  4. [Aufruf] iobroker.link Test
test
112 Beiträge 11 Kommentatoren 15.8k Aufrufe 12 Beobachtet
  • sigi234S sigi234
    Ok, teste ich was ist der erlaubte Benutzer?
    link.0	2019-03-12 12:11:25.151	error	AccessClient: error getting connection requests: Bad Gateway
    link.0	2019-03-12 12:15:48.542	debug	AccessClient: Registered agent xxxx@xxxx.xx with 2 devices
    link.0	2019-03-12 12:15:48.419	debug	AccessClient: registering agent at https://iobroker.link/
    link.0	2019-03-12 12:15:48.317	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:15:38.235	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:15:28.158	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:15:18.079	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:15:08.004	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:14:57.934	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:14:47.837	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:14:37.757	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:14:37.757	info	Connected to https://iobroker.link
    link.0	2019-03-12 12:14:27.692	error	AccessClient: error getting connection requests: Bad Gateway
    link.0	2019-03-12 12:14:19.994	debug	system.adapter.admin.0: logging true
    link.0	2019-03-12 12:14:17.621	error	AccessClient: error getting connection requests: Bad Gateway
    link.0	2019-03-12 12:14:17.621	info	Disconnected to https://iobroker.link
    link.0	2019-03-12 12:14:07.542	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:13:57.470	debug	AccessClient: no connection requests found
    link.0	2019-03-12 12:13:57.469	info	Connected to https://iobroker.link
    Ok, besser:
    BluefoxB Offline
    BluefoxB Offline
    @sigi234 Danke. Ich werde suchen.
    • sigi234S sigi234
      Ok, besser:
      BluefoxB Offline
      BluefoxB Offline
      @sigi234 Und konntest du deine Instanz erreichen?
      • BluefoxB Bluefox
        sigi234S Online
        sigi234S Online
        @Bluefox sagte in [Aufruf] iobroker.link Test:
        Leider nein:
        N 1 Antwort Letzte Antwort
        • BBTownB Offline
          BBTownB Offline
          BBTown
          schrieb am zuletzt editiert von BBTown
          Ich habe nicht einmal Ansatzweise verstanden welche Informationen wo eingtragen werden sollen/müssen.
          Was um aller Welt ist ein "Kundenname"?
          Was gehört in den Bereich "Benutzer" rein? Der App-Key "@pro_xxxxx" wie er auch im Cloud-Adapter eingtragen ist?
          Nachtrag:
          Auch auf der GitHub Seite findet man diesbezüglich keine Informationen :-(
          • BBTownB BBTown
            Nachtrag:
            N Offline
            N Offline
            nureintechniker
            @BBTown "Kundenname" - das ist ein Name unter dem Deine iobroker Installation auf https://iobroker.link auftauchen wird. Wenn Du mehrere iobroker Installationen hast, dann wird dieser Name helfen die zu unterscheiden. Der "Benutzer" ist der login, den Du auf iobroker.pro anlegen kannst und dem Du erlaubst auf Deine iobroker Installationen remote zu zugreifen. Normalerweise würdest Du hier Deinen eigenen Login (e-mail) eintragen. Mit diesem Login meldest Du Dich auch auf iobroker.link an.
            BBTownB 1 Antwort Letzte Antwort
            • sigi234S sigi234
              Leider nein:
              N Offline
              N Offline
              nureintechniker
              @sigi234 Hast Du auch die richtige Portnummer für "iobroker_admin" konfiguriert?
              • N nureintechniker
                sigi234S Online
                sigi234S Online
                @nureintechniker
                • N nureintechniker
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @nureintechniker sagte in [Aufruf] iobroker.link Test:
                  Ok - also der Log-In-Benutzer, den ich ursprünglich bei der Registrierung bei iobroker.pro verwendet habe ... da hatte ich zu kompliziert gedacht, danke Dir!
                  Soweit so gut, allerdings erhalten ich anschließend beim Klick auf Links unter "Geräte" ebenfalls den Hinweis "Not Found"
                  sigi234S N 2 Antworten Letzte Antwort
                  • sigi234S sigi234
                    @nureintechniker
                    N Offline
                    N Offline
                    nureintechniker
                    @sigi234 hm... komisch. Da taucht ja "iobroker<blank>admin" gar nicht auf. Ist es eine "default" Konfiguration?
                    • BBTownB BBTown
                      sigi234S Online
                      sigi234S Online
                      @BBTown sagte in [Aufruf] iobroker.link Test:
                      Das ist ja dann die E-Mail Adresse.......oder?
                      N BBTownB 2 Antworten Letzte Antwort
                      • sigi234S sigi234
                        N Offline
                        N Offline
                        nureintechniker
                        @sigi234 richtig. Deine e-mail Adresse
                        • sigi234S sigi234
                          BBTownB Offline
                          BBTownB Offline
                          BBTown
                          @sigi234 ja, die email adresse
                          • BBTownB BBTown
                            N Offline
                            N Offline
                            nureintechniker
                            schrieb am zuletzt editiert von nureintechniker
                            @BBTown said in [Aufruf] iobroker.link Test:
                            Geräte
                            Beim Klick auf die "Geräte" in Adapter-Konfiguration oder auf https://iobroker.link nach dem Du eine Verbindung hergestellt hast?
                            • N nureintechniker
                              Geräte
                              BBTownB Offline
                              BBTownB Offline
                              BBTown
                              @nureintechniker
                              1. auf https://iobroker.link
                              2. Anmeldung
                              3. Im Dashboard kann ich sehen:
                              • Verfügbare Server: 1
                              • Server Online: 1
                              • Verbindungen insgesamt: 2
                              1. Ich wechsel auf "Server" (unterhalb von "Dashboard")
                              2. Klick auf den grünen Telefonhörer (starten/einwählen)
                              3. Ich sehe unter "Akzeptiert" eine grüne Darstellung von Datum/Uhrzeit
                              4. Klick auf "Geräte"
                              5. es öffnet sich ein "Seitenfenster" mit 2 Links zu "ioBroker Admin" und "ioBroker Web"
                              • in diesem Link ist wohl eine mir zugeordnete eindeutige ID enthalten (?)
                              1. nach Klick auf den Link erscheint nach einer Weile im Browserfenster "Not Found"
                              • BBTownB Offline
                                BBTownB Offline
                                BBTown
                                Ich habe noch ein paar Verständnisfragen
                                Gibt es Voraussetzungen?
                                • Ports in Firewall öffnen? - nein, nicht notwendig
                                • wird der cloud-adapter benötigt? - nein, der muss nicht parallel laufen
                                • sind die Ports (80, 9082, 3001 (UDP) vorgegeben? - nein, die eigenen Ports verwenden
                                • auch wenn ich lokal nicht mit Port 80 sondern 8081 auf Admin und mit 8082 statt 9082 auf Web/VIS? zugreife?- genau diese Ports müssen verwendet werden
                                • sigi234S Online
                                  sigi234S Online
                                  Funktioniert jetzt...........
                                  • BBTownB BBTown
                                    sigi234S Online
                                    sigi234S Online
                                    @BBTown
                                    Man muss DIE EIGENEN Ports eintragen! UDP muss ich noch rausfinden......
                                    PORT rausfinden:
                                    • BBTownB BBTown
                                      @nureintechniker
                                      2. Anmeldung
                                      • Server Online: 1
                                      N Offline
                                      N Offline
                                      nureintechniker
                                      @BBTown könntest Du die "Geräte"-Seite deiner Adapter-Konfiguration in iobroker hier posten? Was die Ports angeht, die gesamte Kommunikation geht über SSH-Tunnel, den Dein Adapter zu iobroker.link aufbaut. Die Geräte sollten aber tatsächlichen Ports konfiguriert bekommen, da der Adapter sonst den Traffic nicht korrekt umleiten kann.
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        Läuft dein admin auch wie bei mir unter port 80 und nicht wie default unter 8081??
                                        • N nureintechniker
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          @nureintechniker ist die "ID" in den Geräte-Links unkritisch oder soll ich die unleserlich machen?
                                          @Bluefox ich habe 8081 und 8082 als Ports - habe ich in den Einstellungen auch bereits geändert.
                                          Nur die Zeile mit mit ConnectionUDP habe ich manuell hinzugefügt, die war bei mir nicht vorhanden
