  4. [Aufruf] ZigBee CC253x Adapter
1.1k Beiträge 131 Kommentatoren 488.6k Aufrufe 7 Beobachtet
    Arnulf
    #990
    @besterquester:
    ja da steht was drinnen.
    {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018e1b318","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1547487414,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterLi$
    {"$indexCreated":{"fieldName":"id","unique":true,"sparse":false}}
    {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018e1b318","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1547487432,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterLi$
    {"id":2,"type":"EndDevice","ieeeAddr":"0x00158d0002c586d2","nwkAddr":15146,"manufId":4151,"epList":[1],"status":"online","joinTime":1547488316,"endpoints":{"1":{"profId":260,"epId":1,"devId":263,"inClusterList"$
    {"id":2,"type":"EndDevice","ieeeAddr":"0x00158d0002c586d2","nwkAddr":15146,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sensor_motion.aq2","epList":[1],"status":"online","joinTime":$
    {"id":3,"type":"EndDevice","ieeeAddr":"0x00158d00025583c8","nwkAddr":34269,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488696,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":3,"type":"EndDevice","ieeeAddr":"0x00158d00025583c8","nwkAddr":34269,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748869$
    {"id":4,"type":"EndDevice","ieeeAddr":"0x00158d00023ac6dc","nwkAddr":9281,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488789,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluster$
    {"id":4,"type":"EndDevice","ieeeAddr":"0x00158d00023ac6dc","nwkAddr":9281,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":1547488789$
    {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d00025583a5","nwkAddr":65210,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488879,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d00025583a5","nwkAddr":65210,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748887$
    {"id":6,"type":"EndDevice","ieeeAddr":"0x00158d0002b5a2f0","nwkAddr":33900,"manufId":4151,"epList":[1,2,3],"status":"online","joinTime":1547488967,"endpoints":{"1":{"profId":260,"epId":1,"devId":24321,"inCluste$
    {"id":6,"type":"EndDevice","ieeeAddr":"0x00158d0002b5a2f0","nwkAddr":33900,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sens","epList":[1,2,3],"status":"online","joinTime":154748896$
    Ich habe die Temp neu angelernt die Bewegungsmelder hängen an der Wand. Die zeigen immer noch not conected an
    g Bester `
    Bei dir stehem die IDs ja noch öfter drin als bei mir. Bei mir ist das "nur" zweimal
    • besterquesterB Offline
      besterquester
      #991
      @Arnulf:
      @besterquester:
      g Bester `
      Bei dir stehem die IDs ja noch öfter drin als bei mir. Bei mir ist das "nur" zweimal `
      Hat jemand schon versucht die doppelten zu löschen was passiert dann -> neu paaren :)
      • arteckA Offline
        arteckA Offline
        arteck
        #992
        Leute wenn ihr nicht wisst was ihr macht dann lasst es..
        ja bei mir stehen die Geräte auch doppelt drin.
        • arteckA Offline
          arteckA Offline
          arteck
          #993
          @CKMartens:
          Das Problem ist gelöst.
          Für bluez muste ich den Befehl
          setcap cap_net_raw+eip $(eval readlink -f which node)
          eingeben danach wurde auch der Zigbee Adapter grün
          Ich bin gerade etwas am Verzweifeln. Nachdem ich heute meinen Server neu aufsetzen musste und iobroker neu instaliert habe bekomme ich den Zigbee nicht mehr zum laufen.
          node und nodejs sind v8.15.0
          npm ist 6.15
          zigbee Adapter ist 0.8.2a von github.com
          Server Ubuntu 18.05
          ls -la /dev/serial/by-id
          gibt folgendes aus:
          lrwxrwxrwx 1 root root 13 Jan 14 19:18 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED2570-if00 -> ../../ttyACM0
          Felherlog:
          zigbee.0 2019-01-14 19:37:34.705 debug User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1547491054701,"q":0,"from":"system.adapter.zigbee.0","lc":1547490902187}
          zigbee.0 2019-01-14 19:37:34.113 error Error while starting zigbee-shepherd!. Error: Error: Permission denied, cannot open /dev/ttyACM0
          zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.109Z zigbee:controller error Error while starting zigbee-shepherd! Error: Error: Permission denied, cannot open /dev/ttyACM0
          zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.106Z zigbee-shepherd:init zigbee-shepherd booting...
          zigbee.0 2019-01-14 19:37:34.113 info Starting zigbee-shepherd
          zigbee.0 2019-01-14 19:37:34.113 debug 2019-01-14T18:37:34.105Z zigbee:controller info Starting zigbee-shepherd undefined
          zigbee.0 2019-01-14 19:36:34.105 debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds)
          zigbee.0 2019-01-14 19:36:34.104 debug 2019-01-14T18:36:34.104Z zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds) undefined
          zigbee.0 2019-01-14 19:36:34.085 debug 2019-01-14T18:36:34.085Z zigbee-shepherd:init zigbee-shepherd booting...
          zigbee.0 2019-01-14 19:36:34.069 info Start on port: /dev/ttyACM0 with panID 6754 channel 11
          zigbee.0 2019-01-14 19:36:34.066 info starting. Version 0.8.2-a in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.0
          Bin mit meinem Latein bisschen am Ende, vor allem da es ja auf dem "alten" System ohne Probleme lief. `
          lesen kannst du aber schon oder ??
          • CKMartensC Offline
            CKMartensC Offline
            CKMartens
            #994
            Selten so freundliche Nachrichten gelesen
            • L Offline
              ltsalvatore
              #995
              @CKMartens:
              Selten so freundliche Nachrichten gelesen `
              :lol:
                CKMartensC Offline
                CKMartens
                #996
                @ltsalvatore:
                @CKMartens:
                :lol: `
                Vieleicht sollte dann auch auf iobroker.net unter "Social support" stehen das nur Pros erwünscht sind und Anfänger lieber ein anderes System benutzen sollten :lol:
                  Arnulf
                  #997
                  ich glaube nicht, dass das böse gemeint war. Ich habe arteck eigentlich bisher sehr geduldig empfunden.
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    #998
                    @CKMartens:
                    @ltsalvatore:
                    @CKMartens:
                    :lol: `
                    Vieleicht sollte dann auch auf iobroker.net unter "Social support" stehen das nur Pros erwünscht sind und Anfänger lieber ein anderes System benutzen sollten :lol: `
                    wow…momentmal ... was sollte ich dazu schreiben..
                    Sehr geehrter Herr xxx,
                    Sie wissen schon, dass die Informationen die hier angezeigt wurden
                    zur Ihrer Kenntniss in lesbarer Form vorliegen und Sie diese selbt auch als solche zur kenntniss nehmen sollten…
                    Mit freundlichen Grüssen
                    arteck
                    so besser...
                    falls du übersetzung Brauchst https://www.google.com/search?client=firefox-b-ab&ei=PLU9XPKwKoLLwAK-ra6YBQ&q=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&oq=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&gs_l=psy-ab.3...18575.18926..19966...0.0..0.117.218.0j2......0....1j2..gws-wiz.......0i71j0i131j0.f48KVg023LE
                    • L Offline
                      ltsalvatore
                      #999
                      @arteck:
                      @CKMartens:
                      @ltsalvatore:
                      :lol: `
                      arteck
                      so besser...
                      falls du übersetzung Brauchst https://www.google.com/search?client=firefox-b-ab&ei=PLU9XPKwKoLLwAK-ra6YBQ&q=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&oq=%C3%BCbersetzer+Error%3A+Permission+denied%2C+cannot+open+%2Fdev%2FttyACM0&gs_l=psy-ab.3...18575.18926..19966...0.0..0.117.218.0j2......0....1j2..gws-wiz.......0i71j0i131j0.f48KVg023LE `
                      that's too formal
                      IT Crowd S01E02 :-D
                        CKMartensC Offline
                        CKMartens
                        #1000
                        @arteck:
                        @CKMartens:
                        @ltsalvatore:
                        :lol: `
                        arteck
                        so besser...
                        Wow… wir verhalten uns ja richtig erwachsen....
                        Aber danke, wenn Du meinen ersten Post richtig gelesen hättest, hab ich geschrieben das das Problem gelöst ist.
                        Noch ein schönes Leben
                        • Q Offline
                          Q Offline
                          Querbeet
                          #1001
                          Also ich finde, dass man nach 2600+ Posts auch mal nen schlechten Tag haben darf…
                            Kueppert
                            #1002
                            Dito, arti ist immer hilfsbereit-auch zu mir, obwohl ich kein pro bin ;)
                            Und ich habe die Äußerung von artek jetzt garnicht als böse interpretiert… Sei es drum.
                            VG Thorsten
                            Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                            • F Offline
                              Freaknet
                              #1003
                              Hi zusammen,
                              Erstmal super Forum! Hab schon viel gelernt ;-)
                              Ich hab mich jetzt auch durch den Thread durchgekämpft/gelesen um mein Problem ggf. selbst zu lösen, leider ohne Erfolg :-(
                              Nutze den CC2531 Zigbee-USB-Stick in meinem Beelink als Coordinator mit iobroker und der Zigbee-Version 0.8.0.
                              Ich habe auch schon erfolgreich 5 Xiaomi Temp. Sensoren und 2 als Router dienende Osram Smart+ Steckdosen einrichten können.
                              Jetzt wollt ich noch eine Innr Lampe RS125 und eine RB162 einpflegen (die RS125 sollte ja funktionieren laut GitHub). Das erkennen funktioniert auch soweit, jedoch lassen sich die Lampe nicht steuern und sie werden nur als Device angezeigt ohne Switch und Link-Quality (in einem Ordner) wie es z.B. bei der Osram Smart+ Steckdose ist.
                              Auch ein Bild von der Lampe wird nicht angezeigt.
                              Vielleicht kann mir jemand weiterhelfen!? Danke im Voraus dafür!
                              Freaknet
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #1004
                                @Freaknet:
                                Hi zusammen,
                                Freaknet `
                                viewtopic.php?f=24&t=18214
                                  AndrK
                                  #1005
                                  Hallo Leute,
                                  nachdem der Zigbee Adapter bei mir grundsätzlich läuft, würde ich sukzessive mein Hause mit mehr Zigbee Komponenten durchdringen. Im Blick sind hier meine konventionellen Lichtschalter. Ich plane nicht alle Leuchtmittel zu ersetzen, sonder Zigbee-fähige Lichtschalter einzubauen. Mein Ziel ist es das Licht über die neuen Lichtschalter zu schalten, als auch über ioBroker oder Alexa.
                                  Ich könnte zwar die vorhandenen Lichtschalter nehmen und dahinter Shellys klemmen, aber ein Touch- oder Berührungsloser Schalter wäre auch was feines.
                                  Bewegungsmelder sind eher unpraktisch in Wohn- oder Arbeitszimmer, aber für Dielen gut geeignet.
                                  Habt Ihr Ideen, Erfahrungen oder gar Produkte, die bereits funktionieren.
                                  Ciao und vielen Dank im Voraus.
                                  Andreas
                                  PS: An dieser Stelle auch vielen Dank an die Gurus hier, die uns Neulinge die Baisc-Fragen beantworten und/oder dieses Projekt hier nach vorne bringen. ….. ich meine das ioBroker ZigBee CC253x Adapter Projekt. .... ohne Euch hätten wir 2-3 Bridges zu Hause!
                                  • E Offline
                                    eMd
                                    #1006
                                    ich habe einen aqara fensterkontakt im DG installiert der leider keinen Empfang zum Stick hat. Nun habe ich eine Osram plug im EG angelernt und im OG anschließend in eine Dose gesteckt, aber sie bekommt keine Verbindung… Der etwas weiter entfernte fensterkontakt im gleichen Raum funktioniert einwandfrei. Mache ich iwas falsch?
                                    MfG
                                    eMd
                                    Master: Intel NUC 16GB/500GB
                                    Slave: Raspberry Pi 3 + Homematicmodul
                                    Shelly, Google Home, Zigbee Aqara, Sonoff
                                    Meine VIS: https://youtu.be/JMYr2KYlpME
                                    • ? Offline
                                      #1007
                                      @modmax:
                                      Einige Lampen versuchen sich selbstständig zu pairen. Klappt auch, wenn man Sie schon mal am angelernt waren.
                                      Die Geräte verschwinden dann zwar aus der shepherd.db, wohl aber nicht aus dem Stick/Router selber;
                                      solange man den nicht neu flasht.
                                      Lösung war bei mir daher immer:
                                      1.) Die zu entfernete Lampe/Plug vom Strom nehmen
                                      2.) DIe Lampe aus dem Adapter löschen; nach ca. 10 Sekunden erscheint ne Fehlermeldung, wegen keine COnnection wird dann aber doch gelöscht
                                      3.) Zigbee-Adapter stoppen
                                      4.) Lampe zurüpcksetzen und an andwerem Gateway anlernen (Hue/Osram/Tradfri)
                                      5.) Zigbee-Adapter wieder starten; wenn dann das Gerät als "undefined" wieder auftaucht dann nun einfgach nochmal löschen
                                      MfG Markus `
                                      Kurzes Update!
                                      die obige Lösung hat bei mir nicht funktioniert, da die Ikea Lampen nicht resettet werden konnten. In einem Forum habe ich eine Lösung für dieses Problem gefunden.
                                      Man benötigt einen Hue Dimmer. In 5 cm Abstand zur Lampe gleichzeitig An- und Aus drücken. Nach 10 Sekunden sind die Lampen resettet und können nun wieder angelernt werden. Hat bei mir Super funktioniert.
                                        AndrK
                                        #1008
                                        Hallo Leute,
                                        …. etwas Frust macht sich breit.
                                        Ein einfachstes Szenario funktioniert nicht mehr.
                                        • CC253x Adater
                                        • Osram Plug
                                        • Tradfri Blub E27 W opal 1000l
                                          in der Netzwerkkarte waren sie auch in dieser Reihenfolge miteinander verbunden. Hatte gut funktioniert.
                                        Heute Mittag hat mein Frauchen den Plug rausgezogen und die Lampe (Stehlampe ausgeschaltet). Ich Plug wieder rein, der war sofort wieder OK, aber die Lampe verbindet sich nicht mehr. Weder mit dem Plug, noch mit dem Coordinator. Auch nicht, als ich die Stehlampe direkt neben den Raspi gestellt habe.
                                        Als nicht mehr funktioniert hat, habe ich die Blub gelöscht, zurückgesetzt und neu gepairt. Das hat funktioniert und war danach direkt mit dem Coordinator verbunden.
                                        Lampe wieder ein Stockwerk runtergetragen, eingesteckt. Nichts! In der Netzwerkkarte ist er mit "0" mit dem Coordinator verbunden, mit dem Plug verbindet er sich nicht, obwohl dieser zwischen Raspi und Lampe ist.
                                        Lampe wieder hochgetragen, neben den Raspi gestellt. Nichts! Netzwerkkarte ist er mit "0" mit dem Coordinator verbunden.
                                        Klar, habe ich Adapter gestoppt, gestartet, alles incl. Raspi gebootet.
                                        Kann ich den Adapter nochmals komplett neu Aufsetzen?
                                        Ciao und danke für Eure Hilfe
                                        Andreas
                                        • C Offline
                                          CrazyCreator
                                          #1009
                                          Ich denke meine Frage ist ein bisschen OffTopic. da es hier ja eigentlich um den CC253 geht.
                                          Aber vielleicht kann mir ja trotzdem jemand helfen.
                                          Ich habe mir zum testen eine Aquara Switch bestellt, der auch ohne Probleme in meinem Testaufbau funktioniert.
                                          Soweit so gut. Jetzt würde ich mir damit gerne die komplette Wohnung ausstatten, finde aber leider keine
                                          passende Hohlraumdose für diese Art von Schalter, da die ja hinten viereckig sind und nicht in unsere deutschen runden
                                          Standard-Hohlraumdosen passen. Hat da jemand schon was gefunden bzw. verbaut?
                                          Es geht um diese Art von Schaltern:
