  4. [Aufruf] ZigBee CC253x Adapter
1.1k Beiträge 131 Kommentatoren 488.6k Aufrufe 7 Beobachtet
  • besterquesterB Offline
    besterquester
    #986
    ja da steht was drinnen.
    {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018e1b318","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1547487414,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterLi$
    {"$indexCreated":{"fieldName":"id","unique":true,"sparse":false}}
    {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018e1b318","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1547487432,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterLi$
    {"id":2,"type":"EndDevice","ieeeAddr":"0x00158d0002c586d2","nwkAddr":15146,"manufId":4151,"epList":[1],"status":"online","joinTime":1547488316,"endpoints":{"1":{"profId":260,"epId":1,"devId":263,"inClusterList"$
    {"id":2,"type":"EndDevice","ieeeAddr":"0x00158d0002c586d2","nwkAddr":15146,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sensor_motion.aq2","epList":[1],"status":"online","joinTime":$
    {"id":3,"type":"EndDevice","ieeeAddr":"0x00158d00025583c8","nwkAddr":34269,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488696,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":3,"type":"EndDevice","ieeeAddr":"0x00158d00025583c8","nwkAddr":34269,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748869$
    {"id":4,"type":"EndDevice","ieeeAddr":"0x00158d00023ac6dc","nwkAddr":9281,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488789,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluster$
    {"id":4,"type":"EndDevice","ieeeAddr":"0x00158d00023ac6dc","nwkAddr":9281,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":1547488789$
    {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d00025583a5","nwkAddr":65210,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488879,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d00025583a5","nwkAddr":65210,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748887$
    {"id":6,"type":"EndDevice","ieeeAddr":"0x00158d0002b5a2f0","nwkAddr":33900,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488967,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":6,"type":"EndDevice","ieeeAddr":"0x00158d0002b5a2f0","nwkAddr":33900,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748896$
    Ich habe die Temp neu angelernt die Bewegungsmelder hängen an der Wand. Die zeigen immer noch not conected an
    g Bester
    • CKMartensC Offline
      CKMartensC Offline
      CKMartens
      #987
      Das Problem ist gelöst.
      Für bluez muste ich den Befehl
      setcap cap_net_raw+eip $(eval readlink -f which node)
      eingeben danach wurde auch der Zigbee Adapter grün
      Ich bin gerade etwas am Verzweifeln. Nachdem ich heute meinen Server neu aufsetzen musste und iobroker neu instaliert habe bekomme ich den Zigbee nicht mehr zum laufen.
      node und nodejs sind v8.15.0
      npm ist 6.15
      zigbee Adapter ist 0.8.2a von github.com
      Server Ubuntu 18.05
      ls -la /dev/serial/by-id
      gibt folgendes aus:
      lrwxrwxrwx 1 root root 13 Jan 14 19:18 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED2570-if00 -> ../../ttyACM0
      Felherlog:
      zigbee.0 2019-01-14 19:37:34.705 debug User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1547491054701,"q":0,"from":"system.adapter.zigbee.0","lc":1547490902187}
      zigbee.0 2019-01-14 19:37:34.113 error Error while starting zigbee-shepherd!. Error: Error: Permission denied, cannot open /dev/ttyACM0
      zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.109Z zigbee:controller error Error while starting zigbee-shepherd! Error: Error: Permission denied, cannot open /dev/ttyACM0
      zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.106Z zigbee-shepherd:init zigbee-shepherd booting...
      zigbee.0 2019-01-14 19:37:34.113 info Starting zigbee-shepherd
      zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.105Z zigbee:controller info Starting zigbee-shepherd undefined
      zigbee.0 2019-01-14 19:36:34.105 debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds)
      zigbee.0 2019-01-14 19:36:34.104 debug 2019-01-14T18:36:34.104Z zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds) undefined
      zigbee.0 2019-01-14 19:36:34.085 debug 2019-01-14T18:36:34.085Z zigbee-shepherd:init zigbee-shepherd booting...
      zigbee.0 2019-01-14 19:36:34.069 info Start on port: /dev/ttyACM0 with panID 6754 channel 11
      zigbee.0 2019-01-14 19:36:34.066 info starting. Version 0.8.2-a in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.0
      Bin mit meinem Latein bisschen am Ende, vor allem da es ja auf dem "alten" System ohne Probleme lief.
        AndrK
        #988
        Hallo CKMartens,
        was kommt bei Dir bei
        ls -la /dev/ttyACM0
        bei mir (Raspi) sehe ich:
        crw-rw---- 1 root dialout 166, 0 Jan 14 10:14 /dev/ttyACM0
        AndrK
          Arnulf
          #989
          @arteck:
          @Arnulf:
          Vielen Dank.
          Damit habe ich die DB gefunden
          Es ist doch sicher nicht normal, dass da die IDs doppelt auftauchen, oder?
          Die DB ist 42 Zeilen groß (42 Zeilen, die mit "["id":" beginen habe aber aktuell nur 20 Devices in meiner Adapter-Geräteliste
          Muss ich da jetzt Zeilen löschen?
          Wenn ja, welche?
          Und: Wie öffne ich am Besten die Schreibgeschützte Datei? ioBroker muss sicher vorher gestoppt werden. Oder?
          [update]
          Hier mal die linken Zeichen der Shepherd-DB.
          Vielleicht ist das doch so korrekt. Zumindest könnte die obere Hälfte der normale Eintrag und die untere Hälfte der Index sein
          ! {"id":24,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":25,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":26,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":17,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":2,"type":"Router","ieeeAddr":"0x00178801030
          ! {"id":11,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":19,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":20,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":18,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":12,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":21,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":16,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":27,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":5,"type":"Router","ieeeAddr":"0x7cb03eaa00b
          ! {"id":13,"type":"Router","ieeeAddr":"0x7cb03eaa00
          ! {"id":14,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b
          ! {"id":15,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":10,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":22,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"id":23,"type":"EndDevice","ieeeAddr":"0x00158d0
          ! {"$indexCreated":{"fieldName":"id","unique":true
          [Update]
          Ich habe auch die Geräte, die im Adapter gelistet sind mit den Werten in der DB verglichen.
          Alles drin. Auch die als Router fungierenden Geräte.
          Nur halt eben doppelt `
          da ich gearde im Tall der Ahnungslosen bin.. was war dein Problem nochmal ??? `
          :D
          … dass ich im Moment keine Geräte anlernen kann. Keine Humity-Semsoren und auch heute meinen Aqara-Cube nicht.
          Ich hatte die Datenbank in Verdacht. Dass entweder was Falsches drinsteht oder was Altes.
          Ich vermute aber, die ist so weit OK
            Arnulf
            #990
            @besterquester:
            g Bester `
            Bei dir stehem die IDs ja noch öfter drin als bei mir. Bei mir ist das "nur" zweimal
              besterquester
              #991
              @Arnulf:
              @besterquester:
              g Bester `
              Bei dir stehem die IDs ja noch öfter drin als bei mir. Bei mir ist das "nur" zweimal `
              Hat jemand schon versucht die doppelten zu löschen was passiert dann -> neu paaren :)
              • arteckA Offline
                arteckA Offline
                arteck
                #992
                Leute wenn ihr nicht wisst was ihr macht dann lasst es..
                ja bei mir stehen die Geräte auch doppelt drin.
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #993
                  @CKMartens:
                  npm ist 6.15
                  Server Ubuntu 18.05
                  gibt folgendes aus:
                  Felherlog:
                  Bin mit meinem Latein bisschen am Ende, vor allem da es ja auf dem "alten" System ohne Probleme lief. `
                  lesen kannst du aber schon oder ??
                    CKMartensC Offline
                    CKMartens
                    #994
                    Selten so freundliche Nachrichten gelesen
                    • L Offline
                      ltsalvatore
                      #995
                      @CKMartens:
                      Selten so freundliche Nachrichten gelesen `
                      :lol:
                        CKMartensC Offline
                        CKMartens
                        #996
                        @ltsalvatore:
                        @CKMartens:
                        :lol: `
                        Vieleicht sollte dann auch auf iobroker.net unter "Social support" stehen das nur Pros erwünscht sind und Anfänger lieber ein anderes System benutzen sollten :lol:
                          Arnulf
                          #997
                          ich glaube nicht, dass das böse gemeint war. Ich habe arteck eigentlich bisher sehr geduldig empfunden.
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #998
                            @CKMartens:
                            @ltsalvatore:
                            @CKMartens:
                            :lol: `
                            Vieleicht sollte dann auch auf iobroker.net unter "Social support" stehen das nur Pros erwünscht sind und Anfänger lieber ein anderes System benutzen sollten :lol: `
                            wow…momentmal ... was sollte ich dazu schreiben..
                            Sehr geehrter Herr xxx,
                            Sie wissen schon, dass die Informationen die hier angezeigt wurden
                            zur Ihrer Kenntniss in lesbarer Form vorliegen und Sie diese selbt auch als solche zur kenntniss nehmen sollten…
                            Mit freundlichen Grüssen
                            arteck
                            so besser...
                            falls du übersetzung Brauchst https://www.google.com/search?client=firefox-b-ab&ei=PLU9XPKwKoLLwAK-ra6YBQ&q=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&oq=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&gs_l=psy-ab.3...18575.18926..19966...0.0..0.117.218.0j2......0....1j2..gws-wiz.......0i71j0i131j0.f48KVg023LE
                            • L Offline
                              ltsalvatore
                              #999
                              @arteck:
                              @CKMartens:
                              @ltsalvatore:
                              :lol: `
                              arteck
                              so besser...
                              falls du übersetzung Brauchst https://www.google.com/search?client=firefox-b-ab&ei=PLU9XPKwKoLLwAK-ra6YBQ&q=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&oq=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&gs_l=psy-ab.3...18575.18926..19966...0.0..0.117.218.0j2......0....1j2..gws-wiz.......0i71j0i131j0.f48KVg023LE `
                              that's too formal
                              IT Crowd S01E02 :-D
                                CKMartensC Offline
                                CKMartens
                                #1000
                                @arteck:
                                @CKMartens:
                                @ltsalvatore:
                                :lol: `
                                arteck
                                so besser...
                                Wow… wir verhalten uns ja richtig erwachsen....
                                Aber danke, wenn Du meinen ersten Post richtig gelesen hättest, hab ich geschrieben das das Problem gelöst ist.
                                Noch ein schönes Leben
                                • Q Offline
                                  Q Offline
                                  Querbeet
                                  #1001
                                  Also ich finde, dass man nach 2600+ Posts auch mal nen schlechten Tag haben darf…
                                    Kueppert
                                    #1002
                                    Dito, arti ist immer hilfsbereit-auch zu mir, obwohl ich kein pro bin ;)
                                    Und ich habe die Äußerung von artek jetzt garnicht als böse interpretiert… Sei es drum.
                                    VG Thorsten
                                    Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                                    • F Offline
                                      Freaknet
                                      #1003
                                      Hi zusammen,
                                      Erstmal super Forum! Hab schon viel gelernt ;-)
                                      Ich hab mich jetzt auch durch den Thread durchgekämpft/gelesen um mein Problem ggf. selbst zu lösen, leider ohne Erfolg :-(
                                      Nutze den CC2531 Zigbee-USB-Stick in meinem Beelink als Coordinator mit iobroker und der Zigbee-Version 0.8.0.
                                      Ich habe auch schon erfolgreich 5 Xiaomi Temp. Sensoren und 2 als Router dienende Osram Smart+ Steckdosen einrichten können.
                                      Jetzt wollt ich noch eine Innr Lampe RS125 und eine RB162 einpflegen (die RS125 sollte ja funktionieren laut GitHub). Das erkennen funktioniert auch soweit, jedoch lassen sich die Lampe nicht steuern und sie werden nur als Device angezeigt ohne Switch und Link-Quality (in einem Ordner) wie es z.B. bei der Osram Smart+ Steckdose ist.
                                      Auch ein Bild von der Lampe wird nicht angezeigt.
                                      Vielleicht kann mir jemand weiterhelfen!? Danke im Voraus dafür!
                                      Freaknet
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #1004
                                        @Freaknet:
                                        Hi zusammen,
                                        Freaknet `
                                        viewtopic.php?f=24&t=18214
                                          AndrK
                                          #1005
                                          Hallo Leute,
                                          nachdem der Zigbee Adapter bei mir grundsätzlich läuft, würde ich sukzessive mein Hause mit mehr Zigbee Komponenten durchdringen. Im Blick sind hier meine konventionellen Lichtschalter. Ich plane nicht alle Leuchtmittel zu ersetzen, sonder Zigbee-fähige Lichtschalter einzubauen. Mein Ziel ist es das Licht über die neuen Lichtschalter zu schalten, als auch über ioBroker oder Alexa.
                                          Ich könnte zwar die vorhandenen Lichtschalter nehmen und dahinter Shellys klemmen, aber ein Touch- oder Berührungsloser Schalter wäre auch was feines.
                                          Bewegungsmelder sind eher unpraktisch in Wohn- oder Arbeitszimmer, aber für Dielen gut geeignet.
                                          Habt Ihr Ideen, Erfahrungen oder gar Produkte, die bereits funktionieren.
                                          Ciao und vielen Dank im Voraus.
                                          Andreas
                                          PS: An dieser Stelle auch vielen Dank an die Gurus hier, die uns Neulinge die Baisc-Fragen beantworten und/oder dieses Projekt hier nach vorne bringen. ….. ich meine das ioBroker ZigBee CC253x Adapter Projekt. .... ohne Euch hätten wir 2-3 Bridges zu Hause!
