  4. JavaScript
  5. Servicemeldungen - All inclusive für Homematic -
    1.0k
    6.1k
javascript
1.0k Beiträge 93 Kommentatoren 409.6k Aufrufe 102 Beobachtet
  • cashC cash
    So ein Mist. Danke Dir Sigi
    sigi234S Online
    sigi234S Online
    #198
    @cash sagte in Servicemeldungen - All inclusive für Homematic -:
    0:59:56.929	info	javascript.0 script.js.Test.Skript_1: response: {"statusCode":200,"body":"homematic.com.setLatestVersion('2.41.8', 'HM-CCU2');","headers":{"server":"Apache-Coyote/1.1","content-type":"text/html;charset=utf-8","transfer-encoding":"chunked","date":"Thu, 07 Mar 2019 19:59:57 GMT","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"update.homematic.com","port":80,"hostname":"update.homematic.com","hash":null,"search":"?cmd=js_check_version&version=12345&product=HM-CCU2&serial=12345","query":"cmd=js_check_version&version=12345&product=HM-CCU2&serial=12345","pathname":"/firmware/download","path":"/firmware/download?cmd=js_check_version&version=12345&product=HM-CCU2&serial=12345","href":"http://update.homematic.com/firmware/download?cmd=js_check_version&version=12345&product=HM-CCU2&serial=12345"},"method":"GET","headers":{}}}
    • sigi234S Online
      sigi234S Online
      #199
      Hm..bekomme jetzt Alles 3 Mal?
      21:16:57.236	info	javascript.0 Stop script script.js.CCU2.Servicemeldungen_Homematic_Geraete1
      21:16:59.197	info	javascript.0 Start javascript script.js.CCU2.Servicemeldungen_Homematic_Geraete1
      21:16:59.198	info	javascript.0 Start javascript script.js.CCU2.Servicemeldungen_Homematic_Geraete1
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 13 Geräte mit dem Datenpunkt LOWBAT.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Keine Geräte gefunden mit dem Datenpunkt LOW_BAT.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 15 Geräte mit dem Datenpunkt UNREACH.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 14 Geräte mit dem Datenpunkt STICKY_UNREACH.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 8 Geräte mit dem Datenpunkt CONFIG_PENDING.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 6 Geräte mit dem Datenpunkt UPDATE_PENDING.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 6 Geräte mit dem Datenpunkt DEVICE_IN_BOOTLOADER.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 3 Geräte mit dem Datenpunkt ERROR.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Es gibt: 1 Geräte mit dem Datenpunkt FAULT_REPORTING.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Keine Geräte gefunden mit dem Datenpunkt SABOTAGE.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: Keine Geräte gefunden mit dem Datenpunkt ERROR_NON_FLAT_POSITIONING.
      21:16:59.198	info	javascript.0 script.js.CCU2.Servicemeldungen_Homematic_Geraete1: registered 66 subscriptions and 0 schedules
      • cashC Offline
        cashC Offline
        cash
        #200
        Stop mal Deine Javascript Instanzen. Kann eigentlich nicht mit meinen Script zusammen hängen. Zumindest habe ich keine Probleme bei mir.
        Kannst Du nochmal das Script testen:
        var logging = true;
        var debugging = false;
        var CCU_Version = 2;        //Hier die nr der CCU eintragen 2 = CCU2 oder 3 = CCU3
        //Datenpunkt auswählen wo die installierte Version ersichtlich ist (aus Homematic.Rega Adapter)
        var id_Version_installiert = "hm-rega.0.MEQ0228930.0.FIRMWARE_VERSION"/*hm-rega.0.MEQ0228930.0.FIRMWARE_VERSION*/;
        //Eigentliches Script
        var ccu2 = 'http://update.homematic.com/firmware/download?cmd=js_check_version&version=12345&product=HM-CCU2&serial=12345';
        var ccu3 = 'http://update.homematic.com/firmware/download?cmd=js_check_version&version=12345&product=HM-CCU3&serial=12345';
        var ccu;
        if(CCU_Version == 3){ccu = ccu3;}
        else{ccu = ccu2;}
        var request = require('request'),
        url = ccu;
        request({url : url},
            function (error, response, body) {
                var Version_installiert = (getState(id_Version_installiert).val).trim();
                var Version = body.split("'");
                if(error){
                    log('error: ' + error);
                else{
                    if(Version_installiert == Version[1]){
                        if(logging){
                            log('Installierte Version der CCU ist aktuell');
                    else{
                        if(logging){
                            log('Version ist nicht aktuell. Installiert: ' +Version_installiert +' --- Verfügbare Version: '+Version[1]);
                    if(debugging){
                        log('body: ' + body);
                        log('Länge ' + Version.length + ' --- Version: ' + Version[1]);
                        log('response: ' + JSON.stringify(response));
        • cashC Offline
          cashC Offline
          cash
          #201
          @sveni_lee mit trim() scheint es besser zu sein. Habe trotzdem mal ein Issue auf GitHub offen gemacht.
          • cashC cash
            var logging = true;
            var ccu;
            else{ccu = ccu2;}
            url = ccu;
                    if(error){
                    else{
                            if(logging){
                        else{
                            if(logging){
                        if(debugging){
            sigi234S Online
            sigi234S Online
            #202
            @cash
            21:25:04.894	info	javascript.0 Stop script script.js.Test.Skript_1
            21:25:04.901	info	javascript.0 Start javascript script.js.Test.Skript_1
            21:25:04.901	info	javascript.0 script.js.Test.Skript_1: registered 0 subscriptions and 0 schedules
            21:25:05.032	info	javascript.0 script.js.Test.Skript_1: Installierte Version der CCU ist aktuell
            • cashC Offline
              cashC Offline
              cash
              #203
              Gut das Script läuft und bringt jetzt auch das erwartete Ergebnis aber das Script wird trotzdem 3 mal ausgeführt? Und alles von der Instanz 0? Irgend etwas stimmt bei Dir nicht.
              • cashC cash
                sigi234S Online
                sigi234S Online
                #204
                @cash
                JS neu gestartet, geht wieder.
                21:29:00.383	info	javascript.0 Stop script script.js.Test.Skript_1
                21:29:04.847	info	javascript.0 Start javascript script.js.Test.Skript_1
                21:29:04.847	info	javascript.0 script.js.Test.Skript_1: registered 0 subscriptions and 0 schedules
                21:29:04.939	info	javascript.0 script.js.Test.Skript_1: Installierte Version der CCU ist aktuell
                • Homer.J.H Offline
                  Homer.J.H Offline
                  Homer.J.
                  #205
                  Frage könnte man das Script auch für die Raspberrymatic anpassen. ?
                  • cashC Offline
                    cashC Offline
                    cash
                    #206
                    @Homer-J Welches Script? Was ist denn bei Rasperimatic anders?
                    Homer.J.H 1 Antwort Letzte Antwort
                    • cashC cash
                      Homer.J.H Offline
                      Homer.J.H Offline
                      Homer.J.
                      schrieb am zuletzt editiert von Homer.J.
                      #207
                      @cash Für die Version auf der CCU ob Aktuell.Screenshot_2019-03-07 logs - ioBroker.png
                      • cashC Offline
                        cashC Offline
                        cash
                        #208
                        @Homer-J Theoretisch schon die Frage ist wo im Internet man die aktuelle Version. Abfragen kann? Welche Version zeigt denn der Datenpunkt mit der installierten Version im Rega Adapter?
                        • cashC cash
                          Homer.J.H Offline
                          Homer.J.H Offline
                          Homer.J.
                          #209
                          @cash 3.43.15.20190223
                          • cashC Offline
                            cashC Offline
                            cash
                            #210
                            @Homer-J Das habe ich befürchtet :-) Wenn es jetzt noch eine Inetadresse hat wo man die aktuelle Version abfragen kann würde es gehen. Aber ich glaube die gibt es so nicht. Das findet man ja nur auf github. Ich gucke es mir bei Gelegenheit mal an. Viel Hoffnung habe ich aber nicht
                            • cashC Offline
                              cashC Offline
                              cash
                              #211
                              Neue Verson auf GitHub. Man kann jetzt in Telegram bestimmen an wen es geht. Also muss das in der Konfiguration auch hinterlegt werden.
                              Jetzt noch mal ne Frage zur Firmware. Wann und wie oft soll erinnert werden das es eine Version gibt? Jeden Tag eine Push wäre ja sehr nervig. Ich selber mache nur sehr ungern bei der ccu ein Update.
                              sigi234S KnallochseK 2 Antworten Letzte Antwort
                              • cashC cash
                                sigi234S Online
                                sigi234S Online
                                #212
                                @cash
                                Es genügt einmal im Monat, weil so oft kommt eh keine raus.......
                                • cashC cash
                                  KnallochseK Offline
                                  KnallochseK Offline
                                  Knallochse
                                  #213
                                  @cash Ich denke, sobald eine neue Firmware freigegeben wurde (1malig) sollte doch reichen
                                  • cashC Offline
                                    cashC Offline
                                    cash
                                    #214
                                    Das finde ich auch einmalig wenn eine neue vorliegt. Nur wie oft soll er prüfen ob eine vorliegt? Da kommt ja nichts automatisch das muss man abfragen. Da finde ich einmal pro Tag eigentlich zuviel wenn man bedenkt das nur 4 Versionen pro Jahr ca erscheinen.
                                    Und nur einmalig eine Info ist halt auch nicht problemlos, da man dazu wieder ein Objekt braucht wo hinterlegt wird das schon einmal benachrichtigt wurde.
                                    • cashC cash
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #215
                                      @cash
                                      Raspberrymatic kommt ca 1 × im Monat ein Update.
                                      • cashC Offline
                                        cashC Offline
                                        cash
                                        #216
                                        Ja aber was nützt es wenn man das nicht gecheit abfragen kann ob ein Update verfügbar ist? Außerdem da es dort sehr regelmäßig ist kann man eigentlich jeden 15. im Monat updaten dafür brauche ich keine Info. Das gleiche gilt ja auch für die Servicemeldung. Wenn ich jeden Tag 5 Kommunikationsstöruzngen kriege brauche ich kein Push mehr darüber. Deswegen schreibe ich auch nicht in meinen Kalender das ich arbeiten muss da ich ja sowieso jeden Tag dahin muss :-)
                                        • cashC cash
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #217
                                          meine Info mit Raspberrymatic mit ca. 1 x im Monat hat sich nur auf Deine Aussage bezogen
