  4. Installationsproblem ioBroker und Proxmox als LXC-Container
iobroker neuinstallation
5 Beiträge 4 Kommentatoren 811 Aufrufe 2 Beobachtet
    andreasploetz
    Hallo Forum,
    bei folgendem Schritt bekomme ich die nachfolgende Fehlermeldung - vielleicht weiß einer von euch was genau hier zu tun ist.
    Installationsschritt
    sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
    Erzeugte Fehlermeldung
    Job for avahi-daemon.service failed because the control process exited with error code.
    See "systemctl status avahi-daemon.service" and "journalctl -xe" for details.
    invoke-rc.d: initscript avahi-daemon, action "start" failed.
    * avahi-daemon.service - Avahi mDNS/DNS-SD Stack
       Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Mon 2019-03-04 15:23:42 UTC; 7ms ago
      Process: 20817 ExecStart=/usr/sbin/avahi-daemon -s (code=exited, status=255)
     Main PID: 20817 (code=exited, status=255)
    Mar 04 15:23:42 CT105 systemd[1]: avahi-daemon.service: Failed to reset devices.list…itted
    Mar 04 15:23:42 CT105 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    Mar 04 15:23:42 CT105 avahi-daemon[20817]: Found user 'avahi' (UID 108) and group 'av…14).
    Mar 04 15:23:42 CT105 avahi-daemon[20817]: Successfully dropped root privileges.
    Mar 04 15:23:42 CT105 avahi-daemon[20817]: chroot.c: fork() failed: Resource temporar…able
    Mar 04 15:23:42 CT105 avahi-daemon[20817]: failed to start chroot() helper daemon.
    Mar 04 15:23:42 CT105 systemd[1]: avahi-daemon.service: Main process exited, code=ex…5/n/a
    Mar 04 15:23:42 CT105 systemd[1]: Failed to start Avahi mDNS/DNS-SD Stack.
    Mar 04 15:23:42 CT105 systemd[1]: avahi-daemon.service: Unit entered failed state.
    Mar 04 15:23:42 CT105 systemd[1]: avahi-daemon.service: Failed with result 'exit-code'.
    Hint: Some lines were ellipsized, use -l to show in full.
    dpkg: error processing package avahi-daemon (--configure):
     subprocess installed post-installation script returned error exit status 1
    Setting up g++ (4:6.3.0-4) ...
    update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode
    Setting up libavahi-client3:amd64 (0.6.32-2) ...
    dpkg: dependency problems prevent configuration of libnss-mdns:amd64:
     libnss-mdns:amd64 depends on avahi-daemon (>= 0.6.16-1); however:
      Package avahi-daemon is not configured yet.
    dpkg: error processing package libnss-mdns:amd64 (--configure):
     dependency problems - leaving unconfigured
    Setting up build-essential (12.3) ...
    Setting up libavahi-client-dev:amd64 (0.6.32-2) ...
    Setting up libavahi-compat-libdnssd1:amd64 (0.6.32-2) ...
    Setting up libavahi-compat-libdnssd-dev:amd64 (0.6.32-2) ...
    Processing triggers for libc-bin (2.24-11+deb9u4) ...
    Processing triggers for dbus (1.10.26-0+deb9u1) ...
    Processing triggers for systemd (232-25+deb9u9) ...
    Errors were encountered while processing:
     avahi-daemon
     libnss-mdns:amd64
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    • E Offline
      Einstein67
      schrieb am zuletzt editiert von Einstein67
      Ich mach meine Iobroker LCX (Debian 9.7.1 Template) folgendermaßen:
      Als Root
      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
      apt install -y nodejs
      npm install -g npm
      Als User:
      curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
      Versuch es mal, funktioniert bei Proxmox perfekt!
      Die Pakete die bei der Node installation nicht angegeben sind, werden vom neuen Installationsscript bei der Iobroker Installation (ohne Fehler) mit installiert.
      A P 2 Antworten Letzte Antwort
      • arteckA Offline
        arteckA Offline
        arteck
        sonst für die teile einzeln aus
        sudo apt-get install -y libavahi-compat-libdnssd-dev
        sudo apt-get install -y libudev-dev
        sudo apt-get install -y libpam0g-dev
        sudo apt-get install -y nodejs
        • E Einstein67
          Als Root
          npm install -g npm
          Als User:
          andreasploetz
          @Einstein67
          Hat super funktioniert - prima :)
          • E Einstein67
            Als Root
            npm install -g npm
            Als User:
            ple
            @Einstein67 sagte in Installationsproblem ioBroker und Proxmox als LXC-Container:
            Als Root
            npm install -g npm
            Als User:
            Ich versuche gerade von einer VM auf ein LXC zu wechseln, nur leider klappt die Installation nicht so richtig. Alles per root bewirkt, dass ich kein Autostart mehr habe. nun wollte ich es machen wie du es bereits beschrieben hast, aber scheitere daran, dass mein User, der mit mit adduser angelegt wurde anscheinend einiges nicht darf. Sudo usw ist bereits installiert.
            Hast du noch eine Idee? Oder hast du deinen User noch irgendwelche Gruppen zugewiesen?
            Gruß und Danke
            Intel Nuc + Proxmox
            82.8k
