  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    @Chaot:
    alten Adapter deinstalliert, neuen "versucht"
    Wie gehabt:
    host.haus	2018-12-21 12:51:02.140	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    javascript.0	2018-12-21 12:50:03.136	error	script.js.Wandtablet.Laden2: Fehler request: Error: connect EHOSTUNREACH 192.168.8.225:2323
    host.haus	2018-12-21 12:50:03.090	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
    host.haus	2018-12-21 12:50:00.089	info	instance system.adapter.tvspielfilm.0 started with pid 4299
    host.haus	2018-12-21 12:50:00.053	info	instance system.adapter.dwd.0 started with pid 4294
    host.haus	2018-12-21 12:49:50.215	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    iobroker	2018-12-21 12:49:49.929	info	exit 0
    iobroker	2018-12-21 12:49:49.906	error	Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    iobroker	2018-12-21 12:49:49.808	info
    iobroker	2018-12-21 12:49:49.806	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    iobroker	2018-12-21 12:49:49.804	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
    iobroker	2018-12-21 12:49:49.803	info	svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0
    iobroker	2018-12-21 12:49:49.801	info	npm WARN
    iobroker	2018-12-21 12:48:30.197	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    iobroker	2018-12-21 12:48:29.584	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
    iobroker	2018-12-21 12:48:29.096	info	url "https://github.com/arteck/iobroker.fullyBrowser"
    Fehlermeldung bei der Installation:
    $ ./iobroker url "https://github.com/arteck/iobroker.fullyBrowser"
    npm
     WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm
     WARN
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    ERROR: Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    process exited with code 0
    du musst über die Katze gehen… da ist noch ein Fehler in den benamsung..
    https://github.com/arteck/iobroker.fullybrowser
    bei dir ist da B vom Browser gross geschrieben... das ist falsch
    • ChaotC Offline
      ChaotC Offline
      Chaot
      Oh, ok.
      Ich hatte den Link nicht mehr und habe den dann aus dem ersten Beitrag genommen. :oops:
        darqzero
        Tausend Dank für diesen Adapter. Ich bin da gerade zufällig drauf gestoßen. Da ich gerade ein Dashboard realisiere, was per Tablet im Flur hängt, kommt das wie gerufen.
        • JB_SullivanJ Offline
          JB_Sullivan
          Wieder mal eine doofe Frage von mir - müssten bei "Button" nicht am Ende der Tabelle diese "Nupsis" sein die wie ein Kingelknopf oder eine "Ti..e" aussehen, mit denen man direkt die Schaltung auslösen kann?
          Bei mir ist da nix
          https://www.dropbox.com/s/d70zna2051hj6 … r.png?dl=0
          • ChaotC Offline
            ChaotC Offline
            Chaot
            Mit welchem Browser`
            Bei mir in Chrome und in Firefox sind die Knöpfe vorhanden.
            Edit: Fehler gefunden:
            Mach mal die Expertenansicht aus. Dann sind die Knöpfe sichtbar!
              JB_Sullivan
              AH - jetzt JA - wieder was gelernt - DANKE SCHÖN !!!
                tempestas
                Beim Auslesen der Batterie scheint es einen Effekt zu geben, dass der State zwischenzeitlich ganz kurz auf "null" gesetzt wird.
                Mein Tablet-Ladeskript schaltet daher ständig an und aus, zuletzt 160 Mal binnen knapp 3 Stunden. Habs jetzt also wieder ausgeschaltet, das hält ja keine Steckdose aus.
                Das Skript selbst hatte ich zuvor mit PAW betrieben, nur den Datenpunkt verändert.
                <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
                • WebrangerW Offline
                  WebrangerW Offline
                  Webranger
                  Das gleiche hab ich auch festgestellt bei mir und konnte es mir nicht erklären.
                  Bin daher erst mal zum Script zurück.
                  Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                    tempestas
                    #66
                    Wird auch von weiteren Usern bestätigt. Siehe "einfach Mal zeigen will" Thread
                    • N Offline
                      N Offline
                      nousefor82
                      #67
                      auch bei mir das gleiche. Dadurch wurde der DutyCycle auf 99% gepuscht.
                      Dachte schon, das liegt an meinem Skript.
                      • G Offline
                        Georgius
                        #68
                        Dann würde ich einfach <20 und >0 abfragen. Wenn der Skript funktioniert sollte der Akku ja nie unter 15 kommen (eigentlich nie unter 20)
                        (20% Akkustand hab ich als Untergrenze angenommen)
                        • ChaotC Offline
                          ChaotC Offline
                          Chaot
                          #69
                          Nö, das scheint irgendwas am Abfrageintervall zu sein.
                          Wenn ich direkt den Wert abfrage:
                          var request = require('request');
                          var link = "http://192.168.XXX.XXX:2323/?cmd=deviceInfo&type=json&password=XXX";
                          var state = "javascript.0.Allgemein.Akku_Tablet"/Akku_Tablet/;
                          ! function fully() {
                          request(link, function(error,response, body) {
                          if(error) log('Fehler request: ' + error, 'error');
                          else {
                          objects = JSON.parse(body);
                          bat = objects.batteryLevel;
                          setState(state, bat);
                          log ("batteryLevel = " + bat);
                          ! fully();
                          schedule('*/10 * * * *', fully);
                          Und den dann zum Laden verwende:
                          const idBatt = 'javascript.0.Allgemein.Akku_Tablet'; // Batterielevel in %
                          const idPlug = 'sonoff.0.Ladestecker.POWER'; // Ladegerät ein
                          const idVis = 'Vis.Batterieanzeige'; // Für Vis
                          >! createState(idVis, 0, {
                          type: 'number',
                          min: 0,
                          max: 7,
                          role: 'level',
                          states: {
                          0: 'leer',
                          1: '20 %',
                          2: '40 %',
                          3: '60 %',
                          4: '80 %',
                          5: 'voll',
                          6: 'Ladegerät'
                          >! var level = getState(idBatt).val;
                          var plug = getState(idPlug).val;
                          >! function batt() {
                          var state = 5; // full 80 %
                          if(level <= 79) state = 4; // 79 %
                          if(level <= 60) state = 3; // 60 %
                          if(level <= 40) state = 2; // 40 %
                          if(level <= 30) state = 1; // 20 %
                          if(level <= 22) state = 0; // empty 20 %
                          if(plug) state = 6; // Ladegerät ein
                          setState(idVis, state, true);
                          if(level >= 80 && plug) setState(idPlug, false);
                          if(level <= 30 && !plug) setState(idPlug, true);
                          >! batt(); // Skriptstart
                          >! on(idBatt, function(dp) {
                          level = dp.state.val;
                          batt();
                          >! on(idPlug, function(dp) {
                          plug = dp.state.val;
                          batt();
                          habe ich den Effekt nicht.
                          Also aus Fully scheint der Wert korrekt zu kommen ohne Schwankungen.
                          Der Ladestecker ist direkt in meinem Büro. So konnte ich das Schalten deutlich hören. Ich habe zwar keine Fehlersuche gemacht, aber als ich aus einem anderen Grund das Script nicht mehr zum Laden verwendet habe war das Schalten plötzlich wieder weg.
                            tempestas
                            #70
                            @Georgius:
                            (20% Akkustand hab ich als Untergrenze angenommen) `
                            "null" ist nicht als Wert der Zahl 0 gemeint sondern als 'Null' in JavaScript. 'Null' is a keyword in JavaScript that signifies 'no value' or nonexistence of any value.
                              Seb0304
                              #71
                              bei mir fällt der Wert auch immer auf Null, die Aktualisierung( bei mir 1 Minute) funktioniert.
                              Ich kopiere mir jetzt den Wert bei Aktualisierung in einen anderen Datenpunkt, dort bleibt er auf dem alten Wert stehen.
                              Den neuen Datenpunkt benutze ich für die Akkuanzeige auf dem VIS und für die Batterieladung.
                              Gruß Sebastian
                                tempestas
                                #72
                                ja, genau den Workaround habe ich auch erstmal gewählt.
                                  WebrangerW Offline
                                  Webranger
                                  #73
                                  Das sollte so aber ja nicht die Lösung sein!
                                  Würde den Adapter schon gerne nutzen ohne irgendwelche extra datenpunkte und so.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #74
                                    installiert mal bitte von GIt
                                    https://github.com/arteck/iobroker.fullybrowser.git
                                    ich hab den Fehler glaube ich gefunden
                                    • ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      #75
                                      Ich habe es mal schnell installiert. Aber momentan noch "im Leerlauf" weil ich erst am Wochenende dazu komme das genauer zu protokollieren.
                                      Bisher beobachte ich vorweg ob irgendwelche seltsamen Effekte auftauchen.
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #76
                                        OK
                                          WebrangerW Offline
                                          Webranger
                                          #77
                                          So wie es auf den ersten Blick aussieht läuft es jetzt mit dem Batterystatus.
                                          Ich beobachte das mal weiter.
                                          Gruss
