  4. SmartVisu
SmartVisu
75 Beiträge 13 Kommentatoren 16.6k Aufrufe 5 Beobachtet
    deta
    So etwas weiter.
    Wenn ich jetzt in der Config was speichern will, dann gibts einen Fehler
    ! PHP Warning: array_replace(): Argument #2 is not an array in /opt/iobroker/iobroker-data/smartvisu_0/lib/config.php on line 93 PHP Warning: Invalid argument supplied for foreach() in /opt/iobroker/iobroker-data/smartvisu_0/lib/includes.php on line 52 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19 PHP Warning: parse_ini_file(/opt/iobroker/iobroker-data/smartvisu_0/lang/config_lang.ini): failed to open stream: No such file or directory in /opt/iobroker/iobroker-data/smartvisu_0/lib/functions.php on line 19
      deta
      Jetzt geht nix mehr..
      ! smartVISU
      ! 15:23, 11.11, v2.9
      ! Error loading Page 'config_index' !
      ! Check config.php -> 'config_pages' for correct Pages/Project configuration
      ! or try the index page!
      Hab es schon komplett noch mal runter geschmissen und neu installiert, aber es geht nicht.
      Was ist das?
      • apollon77A Offline
        Komplett wirklich? Auch unter /opt/iobroker/iobroker-data/smartvisu.0 verzeichnis?
        Gesendet vom Handy …
          deta
          ja, bin schon weiter…. Mit Firefox gehts noch, bei Chrom schreibt er den Fehler... Hab ebend schon mal alls Cookies bei Chrom gelöscht, geht dennoch nicht.
            deta
            mh liegt das an der PHP Version? PHP Version 7.0.30-0+deb9u1
              An der Stelle kann ich dann nur an das smartvisu Projekt an sich verweisen. Mach dort im GitHub am besten ein issue auf. Der Adapter bietet nur eine Möglichkeit das smartvisu php auf dem iobroker Host auszuführen.
                deta
                Ich mache gerade ein System update beim Pi und dann geht php 7.1 mal sehen…
                  deta
                  So bin jetzt bei PHP 7.1 das selbe.. Auch die Daten werden nicht gespeichert. Wenn ich was ändere…
                  Hat noch jemand eine Idee?
                    deeznutz
                    #66
                    ich habe auch das Problem, dass die config.ini nicht gespeichert wird. Habe dazu ein Thema im knx userforum eingestellt: https://knx-user-forum.de/forum/support … %A4gt-fehl… Bisweilen kann man die config.ini von hand editieren um das System zumindest grundsätzlich zum laufen zu bringen. Btw., weiß jemand was ich in der config.ini eintragen muss um den Pagecache zu aktivieren :-) ?
                    Nils
                      deeznutz
                      #67
                      Hmm, da beißt sich die Katze in den Schwanz :-) Zitat des SmartVisu-Entwicklers: > Da dieses Problem ioBroker spezifisch ist, wirst du dort im Forum wahrscheinlich eher Hilfe kriegen als hier.
                      Was tun? Können wir irgendetwas loggen oder debuggen um da weiterzukommen?
                      Nils
                        #68
                        Naja, die Frage ist was davon ioBroker Spezifisch ist weil wir nichts anderes tun als einen PHP Interpreter als Adapter anzubieten. mehr ist der Adapter faktisch nicht.
                        Man muss also mit PHP-Wissen das mal untersuchen um rauszufinden warum das da Problematisch ist. Mein PHP ist zu lange her als das ich das in endlicher zeit rausbekomme.
                          deeznutz
                          #69
                          Ok, dann werde ich noch ein weinig rumprobieren um eine akzeptable Lösung zu finden. Bis dato komme ich auch damit klar, die Konfig per Hand zu editieren… Danke trotzdem!
                          Nils
                            #70
                            Formal warte ich ja auch immer noch auf eine finale smartvisu Version mit der man dann den Adapter offiziell veröffentlichen kann.
                            • D Nicht stören
                              D Nicht stören
                              dirkhe
                              #71
                              Das Problem mit dem Speichern konnte ich lösen, es fehlte der body-parser. Ich würde jetzt nochmal nen bisschen weitertesten und dann ein PR stellen. Für alle die auch schon mal weiter machen wollen
                              main.js
                              Zeile 18
                              var express = require('express');
                              var bodyParser = require('body-parser');
                              Zeile 124
                                  app.use(bodyParser.json());
                                  app.use(bodyParser.urlencoded({extended: true}));
                                  app.use(sphp.express(options));
                                  app.use(express.static(adapter.config.docRoot));
                                #72
                                cooooll … freue mich auf den PR.
                                Ansonsten war der Plan bisher auf die "offizielle 2.9" von Smartvisu zu warten weil aktuell im Adapter noch ein älterer GitHub Stand drin ist. Ich kann aber a sich den Adapter mit jedem Stand "unters Volk bringen" :-) Vllt hast Du auch hier einen Vorschlag
                                • D Nicht stören
                                  D Nicht stören
                                  dirkhe
                                  #73
                                  Ich mache mich jetzt gerade mal mit dem Ding vertraut. Auf jeden Fall habe ich festgestellt, dass es unter einem Apache echt wesentlich performanter läuft als den Wrapper über sphp. Ich würde daher empfehlen einen echten php Webserver aufzusetzten.
                                  Ich checke jetzt auch erstmal direkt von github aus.
                                    #74
                                    Das kann gut sein. Wenn jemand das kann dann ist das der sinnvolle Weg. Für kleinere Anwendungen war die Idee ein "rundum sorglos Paket" anzubieten was als Adapter kommt :-)
                                      Doemel
                                      schrieb am zuletzt editiert von Doemel
                                      #75
                                      gibt es mittlerweile etwas neues zum Adapter?
                                      Ich habe folgendes Problme und zwar bleibt der Adapter bei mir rot. Edit: Mittlerweile ist er grün, habe einfach mal das System komplett rebootet.
                                      System: Debian 9 im LXC Container unter Proxmox
                                      npm 6.90
                                      node + nodejs 10.16.0
                                      PHP 7.3
                                      Woran kann das liegen, habe ansonsten keine Infos gefunden zur Installation.
                                      Es scheinen aber einige Dateien zu fehlen. Wo liegt mein Fehler?
