  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • WebrangerW Offline
    WebrangerW Offline
    Webranger
    @Mic:
    Der Adapter geht bei mir auch noch nicht aufgrund der besagten Fehlermeldungen. `
    Gleiche Fehlermeldung wie bei mir?
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
    • ChaotC Offline
      ChaotC Offline
      Chaot
      Bei mir scheitert es nach wie vor schon bei der Installation:
      iobroker	2018-12-12 21:31:36.077	info	exit 0
      iobroker	2018-12-12 21:31:35.979	info	upload [0] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/fully.png fully.png image/png
      iobroker	2018-12-12 21:31:35.920	info	upload [1] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index.html index.html text/html
      iobroker	2018-12-12 21:31:35.859	info	upload [2] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/index_m.html index_m.html text/html
      iobroker	2018-12-12 21:31:35.786	info	upload [3] fullyBrowser.admin /opt/iobroker/node_modules/iobroker.fullyBrowser/admin/words.js words.js application/javascript
      iobroker	2018-12-12 21:31:35.759	info	got /opt/iobroker/node_modules/iobroker.fullyBrowser/admin
      iobroker	2018-12-12 21:31:35.686	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      iobroker	2018-12-12 21:31:35.684	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm
      iobroker	2018-12-12 21:31:35.682	info	WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
      iobroker	2018-12-12 21:31:35.681	info	WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm
      iobroker	2018-12-12 21:31:35.679	info	npm
      host.haus	2018-12-12 21:31:02.584	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
      iobroker	2018-12-12 21:30:25.199	info	npm install https://github.com/arteck/iobroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2018-12-12 21:30:24.566	info	install https://github.com/arteck/iobroker.fullyBrowser/tarball/master
      iobroker	2018-12-12 21:30:24.076	info	url "https://github.com/arteck/iobroker.fullyBrowser"
      Das klingt irgendwie als müsste ich da was nachinstallieren. Aber ich kann nicht so richtig erkennen was ich da brauche.
      Dazu kommt noch die Meldung:
      host.haus	2018-12-12 21:31:36.473	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      für die ich keine Erklärung finde. Die URL ist ja eingetragen. Also sollte das doch automatisch klappen.
      • G Offline
        Georgius
        Das sind nur Infos, keine Errors. Auch ein Exit 0.
        Sollte alles funktionieren.
        • MicM Offline
          MicM Offline
          Mic
          @ringdingringding:
          Gleiche Fehlermeldung wie bei mir? `
          So sieht es aus, hat arteck aber schon bekommen.
          2018-12-12 19:08:50.588 - info: host.ctioBroker object change system.adapter.fullyBrowser.0
          2018-12-12 19:08:51.381 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: break;
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: ^^^^^
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: SyntaxError: Illegal break statement
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at createScript (vm.js:80:10)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Module._compile (module.js:617:28)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Module.load (module.js:566:32)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
          2018-12-12 19:08:51.382 - error: Caught by controller[0]: at startup (bootstrap_node.js:204:16)
          2018-12-12 19:08:51.383 - error: Caught by controller[0]: at bootstrap_node.js:625:3
          2018-12-12 19:08:51.383 - error: host.ctioBroker instance system.adapter.fullyBrowser.0 terminated with code 1 ()
          2018-12-12 19:08:51.383 - info: host.ctioBroker Do not restart adapter system.adapter.fullyBrowser.0 because disabled or deleted
          2018-12-12 19:08:52.613 - info: host.ctioBroker object change system.adapter.fullyBrowser.0
          2018-12-12 19:08:52.614 - info: host.ctioBroker "system.adapter.fullyBrowser.0" enabled
          2018-12-12 19:08:52.627 - info: host.ctioBroker instance system.adapter.fullyBrowser.0 started with pid 768
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: break;
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: ^^^^^
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: SyntaxError: Illegal break statement
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: at createScript (vm.js:80:10)
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Module._compile (module.js:617:28)
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
          2018-12-12 19:08:52.775 - error: Caught by controller[0]: at Module.load (module.js:566:32)
          2018-12-12 19:08:52.776 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
          2018-12-12 19:08:52.776 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
          2018-12-12 19:08:52.776 - error: Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
          2018-12-12 19:08:52.776 - error: Caught by controller[0]: at startup (bootstrap_node.js:204:16)
          2018-12-12 19:08:52.776 - error: Caught by controller[0]: at bootstrap_node.js:625:3
          2018-12-12 19:08:52.776 - error: host.ctioBroker instance system.adapter.fullyBrowser.0 terminated with code 1 ()
          2018-12-12 19:08:52.776 - info: host.ctioBroker Restart adapter system.adapter.fullyBrowser.0 because enabled
          2018-12-12 19:08:53.645 - info: host.ctioBroker instance system.adapter.ical.0 terminated with code 0 (OK)
          • ChaotC Offline
            ChaotC Offline
            Chaot
            Ja, exit 0 sehe ich ja auch. Aber dann müsste der Adapter doch in den Instanzen auftauchen oder verstehe ich das falsch?
            • G Offline
              Georgius
              Wenn Du die Kachelansicht hast nochmal so tun als ob Du den Adapter installieren willst. Also die 3 Punkte und dann links unten das + Zeichen. Dann wird eine Instanz angelegt.
              • ChaotC Offline
                ChaotC Offline
                Chaot
                Danke.
                Jetzt mit Fehlermeldung:
                host.haus	2018-12-13 06:44:53.758	error	instance system.adapter.fullyBrowser.0 terminated with code 1 ()
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at bootstrap_node.js:625:3
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at startup (bootstrap_node.js:204:16)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Function.Module.runMain (module.js:694:10)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Function.Module._load (module.js:498:3)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Module.load (module.js:566:32)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                Caught	2018-12-13 06:44:53.758	error	by controller[0]: at Module._compile (module.js:617:28)
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: at Object.runInThisContext (vm.js:139:10)
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: at createScript (vm.js:80:10)
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: SyntaxError: Illegal break statement
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: ^^^^^
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: break;
                Caught	2018-12-13 06:44:53.757	error	by controller[0]: /opt/iobroker/node_modules/iobroker.fullyBrowser/main.js:118
                host.haus	2018-12-13 06:44:53.559	info	instance system.adapter.fullyBrowser.0 started with pid 8663
                • arteckA Offline
                  arteckA Offline
                  arteck
                  jaha..schon korrigiert…
                  hab noch auf die schnelle eine Änderung gemacht ..copy...paste.. bäm ..fehler ;)
                  doku fehlt auch noch.. ich weiss
                    WebrangerW Offline
                    Webranger
                    Dann werde ich heute Abend noch mal testen
                    • ChaotC Offline
                      ChaotC Offline
                      Chaot
                      Ich bekomme bei der Installation immer noch die 0.0.6 und den gleichen Fehler
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        so jetzt die Version ist immer noch die 0.0.6
                        • ChaotC Offline
                          ChaotC Offline
                          Chaot
                          Ok, läuft bei mir aktuell ohne Fehlermeldung.
                          Alle Daten scheinen vorhanden.
                          Allerdings hat sich das jetzt irgendwie mit meinem Ladescript überschnitten. Da frage ich den Akkustand direkt ab und Fully verweigert jetzt scheinbar die Verbindung.
                          Macht nichts, da ich ja zur Abfrage jetzt den Adapter nutzen kann.
                          • ChaotC Offline
                            ChaotC Offline
                            Chaot
                            Bei mir läuft der Adapter mittlerweile länger Zeit störungsfrei.
                            Ich nutze ihn allerdings derzeit nur um den Akku zu laden.
                            Die restlichen Datenpunkte werde ich mir nach und nach erarbeiten.
                            Mein Wunsch wäre noch eine Einstellmöglichkeit der Bildschirmhelligkeit.
                            Ich habe gemerkt das durch diverse Updates jedes mal ein Reload erfolgt wenn der Screensaver abgeschaltet wird.
                            Deshalb würde ich gerne per Script die Bildschirmhelligkeit steuern.
                            Unter /?cmd=listSettings&cat=settingsDeviceManagement ist der Punkt aufgeführt.
                            In den Objekten erscheint er allerdings nur als "Info".
                            Somit würde ich einfach Fully ständig in der View lassen und nur den Bildschirm verschieden hell bis ganz dunkel steuern (Über Astro Script).
                            Dadurch umgehe ich den Screensaver und den damit verbundenen lästigen Reload.
                            • MicM Offline
                              MicM Offline
                              Mic
                              Werde ich auch gleich noch mal testen.
                              Wer kann mir denn als quasi "Github"-Newbie erklären, wie ich bei einem Projekt, das nicht von mir ist, die Readme-Datei bearbeiten kann als "Vorschlag"? Denn dann kann ich da gerne schon mal das ganze beschreiben, ähnlich wie bei meinem Fully-Script im Forum-Thread, halt in Englisch.
                              • umbmU Offline
                                umbmU Offline
                                umbm
                                @Mic:
                                Wer kann mir denn als quasi "Github"-Newbie erklären, wie ich bei einem Projekt, das nicht von mir ist, die Readme-Datei bearbeiten kann als "Vorschlag"? Denn dann kann ich da gerne schon mal das ganze beschreiben, ähnlich wie bei meinem Fully-Script im Forum-Thread, halt in Englisch. `
                                Wenn das Projekt nicht deins ist, kannst du auf GitHub nichts bearbeiten sondern nur im Projekt ein https://github.com/arteck/iobroker.fullyBrowser/issues öffnen und darin dem Inhaber das mitteilen, was du möchtest.
                                • R Offline
                                  rascal
                                  Habe den Adapter gerade ausprobiert… echt cooles Teil, gratuliere.
                                  Wäre es möglich, aus Vis die Views auszulesen und in den fullyBrowser Adapter so einzubinden, dass man die View per Knopfdruck wechseln kann?
                                  Ich weis es ist mit Vis möglich, allerdings ein bisschen umständlich mit Instance-ID usw..
                                  • ? Offline
                                    Der Adapter läuft hier seit ein paar Tagen auch einwandfrei, besser als das Javascript, das hatte noch ein paar Fehler.. ( manche Datenpunkte sind nicht angelegt worden )..
                                    ich steuere zur Zeit Screen on/off und die Batterielast, da meine ganzen Tablets alle an der Wand hängen.
                                    Cool ist, dass man auch den Bewegungssensor auslesen kann… wenn also mal ein Tablet von der Wand fällt... :roll: :mrgreen: kann ich mir ne TelegramMsg schicken lassen und gleich über Alexa ein neues bestellen lassen.. :lol: :lol:
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @Chaot:
                                      Dadurch umgehe ich den Screensaver und den damit verbundenen lästigen Reload. `
                                      schau mal https://github.com/arteck/iobroker.full … -absetzten
                                      • metaxaM Offline
                                        metaxaM Offline
                                        metaxa
                                        Hi!
                                        Ich krieg den Adapter nicht auf "grün". Installiert habe ich 0.0.6 und auch auf einem Device mit PLUS License die Remoteeinstellungen lt. Github gesetzt.
                                        Adapter installiert (Code 0):
                                        $ ./iobroker url "https://github.com/arteck/ioBroker.fullyBrowser/tarball/master" fullyBrowser --debug
                                        install https://github.com/arteck/ioBroker.fullyBrowser/tarball/master
                                        npm install https://github.com/arteck/ioBroker.fullyBrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                        iobroker.inst@1.1.2 /opt/iobroker`-- iobroker.fullybrowser@0.0.6
                                        ! npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none was installed.
                                        npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none was installed.
                                        npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.
                                        npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none was installed.
                                        ! ERROR: Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                        process exited with code 0
                                        Instanz erzeugt (Code 0):
                                        $ ./iobroker add fullybrowser  --host iobroker-master-tb
                                        host.iobroker-master-tb install adapter fullybrowser
                                        npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullybrowser"
                                        got /opt/iobroker/node_modules/iobroker.fullybrowser/admin
                                        upload [3] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
                                        upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
                                        upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index.html index.html text/html
                                        upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
                                        host.iobroker-master-tb object system.adapter.fullybrowser created
                                        host.iobroker-master-tb create instance fullybrowser
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.outputCount created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.inputCount created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.uptime created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.memRss created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.memHeapTotal created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.memHeapUsed created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.connected created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0.alive created
                                        host.iobroker-master-tb object system.adapter.fullybrowser.0 created
                                        Im LOG steht (Cannot find start file of adapter) und der Adapter bleibt rot.
                                        host.iobroker-master-tb 2018-12-16 11:40:23.461 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:40:23.459 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:40:21.678 info instance system.adapter.fullybrowser.0 started with pid 26447
                                        host.iobroker-master-tb 2018-12-16 11:39:51.630 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:39:51.630 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:39:49.898 info instance system.adapter.fullybrowser.0 started with pid 26437
                                        host.iobroker-master-tb 2018-12-16 11:39:49.857 info object change system.adapter.fullybrowser.0
                                        host.iobroker-master-tb 2018-12-16 11:39:41.442 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:39:41.442 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:39:39.610 info instance system.adapter.fullybrowser.0 started with pid 26426
                                        host.iobroker-master-tb 2018-12-16 11:39:09.565 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:39:09.564 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:39:08.205 info instance system.adapter.fullybrowser.0 started with pid 26376
                                        host.iobroker-master-tb 2018-12-16 11:38:38.175 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:38:38.175 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:38:36.313 info instance system.adapter.fullybrowser.0 started with pid 26366
                                        host.iobroker-master-tb 2018-12-16 11:38:06.276 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:38:06.275 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:38:04.551 info instance system.adapter.fullybrowser.0 started with pid 26316
                                        host.iobroker-master-tb 2018-12-16 11:37:34.501 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:37:34.500 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        host.iobroker-master-tb 2018-12-16 11:37:33.253 info instance system.adapter.fullybrowser.0 started with pid 26305
                                        host.iobroker-master-tb 2018-12-16 11:37:03.227 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                        host.iobroker-master-tb 2018-12-16 11:37:03.226 error instance system.adapter.fullybrowser.0 terminated with code 10 (Cannot find start file of adapter)
                                        Neuinstallation des Adapters schon 2x gemacht, leider keine Änderung.
                                        Passwort auf dem Device für Remote gesetzt, Port unverändert gelassen (finde nicht mal die Einstellung auf dem Device)
                                        Kann mir bitte irgendwer einen TIp geben?
                                        LG, mxa
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          moment wartmal
