  3. Cloud Dienste
  4. Iobroker.alexa2 v0.4+
618 Beiträge 95 Kommentatoren 215.5k Aufrufe 9 Beobachtet
    mimquadrat
    #97
    same here.
    Unter den Alexa Geräten habe ich noch
    • "Alexa Apps von Janet" (meine Freundin)
    • "Alexa Apps von Martin" (ich)
    • "Dieses Gerät"
    • "Dieses Gerät" (nochmal)
    vielleicht hat das einen Einfluss.
    Bin auf Version 0.52
    Hab gerade noch geupdatet…sind die Fehler da drin normal?
    Schick mir bitte per PN irgendwas wohin ich spenden kann Apollon - starke Arbeit!
    EDIT: Der Adapter läuft sonst gut - nur die Commands gehen nicht (v.a. Speak)
    ! $ ./iobroker url "https://github.com/Apollon77/ioBroker.a … all/master" alexa2
    ! install https://github.com/Apollon77/ioBroker.a ... all/master
    ! npm install https://github.com/Apollon77/ioBroker.a ... all/master --production --save --prefix "/opt/iobroker" (System call)
    ! In file included from ../node_modules/nan/nan.h:192:0, from ../src/epoll.cc:15:
    ! ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe <bool>Nan::ForceSet(v8::Localv8::object, v8::Localv8::value, v8::Localv8::value, v8::PropertyAttribute)’:
    ! ../node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
    ! return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
    ! In file included from ../src/epoll.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value)’:
    ! ../node_modules/nan/nan.h:835:60: warning: ‘v8::Local v8::valuenode::MakeCallback(v8::Isolate
    , v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    ! v8::Isolate::GetCurrent(), target, func, argc, argv);
    ! In file included from ../src/epoll.cc:12:0:/root/.node-gyp/10.8.0/include/node/node.h:172:50: note: declared here
    ! NODE_EXTERN v8::Local v8::valueMakeCallback(
    ! /root/.node-gyp/10.8.0/include/node/node.h:88:42: note: in definition of macro ‘NODE_DEPRECATED’
    ! attribute((deprecated(message))) declarator
    ! ../node_modules/nan/nan.h: In function ‘v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::string, int, v8::Localv8::value
    ! ../node_modules/nan/nan.h:850:62: warning: ‘v8::Local v8::valuenode::MakeCallback(v8::Isolate*, v8::Localv8::object, v8::Localv8::string, int, v8::Localv8::value)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
    ! v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    ! /root/.node-gyp/10.8.0/include/node/node.h:165:50: note: declared here
    ! ../node_modules/nan/nan.h: In function ‘v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, const char
    ! ../node_modules/nan/nan.h:865:62: warning: ‘v8::Local v8::valuenode::MakeCallback(v8::Isolate
    , v8::Localv8::object, const char*, int, v8::Localv8::value)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
    ! v8::Isolate::GetCurrent(), target, method, argc, argv);
    ! /root/.node-gyp/10.8.0/include/node/node.h:158:50: note: declared here
    ! In file included from ../src/epoll.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Local v8::valueNan::Callback::Call_(v8::Isolate
    , v8::Localv8::object, int, v8::Localv8::value) const’:
    ! ../node_modules/nan/nan.h:1479:5: warning: ‘v8::Local v8::valuenode::MakeCallback(v8::Isolate
    , v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value*)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
    ! make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    ! gyp ERR! stack at ChildProcess.emit (events.js:182:13)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:238:12)
    ! gyp ERR! System Linux 4.14.31-v7+
    ! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/epoll
    ! gyp ERR! node -v v10.8.0
    ! gyp ERR! node-gyp -v v3.7.0
    ! gyp ERR! not ok
    ! npm
    ! WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
    ! npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
    ! npm
    ! WARN
    ! optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/epoll):
    ! npm
    ! WARN optional
    ! SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: node-gyp rebuildnpm
    ! WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    ! got /opt/iobroker/node_modules/iobroker.alexa2/admin
    ! upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
    ! upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
    ! upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
    ! upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
    ! upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
    ! upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
    ! upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
    ! upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
    ! upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
    ! upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
    ! upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
    ! upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
    ! upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
    ! upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    ! process exited with code 0</v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::object></v8::value></v8::value></v8::value></v8::object></v8::value></v8::value></v8::object></v8::value></v8::value></v8::value></v8::string></v8::object></v8::value></v8::value></v8::string></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::object></bool>
    • apollon77A Online
      apollon77A Online
      #98
      Hi mimquadrat,
      DIe Installfehler haben mit dem Alexa Adapter nichts zu tun. Da scheinen wohl bei deiner installation native optionale Module zu sein die nicht gebaut werden können und das versucht er jedes mal neu wenn du was anderes installierst.
      Also Du hast die 0.5.2 installiert, danach die Instanz neu gestartet (musst du bei einem GitHub Install manuell tun!) und Speak geht noch nicht?
      Dann brauche ich bitte Debug Log.
      Zuerst eine Routine anlegen in der Alexa App und testen das die auf dem entsprechenden Gerät die Sprachausgabe machen kann. Wenn das tut:
      • Loglevel auf Debug setzen, dann Adapter starten.
      • dann einmal die Routine triggern per Adapter (tut es auch?)
      • dann einmal die Sprachausgabe per speak machen
      Dann von der ganzen Nummer seit Adapterstart das Debuglog aus dem File (/opt/iobroker/log) und per PN schicken.
      Dann kann ich mal vergleichen.
      Ingo
        Matze78
        #99
        Moin moin,
        ich bin gerade zu doof für den Adapter. Kann mir jemand sagen was hier falsch läuft?
        alexa2.0
        2018-08-18 14:04:14.533
        info
        terminating
        alexa2.0
        2018-08-18 14:04:14.486
        warn
        Exception: TypeError: Cannot read property 'alexaCookie' of undefined
        alexa2.0
        error
        at process._tickCallback (internal/process/next_tick.js:104:9)
        alexa2.0
        error
        at _combinedTickCallback (internal/process/next_tick.js:80:11)
        alexa2.0
        error
        at endReadableNT (_stream_readable.js:978:12)
        alexa2.0
        error
        at IncomingMessage.emit (events.js:185:7)
        alexa2.0
        error
        at emitNone (events.js:91:20)
        alexa2.0
        error
        at IncomingMessage. <anonymous>(D:\Automatisierung\ioBroker\node_modules\iobroker.alexa2\node_modules\alexa-cookie2\alexa-cookie.js:107:33)
        alexa2.0
        error
        at request (D:\Automatisierung\ioBroker\node_modules\iobroker.alexa2\node_modules\alexa-cookie2\alexa-cookie.js:162:25)
        alexa2.0
        error
        at D:\Automatisierung\ioBroker\node_modules\iobroker.alexa2\node_modules\alexa-remote2\alexa-remote.js:88:29
        alexa2.0
        error
        alexa2.0
        error
        uncaught exception: Cannot read property 'alexaCookie' of undefined
        alexa2.0
        2018-08-18 14:03:53.071
        error
        Error: You can try to get the cookie manually by opening http://192.168.101.254:64714/ with your browser.
        alexa2.0
        error
        Error: Amazon-Login-Error: Wichtige Mitteilung!: Zum besseren Schutz Ihres Kontos geben Sie bitte nochmals Ihr Passwort ein, und geben Sie dann die Zeichen ein, die in der Abbildung unten gezeigt wer</anonymous>
        Ich habe die URL aufgerufen, die Daten eingetragen und als Rückmeldung "Amazon Alexa Cookie successfully retrieved. You can close the browser." bekommen. Direkt danach kommen die Fehler ins Log.
        Liegt´s an mir oder an Amazon?
        Matze
        • apollon77A Online
          apollon77A Online
          #100
          0.5.2 vom GitHub nehmen!! Du hast die 0.4 und Dienst da nen bug.
          Mit dem ganze Feedback packe ich die 0.5.2 nachher auf npm dann ist die morgen im
          Latest.
          Gesendet vom Handy …
            mimquadrat
            #101
            Hallo Apollon,
            "leider gehts jetzt".
            Leider deshalb, weil ich nicht genau sagen kann was der Auslöser war.
            Ich habe einen Neustart der Instanz gemach (wusste nicht dass das nach einem Update nicht automatisch passiert) und
            ich habe meine Node/NodeJs Versionen mal aufgeräumt (hatte hier verschiedene Versionen…) wie hier gezeigt: viewtopic.php?t=8056
            Danke nochmal an Dich Apollon, spitze was Du und die Anderen hier auf die Beine gestellt habt!
            • apollon77A Online
              apollon77A Online
              #102
              Zum Neustart: bei einer normalen Installation vom latest oder stable erfolgt ein Neustart.
              Bei einer Installation vom GitHub nicht.
                Matze78
                #103
                Cool, die Github-Installation hat geklappt, im Objekt-Manager bekomme ich auch alles gewünschte geschaltet.
                Ich schnalle jetzt nur gerade nicht wie ich in Blockly darauf zugreifen kann… Wie kann ich einem der Objekte einen der Befehle geben?
                Danke!
                Matze
                • sigi234S Online
                  sigi234S Online
                  #104
                  So vielleicht:
                  • O Offline
                    O Offline
                    ooooli
                    #105
                    Super Arbeit Ingo! Dem Forum fehlt eindeutig der Dankebutton [emoji1317] [emoji106]
                    ioBroker Neuling mit 4 Alexas, Sonoff, Netatmo, Lametric Time, Hue, Harmony Hub und einigen anderen Spielereien die es zu verknüpfen gilt
                      Matze78
                      #106
                      Danke sigi, einfacher als gedacht. Habe ein Beispiel in lila gesehen, aber das ist sogar noch einfacher.
                      Wie kann ich prüfen ob der Echo gerade fertig ist?
                      Ich würde gerne einen Einzelbefehl für das "morgenritual" haben. Bedeutet: entsprechende Lampen an, Wetterbericht und danach Radiosender auf Multiroom-Gruppe… Wenn ich die Befehle hintereinander setze, dann wird das erste nie ausgeführt. Mit Verzögerung ist keine Option, der Wetterbericht kann mal kürzer und mal länger sein.
                      Geht da was?
                      Außerdem wäre es cool Multiroom-Gruppen zu ändern. Die Echos können leider immer nur in einer Multiroiom-Gruppe sein. Ich habe zur Zeit 3 Echo´s und 3 Dot´s zu Hause. Im Wohn- und Esszimmer sowie im Büro ist ein Echo, im Bad, Gästebad und in der Küche ein Dot. Nun hätte ich gerne im "Feiermodus" im Wohn- und Esszimmer, in der Küche sowie im Bad die selbe Musik. Im "Guten-Morgen-Modus" hingegen auf allen. Da einer eine Idee zu?
                      Matze
                      • sigi234S Online
                        sigi234S Online
                        #107
                        ich mach vieles über Routinen, wobei der Obere Abschnitt die Befehle an den Dot im Wohnzimmer sendet.
                        Man kann natürlich je Dot einen Routinen-Abschnitt machen, ich bin selber gerade dabei alles zu testen…..
                        Im Multiroombetrieb bin ich auch gerad dabei zu testen….
                        • apollon77A Online
                          apollon77A Online
                          #108
                          @Matze78:
                          Geht da was?
                          Matze `
                          Der Adapter hat keine info wann was ausgeführt wird und so. Also ja, wenn du öfter die gleichen Dinge nacheinander willst sind Routinen die beste Option. Die können Sequenzen (also nacheinander) ausführen. Triggern kannst du die dann per ioBroker.
                          Rein API technisch geht es multiroom zu löschen und neu anzulegen … aber mir fehlt die sinnvolle Idee das als States abzubilden. Bzw delete könnte es ja schon geben über den delete State bei dem multiroom device. Dann müsste man nur einen State machen einmal kommaseparierte Liste an device ids angeben kann um ein neues zu erstellen und dann ändern sich Objekte ...
                          mach mal dazu ein GitHub issue auf bitte.
                          Und wer es noch will/sinnvoll findet bitte per „Daumen hoch“ abstimmen!!!
                          Gesendet vom Handy ...
                            Matze78
                            #109
                            Meint ihr die Routinen in der Alexa-App? Die gehen bei mir nicht auf Multiroom, nur auf einzelne Echos…
                            • sigi234S Online
                              sigi234S Online
                              #110
                              Skript startet Multiroom:
                              setState('alexa2.0.Echo-Devices.xxxxxxxxxxxxxxxxxxxxxxxxxxxx.Music-Provider.Amazon-Music-Playlist', 'xxxxxx');
                              Mein 400er Beitrag…...... :)
                              • apollon77A Online
                                apollon77A Online
                                #111
                                @Matze78:
                                Meint ihr die Routinen in der Alexa-App? Die gehen bei mir nicht auf Multiroom, nur auf einzelne Echos… `
                                Ja das liegt daran das nur Musik im multiroom synchronisiert läuft. Sprachausgaben wären nicht synchronisiert auf den Geräten was blöd ist wenn im gleichen Raum.
                                Dann müsstest du die Routine für jeden Echo starten.
                                • sigi234S Online
                                  sigi234S Online
                                  #112
                                  Geht doch:
                                  Routine anlegen, dann bei ABSPIELEN folgendes eintragen:
                                  Leerzeichen Playlist Sigi auf Überall
                                  Sigi und Überall natürlich mit deinen Daten ersetzen!
                                  Unbedingt ein Leerzeichen vorher setzen.
                                  • L Offline
                                    Lilly
                                    #113
                                    Hallo leider bekomme ich keine Verbindung bei Iobroker zum Adapter. Die Ampel bleibt immer auf Gelb. Passwort und Email stimmt und hab ich mehrmals kontrolliert. Installiert ist die aktuelle Version von Github direkt wie im Forum beschrieben. Könnt ihr mir helfen woran es noch liegen kann bin hier langsam am verzweifeln.
                                    • Dr. BakteriusD Online
                                      Dr. Bakterius
                                      #114
                                      @Lilly: schon mal ins Log geschaut? Hast du 2FA bei Amazon aktiviert?
                                      • L Offline
                                        Lilly
                                        #115
                                        @WaJoWi:
                                        @Lilly: schon mal ins Log geschaut? Hast du 2FA bei Amazon aktiviert? ` Ja ist aktiviert im log steht dann nur eine IP Adresse mir der ich auf die Alexa Seite komm anmelden dort klappt auch aber Verbindung bekomm ich trotzdem nicht her.
                                        Gesendet von meinem VTR-L09 mit Tapatalk
                                        • apollon77A Online
                                          apollon77A Online
                                          #116
                                          Dann bitte Instanz auf debug und dann starten und dann auf die angezeigte url und da einloggen und dann von allem das log senden was du auf Platte unter /opt/ioBroker/log findest.
