Installation auf NUC mit Proxmox
Der Admin startet jetzt, aber ich vermisse alle Adapter.
In den Instanzen steht:
File index.html not found`
Hier hättest Du nur (lange) warten müssen.Im Backup sind nur die Konfigs drin. Die Adapter werden dann sukzessive nachinstalliert. Das siehst du auch im Log.
Gruß,
Eric
Von unterwegs getippert
Ahhhh, jetzt verstehe ich warum die Backups so klein sind….
Was will mir das beim Dash-Button sagen?
host.haus 2018-07-19 11:16:18.298 error instance system.adapter.amazon-dash.0 terminated with code 0 (OK) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Module.load (module.js:565:32) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Object.Module._extensions..js (module.js:663:10) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Module._compile (module.js:652:30) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21) Caught 2018-07-19 11:16:18.298 error by controller[0]: at require (internal/module.js:11:18) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Module.require (module.js:596:17) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Function.Module._load (module.js:497:3) Caught 2018-07-19 11:16:18.298 error by controller[0]: at tryModuleLoad (module.js:505:12) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Module.load (module.js:565:32) Caught 2018-07-19 11:16:18.298 error by controller[0]: at Object.Module._extensions..node (module.js:681:18) Caught 2018-07-19 11:16:18.297 error by controller[0]: Error: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32 amazon-dash.0 2018-07-19 11:16:18.286 info terminating amazon-dash.0 2018-07-19 11:16:17.960 info starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.3 amazon-dash.0 2018-07-19 11:16:17.839 info States connected to redis: 127.0.0.1:6379 amazon-dash.0 2018-07-19 11:16:17.782 error at Module.load (module.js:565:32) amazon-dash.0 2018-07-19 11:16:17.782 error at Object.Module._extensions..js (module.js:663:10) amazon-dash.0 2018-07-19 11:16:17.782 error at Module._compile (module.js:652:30) amazon-dash.0 2018-07-19 11:16:17.782 error at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21) amazon-dash.0 2018-07-19 11:16:17.782 error at require (internal/module.js:11:18) amazon-dash.0 2018-07-19 11:16:17.782 error at Module.require (module.js:596:17) amazon-dash.0 2018-07-19 11:16:17.782 error at Function.Module._load (module.js:497:3) amazon-dash.0 2018-07-19 11:16:17.782 error at tryModuleLoad (module.js:505:12) amazon-dash.0 2018-07-19 11:16:17.782 error at Module.load (module.js:565:32) amazon-dash.0 2018-07-19 11:16:17.782 error at Object.Module._extensions..node (module.js:681:18) amazon-dash.0 2018-07-19 11:16:17.782 error Error: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32 amazon-dash.0 2018-07-19 11:16:17.778 error uncaught exception: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32 host.haus 2018-07-19 11:16:17.207 info instance system.adapter.amazon-dash.0 started with pid 3358</anonymous></anonymous>Der Button und das zugehörige Script funktionieren allerdings
So,
bis auf den Dash Button funktioniert alles wieder.
War irgendwie nicht so einfach wie ich mir das vorgestellt habe, aber machbar.
Ich war so frei den Arbeitsablauf aufzuführen (falls ich das nochmal brauche ;) ) :
--- VM einrichten --- VM starten und installieren mit Putty einloggen und Befehle abarbeiten: sudo apt update && sudo apt upgrade -y sudo reboot curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash - sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs sudo npm install npm@latest -g npm - v Ergebnis = 6.2.0 node -v Ergebnis =v8.11.3 sudo reboot sudo mkdir /opt/iobroker sudo chmod -R 777 /opt/iobroker cd /opt/iobroker sudo npm install iobroker --unsafe-perm sudo reboot sudo iobroker stop cd /opt/iobroker --- Ordner <backups>erstellen und Backup ablegen sudo chmod -R 777 /opt/iobroker (wird benötigt um Backup einzuspielen) sudo iobroker restore 0 Sudo reboot apt-get install redis-server sudo chmod 777 -R /var/lib/redis sudo reboot</backups>In meinem Fall waren die Adapter zunächst nicht verfügbar. Die werden nachinstalliert wenn aus dem kleinen Backup wiederhergestellt wird. Da ich das nicht wusste habe ich über die vorhandenen Ordner "/opt/iobroker" ein komplettes Backup mit allen Ordnern kopiert.
Bis auf Redis ist dann alles sofort gelaufen.
Zusatzarbeiten:
Im Ordner VIS.0 die eigenen Bilder einspielen in allen Sonoffs den MQTT Server neu setzen im PAW Adapter den ioBroker neu eintragen Scripte auf Funktion prüfen (wegen fehlender Verknüpfungen)Bisher ist es so, das scheinbar der ioBroker nicht automatisch startet wenn die VM bootet.
Da muss ich nochmal nachfragen woran das liegen könnte.
Der Adapter "Backitup" hat mir sehr gut geholfen beim einfachen erstellen der Backups.
Aktuell werde ich ihn dann vermutlich nicht mehr benötigen, da ich über Proxmox bequem Abbilder erstellen kann und die schneller zu handhaben sind.
Wenn mir noch jemand helfen kann bei den beiden Problemen Dash Button und Autostart wäre ich recht dankbar. Ansonsten schon jetzt meinen herzlichsten Dank an alle die mir bisher geholfen haben und ganz besonders an @Dutchman der es geschafft hat mich im richtigen Augenblick davon abzuhalten alles durchs Fenster zu donnern.
Mittlerweile bin ich auch stolzer besitzer eines NUCs.
Jetzt hab ich aber n kleines Problem. Ich habe debian 9.5 als VM installiert mit ioBroker usw.
Läuft auch super bloß wenn ich in den Optionen der VM "Beim booten starten" aktiviere dann wird die VM nicht mitgestartet.
Da bekomme ich dann folgende Meldung:
TASK ERROR: start failed: command '/usr/bin/kvm -id 101 -name Debian9-cli -chardev 'socket,id=qmp,path=/var/run/qemu-server/101.qmp,server,nowait' -mon 'chardev=qmp,mode=control' -pidfile /var/run/qemu-server/101.pid -daemonize -smbios 'type=1,uuid=4716a4ed-a688-43d1-9312-15b660b9d52f' -smp '4,sockets=2,cores=2,maxcpus=4' -nodefaults -boot 'menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg' -vga std -vnc unix:/var/run/qemu-server/101.vnc,x509,password -cpu kvm64,+lahf_lm,+sep,+kvm_pv_unhalt,+kvm_pv_eoi,enforce -m 4096 -device 'pci-bridge,id=pci.1,chassis_nr=1,bus=pci.0,addr=0x1e' -device 'pci-bridge,id=pci.2,chassis_nr=2,bus=pci.0,addr=0x1f' -device 'piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2' -device 'usb-tablet,id=tablet,bus=uhci.0,port=1' -device 'virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3' -iscsi 'initiator-name=iqn.1993-08.org.debian:01:9ae4763a016' -drive 'file=/ISO-files/template/iso/debian-9.5.0-i386-netinst.iso,if=none,id=drive-ide2,media=cdrom,aio=threads' -device 'ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200' -device 'virtio-scsi-pci,id=scsihw0,bus=pci.0,addr=0x5' -drive 'file=/ISO-files/images/101/vm-101-disk-1.qcow2,if=none,id=drive-scsi0,format=qcow2,cache=none,aio=native,detect-zeroes=on' -device 'scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100' -netdev 'type=tap,id=net0,ifname=tap101i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on' -device 'virtio-net-pci,mac=42:84:4B:57:24:8C,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300'' failed: got timeoutKann mir da vielleicht jemand weiterhelfen
Johnny
Erst mal Danke an @Chaot für die super Anleitung ich wäre sonst total verzweifelt.
Leider habe ich das Problem das nachdem ich mein Backup einspiele nicht mehr auf ioBroker zugreifen kann obwohl er angeblich läuft, auch ein stoppen ist nicht mehr möglich über putty?
Ich hab’s mir ja kompliziert vorgestellt weil ich habe überhaupt keine Ahnung von dem was ich da eingebe aber sieht so aus als müsste ich zum dritten Mal alles von vorn machen und dann alles neu einrichten und sämtliche VIS neu machen obwohl ich täglich ein Backup mache.
Habe ioBroker ebenfalls auf meinem NUC mit Proxmox zum laufen bekommen (Ubuntuserver 18.04 LTS).
Funktioniert soweit alles, außer der "Auto Start" wie bei PrinzEisenherz1 will noch nicht obwohl in der VM das Häcken gesetzt ist.
Fehlermeldung:
TASK ERROR: start failed: command '/usr/bin/kvm -id 100 -name ioBroker -chardev 'socket,id=qmp,path=/var/run/qemu-server/100.qmp,server,nowait' -mon 'chardev=qmp,mode=control' -pidfile /var/run/qemu-server/100.pid -daemonize -smbios 'type=1,uuid=0624c1b7-c3ea-4994-95cd-86760e54687f' -smp '2,sockets=1,cores=2,maxcpus=2' -nodefaults -boot 'menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg' -vga std -vnc unix:/var/run/qemu-server/100.vnc,x509,password -cpu kvm64,+lahf_lm,+sep,+kvm_pv_unhalt,+kvm_pv_eoi,enforce -m 2000 -device 'pci-bridge,id=pci.2,chassis_nr=2,bus=pci.0,addr=0x1f' -device 'pci-bridge,id=pci.1,chassis_nr=1,bus=pci.0,addr=0x1e' -device 'piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2' -device 'usb-tablet,id=tablet,bus=uhci.0,port=1' -device 'virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3' -iscsi 'initiator-name=iqn.1993-08.org.debian:01:2ac21683882f' -drive 'file=/var/lib/vz/template/iso/ubuntu-18.04-live-server-amd64.iso,if=none,id=drive-ide2,media=cdrom,aio=threads' -device 'ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200' -device 'virtio-scsi-pci,id=scsihw0,bus=pci.0,addr=0x5' -drive 'file=/dev/pve/vm-100-disk-1,if=none,id=drive-scsi0,format=raw,cache=none,aio=native,detect-zeroes=on' -device 'scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100' -netdev 'type=tap,id=net0,ifname=tap100i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on' -device 'virtio-net-pci,mac=16:64:B1:31:E4:AB,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300'' failed: got timeoutHat jemand eine Idee?
Der NUC ist eingetroffen und fertig zusammengezimmert.
Proxmox ist installiert und läuft.
Jetzt die Frage:
Für den ioBroker einen Container oder eine VM erstellen?
Welche Linux-Version wäre am Besten geeignet? `
Für ioBroker würde ich eine VM nehmen, benutze selber Ubuntu 18 LTS läuft sehr gut aber auch Debian ist zu empfehlen
Sent from my iPhone using Tapatalk `
Da ich mich aktuell auch mal wieder mit dem Thema Container beschäftige (Proxmox scheint jetzt meinen WLan Treiber zu kennen), darf ich fragen, warum du eine VM empfehlen würdest? Gibt es speziell bei IOBroker Vorteile in einer VM gegenüber einem Container? Snapshots sind ja bei beiden möglich.
Und nebenbei, welches Dateisystem sollte man bei Proxmox wählen?
Ich hab da mal kurz ne Verständnisfrage.
Sollte man in der selben VM wie ioBroker auch SQL und REDIS installieren oder besser beides auf ne eigene VM?
Johnny
Moin,
Da ich mich aktuell auch mal wieder mit dem Thema Container beschäftige (Proxmox scheint jetzt meinen WLan Treiber zu kennen), darf ich fragen, warum du eine VM empfehlen würdest? Gibt es speziell bei IOBroker Vorteile in einer VM gegenüber einem Container? Snapshots sind ja bei beiden möglich. `
ein Container verwendet quasi das OS der Wirts-/Hostmaschine mit.Bei einer VM bist Du im Prinzip völlig vom Host unabhängig.
Und nebenbei, welches Dateisystem sollte man bei Proxmox wählen? `
Schau Dir mal diesen https://pve.proxmox.com/wiki/Qemu/KVM_Virtual_Machines dazu an. Da ist das alles sehr gut erklärt.Gruß,
Eric
Moin Johnny,
Sollte man in der selben VM wie ioBroker auch SQL und REDIS installieren oder besser beides auf ne eigene VM? `
Redis würde ich machen, da es die aktuelle Arbeits-Datenbank von ioBroker ist.SQL würde ich nicht machen, da dort ja die aufgezeichneten Daten liegen und diese bei einem Snapshot-Rollback ja auch auf den alten (gesicherten) Stand zurückgesetzt werden.
Gruß,
Eric
Alles klar. Danke für die Info.
Ich hab das mit REDIS auf der selben VM wie ioBroker schon mal probiert gehabt aber da hat es mir dann nach paar mal Snapshot zurücksetzen den REDIS zerlegt.
Da ist dann iobroker nicht mehr sauber gelaufen. da kam dann ne Fehlermeldung das irgendwas in REDIS korrupt sei wenn ich````
iobroker statusMomentan hab ichs auf file gesetzt. Gruß Johnny -
Moin,
Eric
Von unterwegs getippert `
Danke für den Link, bzgl. Container und VM war mir das soweit schon klar, ich dachte es gibt evtl einen speziellen Vorteil für IOBroker.
Johnny `
Klappt das jetzt mit dem Autostart ? Wenn ja wo war das Problem?
Gesendet von iPad mit Tapatalk Pro
Ja, mittlerweileklappt es. Das Problem war ne defekte msata.
Gruß johnny
Hallo
Proxmox läuft , VM mit Iobroker läuft auch
Der Autostart von Iobroker selber klappt nicht , hat jemand eine Idee ? Iobroker.sh ist da
Hallo
Gesendet von iPad mit Tapatalk Pro `
Haste es mal hiermit versucht?
chmod +x /etc/init.d/iobroker.sh update-rc.d iobroker.sh defaults rebootGruß
Holger
