  4. [Aufruf] Bring! Adapter
    6.6k
bringeinkaufslistetester
359 Beiträge 41 Kommentatoren 88.7k Aufrufe 35 Beobachtet
  • R Offline
    RappiRN
    Na dann, hier weitere Infos. Der Adapter ist ja jetzt ein paar minuten gelaufen, jetzt kommt:
    root@Orange-Pi:~# ps -aux | grep bring
    root     15030 12.3  3.4 150084 70696 ?        Sl   11:02   0:38 io.bring.0
    root     15239  0.0  0.0   4132  1728 pts/0    S+   11:07   0:00 grep bring
    root     15030 52.5 13.4 354136 276756 ?       Rl   11:02   6:44 io.bring.0
    root     15481  0.0  0.0   4132  1580 pts/0    S+   11:14   0:00 grep bring
    root     15030 76.3 50.4 1128956 1039712 ?     Rl   11:02  17:19 io.bring.0
    root     15783  0.0  0.0   4132  1548 pts/0    S+   11:24   0:00 grep bring
    Im Log steht jetzt sowas:
    bring.0	2019-02-13 10:47:09.940	info	[END] Stopping Bring! adapter...
    bring.0	2019-02-13 11:22:00.349	error	at Timer.listOnTimeout (timers.js:290:5)
    bring.0	2019-02-13 11:22:00.349	error	at tryOnTimeout (timers.js:323:5)
    bring.0	2019-02-13 11:22:00.349	error	at ontimeout (timers.js:498:11)
    bring.0	2019-02-13 11:22:00.349	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:256:18)
    bring.0	2019-02-13 11:22:00.349	error	at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:309:8)
    bring.0	2019-02-13 11:22:00.349	error	at Request.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    bring.0	2019-02-13 11:22:00.349	error	at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/polling-xhr.js:109:10)
    bring.0	2019-02-13 11:22:00.349	error	at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:64:13)
    bring.0	2019-02-13 11:22:00.349	error	Error: xhr post error
    bring.0	2019-02-13 11:22:00.345	error	xhr post error
    Enrico
    • R Offline
      RappiRN
      Ich bin auf einem OrangePi +2e mit Armbian Stretch 5.60
      JS-Controller 1.4.2
      Enrico
      • R RappiRN
        Enrico
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @RappiRN Gibts vom ioBroker Log noch ein paar mehr Zeilen oben drüber? Okay, also Prozess läuft nur ein mal aber frisst ein haufen RAM und CPU.
        Videotutorials & mehr
        • foxriver76F Offline
          foxriver76F Offline
          foxriver76
          @RappiRN Installier mal bitte neu von GitHub.
          • R Offline
            RappiRN
            Test läuft!
            Enrico
            • R Offline
              RappiRN
              Sieht bis jetzt besser aus. Kann aber jetzt nicht mehr weiter testen, muss gleich meinem Nebenerwerb (neben Smarthome 😂 ) nachgehen!
              Werde heute Nacht nochmal berichten.
              root     17909  7.0  1.9 121680 40996 ?        Sl   12:26   0:03 io.bring.0
              root     17944  0.0  0.0   4132  1716 pts/0    S+   12:27   0:00 grep bring
              root     17909  2.8  1.7 131672 35412 ?        Sl   12:26   0:04 io.bring.0
              root     17994  0.0  0.0   4132  1604 pts/0    S+   12:28   0:00 grep bring
              root     17909  1.7  1.6 131160 34232 ?        Sl   12:26   0:05 io.bring.0
              root     18125  0.0  0.0   4132  1620 pts/0    S+   12:32   0:00 grep bring
              root     17909  0.9  1.7 131948 35900 ?        Sl   12:26   0:10 io.bring.0
              root     18420  0.0  0.0   4132  1656 pts/0    S+   12:44   0:00 grep bring
              Enrico
              • R RappiRN
                Enrico
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                @RappiRN sagte in [Aufruf] Bring! Adapter:
                Enrico
                Top, danke fürs erste Feedback.
                • P Offline
                  P-A-L-A-D-I-N
                  @foxriver76 said in [Aufruf] Bring! Adapter:
                  https://github.com/foxriver76/ioBroker.bring
                  Ich habe den Adapter mithilfe des Links installiert. Installierte Version ist 0.0.7, als verfügbare Version wird nichts angezeigt und die Adapter-Karte weist Darstellungsfehler auf (fehlende Icons, die erst beim Überfahren mit der Maus sichtbar werden). Seltsamerweise ist der Adapter bei mir auch nicht unter den Instanzen gelistet - ich kann ihn daher weder konfigurieren, noch aktivieren oder sonst etwas tun.
                  • R Offline
                    RappiRN
                    Wenn du per Link installiert hast, musst du noch eine Instanz erstellen. Im Admin unter Adapter rechts auf das Plus (bei Bring! natürlich) klicken, dann wird erst die Instanz erzeugt, die du dann auch unter Instanzen einstellen kannst!
                    Enrico
                    • P Offline
                      P-A-L-A-D-I-N
                      Oh Mann, bin ich doof! Dadurch, daß das Plus-Zeichen ebenfalls nicht angezeigt wurde, habe ich diesen Schritt doch glatt vergessen! Danke für den Hinweis, jetzt ist auch eine Instanz vorhanden!
                      • KnallochseK Offline
                        KnallochseK Offline
                        Knallochse
                        Habe deinen Bring Adapter ausprobiert. Läuft Super.
                        Für die Darstellung im VIS fände ich es Klasse, wenn ich die html-Daten ohne Tabellenkopf (specification / name) kommen würden. Könnte man das irgendwie abstellen?
                        • KnallochseK Knallochse
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          @Knallochse Danke für dein Feedback, in 0.0.8 gibt es zusätzlich alle Html states nochmal mit NoHead am Ende, diese sind äquivalent zu den original Daten, bis darauf dass der <thead> entfernt wird.
                          KnallochseK 1 Antwort Letzte Antwort
                          • R Offline
                            RappiRN
                            Hab mal kurz zu Hause nachgesehen, der Adapter läuft noch, keine Fehlermeldungen und der RAM steht bei ca. 50 MB.
                            Sieht also gut aus! 👍
                            Enrico
                            • foxriver76F foxriver76
                              KnallochseK Offline
                              KnallochseK Offline
                              Knallochse
                              @foxriver76 Ich danke dir.
                              Mit der NoHeader sind Spec und Name zusammengeschrieben (nicht mehr in Tabellenform)
                              Ich will aber nicht undankbar wirken, es funktioniert auch so wunderbar.
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @Knallochse kannst du das genauer spezifizieren. Also bei mir schaut es genauso aus nur ohne Header ;-)
                                Minimal Beispiel links HTML basic mit klassischem State, rechts mit NoHeader (Steinbodenpflege hat keine Spezifikation)
                                Wenn du das Problem genauer beschreiben kannst, kann ich es mir anschauen.
                                  KnallochseK Offline
                                  KnallochseK Offline
                                  Knallochse
                                  @foxriver76 Gern
                                  Wenn ich den Datenpunkt "contentHtml" wähle, sieht es so aus
                                  Wenn ich den Datenpunkt "contentHtmlNoHead" wähle, sieht es so aus
                                  und wie mir gerade aufgefallen ist aktualisiert sich die Liste auch nicht
                                  R foxriver76F D 3 Antworten Letzte Antwort
                                    KnallochseK Offline
                                    Knallochse
                                    So sieht es mit dem JSON Widget aus
                                    Ich find‘s Super.
                                    Danke nochmal für den Adapter.
                                    Fand vor allen bei der „besseren Hälfte“ Akzeptanz,
                                    und das passiert doch nicht so oft 😂
                                      Ich find‘s Super.
                                      sigi234S Online
                                      sigi234S Online
                                      @Knallochse
                                      20 Kilo Gummibärchen?
                                      • sigi234S sigi234
                                        @Knallochse
                                        KnallochseK Offline
                                        KnallochseK Offline
                                        Knallochse
                                        @sigi234 warum - kannst du das nicht nachvollziehen? 😂
                                          @foxriver76 Gern
                                          RappiRN
                                          @Knallochse sagte in [Aufruf] Bring! Adapter:
                                          @foxriver76 Gern
                                          Sind da vielleicht die Inhalte von content und recentcontent durcheinander geraten?
                                          Enrico
