  4. Z-Wave Adapter Problem
10 Beiträge 4 Kommentatoren 3.8k Aufrufe
  • R Offline
    RDevil63
    ich bräuchte mal Hilfe.
    Habe Open-Zwave compiliert und kann den Adapter auch im Open-ZWave-Control Panel initialisieren und sehe meine Devices.
    Im iobroker gibt es beimHinzufügen des Adapters und auswählen des Devices folgenden Fehler.
    Kann mir da jemand weiterhelfen?
    host.raspberrypi	2018-03-22 16:48:58.514	info	Restart adapter system.adapter.zwave.0 because enabled
    host.raspberrypi	2018-03-22 16:48:58.514	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
    Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Module._compile (module.js:577:32)
    Caught	2018-03-22 16:48:58.514	error	by controller[0]: at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at require (internal/module.js:20:19)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Module.require (module.js:504:17)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Function.Module._load (module.js:445:3)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at tryModuleLoad (module.js:453:12)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Module.load (module.js:494:32)
    Caught	2018-03-22 16:48:58.513	error	by controller[0]: at Object.Module._extensions..node (module.js:604:18)
    Caught	2018-03-22 16:48:58.512	error	by controller[0]: at Error (native)
    Caught	2018-03-22 16:48:58.510	error	by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2018-03-22 16:48:58.494	info	terminating
    zwave.0	2018-03-22 16:48:58.433	error	at Object.Module._extensions..js (module.js:586:10)
    zwave.0	2018-03-22 16:48:58.433	error	at Module._compile (module.js:577:32)
    zwave.0	2018-03-22 16:48:58.433	error	at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
    zwave.0	2018-03-22 16:48:58.433	error	at require (internal/module.js:20:19)
    zwave.0	2018-03-22 16:48:58.433	error	at Module.require (module.js:504:17)
    zwave.0	2018-03-22 16:48:58.433	error	at Function.Module._load (module.js:445:3)
    zwave.0	2018-03-22 16:48:58.433	error	at tryModuleLoad (module.js:453:12)
    zwave.0	2018-03-22 16:48:58.433	error	at Module.load (module.js:494:32)
    zwave.0	2018-03-22 16:48:58.433	error	at Object.Module._extensions..node (module.js:604:18)
    zwave.0	2018-03-22 16:48:58.433	error	at Error (native)
    zwave.0	2018-03-22 16:48:58.433	error	Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2018-03-22 16:48:58.430	error	uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2018-03-22 16:48:58.331	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v6.13.1
    host.raspberrypi	2018-03-22 16:48:56.830	info	instance system.adapter.zwave.0 started with pid 4622
    • arteckA Offline
      arteckA Offline
      arteck
      da fehlt der symlink
      machmal
      sudo ldconfig
      • R Offline
        RDevil63
        Problem gelöst,
        danke für die Info :D
        • AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          Nächstes Mal einen Blick in die Adapter-Anleitung werfen ;)
          Steht alles da: https://github.com/ioBroker/ioBroker.zw … stallation
            mrmomba
            Leider fehlen da zwei Kommandos unter den Known-Issue:
            Die Befehle müssen genau so abgesetzt werden, in der Reihenfolge.
            $ sudo ln -s /usr/local/lib64/libopenzwave.so /usr/local/lib/libopenzwave.so
            $ sudo ln -s /usr/local/lib64/libopenzwave.so.1.4 /usr/local/lib/libopenzwave.so.1.4
            $ sudo ldconfig
            • arteckA Offline
              arteckA Offline
              arteck
              @mrmomba:
              $ sudo ldconfig `
              dir ist klar das die Ordner nicht auf jedem System da sind.. ist dir klar was du da machst ?? oder hast das irgendwo mal gefunden ..
              auf meinem pi ist das total unfug da die /usr/local/lib64/ nicht da sind also was soll ich da als verlinkung reinstellen….
                mrmomba
                Nun,
                so klar ist es mir nicht, aber es war die Lösung für mein Ubuntu auf dem x64.
                Alles andere aus der Anleitung brachte bei mir keine Lösung.
                Es sollte zumindest irgendwo stehen - der Hinweis kommt von der OpenZwave-Seite…
                • arteckA Offline
                  arteckA Offline
                  arteck
                  und da sind wir wieder bei Systemspezifikationen….
                    AlCalzoneA Offline
                    AlCalzone
                    @mrmomba:
                    Es sollte zumindest irgendwo stehen - der Hinweis kommt von der OpenZwave-Seite… `
                    Danke. Für sowas bitte Github Issues erstellen, damit die richtigen Leute es auch sicher lesen. Habe das mal getan.
                      mrmomba
                      @AlCalzone:
                      @mrmomba:
                      Danke. Für sowas bitte Github Issues erstellen, damit die richtigen Leute es auch sicher lesen. Habe das mal getan. `
                      Ich muss gestehen, ich bin ein Git-Hub-Dau und ich müsste mich registrieren.
