  4. neuerdings Fehler bei update von Adaptern
    3.2k
fehleradapterinstallation
19 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • P Offline
    PrinzEisenherz1
    Hi zusammen.
    Neuerdings erhalte ich folgende Meldungen beim installieren oder updaten von Adaptern:
    root@ioBroker-VM:/opt/iobroker# iobroker install vis-map
    NPM version: 6.4.1
    npm install iobroker.vis-map@1.0.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:82:0,
                     from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local<v8::Int32> v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
    In file included from ../src/bufferutil.cc:7:0:
    /root/.node-gyp/8.15.1/include/node/v8.h:9864:14: note: declared here
     Local<Int32> Value::ToInt32() const {
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local<v8::Uint32> v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
    /root/.node-gyp/8.15.1/include/node/v8.h:9858:15: note: declared here
     Local<Uint32> Value::ToUint32() const {
    In file included from ../node_modules/nan/nan_new.h:189:0,
                     from ../node_modules/nan/nan.h:82,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
    ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local<v8::Value> v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
       return v8::BooleanObject::New(value).As<v8::BooleanObject>();
    In file included from /root/.node-gyp/8.15.1/include/node/v8.h:26:0,
    /root/.node-gyp/8.15.1/include/node/v8.h:4895:56: note: declared here
       V8_DEPRECATED("Pass an isolate", static Local<Value> New(bool value));
    /root/.node-gyp/8.15.1/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
    /root/.node-gyp/8.15.1/include/node/v8.h:1475:21: note: declared here
           Local<Script> Compile(Isolate* isolate, Source* source,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
    ../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             v8::String::kNormalString, length);
    /root/.node-gyp/8.15.1/include/node/v8.h:2731:21: note: declared here
           Local<String> NewFromOneByte(Isolate* isolate, const uint8_t* data,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
    ../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
    /root/.node-gyp/8.15.1/include/node/v8.h:2769:38: note: declared here
                            Local<String> NewExternal(
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:237:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
    /root/.node-gyp/8.15.1/include/node/v8.h:1455:45: note: declared here
                            Local<UnboundScript> CompileUnbound(
    ../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:244:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    In file included from ../src/bufferutil.cc:16:0:
    ../node_modules/nan/nan.h: At global scope:
    ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
    ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
    ../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated: use IdleNotificationDeadline() [-Wdeprecated-declarations]
         return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
    /root/.node-gyp/8.15.1/include/node/v8.h:7539:22: note: declared here
                     bool IdleNotification(int idle_time_in_ms));
    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback
    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
         , v8::GCType gc_type_filter = v8::kGCTypeAll) {
    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback) {
    ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback
    ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback) {
    ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
         const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
    ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
    ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
    ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
           _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
         , node::smalloc::FreeCallback callback
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
    ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
             v8::Isolate::GetCurrent(), data, length, callback, hint);
    ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
    ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
         return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
    In file included from ../src/bufferutil.cc:10:0:
    /root/.node-gyp/8.15.1/include/node/node_buffer.h:67:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
     NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
    ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
    ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
         return node::Buffer::New(v8::Isolate::GetCurrent(), size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
    ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
         return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
    ../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
    ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
    In file included from ../src/bufferutil.cc:8:0:
    /root/.node-gyp/8.15.1/include/node/node.h:308:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
    /root/.node-gyp/8.15.1/include/node/node.h:321:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
     inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
    ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
    ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.0-8-686-pae
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
    gyp ERR! node -v v8.15.1
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
                     from ../src/validation.cc:15:
    In file included from ../src/validation.cc:7:0:
    In file included from ../src/validation.cc:15:0:
    In file included from ../src/validation.cc:10:0:
    ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
    ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
    In file included from ../src/validation.cc:8:0:
    make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! not ok
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
    host.ioBroker-VM object system.adapter.vis-map created
    got /opt/iobroker/node_modules/iobroker.vis-map/admin
    upload [3] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/words.js words.js application/javascript
    upload [2] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/vis-map.png vis-map.png image/png
    upload [1] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index_m.html index_m.html text/html
    upload [0] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index.html index.html text/html
    Adapter "system.adapter.vis.0" restarted.
    Woran könnte das liegen? Hatte ich vorher nicht.
    Johnny
    iobroker in VM (proxmox) Debian 9
    nodejs: 8.15.1
    node: 8.15.1
    npm: 6.4.1
    js-controller: 1.5.7
    Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
    SegwayS 1 Antwort Letzte Antwort
    • P Offline
      PrinzEisenherz1
      Keiner ne idee?
      Habe gerade mal den statistics-Adapter installiert und bekomme da auch die ganzen gyp Errors.
      $ ./iobroker add statistics  --host ioBroker-VM
      NPM version: 6.4.1
      npm install iobroker.statistics@0.2.0 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,
      In file included from /root/.node-gyp/8.15.1/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:
      ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
      In file included from ../src/bufferutil.cc:10:0:/root/.node-gyp/8.15.1/include/node/node_buffer.h:67:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
      In file included from ../src/bufferutil.cc:8:0:/root/.node-gyp/8.15.1/include/node/node.h:308:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
      gyp
       ERR!
       build error
      gyp
       ERR! stack Error: `make` failed with exit code: 2gyp ERR!
       stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at emitTwo (events.js:126:13)
      gyp
       ERR! System Linux 4.9.0-8-686-paegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd
       /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v8.15.1
      gyp
       ERR! not ok
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:
      In file included from /root/.node-gyp/8.15.1/include/node/v8.h:26:0,                 from ../src/validation.cc:7:
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:
      ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated: use IdleNotificationDeadline() [-Wdeprecated-declarations]
      ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {
      ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
      ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
      ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
      In file included from ../src/validation.cc:8:0:/root/.node-gyp/8.15.1/include/node/node.h:308:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
      gyp
      ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! System Linux 4.9.0-8-686-paegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp
       ERR! not ok
      npm
       WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
      host.ioBroker-VM install adapter statistics
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.statistics"
      npm
       WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm
       WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm
      WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm
      WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm notice created a lockfile as package-lock.json. You should commit this file.
      got /opt/iobroker/node_modules/iobroker.statistics/admin
      upload [5] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/words.js words.js application/javascript
      upload [4] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/statistics.png statistics.png image/png
      upload [3] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/index_m.html index_m.html text/html
      upload [2] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/index.html index.html text/html
      upload [1] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/custom_m.html custom_m.html text/html
      upload [0] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/custom.html custom.html text/html
      host.ioBroker-VM object system.adapter.statistics created
      host.ioBroker-VM object _design/custom created
      host.ioBroker-VM create instance statistics
      host.ioBroker-VM object system.adapter.statistics.0.outputCount created
      host.ioBroker-VM object system.adapter.statistics.0.inputCount created
      host.ioBroker-VM object system.adapter.statistics.0.uptime created
      host.ioBroker-VM object system.adapter.statistics.0.memRss created
      host.ioBroker-VM object system.adapter.statistics.0.memHeapTotal created
      host.ioBroker-VM object system.adapter.statistics.0.memHeapUsed created
      host.ioBroker-VM object system.adapter.statistics.0.cputime created
      host.ioBroker-VM object system.adapter.statistics.0.cpu created
      host.ioBroker-VM object system.adapter.statistics.0.connected created
      host.ioBroker-VM object system.adapter.statistics.0.alive created
      host.ioBroker-VM object system.adapter.statistics.0 created
      process exited with code 0
      Adapter wird aber installiert und läuft auch.
      Kann ich da die ganzen Error ignorieren?
      Die utf8 warnings hatte ich vorher nicht.
      Hat das alles eventuell mit dem js-controller 1.5.7 zu tun?
      Johnny
        albert
        Was zeigen "node -v” und “nodejs -v” an?
        Es sollten die gleichen Versionen sein.
        Ansonsten mal ein "./reinstall.sh" im iobroker Verzechniss machen "/opt/iobroker/reinstall.sh".
        Aber Achtung, das reinstall kann zusätzliche Aufwände verursachen, bevor du das machst, unbeding alles sichern.
        • P Offline
          PrinzEisenherz1
          wie im ersten Beitrag schon geschrieben habe ich folgende Versionen
          nodejs: 8.15.1
          node: 8.15.1
          npm: 6.4.1
          einen npm rebuild hab ich auch schon durchgeführt, hat aber nichts gebracht.
          Keine Ahnung woher diese Error plötzlich kommen
          • P PrinzEisenherz1
            nodejs: 8.15.1
            node: 8.15.1
            npm: 6.4.1
            albert
            @PrinzEisenherz1 sagte in neuerdings Fehler bei update von Adaptern:
            Sorry, das hatte ich überlesen.
            Dann würde ich wirklich, unabhängig vom npm-rebuild, einen reinstall vom iobroker machen, vielleicht ist da was mit den Versionen aus den Fugen geraten.
            Ich nutze exakt die gleichen Version wie du, ohne diese Probleme. Hatte ähnliche Probleme nach einem update der nodejs Version, die waren nach einem reinstall aber weg.
            • P Offline
              PrinzEisenherz1
              Danke. Dachte eigentlich das mit npm rebuild müsste ausreichen.
              Hab jetzt mal das reinstall Skript laufen. Mal kucken wenns fertig ist ob die Meldungen dann weg sind.
              Johnny
              • P Offline
                PrinzEisenherz1
                Also das reinstall.sh hat mir jetzt die ganze installation zerschossen.
                Gut das ich n Backup habe
                • P PrinzEisenherz1
                  HomoranH Offline
                  HomoranH Offline
                  Dann war wohl vorher etwas faul.
                  Das reinstall kompiliert nur die Instanzen nochmal mit dem aktuellen npm neu
                  • P Offline
                    PrinzEisenherz1
                    Ich weiß aber nicht wo durch. Seit dem update des js-controller lässt sich iobroker auch nicht mehr über iobroker stop beenden.
                    Da meckert die Shell das killall.sh fehlt.
                    Also macht das reinstall.sh nichts anderes wie npm rebuild, oder?
                    Johnny
                    • P PrinzEisenherz1
                      Hi zusammen.
                      NPM version: 6.4.1
                      gyp ERR! not ok
                      gyp ERR! not ok
                      Johnny
                      nodejs: 8.15.1
                      node: 8.15.1
                      npm: 6.4.1
                      SegwayS Offline
                      SegwayS Offline
                      Segway
                      du weisst schon dass dies noch eine Entwicklerversion ist ? Die letzte stable ist 1.4.2
                      Gruß Dirk
                      • P Offline
                        PrinzEisenherz1
                        Ist mir bewusst. Wobei ist die nicht mittlerweile auch im stable?
                        • P PrinzEisenherz1
                          SegwayS Offline
                          SegwayS Offline
                          Segway
                          @PrinzEisenherz1
                          nö im stable ist die 1.4.2
                          wenn man eine Entwicklerversion installiert, können halt unvorhergesehene Sachen passieren.
                          Gruß Dirk
                          • P Offline
                            PrinzEisenherz1
                            Ich hab jetzt mal das Backup zurückgespielt und nochmal das reinstall laufen lassen.
                            bufferutil.target.mk:101: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
                            make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
                            gyp ERR! not ok
                            > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
                            > node-gyp rebuild
                            make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
                              CXX(target) Release/obj.target/validation/src/validation.o
                            validation.target.mk:101: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
                            make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
                            gyp ERR! not ok
                            npm WARN request-promise-core@1.1.2 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
                            npm WARN request-promise-native@1.0.7 requires a peer of request@^2.34 but none is installed. You must install peer dependencies yourself.
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
                            + iobroker.tankerkoenig@2.0.5
                            added 4 packages from 30 contributors and audited 31958 packages in 28.044s
                            found 56 vulnerabilities (38 low, 1 moderate, 17 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                            DONE iobroker.tankerkoenig
                            [..................] - fetchMetadata: sill resolveWithNewModule iobroker.telegram@1.4.3 checking installable status
                            Da ist die Konsole schon stark gefüllt.
                            Hmmm...hab das Problem echt bloß ich?
                            Seltsam wenn das an der 1.5.7 liegen sollte.
                            Mach nachher mal nen downgrade auf die 1.4.2 und kucke wie es da aussieht.
                            • P PrinzEisenherz1
                              gyp ERR! not ok
                              > node-gyp rebuild
                              gyp ERR! not ok
                              SegwayS Offline
                              SegwayS Offline
                              Segway
                              welches reinstall hast du benutzt ? von iobroker.net ? da laufen dann ja diese 4 Schritte durch.
                              Gruß Dirk
                              • P Offline
                                PrinzEisenherz1
                                ich hab die reinstall aus dem install-Ordner genommen.
                                oder soll ich vielleicht node nochmal neu installieren?
                                So, der reinstall ist jetzt durchgelaufen und so sieht es jetzt im logfile aus
                                iobroker.2019-03-18.log
                                • P Offline
                                  PrinzEisenherz1
                                  Hab node nochmal neu installiert und ein reinstall laufen lassen.
                                  Also der Spuk mit den warnings beginnt ab dem reinstall vom js-controller.
                                  ich mache jetzt mal einen downgrade auf die 1.4.2 und mache nochmal einen reinstall.
                                  mal kucken was es da macht.
                                  • P Offline
                                    PrinzEisenherz1
                                    Selbes Problem auch mit js-controller Version 1.4.2
                                    Habe zum Test dasWetter-Adapter aktualisiert und da ist das selbe Problem
                                    dasWetter.txt
                                    Keine Ahnung was da nicht stimmt. Liegt es vielleicht daran das ich iobroker auf nem 32-bit Debian installiert habe?
                                    • P Offline
                                      PrinzEisenherz1
                                      Also ich hab jetzt ein komplett neues System aufgesetzt (jetzt 64Bit) und mit iobroker backup und restore wieder iobroker installiert.
                                      Egal was ich mach (hab jetzt auch node 10.15.3 umgestellt) erhalte ich diese Logeinträge beim installieren und deinstallieren.
                                      Beispiel löschen js2fs instanz
                                      $ ./iobroker del js2fs
                                      Delete adapter "js2fs"
                                      host.ioBroker-VM64 Counted 1 instances of js2fs
                                      host.ioBroker-VM64 Counted 1 adapters for js2fs
                                      host.ioBroker-VM64 Counted 10 states of js2fs
                                      host.ioBroker-VM64 Counted 12 states (system.adapter.js2fs.*) from states
                                      host.ioBroker-VM64 Deleting 12 object(s).
                                      host.ioBroker-VM64 Deleting 12 state(s).
                                      npm uninstall iobroker.js2fs --silent --save --prefix "/opt/iobroker" (System call)
                                      In file included from ../node_modules/nan/nan.h:190:0,                 from ../src/unix_dgram.cc:5:
                                      ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
                                      ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                                         return obj->ForceSet(GetCurrentContext(), key, value, attribs);
                                      In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
                                      ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                               v8::Isolate::GetCurrent(), target, func, argc, argv);
                                      In file included from ../node_modules/nan/nan.h:47:0,
                                      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
                                                       NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                                      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                                           __attribute__((deprecated(message))) declarator
                                      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
                                      ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                                      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
                                      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
                                      ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                               v8::Isolate::GetCurrent(), target, method, argc, argv);
                                      /home/iobroker/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
                                      In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
                                      ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         domain      = info[0]->Int32Value();
                                      In file included from /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:26:0,                 from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63,
                                                       from ../node_modules/nan/nan.h:47,
                                      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
                                         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                      /home/iobroker/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         type        = info[1]->Int32Value();
                                      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         protocol    = info[2]->Int32Value();
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         fd = info[0]->Int32Value();
                                      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                         String::Utf8Value path(info[1]);
                                      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
                                                         explicit Utf8Value(Local<v8::Value> obj));
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         buf = info[1]->ToObject();
                                      In file included from /home/iobroker/.node-gyp/10.15.3/include/node/node.h:63:0,
                                      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                                       Local<Object> Value::ToObject() const {
                                      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         offset = info[2]->Uint32Value();
                                      /home/iobroker/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
                                         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                                      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         length = info[3]->Uint32Value();
                                      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                         String::Utf8Value path(info[4]);
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
                                      Weiß langsam nicht mehr weiter. Alle Adapter sind jetzt stable aber trotzdem dieses Problem
                                      • P Offline
                                        PrinzEisenherz1
                                        jetzt kann ich mit der neuen Installationroutine noch nicht mal mehr auf mein gemountetes cifs mit Script schreiben. iobroker-User. Zum kotzen.
                                        Jetzt schmieren mir alle Kamera-scripte ab die auf den NAS schreiben wollen.
                                        Super.
                                        Ich schmeiss den scheiß gleich raus.
                                        Seit 7 Stunden sitz ich jetzt hier.....kotz....
