  4. [Problem] Dream btw. Enigma2 Adapter
739 Beiträge 82 Kommentatoren 287.7k Aufrufe 15 Beobachtet
  • dslraserD Offline
    dslraserD Offline
    dslraser
    #446
    @NightWatcher:
    Aktuelle Version: https://github.com/Bjoern3003/ioBroker.enigma2
    Base64 Icons sind bei den Bouquets nun auch enthalten. `
    Läuft leider nicht…
    host.DSHOME	2018-10-30 19:43:41.708	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at Parser.emit (events.js:211:7)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at emitOne (events.js:116:13)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:258:7
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:502:7)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at getResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:229:20)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at Object.get (http.js:42:13)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at request (http.js:38:10)
    Caught	2018-10-30 19:43:41.708	error	by controller[0]: at new ClientRequest (_http_client.js:127:13)
    Caught	2018-10-30 19:43:41.707	error	by controller[0]: TypeError: Request path contains unescaped characters</anonymous>
    • dslraserD Offline
      dslraserD Offline
      dslraser
      #447
      @Matten Matten:
      Moin,
      ich hab jetzt das CodeCleaning von <u>NightWatcher</u> übernommen,
      und die dabei entstandenen Probleme beseitigt:
      in Standby = true
      Mute = true
      Command Button waren ohne Funktion
      jetzt schon großen Dank an NightWatcher :!:
      Enigma2 V1.1.1
      Matten Matten `
      Moin,
      ich habe mich gewundert warum meine Kanalumschaltung nicht mehr funktioniert…. Ich prüfe im Script ob die Box an oder aus ist.
      Der Datenpunkt unter enigma2/STANDBY ist immer true, egal ob an oder aus (Mute auch). Ich habe schon neu installiert und auch upload gemacht, der Fehler bleibt bei mir. Kannst Du das bitte nochmal prüfen ?
      • Matten MattenM Offline
        Matten Matten
        #448
        @dslraser:
        Moin,
        Bildschirmfoto 2018-11-01 um 07.33.54.png `
        Die Probleme sind leider seit dem letzten Pull request von NightWatcher wieder da,
        ich werde den Code erneut abändern, das der Adapter wieder läuft.
        Matten Matten
        ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
        • dslraserD Offline
          dslraserD Offline
          dslraser
          #449
          @Matten Matten:
          @dslraser:
          Moin,
          Matten Matten ` Danke Dir
          • hg6806H Offline
            hg6806H Offline
            hg6806
            #450
            Moin!
            Wollte nur Rückmeldung geben, dass in der V 1.1.1 die Play/Pause-Taste nun an der DM7020HD funktioniert.
            Eine Frage ist aber noch offen, welches Widget Ihr für die Testen benutzt.
            Bei dem hqwidget On/Off werden oft bei 1x Drücken 2 Tastendrücke erkannt.
              Matten Matten
              #451
              @hg6806:
              Moin!
              Bei dem hqwidget On/Off werden oft bei 1x Drücken 2 Tastendrücke erkannt. `
              Sorry, da sind jetzt die vis Profis gefragt, ich gebe alle Werte an meine HM CCU weiter und verwende mediola aio neo als Visualisierung.
              Matten Matten
                mikiline
                #452
                @Matten Matten:
                @dslraser:
                Moin,
                Matten Matten `
                Ich erlaube mir mal eine kleine Kritik auszusprechen.
                Es ist schön das sich 2 Entwickler bereit erklären den Adapter weiter zu entwickeln, jedoch ist es nicht sehr schön wie es abläuft. Es wäre doch besser wenn ihr Euch den Adapter auf einer Ressource teilt. Somit gibt es auch immer nur einen Adapterkink zum Installieren und wir reden alle von der gleichen Version.
                Mit mal hier und mal da gibt es meiner Meinung nach nur Verwirrung
                Ansonsten natürlich Top Arbeit und vielen Dank für den Einsatz, der auch immer prombt erfolgt wenn es ein Problem gibt!
                  Matten Matten
                  #453
                  @dslraser:
                  Moin,
                  V1.1.2 Bitte testen
                  bei Möglichkeit, alle Adapter Instanzen löschen, dann auf V1.1.2 updaten und die Instanzen wieder hinzufügen
                  Matten Matten
                  • dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #454
                    @Matten Matten:
                    @dslraser:
                    Moin,
                    V1.1.2 Bitte testen
                    Matten Matten ` okay, danke.
                    Mache ich heute Abend, bin jetzt arbeiten.
                    • J Offline
                      Jan1
                      #455
                      Na diese Version läuft nun auch bei mir, bis jetzt ohne ständige Neuverbindungen zur Dream und Zahnräder an der Dream ;)
                      • dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #456
                        Ich habe es mal per VPN installiert, danke Dir, nun läuft wieder alles.
                        • BBTownB Offline
                          BBTownB Offline
                          BBTown
                          #457
                          mir wird nur die v.1.1.1 angeboten.
                          auch wenn ich über https://github.com/Bjoern3003/ioBroker.enigma2 gehe
                          • dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #458
                            @BBTown:
                            auch wenn ich über https://github.com/Bjoern3003/ioBroker.enigma2 gehe ` https://github.com/Matten-Matten/ioBroker.enigma2.git
                            • BBTownB Offline
                              BBTownB Offline
                              BBTown
                              #459
                              das ist nicht euer ernst …
                              ... jetzt verstehe ich worauf @mikiline hinaus wollte, das ist absurd!!
                                sellino
                                #460
                                ich versuche seit einiger Zeit einen EPG für meinen Bedürfnisse ins Vis einzubinden komm aber nicht richtig weiter.
                                könnt ihr mir bitte bei dem viewtopic.php?f=30&t=18117 Posting helfen? :?
                                Sry, ich wollt nicht den gleichen Post kopieren und einfügen. :roll:
                                • BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  #461
                                  erstes Feedback zur v.1.1.2
                                  • das Polling bzw. die Log-Einträge sind weg
                                  • der genutze Arbeitsspeicher ist stabil bei ca. 45MB
                                  • das ganze an meiner DM8000
                                  well done!!
                                  • J Offline
                                    Jan1
                                    #462
                                    Das zweite!
                                    Ich habe schon geschrieben, dass die 1.1.2 bei mir endlich auch wieder läuft ;)
                                    • BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #463
                                      @Jan1:
                                      Das zweite!
                                      Ich habe schon geschrieben, dass die 1.1.2 bei mir endlich auch wieder läuft ;) ` <u>MEIN</u> erstes feedback ;)
                                      • N Offline
                                        N Offline
                                        NightWatcher
                                        #464
                                        @BBTown:
                                        ... jetzt verstehe ich worauf @mikiline hinaus wollte, das ist absurd!! `
                                        das ist nicht absurd, dass ist der Sinn hinter github. Das meine Version benutzt wird, wurde nie erwartet. Ich biete die nur zum "test". Ich bin bei mir auch bereits einige Stunden weiter, das ist aber noch nicht öffentlich.
                                        es ist jede Menge Arbeit, die vorhandene Version zu entschlanken und zu optimieren.
                                        Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
                                        • dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #465
                                          @NightWatcher:
                                          @BBTown:
                                          es ist jede Menge Arbeit, die vorhandene Version zu entschlanken und zu optimieren. `
                                          Danke Dir für Deine Mühe….
                                          hattest Du meinen Hinweis gesehen ?
                                          viewtopic.php?f=17&t=1739&start=440#p188850
