  4. [gelöst] Backitup macht keine Backups mehr.
backitupfehlermeldungkein backup vorhanden
20 Beiträge 2 Kommentatoren 2.6k Aufrufe 3 Beobachtet
    der-eine
    @simatec, sorry für die späte Rückmeldung.
    Hier das Log von Heute Nacht. Habe inzwischen den Adapter gelöscht und neu installiert sowie das System neu gestartet.
    2019-02-22 03:00:10.082 - debug: backitup.0 [total] exec: done
    2019-02-22 03:00:10.599 - error: backitup.0 uncaught exception: Cannot read property 'val' of null
    2019-02-22 03:00:10.600 - error: backitup.0 TypeError: Cannot read property 'val' of null
    at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/main.js:208:39)
    at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    2019-02-22 03:00:11.676 - error: Caught by controller[0]: TypeError: Cannot read property 'val' of null
    2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/main.js:208:39)
    2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    2019-02-22 03:00:11.680 - error: host.ioBroker-Master instance system.adapter.backitup.0 terminated with code 6 (uncaught exception)
    2019-02-22 03:00:11.680 - info: host.ioBroker-Master Restart adapter system.adapter.backitup.0 because enabled
    2019-02-22 03:00:41.712 - info: host.ioBroker-Master instance system.adapter.backitup.0 started with pid 27000
    2019-02-22 03:00:44.287 - debug: backitup.0 objectDB connected
    2019-02-22 03:00:44.337 - debug: backitup.0 statesDB connected
    2019-02-22 03:00:44.452 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.14.0
    2019-02-22 03:00:44.665 - info: backitup.0 [total] backup was activated at 03:00 every 1 day(s)
    2019-02-22 03:00:44.712 - debug: backitup.0 [total] 10 00 03 */1 * *
    Nodejs = 0.8.15
    NPM 6.8.0
    Backitup 1.1.2
    • D der-eine
      Nodejs = 0.8.15
      NPM 6.8.0
      Backitup 1.1.2
      simatecS Offline
      simatecS Offline
      simatec
      @der-eine
      Welche js-Controller Version ist installiert?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
        der-eine
        schrieb am zuletzt editiert von der-eine
        js-Controller v1.5.7
        • D der-eine
          simatecS Offline
          simatecS Offline
          simatec
          @der-eine
          Hast du mal den Adapter neu gestartet.
          Ich kann diesen Fehler nich rekonstruieren.
          Hast du nach der Installation einen Upload gemacht?
          Die Version 1.1.2 ist inzwischen auch in der latest repro.
          Installiere es mal neu aus der repro
          • simatecS simatec
            @der-eine
            der-eine
            @simatec
            so nochmal gelöscht und neu installiert. Jetzt macht er das Backup unter /opt/ioBroker/backups 👍🏻
            Leider funktioniert es nicht mehr mit Dropbox...
            werde mir den Access Token nochmal anschauen. Ist eigentlich der gleiche wie am Anfang...
            • simatecS Offline
              simatecS Offline
              simatec
              An der dropbox wurde nix geändert ... Füge den Token noch einmal ein ... eventuell ist da was schief gelaufen.
              Was sagt der Log?
              • simatecS simatec
                Was sagt der Log?
                der-eine
                @simatec hab ich schon gemacht. Musste ich ja nach der neu Installation. Werde es heute Nacht nochmal über die Dropbox laufen lassen und poste das Log.
                • D der-eine
                  der-eine
                  Hallo @simatec , jetzt funktioniert alles. Habe es mit dem Standrad Ordnerstruktur probiert. 👍🏻
                  Die Struktur kann ich ja ändern solange die Ordner auf Dropbox vorhanden sind?
                  Danke für deine Unterstützung!
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    Kannst du das Thema dann bitte auf gelöst setzen ;-)
                    • simatecS simatec
                      der-eine
                      @simatec klar mach ich.
