  4. Adapter: fritzdect
Adapter: fritzdect
706 Beiträge 90 Kommentatoren 305.7k Aufrufe 27 Beobachtet
  • H Offline
    Harald_U
    #577
    Ich habe auch die Version 0.2.1 von Github installiert.
    Die Templates werden offensichtlich eingelesen, siehe 2. Zeile:
    2019-01-31 21:26:26.444  - debug: fritzdect.0 templates
    2019-01-31 21:26:26.445  - debug: fritzdect.0 [{"identifier":"tmp6F0093-39091EED0","id":"60005","functionbitmask":"320","applymask":["2",{"hkr_summer":""}],"name":"Alle aus (Sommer)","devices":{"device":[{"identifier":"11795 0308608"},{"identifier":"10971 0671592"},{"identifier":"10971 0667624"},{"identifier":"09995 0063362"}]}},{"identifier":"tmp6F0093-390920878","id":"60008","functionbitmask":"320","applymask":["26",{"hkr_summer":"","hkr_holidays":"","hkr_time_table":""}],"name":"Normal Bad","devices":{"device":{"identifier":"10971 0671592"}}},{"identifier":"tmp6F0093-390920F4A","id":"60009","functionbitmask":"320","applymask":["26",{"hkr_summer":"","hkr_holidays":"","hkr_time_table":""}],"name":"Normal Schlafzimmer","devices":{"device":{"identifier":"09995 0063362"}}},{"identifier":"tmp6F0093-39091E943","id":"60006","functionbitmask":"320","applymask":["8",{"hkr_holidays":""}],"name":"Urlaub Anfang","devices":{"device":[{"identifier":"11795 0308608"},{"identifier":"10971 0671592"},{"identifier":"10971 0667624"},{"identifier":"09995 0063362"}]}},{"identifier":"tmp6F0093-391363146","id":"60007","functionbitmask":"320","applymask":["8",{"hkr_holidays":""}],"name":"Urlaub Ende","devices":{"device":[{"identifier":"11795 0308608"},{"identifier":"10971 0671592"},{"identifier":"10971 0667624"},{"identifier":"09995 0063362"}]}},{"identifier":"tmp6F0093-39091E733","id":"60010","functionbitmask":"320","applymask":["26",{"hkr_summer":"","hkr_holidays":"","hkr_time_table":""}],"name":"Wohnen Home","devices":{"device":[{"identifier":"11795 0308608"},{"identifier":"10971 0667624"}]}},{"identifier":"tmp6F0093-39091E428","id":"60011","functionbitmask":"320","applymask":["26",{"hkr_summer":"","hkr_holidays":"","hkr_time_table":""}],"name":"Wohnen Work","devices":{"device":[{"identifier":"11795 0308608"},{"identifier":"10971 0667624"}]}}]
    2019-01-31 21:26:26.445  - info: fritzdect.0 create Templates 7
    2019-01-31 21:26:26.446  - debug: fritzdect.0 create template.lasttemplate for response
    2019-01-31 21:26:26.450  - error: fritzdect.0 fritzbox returned this {}
    Die Objekte sind bei mir vorhanden und werden auch geschaltet.
    • F Offline
      foxthefox
      #578
      @Harald_U:
      Die Objekte sind bei mir vorhanden und werden auch geschaltet. `
      Hattest du die templates schon in einer älteren Version von fritzdect angelegt?
      Ich denke nämlich, daß in der API noch etwas geändert wurde.
      Adapterüberblick: Profil Github;
      Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
      Ein Aufruf: video
      • F Offline
        foxthefox
        #579
        @hilde0407:
        Ich habe auch von Github die Version 0.2.1 installiert. Auch bei mir werden keine Templates erzeugt.
        In der FritzBox 7490 mit FritzOS 7.01 habe ich 10 Templates angelegt. Diese werden offensichtlich auch vom Adapter erkannt (im Log).
        Anbei das Log, welches ich auf Debug gestellt habe. `
        Bitte mal die Version von GitHub ausprobieren. Es scheint in der API Änderungen gegeben zu haben.
        Ein Aufruf: video
        • H Offline
          hilde0407
          #580
          Ich habe sowohl die Instanz, als auch den Adapter selber gelöscht und dann neu von GitHub installiert … der selbe Fehler!
          • F Offline
            foxthefox
            #581
            @hilde0407:
            Ich habe sowohl die Instanz, als auch den Adapter selber gelöscht und dann neu von GitHub installiert … der selbe Fehler! `
            Dann dauert es etwas mit der behebung, dann muss ich erst rausfinden was durch die geänderte API in die Binsen gegangen ist.
            Ein Aufruf: video
            • H Offline
              hilde0407
              #582
              So, alles noch einmal von vorne gemacht, von GitHub installiert, keine Templates werden angelegt, nun werden aber 2269 Templates gefunden!
              fritzdect.0	2019-01-31 23:52:01.523	debug	devices
              fritzdect.0	2019-01-31 23:52:01.054	error	fritzbox returned this {}
              fritzdect.0	2019-01-31 23:52:01.054	debug	create template.lasttemplate for response
              fritzdect.0	2019-01-31 23:52:01.054	info	create Templates 2269
              fritzdect.0	2019-01-31 23:52:01.054	debug	"<templatelist version="\&quot;1\&quot;"><template identifier="\&quot;tmp43A19D-395754B3A\&quot;" id="\&quot;60002\&quot;" functionbitmask="\&quot;4160\&quot;" applymask="\&quot;16\&quot;"></template></templatelist>
              • F Offline
                foxthefox
                #583
                @hilde0407:
                Ein Aufruf: video
                  Kugelkopf
                  #584
                  Ist denn der ursprüngliche Entwickler des Adapters nicht mehr dabei?
                  Was ist denn da aktuell los?
                  • F Offline
                    foxthefox
                    #585
                    @Kugelkopf:
                    Was ist denn da aktuell los? `
                    Der Adapter Entwickler (ich) ist schon noch dabei, allerdings nutze ich ein Interface, welches generisch von jemanden geschrieben wurde. Ist ein Paket welches mit JavaScript auf die fritzbox kommt. Somit ist die Arbeit für den Adapter die Aufbereitung und Vermittlung zu diesem Stück Software. Für die templates war dort nix vorbereitet und dann habe ich etwas dort eingebracht, was aber vor Veröffentlichung scheinbar nochmals verändert wurde (XML vs JSON Rückgabe) dementsprechend muss ich jetzt nachpflegen.
                    Gruss
                    Klaus
                    Ein Aufruf: video
                      Kugelkopf
                      #586
                      @foxthefox:
                      @Kugelkopf:
                      Gruss
                      Klaus
                      Gesendet von iPhone mit Tapatalk `
                      Alles Klar! Vielen Dank für die Aufklärung =)!
                      • H Offline
                        hilde0407
                        #587
                        Danke für Deine Arbeit foxthefox !
                        • Merlin123M Offline
                          Merlin123M Offline
                          Merlin123
                          #588
                          Welche Version funktioniert denn im Moment am Besten? Hatte die neuste 0.2.x von Github probiert, aber da liest er den Status der Steckdosen nicht aus. die 0.1.4 geht, die 0.1.5 geht auch nicht
                          Beta-Tester
                          • J Offline
                            Jan1
                            #589
                            Stimmt da wird on/off der Dose nicht angezeigt.
                            • F Offline
                              foxthefox
                              #590
                              @Merlin123:
                              Welche Version funktioniert denn im Moment am Besten? Hatte die neuste 0.2.x von Github probiert, aber da liest er den Status der Steckdosen nicht aus. die 0.1.4 geht, die 0.1.5 geht auch nicht `
                              also bei mir läuft die 0.2.0 stabil und Steckdose funzt auch.
                              Ich versuche heute noch die templates zu fixen und dann kommt 0.2.1 raus.
                              Aber Steckdose on/off kann ich nicht nachvollziehen
                              Klaus
                              Ein Aufruf: video
                                Merlin123M Offline
                                Merlin123
                                #591
                                Eine Idee, wieso er den Status nicht anzeigt?
                                Gesendet von meinem CLT-L09 mit Tapatalk
                                Beta-Tester
                                • F Offline
                                  foxthefox
                                  #592
                                  Auf github ist 0.2.1 mit Verbesserungen zu den templates.
                                  Bitte testen und berichten.
                                  Klaus
                                  Ein Aufruf: video
                                  • F Offline
                                    foxthefox
                                    #593
                                    @Merlin123:
                                    Gesendet von meinem CLT-L09 mit Tapatalk `
                                    An der Stelle hab ich eigentlich nix geändert, wenn es auch mit 0.2.1 nicht geht, dann mal bitte im debug Modus schauen oder Posten.
                                    Klaus
                                    Ein Aufruf: video
                                    • L Offline
                                      Leviathan09
                                      #594
                                      Moin,
                                      Kurze Rückmeldung bzgl. der Templates.
                                      Mit der Version 0.2.1 wurden meine erkannt und korrekt im ioBroker erstellt.
                                      Vielen Dank [emoji1303]
                                      • H Offline
                                        hilde0407
                                        #595
                                        Habe die neue Version des Adapters gerade auf die Schnelle aus der Ferne installiert. Es werden die Templates für einen Raum sauber erkannt und auch angelegt, für den anderen Raum leider nicht. Im Log werden einige Warnungen angezeigt, die ich heute Nachmittag posten werde.
                                        • J Offline
                                          Jan1
                                          #596
                                          Der DP switch on/off wird mit 0.2.1 auch sofort angezeigt.
