  4. IObroker All-In-One Lösung
15 Beiträge 3 Kommentatoren 2.3k Aufrufe 1 Beobachtet
    deimos
    dann starte mal den Pi neu, warte 5 Minuten und poste die Ausgabe folgender Befehle:
    sudo pivccu-info
    sudo pivccu-attach cat /var/hm_mode
    sudo pivccu-attach cat /var/log/messages
    sudo pivccu-attach cat /var/log/hmserver.log
    Viele Grüße
    Alex
    • H Offline
      Hightower1976
      Hi Alex,
      Vielen Dank für deine Hilfe.
      Hier die abfragen.
      sudo pivccu-info
      root@RasPi-IOBroker:/home/pi# pivccu-info
      piVCCU version: 3.41.11-11
      Kernel modules: Available
      Raw UART dev:   Available
      Rasp.Pi3 UART:  Assigned to GPIO pins
      HMRF Hardware:  HM-MOD-RPI-PCB
      HMIP Hardware:  HM-MOD-RPI-PCB
      Board serial:   OEQ2299958
      Radio MAC:      0x65175b
      SGTIN:          3014F711A061A7D709AC8036
      State:          RUNNING
      PID:            817
      IP:             192.168.7.2
      IP:             2003:70:ce68:cd54:8f0:29ff:fecc:ae62
      CPU use:        29.39 seconds
      BlkIO use:      55.77 MiB
      Link:           vethpivccu
       TX bytes:      379.89 KiB
       RX bytes:      5.99 MiB
       Total bytes:   6.36 MiB
      oot@RasPi-IOBroker:/home/pi# pivccu-attach cat /var/hm_mode
      HM_HMIP_ADDRESS='0x65175b'
      HM_HMIP_DEV='HM-MOD-RPI-PCB'
      HM_HMIP_DEVNODE='/dev/raw-uart'
      HM_HMIP_SERIAL='OEQ2299958'
      HM_HMIP_SGTIN='3014F711A061A7D709AC8036'
      HM_HMIP_VERSION='2.8.6'
      HM_HMRF_ADDRESS='0x65175b'
      HM_HMRF_DEV='HM-MOD-RPI-PCB'
      HM_HMRF_DEVNODE='/dev/raw-uart'
      HM_HMRF_SERIAL='OEQ2299958'
      HM_HMRF_VERSION='2.8.6'
      HM_HOST='rpi3'
      HM_HOST_GPIO_RESET=''
      HM_HOST_GPIO_UART='/dev/raw-uart'
      HM_LED_GREEN=''
      HM_LED_RED=''
      HM_LED_YELLOW=''
      HM_MODE='NORMAL'
      HM_RTC=''
      Ist als Dateiangehangen weil zu viele Zeichen.
      root@RasPi-IOBroker:/home/pi# pivccu-attach cat /var/log/hmserver.log
      Dec 7 11:23:11 de.eq3.lib.util.dynamics.GenericFactory INFO  [main] @GenericFactory
      Dec 7 11:23:11 de.eq3.lib.util.dynamics.GenericFactory INFO  [main] created instance of HMServerConfiguration with parameter(s)
      Dec 7 11:23:11 de.eq3.lib.util.dynamics.GenericFactory INFO  [main] passed 1 parameter(s), in declarative order [String]
      Dec 7 11:23:18 de.eq3.cbcs.devicedescription.ChannelTypeDescription WARN  [Thread-0] Invalid state parameter or subtype: Parameter ERROR_POWER_SHORT_CIRCUIT_BUS_1 subtype=default
      Dec 7 11:23:18 de.eq3.cbcs.devicedescription.ChannelTypeDescription WARN  [Thread-0] Invalid state parameter or subtype: Parameter ERROR_POWER_SHORT_CIRCUIT_BUS_2 subtype=default
      Dec 7 11:23:18 de.eq3.cbcs.devicedescription.ChannelTypeDescription WARN  [Thread-0] Invalid state parameter or subtype: Parameter ERROR_SHORT_CIRCUIT_DATA_LINE_BUS_1 subtype=default
      Dec 7 11:23:18 de.eq3.cbcs.devicedescription.ChannelTypeDescription WARN  [Thread-0] Invalid state parameter or subtype: Parameter ERROR_SHORT_CIRCUIT_DATA_LINE_BUS_2 subtype=default
      Dec 7 11:23:18 de.eq3.cbcs.devicedescription.ChannelTypeDescription WARN  [Thread-0] Invalid state parameter or subtype: Parameter ERROR_BUS_CONFIG_MISMATCH subtype=default
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [HMIPTRXWriterWorker] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [KeyServerWorker] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [KryoPersistenceWorker] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [TransactionSubsystemHandler] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [FirmwareLoaderFileSystem] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LocalServerPersistentDataLoader] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LocalServerAdapterInitialization] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [BackendCommandHandler] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [DeviceInclusionAcceptHandler] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [CheckDeviceExistHandler] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [IncomingHMIPFrameHandler] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [DeviceBackgroundUpdateSubsystem] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [DeviceLiveUpdateSubsystem] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [DeviceInclusionDefaultConfigurationChanger] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [CyclicSmokeDetectorAwakening] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LocalServerFirmwareUpdateInitialization] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LegacyNotificationHandler] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LegacyAPIWorker] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LegacyBackendNotificationHandler] (3) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LegacyBlindLevelCorrectionHandler] (1) *worker
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: added for deployment [LegacyInitializion] (1)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: deploying 21 classes to Vert.x
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: 21 VertxDeployers initialized
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-4] SYSTEM: start of DeviceInclusionDefaultConfigurationChanger succeeded (8084131c-632c-452c-bd16-de85ff233ab5)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-6] SYSTEM: start of CyclicSmokeDetectorAwakening succeeded (28ed542d-e246-463e-8edc-67dd444fee00)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-7] SYSTEM: start of HMIPTRXWriterWorker succeeded (129c2186-75ea-4228-b427-0a8a87b2990a)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-3] SYSTEM: start of CheckDeviceExistHandler succeeded (ceb63a34-8264-4a08-967f-472ad73e3d30)
      Dec 7 11:23:18 de.eq3.cbcs.server.core.vertx.KeyServerWorker ERROR [vert.x-worker-thread-1] Missing key server configuration parameter (Network.Key) for  mode: KEYSERVER_LOCAL
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-0] SYSTEM: start of KeyServerWorker succeeded (d814ac27-f861-41da-9ef3-c46d55c647df)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-6] SYSTEM: start of TransactionSubsystemHandler succeeded (f56829e9-4105-4eb6-9da0-f02e8d22e909)
      Dec 7 11:23:18 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-2] SYSTEM: start of LegacyBlindLevelCorrectionHandler succeeded (dbfd2b72-dc33-4ba3-b060-00c6650ad58c)
      Dec 7 11:23:19 de.eq3.cbcs.server.core.live_otau.DeviceLiveUpdateSubsystem INFO  [vert.x-eventloop-thread-5] SYSTEM: DeviceLiveUpdateSubsystem started
      Dec 7 11:23:19 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-5] SYSTEM: start of KryoPersistenceWorker succeeded (d076629b-ac3b-4d25-8fb9-0e2b11af2b7a)
      Dec 7 11:23:19 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-1] SYSTEM: start of DeviceLiveUpdateSubsystem succeeded (18f5049a-c146-4e97-b8bd-37e4a2947548)
      Dec 7 11:23:19 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-7] SYSTEM: start of DeviceBackgroundUpdateSubsystem succeeded (a5e3ad6b-7666-4585-b496-8e706166e45f)
      Dec 7 11:23:19 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-3] SYSTEM: start of LocalServerPersistentDataLoader succeeded (ef8b6a95-ca72-4c0c-8847-98031124c2c1)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-4] SYSTEM: start of LegacyNotificationHandler succeeded (014a7b4e-7f7c-4fa4-b02a-43b500b3ed0f)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-4] SYSTEM: start of IncomingHMIPFrameHandler succeeded (160bbd13-a0ec-4a0d-a324-44a51bcad1a2)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-3] SYSTEM: start of DeviceInclusionAcceptHandler succeeded (1d10d0b1-2bec-4ffd-9ae6-05e1f809e4cc)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-6] SYSTEM: start of BackendCommandHandler succeeded (80a1c5b3-78db-45bc-824c-e699178c3cab)
      Dec 7 11:23:21 de.eq3.cbcs.server.core.otau.util.FirmwareLoaderFileSystem INFO  [vert.x-worker-thread-4] SYSTEM: Firmware update directory is set to /etc/config/firmware
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-1] SYSTEM: start of FirmwareLoaderFileSystem succeeded (85040504-02d6-4d38-929f-0db3fe8d8fe0)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-0] SYSTEM: start of LegacyBackendNotificationHandler succeeded (c113226f-09e5-4611-8b75-a810426f9197)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-0] SYSTEM: start of LegacyAPIWorker succeeded (d4656e16-498d-49c2-8b02-8e054a58299a)
      Dec 7 11:23:21 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-6] SYSTEM: start of LocalServerAdapterInitialization succeeded (de5c2af6-32da-491a-9547-bdb0f95ae26e)
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] TRX adapter state 1: HMIP_TRX_App
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] TRX adapter application is already running or started
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] No NWK, try to set address ...
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Try to set radio address 11756918...
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Set max send attempts for 3014F711A061A7D709AC8036 to 3
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Try to get application version...
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Application version 2.8.6
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Bootloader version 1.0.3
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] hmos version 1.20.3
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] MCU type: Si1002_8051
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Duty Cycle: 0.0
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] set DutyCycle limit to ffffffc8
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Set Duty Cycle Limit
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Current Security Counter: 98569472
      Dec 7 11:23:21 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Update security counter to calculation: 98750410
      Dec 7 11:23:22 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] TRX adapter has no linkpartner
      Dec 7 11:23:22 de.eq3.cbcs.server.local.base.internal.HMIPTRXInitialResponseListener INFO  [Thread-6] Adapter with Access Point id 3014F711A061A7D709AC8036 initialized
      Dec 7 11:23:22 de.eq3.cbcs.server.local.base.internal.LocalServerAdapterInitialization INFO  [Thread-6] HMIPTRXInitialResponseListener said that Adapter was initialized
      Dec 7 11:23:22 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-2] SYSTEM: start of LocalServerFirmwareUpdateInitialization succeeded (ea56c18a-3347-41d0-8852-e009a52266df)
      Dec 7 11:23:22 de.eq3.cbcs.server.core.otau.util.FirmwareLoaderFileSystem WARN  [vert.x-worker-thread-1] SYSTEM: Firmware update directory in config file is no valid directory: /etc/config/firmware
      Dec 7 11:23:22 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-5] SYSTEM: start of LegacyInitializion succeeded (dcb28d8d-4b08-4dff-a735-7c7ed135caaf)
      Dec 7 11:23:22 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Checking all devices on all accesspoints for updates
      Dec 7 11:23:22 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: There are 0 APs queued with updatable devices
      Dec 7 11:23:22 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-0] SYSTEM: initial deployment complete _____________________________________________________
      Dec 7 11:23:23 de.eq3.cbcs.server.local.LocalServer INFO  [Thread-0] SYSTEM: Bind XML-RPC api to port 32010
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Default MaxEventLoopExecuteTime: 2000000000
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Default BlockedThreadCheckInterval: 1000
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Default MaxWorkerExecuteTime: 60000000000
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Default EventLoopPoolSize: 8
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [BackendWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [GroupRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [DiagramRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [StorageRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [DeviceFirmwareRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [EnergyPriceRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [CouplingRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [RegaClientWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [GroupConfigurationPersistenceFileSystem] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: added for deployment [HmIPGatewayManagementRequestWorker] (1) *worker
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: deploying 10 classes to Vert.x
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: 10 VertxDeployers initialized
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-5] SYSTEM: start of BackendWorker succeeded (9d3df2dd-a61c-45c7-80bb-b6e1b2b337b6)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-1] SYSTEM: start of GroupConfigurationPersistenceFileSystem succeeded (b8f63a74-68c6-473a-882f-998dc4d38f66)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-0] SYSTEM: start of EnergyPriceRequestWorker succeeded (c6eae292-7ad6-4d6a-a5a7-4550e0c25810)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-1] SYSTEM: start of CouplingRequestWorker succeeded (084c73a6-640a-43d5-9530-155ed8890895)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-2] SYSTEM: start of RegaClientWorker succeeded (fd8e3c26-1857-480c-a006-1681ed6e3e8f)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-5] SYSTEM: start of StorageRequestWorker succeeded (6bd2a189-6b73-4a7f-ad44-390686a4ac63)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-0] SYSTEM: start of DiagramRequestWorker succeeded (f264526d-c02a-4c74-8b23-3e97c3cd2d5e)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-3] SYSTEM: start of GroupRequestWorker succeeded (2ff58e25-1f3f-4605-9e0c-408f06982d8f)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-1] SYSTEM: start of DeviceFirmwareRequestWorker succeeded (9d9a397d-bd4f-4c32-99c0-c44532b4de58)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [vert.x-eventloop-thread-2] SYSTEM: start of HmIPGatewayManagementRequestWorker succeeded (d4e54333-f6f7-4efe-a401-721640614111)
      Dec 7 11:23:26 de.eq3.cbcs.vertx.management.VertxManager INFO  [Thread-1] SYSTEM: initial deployment complete _____________________________________________________
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Starting HMServer at 127.0.0.1:39292
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Read Configuration
      Dec 7 11:23:26 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create Bidcos Dispatcher
      Dec 7 11:23:27 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] InitBidCosCache
      Dec 7 11:23:28 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-3] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.7.3:2010
      Dec 7 11:23:28 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-3] init finished
      Dec 7 11:23:28 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer INFO  [vert.x-worker-thread-4] Added InterfaceId: hm-rpc.1
      Dec 7 11:23:28 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Thread-1] BidCosCache could not be initialized
      Dec 7 11:23:28 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Thread-1] java.net.ConnectException: Connection refused (Connection refused)
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create groupDefinitionProvider
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create VirtualDeviceHolder
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create VirtualDeviceHandlerRega
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create GroupAdministrationService
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create GroupDeviceDispatcher
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create GroupDeviceHandler
      Dec 7 11:23:28 de.eq3.ccu.groupdevice.service.GroupDeviceHandler INFO  [Thread-1] @GroupDeviceHandler - initializing...
      Dec 7 11:23:28 de.eq3.ccu.groupdevice.service.GroupDeviceHandler INFO  [Thread-1] --> created groupDeviceDispatcher (GroupDeviceService to BidCoS (via Dispatcher))
      Dec 7 11:23:28 de.eq3.ccu.groupdevice.service.GroupDeviceHandler INFO  [Thread-1] --> created virtualDeviceHandler (GroupDeviceService to ReGa)
      Dec 7 11:23:28 de.eq3.ccu.groupdevice.service.GroupDeviceHandler INFO  [Thread-1] --> got groupDefinitionProvider
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create BidCosGroupMemberProvider
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Init groupAdministrationService
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Init Virtual OS Device
      Dec 7 11:23:28 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Init ESHLight Bridge
      Dec 7 11:23:30 org.eclipse.smarthome.binding.hue.handler.HueBridgeHandler INFO  [safeCall-3] Polling interval not configured for this hue bridge. Using default value: 10s
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create RrdDatalogging
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create MeasurementService
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Init MeasurementService
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create HTTP Server
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create BidCos context and start handler
      Dec 7 11:23:30 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Create group context and start handler
      Dec 7 11:23:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:23:30 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-0] (un)registerCallback on LegacyServiceHandler called from url: http://127.0.0.1:39292/bidcos
      Dec 7 11:23:30 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-0] init finished
      Dec 7 11:23:30 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer INFO  [vert.x-worker-thread-2] Added InterfaceId: HmIP-RF_java
      Dec 7 11:23:31 de.eq3.ccu.server.BaseHMServer INFO  [Thread-1] Starting HMServer done
      Dec 7 11:23:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:23:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:23:40 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO  [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: xmlrpc_bin://127.0.0.1:31999
      Dec 7 11:23:40 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO  [vert.x-eventloop-thread-4] Added InterfaceId: 1007
      Dec 7 11:23:40 de.eq3.ccu.virtualdevice.service.internal.rega.BackendWorker INFO  [vert.x-worker-thread-11] Execute BackendCommand: de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand
      Dec 7 11:23:40 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] updateDevicesForClient -> 34 device addresses will be added
      Dec 7 11:23:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:23:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:23:50 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-1] (un)registerCallback on LegacyServiceHandler called from url: xmlrpc_bin://127.0.0.1:31999
      Dec 7 11:23:50 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-1] init finished
      Dec 7 11:23:50 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer INFO  [vert.x-worker-thread-3] Added InterfaceId: 1011
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of INT0000002
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Raphael
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Philips hue
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Flur eingan
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Stehlampe W
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Mia
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Badezimmer
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Flur Hof
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Nachttisch
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Lampe 3 Boy
      Dec 7 11:23:51 de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand INFO  [vert.x-worker-thread-11] set ready config of HU-Lichtband
      Dec 7 11:23:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:24:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:25:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:26:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:27:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: 0 Accesspoints in Queue
      Dec 7 11:28:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
      Dec 7 11:28:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Eventlistener Handler utilization: 0/50 used
      Dec 7 11:28:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:28:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:29:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:30:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:31:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:32:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: 0 Accesspoints in Queue
      Dec 7 11:33:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
      Dec 7 11:33:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Eventlistener Handler utilization: 0/50 used
      Dec 7 11:33:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:33:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:34:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:35:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:36:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:37:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: 0 Accesspoints in Queue
      Dec 7 11:38:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
      Dec 7 11:38:19 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-1] SYSTEM: Eventlistener Handler utilization: 0/50 used
      Dec 7 11:38:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:38:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:39:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:40:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:41:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:42:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:42:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:42:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:42:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      Dec 7 11:42:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-3] Could not register BidCos-RF_java
      13307_messages.txt
        deimos
        in den Ausgaben sieht man sehr gut, dass dein Funkmodul einwandfrei erkannt wird. Allerdings kommt der rfd scheinbar nicht komplett hoch. Da dein Loglevel auf Debug steht und es sich um ein Rolling Log handelt, rauschen da aber so viele Nachrichten durch, dass die Nachrichten am Anfang verdrängt werden und man die daher nicht mehr im Log sieht. Da müsstest du mal das Loglevel runterdrehen auf Info und danach den Pi einmal neustarten und die Logs dann nochmal posten.
        Glaskugel-Raten von mir: Du hattest vorher YAHM und hast die notwendigen und dokumentierten Schritte für die Migration von YAHM nicht durchgeführt?
        Viele Grüße
        Alex
        • H Offline
          Hightower1976
          Hi Alex,
          @deimos:
          Da müsstest du mal das Loglevel runterdrehen auf Info und danach den Pi einmal neustarten und die Logs dann nochmal posten. `
          Blöde frage von mir. wo und wie drehe ich das runter?
          @deimos:
          Glaskugel-Raten von mir: Du hattest vorher YAHM und hast die notwendigen und dokumentierten Schritte für die Migration von YAHM nicht durchgeführt? `
          nö. Habe die All-in-one Lösung installiert und wärendessen auf pivccu3 nach Anleitung vom GitHub ein upgrade gemacht. Wollte ein backup einspielen und das Quellsystem (RPI2 mit dem Modul und Raspmagic drauf" hatte die V3.41 von CCU drauf.
            deimos
            @Hightower1976:
            @deimos:
            Blöde frage von mir. wo und wie drehe ich das runter? `
            Irgendwo in der Systemsteuerung in der WebUI, ich weiß grade nicht auswendig, in unter welchem Punkt das genau war.
            Viele Grüße
            Alex
            • H Offline
              Hightower1976
              Hab es gefunden.
              habe die Logdatei aus der WebUI geladen und angehängt. habe die nicht über ssh geholt. hoffe das hilft auch.
              Danke Dir
              13307_homematic-raspi-2018-12-07-2.log
                deimos
                bitte einmal die Ausgabe von
                sudo pivccu-attach cat /etc/config/rfd.conf
                sudo pivccu-attach cat /etc/config/InterfacesList.xml
                Was für ein System hattest du vor RaspberryMatic?
                Viele Grüße
                Alex
                • H Offline
                  Hightower1976
                  Hi Alex,
                  @deimos:
                  [quote]pi@RasPi-IOBroker:~ $ sudo pivccu-attach cat /etc/config/rfd.conf
                  # TCP Port for XmlRpc connections
                  Listen Port = 32001
                  Log Destination = Syslog
                  Log Identifier = rfd
                  Log Level = 1
                  Persist Keys = 1
                  # PID File = /var/rfd.pid
                  # UDS File = /var/socket_rfd
                  Device Description Dir = /firmware/rftypes
                  Device Files Dir = /etc/config/rfd
                  Key File = /etc/config/keys
                  Address File = /etc/config/ids
                  Firmware Dir = /firmware
                  Replacemap File = /firmware/rftypes/replaceMap/rfReplaceMap.xml
                  Fire NACK Error Events = true
                  Improved Coprocessor Initialization = true
                  #[Interface 0]
                  #Type = CCU2
                  #ComPortFile = /dev/mmd_bidcos
                  #AccessFile = /dev/null
                  #ResetFile = /dev/null `
                  [quote]pi@RasPi-IOBroker:~ $ sudo pivccu-attach cat /etc/config/InterfacesList.xml
                   <interfaces v="1.0"><ipc><name>BidCos-RF</name>
                  	 	<url>xmlrpc_bin://127.0.0.1:32001</url>
                  	 	<info>BidCos-RF</info></ipc>
                  	 <ipc><name>VirtualDevices</name>
                  	 	<url>xmlrpc://127.0.0.1:39292/groups</url>
                  	 	<info>Virtual Devices</info></ipc>
                  	 <ipc><name>HmIP-RF</name>
                  	 	<url>xmlrpc://127.0.0.1:32010</url>
                  	 	<info>HmIP-RF</info></ipc>
                  	 <ipc><name>CUxD</name>
                  	 	<url>xmlrpc_bin://127.0.0.1:8701</url>
                  	 	<info>CUxD</info></ipc></interfaces>  `
                  Was für ein System hattest du vor RaspberryMatic? `
                  eine Kombi von Docker mit IOBroker und nem Raspberry auf dem RaspberryMagic lief.
                    deimos
                    ich hatte gefragt, was du vor RaspberryMatic hattest. 😉
                    Problem kommt daher, dass in deiner rfd.conf das Interface 0 auskommentiert ist. Da darfst du aber nicht den gazen Block anpassen, sondern nur
                    [Interface 0]
                    Type = CCU2
                    Danach dann ein Reboot.
                    Diese Datei kommt aus deinem Backup, die muss also schon vorher defekt gewesen sein, daher auch die Frage, was du vor RaspberryMatic hattest. Oder hattest du vorher kein Funkmodul, sondern nur ein LAN GW?
                    Viele Grüße
                    Alex
                    • H Offline
                      Hightower1976
                      @deimos:
                      Ein paar Hue Lampen `
                      @deimos:
                      Viele Grüße
                      Alex `
                      Das Backup kommt aus dem RasperryMagic.
                      Der aktuell noch sauber laufen kann. Hab den noch in dem Zustand wie er Monate lang lieg.
                      Ich teste das nachher mal und gebe Feedback. Danke dir viel Mals.
                      • H Offline
                        Hightower1976
                        Hi Alex,
                        top. hat nun super funktioniert. Das ist es gewesen.
                        Danke dir
                        • madjack84M Offline
                          madjack84M Offline
                          madjack84
                          schrieb am zuletzt editiert von madjack84
                          @deimos :
                          iobroker arbeitet unter 192.168.178.24 und will sich per RPC mit der piVCCU3 verbinden. bei der Einrichtung hatte ich die 192.168.188.75 verwendet. Diese scheint sich nun nicht mehr auf den 192.168.178.24 zu ändern.
                          Weißt du wo ich das adaptieren könnte?
                          besten Dank :)
                          Lösung: RPC Adapter löschen und neu erstellen. Nun scheint es zu funktionieren. Ich beobachte mal und melde noch mal den Status. Es liegt nicht an piVCCU. Sorry für die RPC Unwissenheit :(
                          An der Stelle noch Danke für die gute Arbeit bei piVCCU!!!!
                          nuc i3, Proxmox, raspimatic (PI3), 15 shellies, shelly 4pro/25/RGB, wled sonoff, 7x xiaomi sensoren, 4xEchos, 4 Tasmota Steckdosen, motionEye, nspanel, Ring, hoymiles usw
