  4. Time Trigger per VIS ändern
    5.8k
16 Beiträge 9 Kommentatoren 3.5k Aufrufe 7 Beobachtet
    Kuddel
    Aktuell scheitere ich schon Daran, die gewünschte Weckzeit in eine Variable zu schreiben ^^
    Welches Widget sollte ich verwenden?
    • htreckslerH Offline
      htreckslerH Offline
      htrecksler
      Forum Testing
      z. B. dieses…
      [{"tpl":"tplJquiInput","data":{"oid":"javascript.0.Settings.Allgemein.ZeitMorgensHochLatest","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","label":"","digits":"0","size":"5","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-input ","asString":true,"lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"name":"R0_RollHochSpätestens_Wert_Z5","lc-is-moment":false,"lc-zindex":0},"style":{"left":"200px","top":"110px","width":"150px","height":"auto","z-index":"5","font-family":""},"widgetSet":"jqui"}]
      Gruss Hermann
        Kuddel
        Danke htrecksler für die Antwort.
        Leider habe ich keinen Plan, wie ich jetzt dein Script in mein VIS einfüge ^^
        Magst du mir nochmal einen Tip geben ?
          Das ist kein Script sondern ein Widget ;-)
          Im Vis Editor auf Widget importieren gehen, den Code in das Popup kopieren und bestätigen.
          http://www.iobroker.net/docu/?page_id=2 … #Widgets_2
          Unterpunkt 18
            Kuddel
            Import, ja natürlich :-D Oh peinlich, daran hab ich gar nicht gedacht.
            Ich habe vorm import den Verweis auf mein Objekt angepasst. Sprich "javascript.0.sonstige.weckzeit"
            Das Objekt wird jetzt korrekt über die VIS geändert.
            Da habe ich ja schonmal den ersten Schritt.
            Aktuell wird mein Schlafzimmerlicht per Blockly gesteuert. Würde ich natürlich gern beibehalten, wenn möglich, da ich von Java (noch) keine Ahnung habe.
            Falls es nicht geht, würde ich für diesen Anwendungsfall auch ein Javascript verwenden.
            Hier ist mein Blockly Script
            ! var Warten; ! schedule("35 5 * * 1-5", function () { if (getState("javascript.0.sonstige.arbeitsstatus").val == 0 && getState("tr-064.2.devices.Daniel.active").val == true && getState("feiertage.0.heute.boolean").val == false && getState("hm-rpc.0.MEQ0665968.1.STATE").val == false) { setState("hm-rpc.0.MEQ0665968.1.STATE"/*LS - Schlafzimmer - Schaltaktor.STATE*/, true); Warten = setTimeout(function () { if (getState("hm-rpc.0.MEQ0665968.1.STATE").val == true) { setState("hm-rpc.0.MEQ0665968.1.STATE"/*LS - Schlafzimmer - Schaltaktor.STATE*/, false); } }, 60000); } }); !
              Kuddel
              Ich habe es jetzt hinbekommen. Zwar nicht mit der eingestellten Zeit als direkten Trigger, aber es sollte so auch gehen_
              • coyoteC Offline
                coyoteC Offline
                coyote
                Hey,
                muss hier mal kurz nachfragen. Ich habe das Script von Paul heute eingebaut, um z.B. ein Lampe oder auch meine PoolPumpe Variabel ein- und auszuschalten. Hatte vorher ein anderes Script, war glaube auch von Paul aber schon etwas älter.
                Jetzt ist es aber so (bei beiden Scripten), dass wenn der Javascript Adapter neu startet (aus welchem Grund auch immer) steht zwar die Zeit noch in dem Datenpunkt, jedoch wird der Timer nicht mehr getriggert. Klar, läuft ja auch über die "on" Funktion wenn die Zeit geändert wird.
                Wie müsste denn das Script aussehen, wenn beim Javascript Adapter Start auch der "alte" Datenpunkt gelesen werden soll, ohne dass die Zeit verändert wurde und darauf wieder getriggert wird.
                • paul53P Offline
                  @coyote:
                  const idWeckzeit = '...';  // Weckzeit als String "hh:mm"
                  const idWecker = '...'; //  boolean
                  var t = getState(idWeckzeit).val.split(':');
                  var timer = schedule(t[1] + ' ' + t[0] + ' * * *', function() {
                     setState(idWecker, true);
                  on(idWeckzeit, function(dp) {
                     t = dp.state.val.split(':');
                     clearSchedule(timer);
                  • coyoteC Offline
                    coyoteC Offline
                    coyote
                    Danke dir Paul, funktioniert wie gewünscht :D
                    • X Offline
                      X Offline
                      xmace
                      gibt es einen smarten weg die Funktion für mehrere Aktoren & Zeiten zu erstellen?
                      Hab das jetzt einfach mal dupliziert bzw. vervierfacht für 2 Aktoren & 4 Zeiten (an/aus)
                      const idZeitAN1 = 'javascript.0.STKD.DG1.Spielecke_Zeit_AN';  // Einschaltzeit als String "hh:mm"
                      const idZeitAUS1 = 'javascript.0.STKD.DG1.Spielecke_Zeit_AUS';  // Ausschaltzeit als String "hh:mm"
                      const idSwitch1 = 'javascript.0.STKD.DG1.Spielecke'; //  boolean
                      const idZeitAN2 = 'javascript.0.STKD.DG1.Schlafzi_Zeit_AN';  // Einschaltzeit als String "hh:mm"
                      const idZeitAUS2 = 'javascript.0.STKD.DG1.Schlafzi_Zeit_AUS';  // Ausschaltzeit als String "hh:mm"
                      const idSwitch2 = 'javascript.0.STKD.DG1.Schlafzi'; //  boolean
                      var t1 = getState(idZeitAN1).val.split(':');
                      var t2 = getState(idZeitAUS1).val.split(':');
                      var t3 = getState(idZeitAN2).val.split(':');
                      var t4 = getState(idZeitAUS2).val.split(':');
                      var timer1 = schedule(t1[1] + ' ' + t1[0] + ' * * *', function() {
                         if (getState("javascript.0.Anwesend").val === true){
                      	setState(idSwitch1, true);}
                      var timer2 = schedule(t2[1] + ' ' + t2[0] + ' * * *', function() {
                         setState(idSwitch1, false);
                      var timer3 = schedule(t3[1] + ' ' + t3[0] + ' * * *', function() {
                      	setState(idSwitch2, true);}
                      var timer4 = schedule(t4[1] + ' ' + t4[0] + ' * * *', function() {
                         setState(idSwitch2, false);
                      on(idZeitAN1, function(dp) {
                         t1 = dp.state.val.split(':');
                      on(idZeitAUS1, function(dp) {
                         t2 = dp.state.val.split(':');
                      on(idZeitAN2, function(dp) {
                         t3 = dp.state.val.split(':');
                      on(idZeitAUS2, function(dp) {
                         t4 = dp.state.val.split(':');
                      • X xmace
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @xmace Da gibt es eine elegantere Lösung. Sie ist etwas länger, aber skalierter.
                        Schlussendlich setzt du nur im array "ids" die Namen der Datenpunkte die du hast (oder haben willst), und bei createStates ob das script sie bauen soll oder nicht
                        Den rest macht das script selber. Es erstellt ein Mapping fuer die Timer und ein Mapping fuer die Funktionen die beim Timer aufgerufen werden sollen, sowie die Trigger zum umsetzen.
                        var ids = [ 'STKD.DG1.Schlafzi','STKD.DG1.Spielecke' ];
                        const createStates = true;
                        var knownTimers = {};
                        var SheduleFunctions = {}
                        for (var idx in ids) {
                            let id = ids[idx];
                            let sid = 'javascript.0.'+id;
                            let tid = sid+"_Zeit_AN";
                            if (createStates) {
                                console.log(getState(id + '_Zeit_AN'))
                                if (getState(id + '_Zeit_AN').notExist) createState(id + '_Zeit_AN', '09:00');
                                if (getState(id + '_Zeit_AUS').notExist) createState(id + '_Zeit_AUS', '09:01');
                                if (getState(id).notExist) createState(id, false);
                            let shed = null;
                            SheduleFunctions[tid] = function() {
                        	     setState(sid, true);}
                            let state = getState(tid);
                            if (!state.notExist)
                                let time = state.val.split(':')
                                if (time.length >= 2) {
                                    knownTimers[tid] = schedule(time[1] + ' ' + time[0] + ' * * *', SheduleFunctions[tid]);
                            else knownTimers[tid] = null;
                            on ({id: tid, change: 'ne', ack:false}, function(obj) { UpdateTimer(obj); })
                            sid = 'javascript.0.STKD.DG1.'+id;
                            tid = sid+"_Zeit_AUS";
                            shed = null;
                            if (knownTimers.hasOwnProperty(tid)) { shed = knownTimers[tid]; }
                            if (shed != null) { clearSchedule(shed); }
                            if (state.val)
                            on ({id: tid, change: 'ne', ack: false}, function(obj) { UpdateTimer(obj); })
                        function UpdateTimer(obj)
                            let time = obj.state.val.split(':');
                            setState(obj.id, obj.val, true);
                            if (knownTimers[obj.id] != null) clearSchedule(knownTimers[obj.id]);
                                knownTimers[obj.id] = schedule(time[1] + ' ' + time[0] + ' * * *', SheduleFunctions[obj.id]);
                            else
                            { knownTimers[obj.id] = null; }
                        X 1 Antwort Letzte Antwort
                        • AsgothianA Asgothian
                              let id = ids[idx];
                              if (createStates) {
                              let shed = null;
                              shed = null;
                              if (state.val)
                              else
                          X Offline
                          X Offline
                          xmace
                          @Asgothian
                          super vielen Dank!!
                          • padrinoP Online
                            padrinoP Online
                            padrino
                            schrieb am zuletzt editiert von padrino
                            falscher Thread... Beitrag könnte gelöscht werden
                              Per Javascript ist es leicht zu realisieren.
                              var timer = null;
                                 var t = dp.state.val.split(':');
                              hanssH Offline
                              hanssH Offline
                              hanss
                              Hallo paul53,
                              also das ist wirklich super, welche Tricks Du draufhast und die auch funktionieren.
                              Vielen Dank
