                    v8.15.1
                    Ich habe jetzt nicht weiter gemacht, das scheint mir doch sonderbar. Wie kann node nicht installiert sein wenn node -v mir die Version anzeigt?
                    • M mawin
                      $ node -v
                      v8.15.1
                      HomoranH Offline
                      HomoranH Offline
                      @mawin
                      Was sagt
                      which node
                        mawin
                        $ which node
                        /usr/local/bin/node
                        Danke!
                          mawin
                          wenns hilft :
                          mw@ioBroker-02:~$ which node
                          /usr/local/bin/node
                          mw@ioBroker-02:~$ which npm
                          /usr/local/bin/npm
                          mw@ioBroker-02:~$ which nodejs
                          /usr/bin/nodejs
                            mawin
                            sudo mv npm npmold
