  4. [Aufruf] Xbox Adapter testen
    1.0k
    6.1k
adapterxbox
205 Beiträge 13 Kommentatoren 50.4k Aufrufe 2 Beobachtet
    DKM
    #170
    Ich melde mich auch mal nach längerer Zeit. Ich erhalte derzeit diesen Fehler:
    host.DKMHS01
    2019-01-04 12:10:42.885
    info
    instance system.adapter.xbox.0 started with pid 6592
    host.DKMHS01
    2019-01-04 12:10:12.874
    info
    Restart adapter system.adapter.xbox.0 because enabled
    host.DKMHS01
    error
    instance system.adapter.xbox.0 terminated with code 0 (OK)
    host.DKMHS01
    error
    Caught by controller[0]: at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    host.DKMHS01
    error
    Caught by controller[0]: at maybeClose (internal/child_process.js:915:16)
    host.DKMHS01
    error
    Caught by controller[0]: at ChildProcess.emit (events.js:214:7)
    host.DKMHS01
    error
    Caught by controller[0]: at emitTwo (events.js:126:13)
    host.DKMHS01
    error
    Caught by controller[0]: at ChildProcess.exithandler (child_process.js:283:5)
    host.DKMHS01
    error
    Caught by controller[0]: at exec (C:\ioBroker\node_modules\iobroker.xbox\main.js:153:52)
    host.DKMHS01
    2019-01-04 12:10:12.873
    error
    Caught by controller[0]: TypeError: Cannot read property 'replace' of undefined
    xbox.0
    2019-01-04 12:10:12.338
    error
    TypeError: Cannot read property 'replace' of undefined at exec (C:\ioBroker\node_modules\iobroker.xbox\main.js:153:52) at ChildProcess.exithandler (child_process.js:283:5) at emitTwo (even
    xbox.0
    2019-01-04 12:10:12.337
    error
    uncaught exception: Cannot read property 'replace' of undefined
    xbox.0
    2019-01-04 12:10:05.508
    error
    [START] Restarting adapter in 30 seconds
    xbox.0
    error
    [START] Failed starting REST server: Error: Command failed: dir /B C:\ioBroker\node_modules\iobroker.xbox\python_modules\Python3 Datei nicht gefunden
    xbox.0
    2019-01-04 12:10:05.503
    info
    [START] Starting REST server
    Installiert ist 0.4.4
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #171
      @DKM:
      host.DKMHS01
      info
      host.DKMHS01
      info
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      host.DKMHS01
      error
      xbox.0
      error
      xbox.0
      error
      xbox.0
      error
      xbox.0
      error
      xbox.0
      info
      Installiert ist 0.4.4 `
      Glaube da ist mir beim Refactoring was entgangen, schaue später rein. Danke
      Videotutorials & mehr
        foxriver76F Offline
        foxriver76
        #172
        Habe mal was auf GitHub gepusht, läuft hoffentlich wieder unter Win.
          foxriver76F Offline
          foxriver76
          #173
          @DKM:
          Kannst du mal probieren, ob die 0.5.0 wieder korrekt läuft.
          –> Der Xbox Adapter kann nun (ab 0.5.0) auch im https://forum.iobroker.net/viewtopic.php?f=24&t=20387&p=213822&hilit=compact+mode#p213822 gestartet werden.
          –> Ab js-controller 1.6 (oder 2.0, was eben kommt) sind Mail und Passwort (neben der sowieso existenten Verschlüsselung) gar nicht mehr für andere Adapter zugreifbar (wobei das hoffentlich sowieso keiner macht ;--) )
            DKM
            #174
            Geht wieder [emoji16]
            Gesendet von meinem SM-G960F mit Tapatalk
            • J Offline
              jetlife
              #175
              Danke für den Adapter!! Habe ihn nach einiger Bastelarbeit übers Terminal auf dem pi zum Laufen gebracht. Xbox an aus etc. funktioniert.
              Nachdem der pi neu gestartet wurde, steht folgendes im log:
              xbox.0	2019-01-20 14:10:51.763	warn	[CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2019-01-20 04:25:17.990	warn	[LOGIN] <=== Error: null
              xbox.0	2019-01-20 04:25:16.950	warn	[LOGIN] Connection refused, will try again
              Muss die xbox mindestens einmal manuell angeschaltet werden, nach einem pi Neustart? Oder verliert er immer die Verbindung, sobald die xbox länger im Standby war?
                foxriver76F Offline
                foxriver76
                #176
                @jetlife:
                [code
                Muss die xbox mindestens einmal manuell angeschaltet werden, nach einem pi Neustart? Oder verliert er immer die Verbindung, sobald die xbox länger im Standby war? `
                Die Login Meldung bezieht sich auf die Authentifizierung, die nimmt er bei jedem Adapterstart bei Xbox Live (also falls du Username und PW angegeben hast). Wenn danach kein Fehler mehr kam hat die Anmeldung dann geklappt. Ich schaue mal, dass da nicht mehr 'Error: null' geloggt wird. Wegen der Connect Warning, die kommt auch nur wenn der Adapter gestartet wurde und bislang die Xbox die zur angegebenen Live ID gehört nicht im Netzwerk finden konnte (obwohl sie über Ping erreichbar ist). Also ist eigentlich beides nix schlimmes ;-)
                • J Offline
                  jetlife
                  #177
                  Alles klar, vielen Dank für die ausführliche Erklärung und deine Arbeit! Ich konnte die xbox allerdings erst wieder steuern, nachdem ich sie einmal manuell gestartet habe. Seitdem geht wieder alles (auch on/off).
                    foxriver76F Offline
                    foxriver76
                    #178
                    @jetlife:
                    Alles klar, vielen Dank für die ausführliche Erklärung und deine Arbeit! Ich konnte die xbox allerdings erst wieder steuern, nachdem ich sie einmal manuell gestartet habe. Seitdem geht wieder alles (auch on/off). `
                    Also du solltest sie eigentlich anschalten können, unabhängig vom Pi Neustart. Außer wenn die Xbox vom Strom genommen wurde, bzw. nicht in Always-on Modus ist, dann kann sie nicht über den Adapter gestartet werden. Wurde hier in dem Thread mal andiskutiert.
                    • J Offline
                      jetlife
                      #179
                      xbox wurde weder vom Strom genommen, noch ist der instant on modus deaktiviert. Also alles wie es sein soll, lediglich der pi wurde rebootet. Ich beobachte das mal weiter.
                      • J Offline
                        jetlife
                        #180
                        Es hat jetzt die ganze Zeit funktioniert. Seit heute leider nicht mehr. Kann nicht mehr on/off schalten.
                        xbox.0 2019-01-26 19:03:31.967 info [START] Starting REST server
                        xbox.0 2019-01-26 19:03:31.956 info starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
                        host.raspberrypi 2019-01-26 19:03:30.017 info instance system.adapter.xbox.0 started with pid 1670
                        host.raspberrypi 2019-01-26 19:03:27.681 info instance system.adapter.xbox.0 terminated with code 0 (OK)
                        xbox.0 2019-01-26 19:03:27.645 info [END] cleaned everything up…
                        xbox.0 2019-01-26 19:03:27.639 error [CONNECT] <=== socket hang up
                        xbox.0 2019-01-26 19:03:27.637 warn [CONNECT] Ping response, but provided LiveID has not been discovered until now
                        xbox.0 2019-01-26 19:03:27.632 error [DISCOVER] <=== socket hang up
                        xbox.0 2019-01-26 19:03:27.616 info [END] REST server stopped
                        Kann mir jemand bitte weiterhelfen? Danke! Habe bereits pi rebootet sowie den Adapter. Auch mit XBOX an und ausgeschalten probiert. Kommt immer dieser log.
                          foxriver76F Offline
                          foxriver76
                          #181
                          @jetlife:
                          xbox.0	2019-01-26 19:03:27.645	info	[END] cleaned everything up...
                          Kann mir jemand bitte weiterhelfen? Danke! Habe bereits pi rebootet sowie den Adapter. Auch mit XBOX an und ausgeschalten probiert. Kommt immer dieser log. `
                          Zeig mal mehr vom Log. Aus den Infos kann man nix entnehmen, anscheinend wurde unload getriggert und der Rest Server bereits gestoppt und somit kommt die Meldung socket hang up.
                          • J Offline
                            jetlife
                            #182
                            	Zeit
                            Meldung
                            xbox.0	2019-01-27 19:08:28.519	warn	[CONNECT] Ping response, but provided LiveID has not been discovered until now
                            xbox.0	2019-01-27 18:07:49.160	info	[START] Starting REST server
                            xbox.0	2019-01-27 18:07:49.149	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
                            host.raspberrypi	2019-01-27 18:07:47.207	info	instance system.adapter.xbox.0 started with pid 12360
                            host.raspberrypi	2019-01-27 18:07:47.190	info	object change system.adapter.xbox.0
                            host.raspberrypi	2019-01-27 18:07:43.775	info	instance system.adapter.xbox.0 terminated with code 0 (OK)
                            xbox.0	2019-01-27 18:07:43.732	info	[END] cleaned everything up...
                            xbox.0	2019-01-27 18:07:43.728	error	[CONNECT] <=== socket hang up
                            xbox.0	2019-01-27 18:07:43.723	error	[CONNECT] <=== socket hang up
                            xbox.0	2019-01-27 18:07:43.714	info	[END] REST server stopped
                            host.raspberrypi	2019-01-27 18:07:43.584	info	stopInstance system.adapter.xbox.0 killing pid 2605
                            host.raspberrypi	2019-01-27 18:07:43.583	info	stopInstance system.adapter.xbox.0
                            host.raspberrypi	2019-01-27 18:07:43.582	info	object change system.adapter.xbox.0
                            javascript.0	2019-01-27 18:07:42.484	info	received all objects
                            javascript.0	2019-01-27 18:07:41.374	info	received all states
                            javascript.0	2019-01-27 18:07:40.342	info	requesting all objects
                            javascript.0	2019-01-27 18:07:40.339	info	requesting all states
                            javascript.0	2019-01-27 18:07:40.323	info	starting. Version 4.0.11 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.15.0
                            host.raspberrypi	2019-01-27 18:07:36.658	info	instance system.adapter.javascript.0 started with pid 12346
                            host.raspberrypi	2019-01-27 18:07:36.645	info	object change system.adapter.javascript.0
                            history.0	2019-01-27 18:07:34.924	info	starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.history, node: v8.15.0
                            host.raspberrypi	2019-01-27 18:07:33.765	info	instance system.adapter.history.0 started with pid 12336
                            host.raspberrypi	2019-01-27 18:07:33.752	info	object change system.adapter.history.0
                            ping.0	2019-01-27 18:07:26.582	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v8.15.0
                            host.raspberrypi	2019-01-27 18:07:25.398	info	instance system.adapter.ping.0 started with pid 12316
                            host.raspberrypi	2019-01-27 18:07:25.373	info	object change system.adapter.ping.0
                            simple-api.0	2019-01-27 18:07:17.711	info	http server listening on port 8087
                            simple-api.0	2019-01-27 18:07:17.706	info	Allow states only when user is owner: false
                            simple-api.0	2019-01-27 18:07:17.705	info	simpleAPI server listening on port 8087
                            simple-api.0	2019-01-27 18:07:17.672	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v8.15.0
                            socketio.0	2019-01-27 18:07:16.769	info	socket.io server listening on port 8084
                            socketio.0	2019-01-27 18:07:16.695	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v8.15.0
                            host.raspberrypi	2019-01-27 18:07:16.450	info	instance system.adapter.simple-api.0 started with pid 12300
                            host.raspberrypi	2019-01-27 18:07:16.435	info	object change system.adapter.simple-api.0
                            xbox.0	2019-01-27 18:07:16.342	warn	[REQUEST] <=== Could not turn on Xbox
                            host.raspberrypi	2019-01-27 18:07:15.117	info	instance system.adapter.socketio.0 started with pid 12294
                            host.raspberrypi	2019-01-27 18:07:15.090	info	object change system.adapter.socketio.0
                              foxriver76F Offline
                              foxriver76
                              #183
                              An der Stelle an der der Adapter stoppt, hast du ihn manuell beendet?
                              • J Offline
                                jetlife
                                #184
                                Sorry, ja. Hab restartet. Hab jetzt alle möglichen Adapter mal wild restartet und aus irgendeinem Grund connected er jetzt wieder. Kein Plan, was da los ist.
                                visibility
                                build
                                HOST RASPBERRYPIioBroker.admin 3.5.10
                                refresh pausedelete delete_foreverLOG HERUNTERLADENLog-Größe: 0.01 MB
                                	Zeit
                                Meldung
                                xbox.0	2019-01-27 18:25:41.823	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
                                cloud.0	2019-01-27 18:22:55.067	info	Request V3 devices
                                cloud.0	2019-01-27 18:22:55.064	info	Request devices
                                cloud.0	2019-01-27 18:22:48.949	info	Request V3 devices
                                cloud.0	2019-01-27 18:22:48.586	info	Request devices
                                cloud.0	2019-01-27 18:22:31.460	info	Request V3 devices
                                cloud.0	2019-01-27 18:22:31.358	info	Request devices
                                cloud.0	2019-01-27 18:22:16.763	info	Request devices
                                cloud.0	2019-01-27 18:22:16.182	info	Request devices
                                xbox.0	2019-01-27 18:21:55.753	info	[CONNECT] <=== Lost connection to your Xbox (192.168.178.24)
                                cloud.0	2019-01-27 18:21:14.590	warn	Unknown applianceId: Konsole
                                xbox.0	2019-01-27 18:19:35.108	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
                                admin.0	2019-01-27 18:16:55.421	info	Repository received successfully.
                                host.raspberrypi	2019-01-27 18:16:53.900	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                admin.0	2019-01-27 18:16:53.830	info	Request actual repository...
                                xbox.0	2019-01-27 18:13:28.005	warn	[CONNECT] Ping response, but provided LiveID has not been discovered until now
                                xbox.0	2019-01-27 18:13:13.131	warn	[REQUEST] <=== Could not turn on Xbox
                                xbox.0	2019-01-27 18:12:35.637	info	[START] Starting REST server
                                xbox.0	2019-01-27 18:12:35.626	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
                                host.raspberrypi	2019-01-27 18:12:33.628	info	instance system.adapter.xbox.0 started with pid 12522
                                host.raspberrypi	2019-01-27 18:12:31.532	info	instance system.adapter.xbox.0 terminated with code 0 (OK)
                                xbox.0	2019-01-27 18:12:31.341	info	[END] cleaned everything up...
                                xbox.0	2019-01-27 18:12:31.322	info	[END] REST server stopped
                                host.raspberrypi	2019-01-27 18:12:31.102	info	stopInstance system.adapter.xbox.0 killing pid 12463
                                host.raspberrypi	2019-01-27 18:12:31.101	info	object change system.adapter.xbox.0
                                web.0	2019-01-27 18:12:30.644	info	http server listening on port 8082
                                web.0	2019-01-27 18:12:30.640	info	socket.io server listening on port 8082
                                web.0	2019-01-27 18:12:30.318	info	Allow states only when user is owner: false
                                web.0	2019-01-27 18:12:30.317	info	simpleAPI server listening on port 8082
                                web.0	2019-01-27 18:12:30.142	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
                                web.0	2019-01-27 18:12:30.127	error	setObject id missing!!
                                host.raspberrypi	2019-01-27 18:12:28.618	info	instance system.adapter.web.0 started with pid 12509
                                host.raspberrypi	2019-01-27 18:12:26.195	info	instance system.adapter.web.0 terminated with code 0 (OK)
                                web.0	2019-01-27 18:12:26.127	info	terminating http server on port 8082
                                web.0	2019-01-27 18:12:26.103	info	terminated http server on port 8082
                                web.0	2019-01-27 18:12:26.101	info	terminating http server on port 8082
                                host.raspberrypi	2019-01-27 18:12:26.097	info	stopInstance system.adapter.web.0 killing pid 570
                                host.raspberrypi	2019-01-27 18:12:26.096	info	object change system.adapter.web.0
                                xbox.0	2019-01-27 18:12:13.190	warn	[REQUEST] <=== Could not turn on Xbox
                                xbox.0	2019-01-27 18:11:41.136	info	[START] Starting REST server
                                xbox.0	2019-01-27 18:11:41.125	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
                                host.raspberrypi	2019-01-27 18:11:39.182	info	instance system.adapter.xbox.0 started with pid 12463
                                host.raspberrypi	2019-01-27 18:11:37.089	info	instance system.adapter.xbox.0 terminated with code 0 (OK)
                                xbox.0	2019-01-27 18:11:36.942	info	[END] cleaned everything up...
                                xbox.0	2019-01-27 18:11:36.757	info	[END] REST server stopped
                                  foxriver76F Offline
                                  foxriver76
                                  #185
                                  Habe jetzt nicht direkt einen Fehler gesehen, also der Adapter kann sich nur verbinden, wenn die Xbox an ist. Sprich solange die Xbox aus ist, ist der Adapter gelb. Anschalten ist das einzige Kommando das klappen 'kann', wenn die Xbox nicht verbunden ist. Allerdings nicht dann, wenn die Xbox vorher vom Strom getrennt war und seitdem nicht mehr gestartet wurde.
                                  • J Offline
                                    jetlife
                                    #186
                                    Und schon wieder ist sie weg :/ Ich hab so langsam das Gefühl, dass es über wlan nicht richtig funktioniert. Ich probiere es morgen mal mit LAN Verbindung bei der XBOX.
                                    • J Offline
                                      jetlife
                                      #187
                                      @foxriver76:
                                      @Jey Cee:
                                      Ich hab das jetzt mal mit der App getestet, selbes Ergebnis, die Xbox lässt sich nicht starten. Übrigens ist Schnelles Hochfahren dafür immer Notwendig.
                                      Damit ist klar die Xbox muss erstmal gestartet worden sein und ist erst danach im Standby. Das ist darauf zurück zu führen das dass BIOS/UEFI gar kein WOL Unterstützt oder eben nicht aktiviert ist. Es gibt einen Standby Modus von Windows (läuft ja auf der Xbox) der WOL ermöglicht. Das konnte ich herausfinden als ich meinen Laptop per WOL wecken wollte, aber genau das gleiche Problem wie bei der Xbox.
                                      @foxriver76:
                                      Ich habe das Problem selbst und konnte es bislang nicht lösen, allerdings vermuten wir derzeit, dass es irgendwo in der Fritz!Box steckt. Ist die Xbox direkt mit der FritzBox verbunden? Die FritzBox hat ja auch ein Energiemanagment und schaltet die LAN Ports ab wenn da nix mehr kommt. Da könnte eventuell ein Switch dazwischen helfen.
                                      Danke, dass du etwas Licht ins dunkel bringst. Ich habe das ganze bei mir getestet im WLAN der Fritz und per LAN an einem DLAN-Adapter. Für mich persönlich ist es nicht relevant, da ich sowieso über den Harmony Hub die Box an und aus mache. Allerdings ist es schön, wenn man als Adapter-Entwickler den Usern im Falle des Problems helfen kann.
                                      @Jey Cee:
                                      Ich hab die Xbox mal 1-1,5 Stunden im Standby gelassen und das Starten war kein Problem. `
                                      Top, dann ist es wohl wie von dir erörtert die fehlende Wake-on-Lan Funktion von Win. `
                                      Das beschreibt denke ich genau mein Problem. Wobei meine XBOX immer am Strom ist. Ich habe also keine Möglichkeit, meine XBOX per Adapter anzuschalten, sobald diese länger im Standby war? Oder funktioniert das, sobald ich statt WLAN die XBOX per LAN anschließe?
                                        DKM
                                        #188
                                        Habt ihr ne feste IP an der Xbox und in der Fritzbox? Wenn ein Gerät länger nicht im Netz ist, wird die IP freigegeben und alles läuft ins Leere.
                                        Siehe DHCP Lease
                                        • J Offline
                                          jetlife
                                          #189
                                          Ja, feste IP ist natürlich bei allen Geräten eingestellt.
