(GELÖST) Für Alarmanlage 1 Minute Zeit zum deaktivieren einstellen
<block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="EW9L-s[g:Er9BG)9!0S?" x="-1162.266988481531" y="12.463157894737265"><mutation items="2"></mutation> <field name="CONDITION">any</field> <value name="OID0"><shadow type="field_oid" id="WGcjd5]dAb_F17]z2Nw4"><field name="oid">default</field></shadow></value> <value name="OID1"><shadow type="field_oid" id="*GaWR6Hd.BN*jZw8E44@"><field name="oid">default</field></shadow></value> <statement name="STATEMENT"><block type="controls_for" id="%G)]+nJ2dG%8pvVrxukG"><field name="VAR">Alarmzeit</field> <value name="FROM"><shadow type="math_number" id="7b%)Ju~mW=LUDIkSA8rS"><field name="NUM">1</field></shadow></value> <value name="TO"><shadow type="math_number" id="1t;,vQ?*ZLccjuh/{eN:"><field name="NUM">20</field></shadow></value> <value name="BY"><shadow type="math_number" id="P%(@_mwr,4`muky1Ykj%"><field name="NUM">1</field></shadow></value> <statement name="DO"><block type="controls_if" id="cV-iGU14QvuLgB4B^G}y"><value name="IF0"><block type="logic_operation" id="!57^83Yx~jTN_1(CwwSF" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="tdWChO/BX6i]Y@.(2{}b"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="F.s)Osg,jK`.KXjM|nhK"><field name="ATTR">val</field> <field name="OID">ID auswählen</field></block></value> <value name="B"><block type="logic_boolean" id="KyriVEN{HDi;h!/DMiRG"><field name="BOOL">TRUE</field></block></value></block></value> <value name="B"><block type="logic_operation" id="Gl0B0EMNouGRm/S-FyMo"><field name="OP">OR</field> <value name="A"><block type="logic_compare" id="0Dp(Ce+|Weqp|bd#[Op."><field name="OP">EQ</field> <value name="A"><block type="get_value" id="n=-Fer5?ly^dUB(!j}Yw"><field name="ATTR">val</field> <field name="OID">ID auswählen</field></block></value> <value name="B"><block type="logic_boolean" id="KO!ts)md{gTfy33=:Z%r"><field name="BOOL">TRUE</field></block></value></block></value> <value name="B"><block type="logic_compare" id="mjt_s@+prQv4%7?{PA7g"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="kECQ)SC@OLUL?cnj.5V3"><field name="ATTR">val</field> <field name="OID">ID auswählen</field></block></value> <value name="B"><block type="logic_boolean" id="M3aC,)#v#`+[G`;L??7S"><field name="BOOL">TRUE</field></block></value></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="N;%-7IL:=R0nt+Ze19lN"><mutation delay_input="false"></mutation> <field name="OID">Object ID</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="#wkzZL^JTQ80;~y`Q|QM"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></statement></block> -
Probiere mal so:
16431_unbenannt.jpg -
Nehmt lieber das Timeout.
Zur Logik:
Einer der Melder hat breits ausgelöst.
Jetzt NACH Ablauf des Timeouts ERNEUT den Status der Alarmanlage prüfen.
Wenn aus dann mache nichts - wenn ein dann löse Alarm aus.
Christian
Anstatt nach Ablauf des Timeouts erneut zu prüfen kannst du auch an sinnvoller Stelle einen Sonst-Block anfügen und dort das Timeout abbrechen. Dann würde die Aktion, die nach Ablauf des Timeouts ausgeführt werden soll gar nicht ausgeführt werden. Dann musst du nicht an mehreren Stellen etwas prüfen und sollte sich in Zukunft irgendetwas an deiner Logik zum Auslösen ändern musst du es nur an einer Stelle ändern ;)
muss das scharf schalten nicht da hin ?
16431_1845.png -
so ?
Da geht die Alarmanlage alle 10 Sekunden auf scharfstellung, auch wenn ich sie mit dem Taster ausschalte.
Bisher am nähsten dran ist wohl diese
Hier passiert folgendes : Alarm scharf, Tür auf, Schalter gedrückt = Alarm unscharf und alles gut (!) TOPAlarm scharf, Tür auf, Schalter nicht gedrückt = Alarm löst aus (!) Auch TOP
Aber :
Alarm scharf, Tür auf , Tür wieder zu , Schalter nicht gedrückt = Alarm scharf, aber nicht ausgelöst, würde dann nur auslösen, wenn einer der anderen Bewegungsmelder anschlägt… Noch nicht so dass, was ich mir vorstellte.. Ich gehe davon aus, dass die ungebetenen Besucher die Haustür wieder zu machen, sonst fällt das ja zu schnell auf.....
Du darfst nach dem Timeout NICHT mehr auf Öffnung prüfen, denk dran der Melder hat bereits ausgelöst.
Du willst nur die Möglichkeit haben während des Timeouts die Anlage auszuschalten.
Deswegen überprüfst Du nur ob sie noch an ist.
Wenn Du nach dem Timeout nochmal auf Öffnung prüfst, könnte jemand die Tür aufbrechen und wieder schließen und
die Anlage würde nicht auslösen :roll:
Christian
Prima das es nun funktioniert.
Die Logik dahinter ist eigentlich ganz einfach:
Du aktivierst den ausgelösten Alarm, wenn nicht innerhalb des Timeouts deaktiviert wird!
Wenn bei scharf geschalteter Anlage ein Alarmmelder Fenster, Tür, BWM etc. auslöst
wird der Alarm ausgelöst.
Ausnahme die Haustür und korrespondierende Bewegungsmelder, da Du die jedesmal beim Heimkommen selber auslöst.
Deswegen wird bei diesen Meldern die Alarmierung (und nicht die Auslösung, die hat bereits stattgefunden) mittels Timeout verzögert, um Dir die
Chance zu geben deine Anlage unscharf zu stellen, da Du ja kein Einbrecher bist (zumindest nicht in Deiner eigenen Bude :) .
Du prüfst quasi ob Du es nach Deiner Heimkehr, innerhalb des Timeouts, geschafft hast rechtzeitig unscharf zu schalten.
Wenn nicht: gibt es Alarm :lol:
Viele Grüße
Christian
