  4. [Aufruf] DENON & Marantz Adapter
denon
335 Beiträge 28 Kommentatoren 93.7k Aufrufe 11 Beobachtet
    BlueEssi
    #238
    Sorry, wusste nicht, dass ich hätte etwas testen können.
    Der Fehler trat beim ersten Start immer noch auf. Fehlerlog:
    denon.0 2018-09-28 22:25:58.256 error at Manager.ondata (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:335:16)
    denon.0 2018-09-28 22:25:58.256 error at Decoder.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\index.js:251:12)
    denon.0 2018-09-28 22:25:58.256 error at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    denon.0 2018-09-28 22:25:58.256 error at Decoder. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    denon.0 2018-09-28 22:25:58.256 error at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:345:8)
    denon.0 2018-09-28 22:25:58.256 error at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    denon.0 2018-09-28 22:25:58.256 error at Manager. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    denon.0 2018-09-28 22:25:58.256 error at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:244:12)
    denon.0 2018-09-28 22:25:58.256 error at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:319:9)
    denon.0 2018-09-28 22:25:58.256 error at Socket.adapter.getObject (C:\ioBroker\node_modules\iobroker.denon\main.js:762:66)
    denon.0 2018-09-28 22:25:58.256 error TypeError: Cannot read property 'common' of null
    denon.0 2018-09-28 22:25:58.256 error uncaught exception: Cannot read property 'common' of null</anonymous></anonymous>
    Beim zweiten Start der Instanz ging es dann aber.
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #239
      Oh gerade mindestens noch ein Copy Paste Fehler entdeckt, Picture Mode wird als Button angelegt.
      Ich schaue eben mal.
      Videotutorials & mehr
        foxriver76F Offline
        foxriver76
        #240
        Tests laufen eben durch, danach ist die Sache gefixt. Wenn du sowieso einen fähigen Receiver hast, wäre es cool wenn du dann mal probierst den pictureMode zu setzen.
        beste Grüße
        fox
          foxriver76F Offline
          foxriver76
          #241
          Aufgrund von https://github.com/foxriver76/ioBroker.denon/issues/25 bietet 0.5.0 nun die Funktionalität die Speaker Level anzupassen und auszulesen für das aktuelle selectInput.
          Dies ist derzeit möglich für 1x Center 2x Front Speaker und 2x Surround Speaker.
          beste Grüße
          fox
          • E Offline
            Eloee
            #242
            Habe einen Marantz NR1506 bei welchem auch das meiste funktioniert, vielen Dank dafür schonmal!
            Allerdings habe ich auf der Fernbedienung 4 "Smart Select" Knöpfe, auf welche ich mir Internetradio Sender programmiert habe, weil ich die sonst nicht eingeschaltet bekomme da man da immer wieder den Sender neu auswählen muss…
            Habe nun schon mit den quickSelect1-5 States versucht diese Smartselect Einstellungen zu triggern, funktioniert aber leider nicht :?
            Kannst du die SmartSelect Knöpfe auch noch irgendwie aufnehmen?
            Liebe Grüße
            Eloee
              foxriver76F Offline
              foxriver76
              #243
              @Eloee:
              Liebe Grüße
              Eloee `
              "Smart Select" ist wohl Marantz Äquivalent zu "Quick Select"?
              Probier mal bitte mittels settings.exertCommand z. B.
              ZMSMART1
              oder nur
              SMART1
                foxriver76F Offline
                foxriver76
                #244
                Habe in dem Zusammenhang sogar herausgefunden, dass man die Quick Select Source anscheinend doch abfragen kann. Somit könnte man aus den Buttons einen Key-Value state machen, der auch einen acknowledge bekommt. Leider kommt der nicht von selbst und muss mit gepollt werden.
                Dies scheint man mittels
                MSQUICK ?
                für DENON zu erfragen. Bei Marantz entsprechend
                MSSMART ?
                Das würde ebenfalls ermöglichen, für die jeweiligen Marken die Funktionalität zu wechseln.
                  foxriver76F Offline
                  foxriver76
                  #245
                  Bitte GitHub 0.6.0 probieren. Die Buttons werden nicht mehr funktionieren, sondern dafür der quickSelect Datenpunkt, mit Nummern von 1-5.
                  Die quickSelect Buttons bitte manuell löschen, nach einem Upgrade.
                  • E Offline
                    Eloee
                    #246
                    Habe es gestern Nacht noch getestet, funktioniert nun super mit der 0.6.0, vielen Dank für die Mühen !!!!!!
                    Falls sonst jemand weiß, wie man bei einem NR1506 (nicht über SmartSelect) einen Internetradio Sender auswählen kann, immer her damit :)
                    Liebe Grüße
                    Eloee
                      foxriver76F Offline
                      foxriver76
                      #247
                      Mir ist vorhin aufgefallen, dass man Bluetooth nicht über selectInput ansteuern konnte. Habe es nun hinzugefügt, via:
                      setState('denon.0.zoneMain.selectInput', '22', false);
                      oder
                      setState('denon.0.zoneMain.selectInput', 'BT', false);
                      möglich ab 1.1.0. Wer BT nutzen möchte, ohne den Adapter neu hinzuzufügen, sollte die betroffenen States (zoneMain.selectInput + evtl. die der anderen Zones) ein mal löschen.
                      beste Grüße
                      fox
                        foxriver76F Offline
                        foxriver76
                        #248
                        @Eloee:
                        Liebe Grüße
                        Eloee `
                        Ab morgen im Latest, was auch dir helfen könnte, falls von dir nicht sogar der Wunsch auf Github kam:
                        Version 1.2.0 mit den folgenden neuen States:
                        • info.onlinePresets
                        • settings.savePreset
                        • settings.loadPreset
                        Erklärung der States findet ihr hier: https://github.com/foxriver76/ioBroker. … /README.md
                        Einfach mit Strg+F den gewünschten State suchen.
                        beste Grüße
                        fox
                        • C Offline
                          church
                          #249
                          Ich muss mal blöd fragen:
                          Wo finde ich "mute"?
                          Wurde ja öfters hier im Thread erwähnt, ich sehe aber nur "muteIndicator", was scheinbar readonly ist?!
                            foxriver76F Offline
                            foxriver76
                            #250
                            @church:
                            Wurde ja öfters hier im Thread erwähnt, ich sehe aber nur "muteIndicator", was scheinbar readonly ist?! `
                            Ich habe im Post oben drüber die Doku verlinkt, ist sogar auf Deutsch.
                            • MicM Offline
                              MicM Offline
                              Mic
                              #251
                              @foxriver76:
                              • settings.loadPreset `
                              Klasse, vielen Dank für diese neue Funktion! Läuft soweit sehr gut bei mir :) Endlich kann ich damit über VIS die Online-Musik ansteuern.
                                foxriver76F Offline
                                foxriver76
                                #252
                                @Mic:
                                @foxriver76:
                                Klasse, vielen Dank für diese neue Funktion! Läuft soweit sehr gut bei mir :) Endlich kann ich damit über VIS die Online-Musik ansteuern. `
                                Freut mich, vielen Dank fürs Feedback.
                                • hg6806H Offline
                                  hg6806H Offline
                                  hg6806
                                  #253
                                  Klasse Funktion!
                                  Ich hatte mir die Sender als Buttons programmiert, und über HTTP Get kann man dann den entspr. Sender auswählen.
                                  Mit der neuen Funktion ist es natürlich eleganter.
                                  Wie stellt ihr denn das JSON Widget "Basic table" ein?
                                  Ich bekomme da nichts angezeigt wenn ich da unter Tablr Object ID den Datenpunkt einsetze.
                                    foxriver76F Offline
                                    foxriver76
                                    #254
                                    @hg6806:
                                    Klasse Funktion!
                                    Ich bekomme da nichts angezeigt wenn ich da unter Tablr Object ID den Datenpunkt einsetze. `
                                    Hatte das nicht getestet, mit der Visualisierung. Die läuft wohl nur mit einer JSON Liste. Pushe gleich was:
                                    Minimal Working Example sobald ich gepusht habe schaut so aus:
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      #255
                                      Das Widget müsste doch das "Basic table" sein, oder?
                                      Wie sind denn da die Einstellungen?
                                        foxriver76F Offline
                                        foxriver76
                                        #256
                                        Du brauchst 1.2.1 des DENON Adapters. Kannst von Git holen oder morgen latest oder Konsole mit npm holen.
                                        Dann sollte es mit dem Widget klappen.
                                        • MicM Offline
                                          MicM Offline
                                          Mic
                                          #257
                                          Danke, hab mir den 1.2.1 installiert, aber ich mag lieber eine HTML-Ausgabe in VIS, in der ich direkt auf einen der Preset drücken kann, und dieser dann automatisch gesetzt und per CSS als solches markiert wird.
                                          Habe daher folgendes Script für Denon-Adapter 1.2.1 erstellt, das das JSON entsprechend umwandelt und in einen Datenpunkt setzt.
                                          `const DSTATE_PATH = 'javascript.0.mic.denon-support.';
                                          createState(DSTATE_PATH + 'onlinePresetHtml', '', false);
                                          on('denon.0.settings.loadPreset', refreshPresetList);
                                          on('denon.0.info.onlinePresets', refreshPresetList);
                                          refreshPresetList();
                                          function refreshPresetList() {
                                              currentPreset   = getState('denon.0.settings.loadPreset').val;
                                          	var jsonPreset = JSON.parse(getState('denon.0.info.onlinePresets').val);
                                          	var html = '';
                                              for(var i = 0; i < jsonPreset.length; i++) {
                                                  var obj = jsonPreset[i];
                                                  if ( (obj !== undefined) && (obj !== null) ) {
                                                      if (obj.channel !== '') {
                                          		        html += '';
                                          		        html += '';
                                                  		html += '';
                                          	html += '
                                                          var strCSSCurrPreset = '';
                                                          if(Number(currentPreset) == Number(obj.id)) strCSSCurrPreset = ' id="current-preset"';
                                                  		html += '' + obj.id + '. ' + obj.channel + '';
                                                  		html += ' |
                                          	setState(DSTATE_PATH + 'onlinePresetHtml', html, true);
                                          Das Script bereinigt auch die leeren, nicht gesetzten. Presets
                                          Dann eingebunden via Widget "basic - HTML". Dort dann den HTML-Datenpunkt in geschweiften Klammern:
                                           ![6940_denon2.jpg](/assets/uploads/files/6940_denon2.jpg)
                                          Hier als Ergebnis meine **~~[b]~~experimentelle[/b]** View (muss ich noch hübsch machen und mehr einbauen), links stehen die Online-Radiosender vom Denon, aktuell ausgewählt ist Nr. 1, beim Drücken auf einen anderen wird dieser entsprechend ausgewählt und mittels CSS id "current-preset" entsprechend die Farbe (hier: #14d8cc) zugewiesen.
                                           ![6940_denon.png](/assets/uploads/files/6940_denon.png) [/i]
