  4. neuerdings Fehler bei update von Adaptern
fehleradapterinstallation
19 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • P PrinzEisenherz1
    Hi zusammen.
    Neuerdings erhalte ich folgende Meldungen beim installieren oder updaten von Adaptern:
    root@ioBroker-VM:/opt/iobroker# iobroker install vis-map
    NPM version: 6.4.1
    npm install iobroker.vis-map@1.0.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:82:0,
                     from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local<v8::Int32> v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
    In file included from ../src/bufferutil.cc:7:0:
    /root/.node-gyp/8.15.1/include/node/v8.h:9864:14: note: declared here
     Local<Int32> Value::ToInt32() const {
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local<v8::Uint32> v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
    /root/.node-gyp/8.15.1/include/node/v8.h:9858:15: note: declared here
     Local<Uint32> Value::ToUint32() const {
    In file included from ../node_modules/nan/nan_new.h:189:0,
                     from ../node_modules/nan/nan.h:82,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
    ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local<v8::Value> v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
       return v8::BooleanObject::New(value).As<v8::BooleanObject>();
    In file included from /root/.node-gyp/8.15.1/include/node/v8.h:26:0,
    /root/.node-gyp/8.15.1/include/node/v8.h:4895:56: note: declared here
       V8_DEPRECATED("Pass an isolate", static Local<Value> New(bool value));
    /root/.node-gyp/8.15.1/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
    /root/.node-gyp/8.15.1/include/node/v8.h:1475:21: note: declared here
           Local<Script> Compile(Isolate* isolate, Source* source,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
    ../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             v8::String::kNormalString, length);
    /root/.node-gyp/8.15.1/include/node/v8.h:2731:21: note: declared here
           Local<String> NewFromOneByte(Isolate* isolate, const uint8_t* data,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
    ../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
    /root/.node-gyp/8.15.1/include/node/v8.h:2769:38: note: declared here
                            Local<String> NewExternal(
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:237:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
    /root/.node-gyp/8.15.1/include/node/v8.h:1455:45: note: declared here
                            Local<UnboundScript> CompileUnbound(
    ../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:244:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    In file included from ../src/bufferutil.cc:16:0:
    ../node_modules/nan/nan.h: At global scope:
    ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
    ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
    ../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated: use IdleNotificationDeadline() [-Wdeprecated-declarations]
         return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
    /root/.node-gyp/8.15.1/include/node/v8.h:7539:22: note: declared here
                     bool IdleNotification(int idle_time_in_ms));
    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback
    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
         , v8::GCType gc_type_filter = v8::kGCTypeAll) {
    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback) {
    ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback
    ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback) {
    ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
         const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
    ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
    ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
    ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
           _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
         , node::smalloc::FreeCallback callback
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
    ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
             v8::Isolate::GetCurrent(), data, length, callback, hint);
    ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
    ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
         return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
    In file included from ../src/bufferutil.cc:10:0:
    /root/.node-gyp/8.15.1/include/node/node_buffer.h:67:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
     NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
    ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
    ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
         return node::Buffer::New(v8::Isolate::GetCurrent(), size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
    ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
         return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
    ../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
    ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
    In file included from ../src/bufferutil.cc:8:0:
    /root/.node-gyp/8.15.1/include/node/node.h:308:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
    /root/.node-gyp/8.15.1/include/node/node.h:321:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
    ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
    ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.0-8-686-pae
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
    gyp ERR! node -v v8.15.1
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
                     from ../src/validation.cc:15:
    In file included from ../src/validation.cc:7:0:
    In file included from ../src/validation.cc:15:0:
    In file included from ../src/validation.cc:10:0:
    ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
    ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
    In file included from ../src/validation.cc:8:0:
    make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! not ok
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
    host.ioBroker-VM object system.adapter.vis-map created
    got /opt/iobroker/node_modules/iobroker.vis-map/admin
    upload [3] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/words.js words.js application/javascript
    upload [2] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/vis-map.png vis-map.png image/png
    upload [1] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index_m.html index_m.html text/html
    upload [0] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index.html index.html text/html
    Adapter "system.adapter.vis.0" restarted.
    Woran könnte das liegen? Hatte ich vorher nicht.
    Johnny
    iobroker in VM (proxmox) Debian 9
    nodejs: 8.15.1
    node: 8.15.1
    npm: 6.4.1
    js-controller: 1.5.7
    SegwayS Offline
    SegwayS Offline
    Segway
    @PrinzEisenherz1 sagte in neuerdings Fehler bei update von Adaptern:
    du weisst schon dass dies noch eine Entwicklerversion ist ? Die letzte stable ist 1.4.2
    Gruß Dirk
    • P Offline
      PrinzEisenherz1
      Ist mir bewusst. Wobei ist die nicht mittlerweile auch im stable?
      Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
      SegwayS 1 Antwort Letzte Antwort
      • P PrinzEisenherz1
        SegwayS Offline
        SegwayS Offline
        Segway
        @PrinzEisenherz1
        nö im stable ist die 1.4.2
        wenn man eine Entwicklerversion installiert, können halt unvorhergesehene Sachen passieren.
        Gruß Dirk
        • P Offline
          PrinzEisenherz1
          Ich hab jetzt mal das Backup zurückgespielt und nochmal das reinstall laufen lassen.
          bufferutil.target.mk:101: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
          make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
          gyp ERR! not ok
          > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
          > node-gyp rebuild
          make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
            CXX(target) Release/obj.target/validation/src/validation.o
          validation.target.mk:101: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
          make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
          gyp ERR! not ok
          npm WARN request-promise-core@1.1.2 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
          npm WARN request-promise-native@1.0.7 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
          + iobroker.tankerkoenig@2.0.5
          added 4 packages from 30 contributors and audited 31958 packages in 28.044s
          found 56 vulnerabilities (38 low, 1 moderate, 17 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          DONE iobroker.tankerkoenig
          [..................] - fetchMetadata: sill resolveWithNewModule iobroker.telegram@1.4.3 checking installable status
          Da ist die Konsole schon stark gefüllt.
          Hmmm...hab das Problem echt bloß ich?
          Seltsam wenn das an der 1.5.7 liegen sollte.
          Mach nachher mal nen downgrade auf die 1.4.2 und kucke wie es da aussieht.
          • P PrinzEisenherz1
            gyp ERR! not ok
            > node-gyp rebuild
            gyp ERR! not ok
            SegwayS Offline
            SegwayS Offline
            Segway
            welches reinstall hast du benutzt ? von iobroker.net ? da laufen dann ja diese 4 Schritte durch.
            Gruß Dirk
            • P Offline
              PrinzEisenherz1
              ich hab die reinstall aus dem install-Ordner genommen.
              oder soll ich vielleicht node nochmal neu installieren?
              So, der reinstall ist jetzt durchgelaufen und so sieht es jetzt im logfile aus
              iobroker.2019-03-18.log
              • P Offline
                PrinzEisenherz1
                Hab node nochmal neu installiert und ein reinstall laufen lassen.
                Also der Spuk mit den warnings beginnt ab dem reinstall vom js-controller.
                ich mache jetzt mal einen downgrade auf die 1.4.2 und mache nochmal einen reinstall.
                mal kucken was es da macht.
                • P Offline
                  PrinzEisenherz1
                  Selbes Problem auch mit js-controller Version 1.4.2
                  Habe zum Test dasWetter-Adapter aktualisiert und da ist das selbe Problem
                  dasWetter.txt
                  Keine Ahnung was da nicht stimmt. Liegt es vielleicht daran das ich iobroker auf nem 32-bit Debian installiert habe?
                  • P Offline
                    PrinzEisenherz1
                    Also ich hab jetzt ein komplett neues System aufgesetzt (jetzt 64Bit) und mit iobroker backup und restore wieder iobroker installiert.
                    Egal was ich mach (hab jetzt auch node 10.15.3 umgestellt) erhalte ich diese Logeinträge beim installieren und deinstallieren.
                    Beispiel löschen js2fs instanz
                    $ ./iobroker del js2fs
                    Delete adapter "js2fs"
                    host.ioBroker-VM64 Counted 1 instances of js2fs
                    host.ioBroker-VM64 Counted 1 adapters for js2fs
                    host.ioBroker-VM64 Counted 10 states of js2fs
                    host.ioBroker-VM64 Counted 12 states (system.adapter.js2fs.*) from states
                    host.ioBroker-VM64 Deleting 12 object(s).
                    host.ioBroker-VM64 Deleting 12 state(s).
                    npm uninstall iobroker.js2fs --silent --save --prefix "/opt/iobroker" (System call)
                    In file included from ../node_modules/nan/nan.h:190:0,                 from ../src/unix_dgram.cc:5:
                    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
                    ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                       return obj->ForceSet(GetCurrentContext(), key, value, attribs);
                    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
                    ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                             v8::Isolate::GetCurrent(), target, func, argc, argv);
                    In file included from ../node_modules/nan/nan.h:47:0,
                    /home/iobroker/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
                                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                    /home/iobroker/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                         __attribute__((deprecated(message))) declarator
                    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
                    ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                    /home/iobroker/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
                    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
                    ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                             v8::Isolate::GetCurrent(), target, method, argc, argv);
                    /home/iobroker/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
                    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
                    ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       domain      = info[0]->Int32Value();
                    In file included from /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:26:0,                 from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63,
                                     from ../node_modules/nan/nan.h:47,
                    /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
                       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                    /home/iobroker/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       type        = info[1]->Int32Value();
                    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       protocol    = info[2]->Int32Value();
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       fd = info[0]->Int32Value();
                    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                       String::Utf8Value path(info[1]);
                    /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
                                       explicit Utf8Value(Local<v8::Value> obj));
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       buf = info[1]->ToObject();
                    In file included from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63:0,
                    /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                     Local<Object> Value::ToObject() const {
                    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       offset = info[2]->Uint32Value();
                    /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
                       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       length = info[3]->Uint32Value();
                    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                       String::Utf8Value path(info[4]);
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
                    process exited with code 0
                    Weiß langsam nicht mehr weiter. Alle Adapter sind jetzt stable aber trotzdem dieses Problem
                    • P Offline
                      PrinzEisenherz1
                      jetzt kann ich mit der neuen Installationroutine noch nicht mal mehr auf mein gemountetes cifs mit Script schreiben. iobroker-User. Zum kotzen.
                      Jetzt schmieren mir alle Kamera-scripte ab die auf den NAS schreiben wollen.
                      Super.
                      Ich schmeiss den scheiß gleich raus.
                      Seit 7 Stunden sitz ich jetzt hier.....kotz....
