  4. Smartmeter optische Schnittstelle
    6.6k
smartmeterd0-schnittstelleoptische schnittstelleserielle schnittstelle
42 Beiträge 10 Kommentatoren 8.9k Aufrufe 6 Beobachtet
  • T tilly
    @wendy2702
    habe mit "ls -la /dev/serial/by-id/" den absoluten pfad rausgesucht
    dmesg liefert
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0xf00
    [    0.000000] Linux version 4.14.98-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.                                                       3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 SMP Tue Feb 12 20:27:48                                                        GMT 2019
    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio                                                       n cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
    [    0.000000] On node 0 totalpages: 242688
    [    0.000000] free_area_init_node: node 0, pgdat 80c85780, node_mem_map ba39f00                                                       0
    [    0.000000]   Normal zone: 2133 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
    [    0.000000] percpu: Embedded 17 pages/cpu @ba349000 s38720 r8192 d22720 u6963                                                       2
    [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=4                                                       16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dw                                                       c_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=8087cb8e-02                                                        rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 940236K/970752K available (7168K kernel code, 577K rwdata                                                       , 2080K rodata, 1024K init, 698K bss, 22324K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                       lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                       modules : 0x7f000000 - 0x80000000   (  16 MB)
                         .text : 0x80008000 - 0x80800000   (8160 kB)
                         .init : 0x80b00000 - 0x80c00000   (1024 kB)
                         .data : 0x80c00000 - 0x80c906d4   ( 578 kB)
                          .bss : 0x80c97ef8 - 0x80d468f0   ( 699 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 25298 entries in 75 pages
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                                                        0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980                                                       46511078ns
    [    0.000030] Switching to timer-based delay loop, resolution 52ns
    [    0.000346] Console: colour dummy device 80x30
    [    0.000974] console [tty1] enabled
    [    0.001020] Calibrating delay loop (skipped), value calculated using timer fr                                                       equency.. 38.40 BogoMIPS (lpj=192000)
    [    0.001068] pid_max: default: 32768 minimum: 301
    [    0.001486] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001531] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.002764] Disabling memory control group subsystem
    [    0.002921] CPU: Testing write buffer coherency: ok
    [    0.003552] CPU0: update cpu_capacity 1024
    [    0.003593] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
    [    0.004245] Setting up static identity map for 0x100000 - 0x10003c
    [    0.004467] Hierarchical SRCU implementation.
    [    0.005525] smp: Bringing up secondary CPUs ...
    [    0.006701] CPU1: update cpu_capacity 1024
    [    0.006711] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
    [    0.007955] CPU2: update cpu_capacity 1024
    [    0.007965] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
    [    0.009183] CPU3: update cpu_capacity 1024
    [    0.009195] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
    [    0.009343] smp: Brought up 1 node, 4 CPUs
    [    0.009485] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.009511] CPU: All CPU(s) started in HYP mode.
    [    0.009533] CPU: Virtualization extensions available.
    [    0.010855] devtmpfs: initialized
    [    0.023730] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c                                                        with crng_init=0
    [    0.024558] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7                                                        rev 5
    [    0.024929] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                                                       x_idle_ns: 19112604462750000 ns
    [    0.024989] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.025811] pinctrl core: initialized pinctrl subsystem
    [    0.026961] NET: Registered protocol family 16
    [    0.030182] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.036646] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint                                                        registers.
    [    0.036701] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.036985] Serial: AMBA PL011 UART driver
    [    0.039334] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.081867] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dma                                                       chans=0x1
    [    0.083896] SCSI subsystem initialized
    [    0.084269] usbcore: registered new interface driver usbfs
    [    0.084367] usbcore: registered new interface driver hub
    [    0.084538] usbcore: registered new device driver usb
    [    0.090357] raspberrypi-firmware soc:firmware: Attached to firmware from 2019                                                       -02-12 19:42
    [    0.092151] clocksource: Switched to clocksource arch_sys_counter
    [    0.180156] VFS: Disk quotas dquot_6.6.0
    [    0.180317] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.180597] FS-Cache: Loaded
    [    0.180926] CacheFiles: Loaded
    [    0.194255] NET: Registered protocol family 2
    [    0.195287] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.195449] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.195659] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.195866] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.195951] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.196306] NET: Registered protocol family 1
    [    0.197035] RPC: Registered named UNIX socket transport module.
    [    0.197074] RPC: Registered udp transport module.
    [    0.197097] RPC: Registered tcp transport module.
    [    0.197121] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.199048] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter                                                       s available
    [    0.203051] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.214155] FS-Cache: Netfs 'nfs' registered for caching
    [    0.215101] NFS: Registering the id_resolver key type
    [    0.215168] Key type id_resolver registered
    [    0.215192] Key type id_legacy registered
    [    0.215229] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.218146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                                                       51)
    [    0.218404] io scheduler noop registered
    [    0.218436] io scheduler deadline registered (default)
    [    0.218711] io scheduler cfq registered
    [    0.218741] io scheduler mq-deadline registered
    [    0.218765] io scheduler kyber registered
    [    0.221118] BCM2708FB: allocated DMA memory fad00000
    [    0.221193] BCM2708FB: allocated DMA channel 0 @ bb813000
    [    0.230658] Console: switching to colour frame buffer device 82x26
    [    0.240597] bcm2835-rng 3f104000.rng: hwrng registered
    [    0.243431] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000                                                       000(1024 MiB)
    [    0.249372] vc-sm: Videocore shared memory driver
    [    0.252585] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2                                                       00000
    [    0.272375] brd: module loaded
    [    0.287070] loop: module loaded
    [    0.289680] Loading iSCSI transport class v2.0-870.
    [    0.293345] libphy: Fixed MDIO Bus: probed
    [    0.296087] usbcore: registered new interface driver lan78xx
    [    0.298744] usbcore: registered new interface driver smsc95xx
    [    0.301197] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.331674] dwc_otg 3f980000.usb: base=0xf0980000
    [    0.534495] Core Release: 2.80a
    [    0.536975] Setting default values for core params
    [    0.539553] Finished setting default values for core params
    [    0.742597] Using Buffer DMA mode
    [    0.745184] Periodic Transfer Interrupt Enhancement - disabled
    [    0.747896] Multiprocessor Interrupt Enhancement - disabled
    [    0.750592] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.753267] Dedicated Tx FIFOs mode
    [    0.756330] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad                                                       14000 dma = 0xfad14000 len=9024
    [    0.761532] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    0.773903] dwc_otg: Microframe scheduler enabled
    [    0.773985] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805ed94c
    [    0.776555] WARN::hcd_init_fiq:460: FIQ ASM at 0x805edcb4 length 36
    [    0.779080] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
    [    0.781712] dwc_otg 3f980000.usb: DWC OTG Controller
    [    0.784341] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number                                                        1
    [    0.787002] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
    [    0.789623] Init: Port Power? op_state=1
    [    0.792216] Init: Power Port (0)
    [    0.794991] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    0.797607] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                       1
    [    0.800208] usb usb1: Product: DWC OTG Controller
    [    0.802788] usb usb1: Manufacturer: Linux 4.14.98-v7+ dwc_otg_hcd
    [    0.805368] usb usb1: SerialNumber: 3f980000.usb
    [    0.808787] hub 1-0:1.0: USB hub found
    [    0.811310] hub 1-0:1.0: 1 port detected
    [    0.814415] dwc_otg: FIQ enabled
    [    0.814422] dwc_otg: NAK holdoff enabled
    [    0.814428] dwc_otg: FIQ split-transaction FSM enabled
    [    0.814441] Module dwc_common_port init
    [    0.814823] usbcore: registered new interface driver usb-storage
    [    0.817528] mousedev: PS/2 mouse device common for all mice
    [    0.820050] IR NEC protocol handler initialized
    [    0.822537] IR RC5(x/sz) protocol handler initialized
    [    0.825035] IR RC6 protocol handler initialized
    [    0.827496] IR JVC protocol handler initialized
    [    0.829848] IR Sony protocol handler initialized
    [    0.832235] IR SANYO protocol handler initialized
    [    0.834609] IR Sharp protocol handler initialized
    [    0.836865] IR MCE Keyboard/mouse protocol handler initialized
    [    0.839161] IR XMP protocol handler initialized
    [    0.842435] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
    [    0.845135] bcm2835-cpufreq: min=600000 max=900000
    [    0.847988] sdhci: Secure Digital Host Controller Interface driver
    [    0.850397] sdhci: Copyright(c) Pierre Ossman
    [    0.853265] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    0.855861] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.859050] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.861697] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.864408] usbcore: registered new interface driver usbhid
    [    0.866992] usbhid: USB HID core driver
    [    0.870283] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
    [    0.874738] [vc_sm_connected_init]: start
    [    0.883700] [vc_sm_connected_init]: end - returning 0
    [    0.887086] Initializing XFRM netlink socket
    [    0.889665] NET: Registered protocol family 17
    [    0.892454] Key type dns_resolver registered
    [    0.895470] Registering SWP/SWPB emulation handler
    [    0.899057] registered taskstats version 1
    [    0.909275] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    0.912291] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud                                                        = 0) is a PL011 rev2
    [    1.932942] console [ttyAMA0] enabled
    [    1.942109] sdhost: log_buf @ bad13000 (fad13000)
    [    2.022190] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    2.031793] of_cfs_init
    [    2.037112] of_cfs_init: OK
    [    2.043176] Waiting for root device PARTUUID=8087cb8e-02...
    [    2.050915] Indeed it is in host mode hprt0 = 00021501
    [    2.148469] random: fast init done
    [    2.161620] mmc0: host does not support reading read-only switch, assuming wr                                                       ite-enable
    [    2.177100] mmc0: new high speed SDHC card at address 0001
    [    2.186020] mmcblk0: mmc0:0001 00000 29.8 GiB
    [    2.195128]  mmcblk0: p1 p2
    [    2.235971] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                                                       pts: (null)
    [    2.249728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    2.262204] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    2.272037] Indeed it is in host mode hprt0 = 00001101
    [    2.332319] devtmpfs: mounted
    [    2.342045] Freeing unused kernel memory: 1024K
    [    2.512579] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
    [    2.522388] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    2.533538] hub 1-1:1.0: USB hub found
    [    2.540392] hub 1-1:1.0: 5 ports detected
    [    2.825554] systemd[1]: System time before build time, advancing clock.
    [    2.862222] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    2.969488] NET: Registered protocol family 10
    [    2.978518] Segment Routing with IPv6
    [    2.996011] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    3.012757] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
    [    3.022810] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber                                                       =0
    [    3.036129] smsc95xx v1.0.6
    [    3.045903] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.063530] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SEL                                                       INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                                       XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
    [    3.091627] systemd[1]: Detected architecture arm.
    [    3.118309] systemd[1]: Set hostname to <raspberrypi>.
    [    3.136443] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-                                                       1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:49:73:34
    [    3.182629] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.235923] uart-pl011 3f201000.serial: no DMA platform data
    [    3.239555] random: systemd-cryptse: uninitialized urandom read (16 bytes rea                                                       d)
    [    3.262243] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
    [    3.372246] usb 1-1.3: device descriptor read/64, error -32
    [    3.592236] usb 1-1.3: device descriptor read/64, error -32
    [    3.805423] systemd[1]: Set up automount Arbitrary Executable File Formats Fi                                                       le System Automount Point.
    [    3.812281] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
    [    3.835651] systemd[1]: Started Forward Password Requests to Wall Directory W                                                       atch.
    [    3.853750] systemd[1]: Reached target Swap.
    [    3.865313] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    3.879613] systemd[1]: Listening on udev Kernel Socket.
    [    3.893347] systemd[1]: Created slice System Slice.
    [    3.909685] systemd[1]: Mounting Debug File System...
    [    3.922259] usb 1-1.3: device descriptor read/64, error -32
    [    4.147505] usb 1-1.3: device descriptor read/64, error -32
    [    4.272603] usb 1-1-port3: attempt power cycle
    [    4.666298] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.800854] systemd-journald[96]: Received request to flush runtime journal f                                                       rom PID 1
    [    4.932264] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
    [    4.966709] usb 1-1.3: New USB device found, idVendor=0658, idProduct=0200
    [    4.966734] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber                                                       =0
    [    5.062243] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
    [    5.217454] usb 1-1.5: New USB device found, idVendor=0451, idProduct=16a8
    [    5.217477] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber                                                       =3
    [    5.217489] usb 1-1.5: Product: TI CC2531 USB CDC
    [    5.217499] usb 1-1.5: Manufacturer: Texas Instruments
    [    5.217509] usb 1-1.5: SerialNumber: __0X00124B0018E1A2EA
    [    5.309255] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    [    5.331262] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
    [    5.332723] usbcore: registered new interface driver cdc_acm
    [    5.332739] cdc_acm: USB Abstract Control Model driver for USB modems and ISD                                                       N adapters
    [    5.550533] snd_bcm2835: module is from the staging directory, the quality is                                                        unknown, you have been warned.
    [    5.559884] bcm2835_alsa bcm2835_alsa: card created with 8 channels
    [    7.344273] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [    7.345076] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    7.345237] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [    7.444029] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1                                                       02396k SSFS
    [    8.748746] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE                                                       1
    [   59.510421] random: crng init done
    [   59.510444] random: 7 urandom warning(s) missed due to ratelimiting
    [ 8050.932248] usb 1-1.2: new full-speed USB device number 8 using dwc_otg
    [ 8051.065778] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523
    [ 8051.065797] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber                                                       =0
    [ 8051.065809] usb 1-1.2: Product: USB2.0-Serial
    [ 8051.152012] usbcore: registered new interface driver usbserial
    [ 8051.152113] usbcore: registered new interface driver usbserial_generic
    [ 8051.152334] usbserial: USB Serial support registered for generic
    [ 8051.156472] usbcore: registered new interface driver ch341
    [ 8051.156588] usbserial: USB Serial support registered for ch341-uart
    [ 8051.156713] ch341 1-1.2:1.0: ch341-uart converter detected
    [ 8051.159495] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
    [ 8571.606831] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb s                                                       topped: -32
    [ 8571.606935] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb s                                                       topped: -32
    [ 8571.852129] usb 1-1.2: USB disconnect, device number 8
    [ 8571.852691] usb 1-1.2: failed to send control message: -19
    [ 8571.853208] ch341-uart ttyUSB0: ch341-uart converter now disconnected from tt                                                       yUSB0
    [ 8571.853308] ch341 1-1.2:1.0: device disconnected
    [ 8688.623792] usb 1-1.2: new full-speed USB device number 9 using dwc_otg
    [ 8688.757069] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523
    [ 8688.757087] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber                                                       =0
    [ 8688.757098] usb 1-1.2: Product: USB2.0-Serial
    [ 8688.758405] ch341 1-1.2:1.0: ch341-uart converter detected
    [ 8688.762557] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
    [ 9361.100082] usb 1-1.2: USB disconnect, device number 9
    [ 9361.100805] ch341-uart ttyUSB0: ch341-uart converter now disconnected from tt                                                       yUSB0
    [ 9361.100896] ch341 1-1.2:1.0: device disconnected
    [10585.588519] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
    [10585.721942] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523
    [10585.721961] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber                                                       =0
    [10585.721969] usb 1-1.2: Product: USB2.0-Serial
    [10585.723259] ch341 1-1.2:1.0: ch341-uart converter detected
    [10585.726866] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
    wendy2702W Online
    wendy2702W Online
    @tilly sagte in Smartmeter optische Schnittstelle:
    ttyUSB0
    Das ist denke ich dein device.
      tilly
      ich nehme immer gerne den absoluten Pfad, falls mal was umgesteckt wird. Aber zum testen hab ich nun mal ttyUSB0 genommen. Außerdem die Einstellungen von RappiRN genommen. Leider immer noch keine Daten.
      • wendy2702W Online
        wendy2702W Online
        Screenshot der Einstellungen?
        Wie ist der Pfad eingetragen?
        Instanz auf Debug stellen und logfile liefern!
        • wendy2702W wendy2702
          tilly
          @wendy2702
          Pfad ist "ttyUSB0"
          Hier das Logfile
          smartmeter.0	2019-03-26 19:15:17.215	warn	No or too long answer from Serial Device after last request.
          smartmeter.0	2019-03-26 19:15:17.213	info	Error: No or too long answer from Serial Device after last request.
          • wendy2702W Online
            wendy2702W Online
            Hast du mit minicom auf dem iobroker Rechner getestet?
            Liefert
            cat /dev/ttyUSB0
            Etwas?
            Steht das logging für die Instanz auf DEBUG?
            Wenn der Adapter läuft darf nicht weiteres auf das Device zu greifen.
              Liefert
              cat /dev/ttyUSB0
              Etwas?
              tilly
              @wendy2702 said in Smartmeter optische Schnittstelle:
              minicom liefert am Zähler nichts. Mit einer Fernbedienung für TV habe ich die folgendes empfangen.
              cat /dev/ttyUSB0
              liefert nichts
              also bei log kann man ja adebug, silly, info, warn oder error auswählen. Steht auf debug.
              oder wie macht man das?
              • wendy2702W Online
                wendy2702W Online
                Sitzt der Lesekopf richtig auf dem Zähler?
                Was ist das für ein Rechner?
                Den mal neu gestartet?
                Wenn es ganz dumm läuft hat dein EVU die Schnittstelle abgeschaltet.
                Hier den Thread mal nach deinem Zähler durchsuchen, gibt einige Einträge dazu und mögliche Lösungen.
                Ist am Handy für mich zu mühselig.
                R T 2 Antworten Letzte Antwort
                  RappiRN
                  Dem
                  @wendy2702 sagte in Smartmeter optische Schnittstelle:
                  würde das untere allerdings widersprechen, oder?
                  Wenn man mit einer Kamera sich den Stromzähler(Easy Meter Q3DB1024 mit D0 Schnittstelle) anschaut, wird dort ca. alle 2s gesendet.
                  Enrico
                  • wendy2702W Online
                    wendy2702W Online
                    Naja,
                    Wenn da was „blinkt“ oder „leuchtet“ muss das nicht zwingend ein verwertbares Daten Telegramm sein.
                    Aber der Einwand ist berechtigt.... schwer zu sagen.
                    Habe aber auch keine Ahnung ob der TTL-USB Adapter eventuell noch eine spezielle Library oder etwas anderes benötigt.
                    • wendy2702W Online
                      wendy2702W Online
                      Welche Version vom Smartmeter Adapter?
                      Welche Node/Nodejs/NPM Versionen?
                      Gab es bei der Installation n vom Adapter/Instanz irgendwelche Error / Warnings im log?
                        tilly
                        1.2.2
                        Node: v8.15.1
                        npm 6.4.1
                        ? hab ich über iobroker gemacht
                          tilly
                          Denke schon, habe schon verschiedene Positionen ausprobiert.
                          Raspberry pi
                          diverse mal
                          Müsste in iobroker nicht irgendwas erscheinen, wenn ich mit einer Fernbedienung vom TV auf den Lesekopf ziele?
                          • wendy2702W Online
                            wendy2702W Online
                            Nein.
                            Höchstens etwas bei dem cat ....
                              Nein.
                              tilly
                              Nein.
                              Ja mit der Fernbedienung kommt was bei cat...
                              Sonst nichts?
                                tilly
                                Hab keine Ahnung wo es noch dran liegen kann.
                                Die Versorgungsspannung für den IR-Schreibe-Lesekopf mit TTL-Ausgang ist ja 3,3V, oder?
                                Sollten RX/TX getauscht sein? Aber dann bekäme ich doch keine Daten mit der TV-Ferbedienung.
                                • wendy2702W Online
                                  wendy2702W Online
                                  Wie sieht der Kopf aus und wie sitzt er auf dem Zähler ?
                                  Photos!
                                    Photos!
                                    tilly
                                    Photos!
                                    • RöstkartoffelR Offline
                                      Röstkartoffel
                                      An meinem Zähler sitzt der Leselopf so, bei dir ist er zu weit rechts:
                                      NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                                      • T tilly
                                        Photos!
                                        slonnet
                                        schrieb am zuletzt editiert von slonnet
                                        @tilly
                                        Das ist die falsche Schnittstelle!
                                        Die vorne muss du nehmen!
                                        Zumindest bei meinem Q3B ist es die vordere!
                                        RöstkartoffelR 1 Antwort Letzte Antwort
                                        • wendy2702W Online
                                          wendy2702W Online
                                          @slonnet sagte in Smartmeter optische Schnittstelle:
                                          @tilly
                                          Was liest du denn vorne aus oder zählst du nur die Impulse?
