  4. Js-controller 1.5.3 in latest verfügbar
97 Beiträge 27 Kommentatoren 21.1k Aufrufe
  • sigi234S Online
    sigi234S Online
    @apollon77:
    @sigi234:
    Noch immer der Fehler EMPTY ID
    host.Medion	2018-09-15 22:20:24.375	info	instance system.adapter.vis.0 terminated while should be started once
    vis.0	2018-09-15 22:20:20.822	info	vis license is OK.
    vis.0	2018-09-15 22:20:20.712	info	starting. Version 1.1.7 in C:/ioBroker/node_modules/iobroker.vis, node: v8.11.3
    vis.0	2018-09-15 22:20:20.665	debug	statesDB connected
    vis.0	2018-09-15 22:20:20.665	debug	objectDB connected
    javascript.0	2018-09-15 22:20:01.049	info	script.js.Sigi.UWZ: []
    javascript.0	2018-09-15 22:20:01.033	info	script.js.Sigi.UWZ: []
    host.Medion	2018-09-15 22:19:50.039	info	instance system.adapter.feiertage.0 terminated with code 0 (OK)
    feiertage.0	2018-09-15 22:19:49.522	info	adapter feiertage objects written
    feiertage.0	2018-09-15 22:19:49.522	info	Next holiday: Nationalfeiertag in Österreich is in 41 days on 26.10.2018
    feiertage.0	2018-09-15 22:19:49.459	info	starting. Version 1.0.9 in C:/ioBroker/node_modules/iobroker.feiertage, node: v8.11.3
    host.Medion	2018-09-15 22:19:48.131	info	instance system.adapter.feiertage.0 started with pid 8320
    host.Medion	2018-09-15 22:19:48.100	info	instance scheduled system.adapter.feiertage.0 0 0 * * *
    host.Medion	2018-09-15 22:19:40.090	info	instance scheduled system.adapter.daswetter.0 14,43,59 * * * *
    host.Medion	2018-09-15 22:19:14.413	info	instance system.adapter.ical.2 terminated with code 0 (OK)
    web.0	2018-09-15 22:19:14.365	info	<==Disconnect system.user.admin from ::1 vis.0
    Hast du hier bitte mal noch die Browser consolen ausgabe?
    Gesendet vom Handy … `
    Create inner vis object hm-rpc.0.xxxxxxxxxx.4.MANU_MODE
    vis.js:2970 Create inner vis object ping.0.MedionPc.192_xxxxxxxxxxx
    vis.js:2970 Create inner vis object kodi.0.previous
    vis.js:2970 Create inner vis object 127.0.0.1:80
    vis.js:2970 Create inner vis object kodi.0.clear
    vis.js:2970 Create inner vis object kodi.0.system.Reboot
    vis.js:2970 Create inner vis object kodi.0.system.Shutdown
    vis.js:2970 Create inner vis object hm-rpc.0.OEQxxxxxxxxx.1.STATE
    vis.js:2970 Create inner vis object hue.0.Philips_hue.WC.on
    vis.js:2970 Create inner vis object 125
    vis.js:2970 Create inner vis object 100
    vis.js:2970 Create inner vis object 50
    vis.js:2970 Create inner vis object ping.0.MedionPc.192_16xxxx_22
    vis.js:2970 Create inner vis object hm-rpc.0.Nxxxxxxxx.1.LOWBAT
    vis.js:2970 Create inner vis object ping.0.MedionPc.192_168_178
    vis.js:2970 Create inner vis object 0
    vis.js:2970 Create inner vis object system.adapter.javascript.0.alive
    vis.js:2970 Create inner vis object javascript.0.HWInfo.MedionPc.CPU.Load
    vis.js:2970 Create inner vis object javascript.0.HWInfo.MedionPc.CPU.Speed
    vis.js:2970 Create inner vis object javascript.0.HWInfo.MedionPc.CPU.Temp
    vis.js:2970 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.next
    vis.js:2970 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.prev
    vis.js:2970 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.playPause
    vis.js:2970 Create inner vis object ping.0.Medion.192_168_178_51
    vis.js:2970 Create inner vis object ping.0.MedionPc.192_168_178_35
    vis.js:2970 Create inner vis object vis.0.Huawai.battery.level
    vis.js:2970 Create inner vis object hm-rpc.0.NEQ1xxxxxxxxxxxUNREACH
    vis.js:2970 Create inner vis object hm-rpc.0.NExxxxxxxxxxxxx.STICKY_UNREACH
    vis.js:2970 Create inner vis object hm-rpc.0.xxxxxxxxxxxxxx0.UNREACH
    vis.js:2970 Create inner vis object system.adapter.hue.0.connected
    vis.js:2970 Create inner vis object javascript.0.scriptEnabled.Ansage_Temperatur
    vis.js:2970 Create inner vis object javascript.0.scriptEnabled.Ansage_Wind
    vis.js:2970 Create inner vis object javascript.0.scriptEnabled.Ansage_alles
    vis.js:2970 Create inner vis object javascript.0.scriptEnabled.Ansage_Hausmüll
    vis.js:2970 Create inner vis object javascript.0.scriptEnabled.Ansage_Geburtstag
    vis.js:2970 Create inner vis object http://192.168.178.27:50000/tts=test
    vis.js:2970 Create inner vis object javascript.0.Status.Lichter.State
    vis.js:2970 Create inner vis object hm-rpc.0.NEQ1xxxxxxxxxxx.POWER
    vis.js:2970 Create inner vis object 150
    vis.js:2970 Create inner vis object 962
    vis.js:2970 Create inner vis object 940
    vis.js:2970 Create inner vis object 1200
    vis.js:2970 Create inner vis object 200
    vis.js:2970 Create inner vis object dwd.0.warning.text
    vis.js:2970 Create inner vis object dwd.0.warning.severity
    vis.js:2970 Create inner vis object javascript.2.Grafana.DashboardURL
    vis.js:2970 Create inner vis object daswetter.0.NextDaysDetailed.Location
    vis.js:2970 Create inner vis object daswetter.0.NextDaysDetailed.0d.4h.Clouds
    vis.js:2970 Create inner vis object tun
    vis.js:2970 Create inner vis object yamaha.0.Realtime.BT.DEVICENAME
    translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
    7translate.js:20 "ctrl - Bool": {"en": "ctrl - Bool", "de": "ctrl - Bool", "ru": "ctrl - Bool"},
    edit.html:18038 Version vis-timeandweather: 1.1.7
    jquery.zweatherfeed.js:555 w01297
    bars.js:55 Version vis-bars:0.1.4
    selectID.js:771 Error: Assertion failed
        at Function.error (jquery-1.11.2.min.js:2)
        at d (jquery.fancytree-all.min.js:40)
        at g (jquery.fancytree-all.min.js:40)
        at r.nodeRender (jquery.fancytree-all.min.js:40)
        at r.nodeRender (jquery.fancytree-all.min.js:12)
        at r._callHook (jquery.fancytree-all.min.js:12)
        at f (jquery.fancytree-all.min.js:13)
        at r.nodeSetExpanded (jquery.fancytree-all.min.js:13)
        at r.h (jquery.fancytree-all.min.js:12)
        at r.nodeSetExpanded (jquery.fancytree-all.min.js:40)
    (anonymous) @ selectID.js:771
    visit @ jquery.fancytree-all.min.js:12
    showActive @ selectID.js:764
    initTreeDialog @ selectID.js:3178
    show @ selectID.js:3541
    $.fn.selectId @ selectID.js:3921
    click @ visEditInspect.js:109
    dispatch @ jquery-1.11.2.min.js:3
    r.handle @ jquery-1.11.2.min.js:3
    selectID.js:417 Error: Assertion failed
        at q.render (jquery.fancytree-all.min.js:12)
        at q.sortChildren (jquery.fancytree-all.min.js:12)
        at sort (selectID.js:415)
        at sort (selectID.js:421)
    selectID.js:417 Error: Assertion failed prev. row must have a tr, or is system root
    • kmxakK Offline
      kmxakK Offline
      kmxak
      Erstmal nur zur Info
      folgender fehler kam auf allen meinen iobroker installationen von 1.5.2 auf 1.5.3
      iobroker controller daemon stopped.
      fs.js:1177
      return binding.chmod(pathModule._makeLong(path), modeNum(mode));
      ! Error: ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/iobr oker.js-controller/lib/../killall.sh'
      at Error (native)
      at Object.fs.chmodSync (fs.js:1177:18)
      at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/s etup.js:286:32)
      at emitOne (events.js:101:20)
      at Daemon.emit (events.js:188:7)
      at Daemon. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.j s:267:14)
      at Daemon._tryKill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:2 77:23)
      at ontimeout (timers.js:386:11)
      at tryOnTimeout (timers.js:250:5)
      at Timer.listOnTimeout (timers.js:214:5)</anonymous>
      SSL Fehler beim Telegram adapter ist noch da. Ansonsten nutze ich aktuell kein ssl
      host.ioBroker	2018-09-15 22:51:52.059	error	instance system.adapter.telegram.0 terminated with code 0 (OK)
      host.ioBroker	2018-09-15 22:51:52.059	error	Caught by controller[1]: at WritableState.onwrite (_stream_writable.js:90:5)
      host.ioBroker	2018-09-15 22:51:52.059	error	Caught by controller[1]: at onwrite (_stream_writable.js:378:7)
      host.ioBroker	2018-09-15 22:51:52.059	error	Caught by controller[1]: at afterWrite (_stream_writable.js:387:3)
      host.ioBroker	2018-09-15 22:51:52.059	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:249:5
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:368:7
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:536:18
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:841:10)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WebSocket.emit (events.js:191:7)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at emitTwo (events.js:106:13)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:442:14)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:268:10)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:451:14)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      host.ioBroker	2018-09-15 22:51:52.058	error	Caught by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:724:21)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.telegram/main.js:65:32
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Object.Greenlock.create (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:258:13)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at promisifyAllSelf (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:15:20)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at Array.forEach (native)
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:17:33
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[1]: TypeError: util.promisify is not a function
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319\. at module.js:577:32
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[0]: In the future, you will have to enable it yourself.
      host.ioBroker	2018-09-15 22:51:52.057	error	Caught by controller[0]: Sat, 15 Sep 2018 20:51:51 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      telegram.0	2018-09-15 22:51:51.542	error	TypeError: util.promisify is not a function at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:17:33 at Array.forEach (native) at promisifyAllSelf (/opt/i
      telegram.0	2018-09-15 22:51:51.542	error	uncaught exception: util.promisify is not a function</anonymous></anonymous></anonymous></anonymous>
      Gruß Alex
        Kev0
        mit dem zurückspielen auf 1.4.2 ist bei mir wieder alles im Lot.
        Denke da ist noch irgendwo der wurm drin
        • apollon77A Offline
          Was heisst alles im lot? Plötzlich alle states und Objekte wieder da die vorher fehlten der wie?
          Du bist gerade der einzige mit diesem Problem und das ist sehr komisch :-(
            Kev0
            Ja die States und Instances sind wieder wie vor dem Update vorhanden. Zum Glück ;-) Ich weiss nicht was schief gelaufen ist, ich konnte jedoch nach mehrmaligem reboot ( auch vom Strom trennen) keinen normalen Zustand herbeiführen. Jedes mal wurden die Instanzen nicht sauber geladen und states sowie Skripte waren futsch.
            • ChaotC Offline
              ChaotC Offline
              Chaot
              Bei mir sind die DashButton außer Funktion:
              host.haus	2018-09-15 22:37:51.275	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:25)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:830:13)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:54)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5290:18)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter.emit (events.js:208:7)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at emitNone (events.js:106:13)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
              Caught	2018-09-15 22:37:51.275	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
              Caught	2018-09-15 22:37:51.274	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
              Caught	2018-09-15 22:37:51.274	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
              Caught	2018-09-15 22:37:51.274	error	by controller[0]: Error: socket: Operation not permitted
              host.haus	2018-09-15 22:37:50.499	info	instance system.adapter.amazon-dash.0 started with pid 2380</anonymous>
              Wenn ich versuche nachzuinstallieren habe ich das hier in der Konsole:
              root@haus:/home/haus# npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" --unsafe-perm
              npm ERR! code 128
              npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
              npm ERR! fatal: failed to stat '/root/.npm/_cacache/tmp/git-clone-5a5e4840': Permission denied
              npm ERR!
              npm ERR!     /root/.npm/_logs/2018-09-16T06_23_56_137Z-debug.log
              Bis Version 1.5.0. haben die Button funktioniert.
              1.5.1 und 1.5.2 habe ich ausgelassen.
                Operation not permitted weißt auf fehlende rechte hin. Das muss unter root laufen. Hat aber mit dem Controller nix zu tun.
                Beim install das gleiche.
                Ja für install ist in 1.5.x eine Änderung drin das es weniger Probleme geben sollte und mit —unsafe-perm installiert wird.
                Also kurz: der Adapter braucht root/sudo,war aber an dich schon immer so.
                • ChaotC Offline
                  ChaotC Offline
                  Chaot
                  Der Adapter muss im ioBroker unter root laufen?
                  Wie geht das?
                  Und warum hat das bisher einwandfrei funktioniert?
                  Die Installation (oder der Versuch) ist definitiv unter root erfolgt.
                  • StabilostickS Offline
                    Stabilostick
                    @chaot:
                    Mache bitte ein Downgrade von NPM auf 4.6.1 und versuche die Installation noch einmal.
                    npm i -g npm@4.6.1
                    • ChaotC Offline
                      ChaotC Offline
                      Chaot
                      Nachdem ich den JSControler neu installiert habe scheint alles wieder zu laufen.
                      Aber ich habe bei der Installation das nächste Problem bekommen:
                      npm WARN saveError ENOENT: no such file or directory, open '/home/haus/package.json'
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      npm WARN enoent ENOENT: no such file or directory, open '/home/haus/package.json'
                      npm WARN haus No description
                      npm WARN haus No repository field.
                      npm WARN haus No README data
                      npm WARN haus No license field.
                      + iobroker.js-controller@1.5.3
                      added 344 packages from 247 contributors and audited 785 packages in 74.181s
                      found 27 vulnerabilities (19 low, 8 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      root@haus:/home/haus# npm audit fix
                      npm ERR! code EAUDITNOPJSON
                      npm ERR! audit No package.json found: Cannot audit a project without a package.json
                      npm ERR!     /root/.npm/_logs/2018-09-16T07_42_12_245Z-debug.log
                      npm audit und npm audit fix geben den gleichen Fehler aus
                        @Chaot:
                        Die Installation (oder der Versuch) ist definitiv unter root erfolgt. `
                        Dann Versuch mal npm cache clean unter root
                          @Chaot:
                          npm audit und npm audit fix geben den gleichen Fehler aus `
                          Ignoriere das mit dem audit. Ist kein Fehler
                            Stabilostick
                            Die Warnung ist ok. Das ist kein Fehler. Deshalb brauchst Du auch den „audit fix“ nicht zu machen.
                              Kev0
                              Habs jetzt nochmal von 1.4.2 auf 1.5.3 probiert, selbes Ergebnis die hm-rpc datenpunkte haben keinen Namen mehr und Skripte sind alle futsch.
                              Leider habe ich keinen log von der installation.
                              • SteffS Offline
                                SteffS Offline
                                Steff
                                Moin,
                                habe in den letzten Tagen ebenfalls den js-controller von 1.4.9 über 1.5.0, 1.5.2 auf 1.5.3 "gehoben". Jeweils mit Reboot des RPi´s. Bisher habe ich keine Probleme erkennen können (Scripte laufen wie sie sollen, etc.). Lediglich folgende Dinge sind mir aufgefallen.
                                Seit 1.5.2 bekomme ich beim stoppen von ioBroker folgende Fehlermeldung:
                                fs.js:1177
                                ! Error: ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/iobroker.js-controller/lib/../killall.sh'
                                at Error (native)
                                at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:286:32)
                                at Daemon. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:267:14)
                                at Daemon._tryKill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:277:23)
                                Ein Update auf 1.5.3 brachte keine Veränderung. Ein Start von ioBroker ist ohne Fehlermeldung möglich.
                                Den Fehler mit der "Empty ID" in der Dateiauswahl kann ich ebenfalls bestätigen (zumindest ab 1.5.2).
                                Auch die Warnung im Log: "Disable logging, because no one socket connected" taucht des öfteren einmal auf, hauptsächlich wenn ich den Reiter Scripte" anklicke. Dies hat @metaxa eine Seite vorher ebenfalls beschrieben.
                                Gruß Steffen
                                ioBroker auf Intel NUC 7CJYH / Debian 13 "Trixie" / States & Objects in JSONL / Repo --> Beta / HM CCU2 V2.61.7 / Siemens LOGO! (0BA7 / 0BA8)
                                Admin V7.8.24 / Node V22.22.2 / NPM V10.9.7 / JSC V7.1.2 / JSE V9.2.2
                                • Dr. BakteriusD Offline
                                  Dr. Bakterius
                                  Ich habe ebenfalls die Fehlermeldungen beim Stoppen des iobroker. Dadurch bricht auch raspiBackup ab und erstellt keine Sicherung. Ebenfalls bei mir das Problem mit 'Empty ID' im VIS-Editor.
                                  Ich bin jetzt wieder zurück auf 1.4.2 - damit funktioniert alles. Vielleicht starte ich in ein paar Wochen wieder einen Versuch wenn sich der WAF wieder erholt hat. :)
                                  • L Offline
                                    lonsimbt
                                    Nach Upgrade auf meinem tinkerboard auf Version 1.5.3 laufen grundsätzlich alle Adapter und Skripte.
                                    Plattform: linux
                                    Die Architektur: arm
                                    CPUs: 4
                                    Geschwindigkeit: 1800 MHz
                                    Modell: ARMv7 Processor rev 1 (v7l)
                                    RAM: 1.9 GB
                                    System uptime: 03:19:44
                                    Node.js: v8.12.0
                                    Festplattengröße: 14.3 GiB
                                    Festplatten frei: 11.6 GiB
                                    Adapter zählen: 222
                                    NPM: v6.4.1
                                    Uptime: 03:19:28
                                    Aktivierte Instanzen: 16
                                    Beim Stoppen des iobroker erhalte ich ebenfalls eine Fehlermeldung:
                                    ` > Stopping iobroker controller daemon…
                                    fs.js:1123
                                    at Object.fs.chmodSync (fs.js:1123:18)
                                    at emitOne (events.js:121:20)
                                    at Daemon.emit (events.js:211:7)
                                    at ontimeout (timers.js:498:11)
                                    at tryOnTimeout (timers.js:323:5)
                                    at Timer.listOnTimeout (timers.js:290:5)</anonymous> `
                                    Gruß Marco
                                    iobroker im Container (debian Bullseye) unter proxmox 7.1
                                    debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                                    40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                                      AndyUM61
                                      nun möchte ich auch mal was zu dem Thema beitragen:
                                      Ist denn auch jemand hier der ioBroker unter Windows zu laufen hat?
                                      Ich habe mir durch den Versuch auf js-controller v.1.5.0 mein System ziemlich zerschossen.
                                      Die Systemauslastung lag dauerhaft auf 99%, es wurden bis zu 1000 Prozesse gestartet mit über 100.000 Handles - stätig steigend!!
                                      Es war nur sehr schwer möglich ioBroker überhaupt zu beenden.
                                      ioBroker hat meine sämtlichen Actoren, sei es Homematic, FritzBox oder MQTT per Zufall angesteuert. Das totale SmartHome-Chaos!!!
                                      Auf der FritzBox wurde sogar das WLAN deaktiviert!!
                                      Ich konnte mir nur behelfen, indem ich die Netzwerkverbindung zur Raspberrymatic vorerst physikalisch getrennt (Stecker gezogen) habe.
                                      Ich bin dann wieder auf die 1.4.2 gegangen, und alles funktioniert wieder halbwegs.
                                      Das Einzige was nicht mehr funktioniert ist die Adapter-Seite. Es werden keine Adapter angezeigt.
                                      Wenn ich auf das Schraubenschlüssel-Symbol gehe, sagt er mir, dass die config-Datei nicht vorhanden ist:(.
                                      Vielleicht kann mir ja jemand sagen, wie ich das wieder hin bekomme!?
                                      Heute ein erneuter Versuch auf die v 1.5.3 zu updaten…. gleiche Probleme....
                                      Irgendwie steckt in der v1.5.xx total der Wurm drin....
                                      Windows 8.1, node v10.8.0, npm v6.4.1
                                      Internette Grüße
                                      Andy
                                      RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
                                        Kev0
                                        Adapter oder Instanzen?
                                        Zweites war bei mir auch futsch (raspi)
                                          AndyUM61
                                          @Kev0:
                                          Instanzen funktionieren, aber Adapter leider nicht mehr.
                                          Leider kann man somit auch nichts zusätzliches nachinstallieren:(.
                                          Internette Grüße
                                          Andy
