  4. Zigbee down nach Kernel Update (npm not found)
zigbeekernelupdateerror
25 Beiträge 4 Kommentatoren 2.1k Aufrufe 4 Beobachtet
  • M maxpd
    Fehlermeldungen im Log:
    host.raspberrypi	2019-02-15 22:06:39.186	error	instance system.adapter.zigbee.0 terminated with code 1 ()
    Caught	2019-02-15 22:06:39.186	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    Caught	2019-02-15 22:06:39.186	error	by controller[0]: at Module._compile (module.js:652:30)
    Caught	2019-02-15 22:06:39.186	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/cc-znp/node_modules/serialport/lib/bindings/linux.js:2:36)
    Caught	2019-02-15 22:06:39.186	error	by controller[0]: at bindings (/opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:81:44)
    Caught	2019-02-15 22:06:39.186	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: at Module.require (module.js:596:17)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: at Function.Module._load (module.js:497:3)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: at tryModuleLoad (module.js:505:12)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: at Module.load (module.js:565:32)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: at Object.Module._extensions..node (module.js:681:18)
    Caught	2019-02-15 22:06:39.185	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: was compiled against a different Node.js version using
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/Release/serialport.node'
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: ^
    Caught	2019-02-15 22:06:39.184	error	by controller[0]: throw e
    Caught	2019-02-15 22:06:39.183	error	by controller[0]: /opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:88
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @maxpd sagte in Zigbee down nach Kernel Update (npm not found):
    Caught 2019-02-15 22:06:39.185 error by controller[0]: the module (for instance, using npm rebuild or npm install).
    Da steht was zu tun ist:
    in/opt/iobroker : npm rebuild (ggf. mit sudo)
    A.
      maxpd
      Ja, dabei passiert leider gar nichts. Gibt auch keine Rückmeldung.
      maxpd
      • M maxpd
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @maxpd
        mit oder ohne sudo ?
        A.
          maxpd
          beidem :(
          maxpd
          • M maxpd
            beidem :(
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @maxpd
            Dann kann ich dir nur raten den Zigbee Adapter zu entfernen und neu zu installieren.
            Die gute Nachricht: die Namen der Datenpunkte sind HW abhängig, sie ändern sich bei einer Neuinstallation nicht. Auch die Datenbank (Shepherd.db) bleibt erhalten, du musst also nichts neu anlernen.
            A.
              maxpd
              Super, danke für die Info. Ich habe vorm Kernel Update natürlich noch ein Backup gemacht, dass ich einspielen könnte.
              Nur was ist besser:
              Aktueller Kernel oder
              Falsche Node.js
              maxpd
              • apollon77A Offline
                Was genau heisst denn "es gibt bei npm rebuild keine rückmeldung"? Du hast es aber schon im iobroker-Verzeichnis (/opt/iobroker) ausgeführt?!
                  maxpd
                  wo ich es ausgeführt hatte, weiß ich tatsächlich nicht mehr. Allerdings habe ich jetzt npm install im /iobroker.zigbee Order ausgeführt. Jetzt läuft es. Keine Ahnung was ich mit meinen Versuchen jetzt alles sonst zusammengebaut habe ^^
                  maxpd
                  • BluelinuxB Offline
                    BluelinuxB Offline
                    Bluelinux
                    Halli Hallo alle zusammen,
                    ich versuche nun seit Tagen meinen Zigbee adapter wieder in den gang zu bekommen jedoch OHNE Erfolg. Ich habe alles was hier schon beschrieben wird probiert.
                    Nix passiert leider.
                    hier mal mein LOG
                    2019-03-03 11:23:16.445 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:96
                    2019-03-03 11:23:16.445 - error: Caught by controller[0]: throw err
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: ^
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/build/bindings.node
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/build/Debug/bindings.node
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/build/Release/bindings.node
                    2019-03-03 11:23:16.446 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/out/Debug/bindings.node
                    2019-03-03 11:23:16.451 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/Debug/bindings.node
                    2019-03-03 11:23:16.451 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/out/Release/bindings.node
                    2019-03-03 11:23:16.451 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/Release/bindings.node
                    2019-03-03 11:23:16.451 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/build/default/bindings.node
                    2019-03-03 11:23:16.451 - error: Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/compiled/8.11.1/linux/arm/bindings.node
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:93:9)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/lib/linux.js:1:98)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at Module.load (module.js:565:32)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
                    2019-03-03 11:23:16.452 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
                    2019-03-03 11:23:16.453 - error: Caught by controller[0]: at Module.require (module.js:596:17)
                    2019-03-03 11:23:16.453 - error: Caught by controller[0]: at require (internal/module.js:11:18)
                    2019-03-03 11:23:16.453 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/bindings/lib/index.js:14:22)
                    2019-03-03 11:23:16.453 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 ()
                    eventuell hat da jeman eine Idee...
                    Mein System besteht aus einem Raspberry 3b+ wenn noch Info fehlen reiche ich sie gerne nach ....
                    Danke an alle
                    BluelinuxB 1 Antwort Letzte Antwort
                      ja bitte mal neu installieren. Da ist beim Installieren was schief gegangen.
                        BluelinuxB Offline
                        Bluelinux
                        Hallo miteinander...
                        gestern kam ein neues Admin update und nun ist es so das der Adapter wenigstens wieder auf Gelb geht aber irgendwie scheint er keine Verbindung mit dem Stick herzustellen. Welchen Kanal muss man denn dort einstellen???
                        Nervt mich total das es nicht mehr geht.
                          Was genau steht denn im Log wenn DU den Adapter startest? Mit Admin hat das an sich nichts zu tun
                          • BluelinuxB Bluelinux
                            hier mal mein LOG
                            Danke an alle
                            BluelinuxB Offline
                            BluelinuxB Offline
                            Bluelinux
                            @apollon77 hier ist meine log datei ... da müsste es drin stehen.... allerdings habe ich seit gestern ein neues problem denn nun geht nix mehr.... ich könnte so brechen......wenn ich versuche den Iobroker zu starten sagt er immer er kan adresse 0.0.0......... nicht erreichen .... ich habe langsam das gefühl ich komme um eine neue Instalation nicht drum herum
                              Also der Fehler sagt nur das serialport nicht sauber installiert wurde. "npm rebuild" könnte helfen oder Adapter neu installieren
                                BluelinuxB Offline
                                Bluelinux
                                erst mal möchte ich mich für den Support bedanken.
                                leider bringt dieser Befehl " npm rebuild" auch keinen erfolg....
                                kann man den serialport nicht neu installieren oder so?
                                  Kein Erfolg heisst? Fehlermeldungen?
                                    maxpd
                                    Bei mir ist er gestern plötzlich wieder ausgestiegen mit:
                                    zigbee.0 2019-03-10 07:53:14.667 error exception by stop: callback is not defined
                                    zigbee.0 2019-03-10 07:53:14.666 error at Signal.wrap.onsignal (internal/process.js:208:44)
                                    zigbee.0 2019-03-10 07:53:14.666 error at process.emit (events.js:208:7)
                                    zigbee.0 2019-03-10 07:53:14.666 error at emitNone (events.js:106:13)
                                    zigbee.0 2019-03-10 07:53:14.666 error at Object.onceWrapper (events.js:313:30)
                                    zigbee.0 2019-03-10 07:53:14.666 error at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5023:21)
                                    zigbee.0 2019-03-10 07:53:14.666 error at Object.unload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:52:11)
                                    zigbee.0 2019-03-10 07:53:14.666 error ReferenceError: callback is not defined
                                    zigbee.0 2019-03-10 07:53:14.665 error uncaught exception: callback is not defined
                                    zigbee.0 2019-03-10 07:53:08.607 error exception by stop: callback is not defined
                                    zigbee.0 2019-03-10 07:53:08.607 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                    zigbee.0 2019-03-10 07:53:08.607 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                    zigbee.0 2019-03-10 07:53:08.607 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                    zigbee.0 2019-03-10 07:53:08.607 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:780:25)
                                    zigbee.0 2019-03-10 07:53:08.607 error at process.exit (internal/process.js:157:15)
                                    zigbee.0 2019-03-10 07:53:08.607 error at process.emit (events.js:211:7)
                                    zigbee.0 2019-03-10 07:53:08.607 error at emitOne (events.js:116:13)
                                    zigbee.0 2019-03-10 07:53:08.607 error at Object.onceWrapper (events.js:315:30)
                                    zigbee.0 2019-03-10 07:53:08.607 error at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5023:21)
                                    zigbee.0 2019-03-10 07:53:08.607 error at Object.unload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:52:11)
                                    zigbee.0 2019-03-10 07:53:08.607 error ReferenceError: callback is not defined
                                    zigbee.0 2019-03-10 07:53:08.606 error uncaught exception: callback is not defined
                                    zigbee.0 2019-03-10 07:53:08.590 error already running
                                    maxpd
                                      maxpd
                                      Heute habe ich den Adapter komplett gelöscht und neu installiert und stoße auf das alte Problem:
                                      host.raspberrypi 2019-03-12 21:13:36.604 error instance system.adapter.zigbee.0 terminated with code 1 ()
                                      host.raspberrypi 2019-03-12 21:13:36.604 error Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                                      host.raspberrypi 2019-03-12 21:13:36.604 error Caught by controller[0]: at Module._compile (module.js:652:30)
                                      host.raspberrypi 2019-03-12 21:13:36.604 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/cc-znp/node_modules/serialport/lib/bindings/linux.js:2:36)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:81:44)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at require (internal/module.js:11:18)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at Module.require (module.js:596:17)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at Function.Module._load (module.js:497:3)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at tryModuleLoad (module.js:505:12)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at Module.load (module.js:565:32)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: at Object.Module._extensions..node (module.js:681:18)
                                      host.raspberrypi 2019-03-12 21:13:36.603 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: was compiled against a different Node.js version using
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/Release/serialport.node'
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: ^
                                      host.raspberrypi 2019-03-12 21:13:36.602 error Caught by controller[0]: throw e
                                      host.raspberrypi 2019-03-12 21:13:36.601 error Caught by controller[0]: /opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:88
                                      Also habe ich wieder npm install /iobroker.zigbee versucht, allerdings weiger er sich:
                                      Wenn ich das ganze in /opt/iobroker : npm rebuild ausführe, dann kommen 1000 andere fehlermeldungen
                                      maxpd
                                        maxpd
                                        Sicherheitskritische Lösung:
                                        sudo chmod -R 777 /opt/iobroker && sudo chmod -R 777 /root
                                        npm rebuild
                                        maxpd
                                          Wie wäre es eher mit dem "Installation Fixer"?
                                          Ansonsten oben ist "nom install /iobroker.zigbee" mal mindestens der Slash zuviel
