  4. Absturz in fhem Adapter
49 Beiträge 2 Kommentatoren 4.4k Aufrufe
    aski71
    Das hier ist der debug Output:
    fhem.0	2018-12-30 13:33:35.813	info	[debug] check finished!!!
    fhem.0	2018-12-30 13:33:35.813	info	[debug] >> state = off -> fhem.0.Wecker.state = off | type: string | read: true | role: state | Funktion: switch
    fhem.0	2018-12-30 13:33:35.813	info	[debug] >> state = off -> fhem.0.Wecker.state_switch = false | type: boolean | read: true | write: true | role: switch | Funktion: switch
    fhem.0	2018-12-30 13:33:35.812	info	[debug] >> sonosSZenabled = 0 -> fhem.0.Wecker.sonosSZenabled = 0 | type: number | read: true | role: value | Funktion: no
    fhem.0	2018-12-30 13:33:35.812	warn	| included in fhem.x.info.Config.ignorePossibleSets
    fhem.0	2018-12-30 13:33:35.812	warn	}
    fhem.0	2018-12-30 13:33:35.812	warn	'localtime' => 'W124/T05:50:00'
    fhem.0	2018-12-30 13:33:35.812	warn	'description' => 'L_04_A9Aeu_start wake up',
    fhem.0	2018-12-30 13:33:35.812	warn	'time' => 'W124/T04:50:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'created' => '2018-11-05T05:49:50',
    fhem.0	2018-12-30 13:33:35.812	warn	},
    fhem.0	2018-12-30 13:33:35.812	warn	'address' => '/api/<xyz>/sensors/4/state'
    fhem.0	2018-12-30 13:33:35.812	warn	'flag' => $VAR1->{'1'}{'recycle'}
    fhem.0	2018-12-30 13:33:35.812	warn	'body' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'method' => 'PUT',
    fhem.0	2018-12-30 13:33:35.812	warn	'command' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'name' => "Nat\x{fc}rlich Aufwachen Elke",
    fhem.0	2018-12-30 13:33:35.812	warn	'recycle' => $VAR1->{'1'}{'recycle'},
    fhem.0	2018-12-30 13:33:35.812	warn	'status' => 'disabled',
    fhem.0	2018-12-30 13:33:35.812	warn	'2' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'created' => '2018-11-07T23:03:18'
    fhem.0	2018-12-30 13:33:35.812	warn	'address' => '/api/<xyz>/sensors/5/state',
    fhem.0	2018-12-30 13:33:35.812	warn	'time' => 'W124/T05:29:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'name' => "Nat\x{fc}rlich Aufwachen Alex",
    fhem.0	2018-12-30 13:33:35.812	warn	'localtime' => 'W124/T06:29:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'description' => 'L_04_njqbA_start wake up',
    fhem.0	2018-12-30 13:33:35.812	warn	'4' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'scene' => 'V080xDoezs6QZjg'
    fhem.0	2018-12-30 13:33:35.812	warn	'address' => '/api/<xyz>/groups/0/action',
    fhem.0	2018-12-30 13:33:35.812	warn	'time' => 'PT00:01:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'starttime' => '2018-12-27T04:50:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'name' => 'L_04_A9Aeu',
    fhem.0	2018-12-30 13:33:35.812	warn	'localtime' => 'PT00:01:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'autodelete' => $VAR1->{'1'}{'autodelete'},
    fhem.0	2018-12-30 13:33:35.812	warn	'description' => 'L_04_A9Aeu_trigger end scene',
    fhem.0	2018-12-30 13:33:35.812	warn	'3' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'name' => 'L_04_njqbA'
    fhem.0	2018-12-30 13:33:35.812	warn	'starttime' => '2018-12-27T05:29:00',
    fhem.0	2018-12-30 13:33:35.812	warn	'created' => '2018-11-07T23:03:18',
    fhem.0	2018-12-30 13:33:35.812	warn	'scene' => 'rG7qkF-1HZ8nT9W'
    fhem.0	2018-12-30 13:33:35.812	warn	'description' => 'L_04_njqbA_trigger end scene',
    fhem.0	2018-12-30 13:33:35.812	warn	'5' => {
    fhem.0	2018-12-30 13:33:35.812	warn	'status' => 0
    fhem.0	2018-12-30 13:33:35.812	warn	'address' => '/api/<xyz>/sensors/3/state',
    fhem.0	2018-12-30 13:33:35.812	warn	'created' => '2018-12-17T14:41:39',
    fhem.0	2018-12-30 13:33:35.812	warn	'time' => 'PT00:00:10',
    fhem.0	2018-12-30 13:33:35.812	warn	'starttime' => '2018-12-17T14:41:39',
    fhem.0	2018-12-30 13:33:35.812	warn	'name' => 'Dimmer Switch 2 Reset',
    fhem.0	2018-12-30 13:33:35.812	warn	'recycle' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
    fhem.0	2018-12-30 13:33:35.812	warn	'autodelete' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' ),
    fhem.0	2018-12-30 13:33:35.812	warn	'localtime' => 'PT00:00:10',
    fhem.0	2018-12-30 13:33:35.812	warn	'description' => 'Resets dimmer switch scene cycler',
    fhem.0	2018-12-30 13:33:35.812	warn	'1' => {
    fhem.0	2018-12-30 13:33:35.812	warn	[debug] >> hueSchedulesList = {
    fhem.0	2018-12-30 13:33:35.811	warn	| included in fhem.x.info.Config.ignorePossibleSets
    fhem.0	2018-12-30 13:33:35.811	warn	]
    fhem.0	2018-12-30 13:33:35.811	warn	}
    fhem.0	2018-12-30 13:33:35.811	warn	'/schedules/2/status' => 'disabled'
    fhem.0	2018-12-30 13:33:35.811	warn	'success' => {
    fhem.0	2018-12-30 13:33:35.811	warn	{
    fhem.0	2018-12-30 13:33:35.811	warn	[debug] >> hueElkeLichtWeckerReturn = [
    fhem.0	2018-12-30 13:33:35.811	info	[debug] >> hueElkeLichtWecker = disabled -> fhem.0.Wecker.hueElkeLichtWecker = disabled | type: string | read: true | role: text | Funktion: no
    fhem.0	2018-12-30 13:33:35.811	warn	'/schedules/4/status' => 'disabled'
    fhem.0	2018-12-30 13:33:35.811	warn	[debug] >> hueAlexLichtWeckerReturn = [
    fhem.0	2018-12-30 13:33:35.810	info	[debug] >> hueAlexLichtWecker = disabled -> fhem.0.Wecker.hueAlexLichtWecker = disabled | type: string | read: true | role: text | Funktion: no
    fhem.0	2018-12-30 13:33:35.803	info	[debug] > check Readings
    fhem.0	2018-12-30 13:33:35.802	info	[debug] >> mixed = noArg -> fhem.0.Wecker.mixed | type: boolean | write: true | role: button | min: undefined | max: undefined | unit: undefined | states: undefined
    fhem.0	2018-12-30 13:33:35.802	info	[debug] >> off = noArg -> fhem.0.Wecker.off | type: boolean | write: true | role: button | min: undefined | max: undefined | unit: undefined | states: undefined
    fhem.0	2018-12-30 13:33:35.802	info	[debug] >> on = noArg -> fhem.0.Wecker.on | type: boolean | write: true | role: button | min: undefined | max: undefined | unit: undefined | states: undefined
    fhem.0	2018-12-30 13:33:35.801	info	[debug] > check PossibleSets
    fhem.0	2018-12-30 13:33:35.801	info	[debug] >> TYPE = dummy -> fhem.0.Wecker.Internals.TYPE = dummy | type: string | read: true | role: text
    fhem.0	2018-12-30 13:33:35.801	warn	[debug] >> STATE = off | not included in fhem.x.info.Config.allowedInternals
    fhem.0	2018-12-30 13:33:35.800	warn	[debug] >> NR = 307 | not included in fhem.x.info.Config.allowedInternals
    fhem.0	2018-12-30 13:33:35.800	info	[debug] >> NAME = Wecker -> fhem.0.Wecker.Internals.NAME = Wecker | type: string | read: true | role: text
    fhem.0	2018-12-30 13:33:35.800	warn	[debug] >> CHANGED = null | not included in fhem.x.info.Config.allowedInternals
    fhem.0	2018-12-30 13:33:35.799	info	[debug] > check Internals
    fhem.0	2018-12-30 13:33:35.799	warn	[debug] >> setList = on:noArg off:noArg mixed:noArg | not included in fhem.x.info.Config.allowedAttributes
    fhem.0	2018-12-30 13:33:35.799	info	[debug] >> room = Schlafzimmer -> fhem.0.Wecker.Attributes.room = Schlafzimmer | type: string | read: true | write: true | role: text
    fhem.0	2018-12-30 13:33:35.798	warn	[debug] >> fp_Home3D = 137,937,5,Wecker, | not included in fhem.x.info.Config.allowedAttributes
    fhem.0	2018-12-30 13:33:35.798	warn	[debug] >> event-on-change-reading = state | not included in fhem.x.info.Config.allowedAttributes
    fhem.0	2018-12-30 13:33:35.797	warn	[debug] >> devStateIcon = on:ring@green off:ring@red mixed:ring@yellow | not included in fhem.x.info.Config.allowedAttributes
    fhem.0	2018-12-30 13:33:35.797	info	[debug] >> alias = Wecker -> fhem.0.Wecker.Attributes.alias = Wecker | type: string | read: true | write: true | role: text
    fhem.0	2018-12-30 13:33:35.797	info	[debug] > check Attributes
    fhem.0	2018-12-30 13:33:35.796	info	[debug] check FHEM Device: Wecker</xyz></xyz></xyz></xyz></xyz>
    • LausiDL Offline
      LausiDL Offline
      LausiD
      Laut dem Log werden die Readings ignoriert…alles was bei debug warn=rot ist wird nicht synchronisiert.
      Muss aber den Text von "included in fhem.x.info.Config.ignorePossibleSets" auf "included in fhem.x.info.Config.ignoreReadings" noch ändern
      Wenn du Objekt Wecker komplett gelöscht hast kommen nach Neustart alle Readings wieder?
      Doku zum FHEM Adapter
      Aktuelles zum FHEM Adapter
      Test FHEM Adapter
        aski71
        Im Moment kommen sie gar nicht, weil ich ja event-on-change-reading auf state gesetzt habe.
        Müsste ich bei Gelegenheit nochmal ausprobieren, das Objekt Wecker zu löschen und neu anlegen zu lassen.
          aski71
          So. Eben nochmal ausprobiert:
          event-on-change-reading Attribut gelöscht.
          Objekt Wecker in iobroker gelöscht.
          fhem Adapter in iobroker neu gestartet.
          Effekt:
          Wecker Objekt wird erzeugt, ohne die Readings aus ignoreReadings. -> Prima.
          Bei Statuschange des Wecker-Objekts in fhem: Trotzdem Absturz des Adapters. -> Nicht prima. ;)
          • LausiDL Offline
            LausiDL Offline
            LausiD
            Habe paar Sachen im Adapter geändert….
            Mach mal nochmal update über github und teste erneut
            Test FHEM Adapter
              aski71
              Leider keine Änderung, wenn ich das event-on-change-reading rausnehme:
              host.homie	2018-12-30 18:11:17.525	error	instance system.adapter.fhem.0 terminated with code 0 (OK)
              Caught	2018-12-30 18:11:17.525	error	by controller[0]: at Socket.Readable.push (_stream_readable.js:208:10)
              Caught	2018-12-30 18:11:17.525	error	by controller[0]: at readableAddChunk (_stream_readable.js:250:11)
              Caught	2018-12-30 18:11:17.525	error	by controller[0]: at addChunk (_stream_readable.js:263:12)
              Caught	2018-12-30 18:11:17.525	error	by controller[0]: at Socket.emit (events.js:211:7)
              Caught	2018-12-30 18:11:17.525	error	by controller[0]: at emitOne (events.js:116:13)
              Caught	2018-12-30 18:11:17.524	error	by controller[0]: at Socket.telnetSocket.on.data (/opt/iobroker/node_modules/iobroker.fhem/lib/telnet.js:97:30)
              Caught	2018-12-30 18:11:17.524	error	by controller[0]: at Telnet.emit (events.js:211:7)
              Caught	2018-12-30 18:11:17.524	error	by controller[0]: at emitOne (events.js:116:13)
              Caught	2018-12-30 18:11:17.519	error	by controller[0]: at Telnet.telnetIn.on.data (/opt/iobroker/node_modules/iobroker.fhem/main.js:2145:33)
              Caught	2018-12-30 18:11:17.519	error	by controller[0]: at parseEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:212:25)
              Caught	2018-12-30 18:11:17.518	error	by controller[0]: 2018-12-30 18:11:17.353 - error: fhem.0 TypeError: Cannot read property 'replace' of undefined
              Caught	2018-12-30 18:11:17.518	error	by controller[0]: 2018-12-30 18:11:17.353 - fhem.0 uncaught exception: Cannot read property 'replace' of undefined
              Caught	2018-12-30 18:11:17.518	error	by controller[0]: at Socket.Readable.push (_stream_readable.js:208:10)
              Caught	2018-12-30 18:11:17.518	error	by controller[0]: at readableAddChunk (_stream_readable.js:250:11)
              Caught	2018-12-30 18:11:17.517	error	by controller[0]: at addChunk (_stream_readable.js:263:12)
              Caught	2018-12-30 18:11:17.516	error	by controller[0]: at Socket.emit (events.js:211:7)
              Caught	2018-12-30 18:11:17.516	error	by controller[0]: at emitOne (events.js:116:13)
              Caught	2018-12-30 18:11:17.516	error	by controller[0]: at Socket.telnetSocket.on.data (/opt/iobroker/node_modules/iobroker.fhem/lib/telnet.js:97:30)
              Caught	2018-12-30 18:11:17.516	error	by controller[0]: at Telnet.emit (events.js:211:7)
              Caught	2018-12-30 18:11:17.515	error	by controller[0]: at Telnet.telnetIn.on.data (/opt/iobroker/node_modules/iobroker.fhem/main.js:2145:33)
              Caught	2018-12-30 18:11:17.515	error	by controller[0]: at parseEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:212:25)
              Caught	2018-12-30 18:11:17.514	error	by controller[0]: TypeError: Cannot read property 'replace' of undefined
              fhem.0	2018-12-30 18:11:17.353	error	at Socket.Readable.push (_stream_readable.js:208:10)
              fhem.0	2018-12-30 18:11:17.353	error	at readableAddChunk (_stream_readable.js:250:11)
              fhem.0	2018-12-30 18:11:17.353	error	at addChunk (_stream_readable.js:263:12)
              fhem.0	2018-12-30 18:11:17.353	error	at Socket.emit (events.js:211:7)
              fhem.0	2018-12-30 18:11:17.353	error	at emitOne (events.js:116:13)
              fhem.0	2018-12-30 18:11:17.353	error	at Socket.telnetSocket.on.data (/opt/iobroker/node_modules/iobroker.fhem/lib/telnet.js:97:30)
              fhem.0	2018-12-30 18:11:17.353	error	at Telnet.emit (events.js:211:7)
              fhem.0	2018-12-30 18:11:17.353	error	at Telnet.telnetIn.on.data (/opt/iobroker/node_modules/iobroker.fhem/main.js:2145:33)
              fhem.0	2018-12-30 18:11:17.353	error	at parseEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:212:25)
              fhem.0	2018-12-30 18:11:17.353	error	TypeError: Cannot read property 'replace' of undefined
              fhem.0	2018-12-30 18:11:17.353	error	uncaught exception: Cannot read property 'replace' of undefined
              • LausiDL Offline
                LausiDL Offline
                LausiD
                Neuer Versuch :-)
                Update github und Test
                Kannst du eigentlich aus den Readings "\n" in FHEM entfernen?
                Test FHEM Adapter
                  aski71
                  Jetzt stürzt er nicht mehr ab, sondern wirft jede Menge Meldungen aus, was er alles ignoriert. :D
                  Ich wüsste nicht, wie ich irgendwelche "\n" entferne.
                  Die kommen vermutlich durch den json Dumper rein. Den wiederum hab ich gebraucht, dass überhaupt was lesbares rauskommt. Sonst steht da nur ein Hash ohne Daten.
                  • LausiDL Offline
                    LausiDL Offline
                    LausiD
                    Ok Meldungen sind auf github wieder raus :-)
                    Test FHEM Adapter
                    • LausiDL Offline
                      LausiDL Offline
                      LausiD
                      Hallo Alex,
                      nach langer Suche ist dies die einzige Möglichkeit die "eigenen" Readings aus Script an ioBroker übertragen.
                      Mit zB "$niceHash1=~ s/\n//g;" wird \n=Zeilenumbruch entfernt.
                      \n in deinen Readings macht schon bei der Übertragung mit telnet jeweils eine einzelne Zeile, deshalb auch im Log ioBroker mehere Zeilen des Event state.
                      LausiD
                      Test FHEM Adapter
                        aski71
                        Hi LausiD,
                        danke für den Tipp. Das funktioniert auch.
                        Einzige Downside ist, dass es natürlich mit den \n in fhem für's Auge schöner lesbar war.
                        Das kann man aber verkraften.
                        In diesem Sinne: High five! War eine schöne produktive Zusammenarbeit. :-)
                        Guten Rutsch und auf ein fantastisches 2019!
                        Gruß Alex
