  4. Installation auf NUC mit Proxmox
128 Beiträge 29 Kommentatoren 34.8k Aufrufe 9 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    Ahhhh, jetzt verstehe ich warum die Backups so klein sind….
    Was will mir das beim Dash-Button sagen?
    host.haus	2018-07-19 11:16:18.298	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Module.load (module.js:565:32)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Module._compile (module.js:652:30)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Module.require (module.js:596:17)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Function.Module._load (module.js:497:3)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at tryModuleLoad (module.js:505:12)
    Caught	2018-07-19 11:16:18.298	error	by controller[0]: at Object.Module._extensions..node (module.js:681:18)
    Caught	2018-07-19 11:16:18.297	error	by controller[0]: Error: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    amazon-dash.0	2018-07-19 11:16:18.286	info	terminating
    amazon-dash.0	2018-07-19 11:16:17.960	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.3
    amazon-dash.0	2018-07-19 11:16:17.839	info	States connected to redis: 127.0.0.1:6379
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Module.load (module.js:565:32)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Object.Module._extensions..js (module.js:663:10)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Module._compile (module.js:652:30)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at require (internal/module.js:11:18)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Module.require (module.js:596:17)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Function.Module._load (module.js:497:3)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at tryModuleLoad (module.js:505:12)
    amazon-dash.0	2018-07-19 11:16:17.782	error	at Object.Module._extensions..node (module.js:681:18)
    amazon-dash.0	2018-07-19 11:16:17.782	error	Error: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    amazon-dash.0	2018-07-19 11:16:17.778	error	uncaught exception: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    host.haus	2018-07-19 11:16:17.207	info	instance system.adapter.amazon-dash.0 started with pid 3358</anonymous></anonymous>
    Der Button und das zugehörige Script funktionieren allerdings
    • ChaotC Offline
      ChaotC Offline
      Chaot
      So,
      bis auf den Dash Button funktioniert alles wieder.
      War irgendwie nicht so einfach wie ich mir das vorgestellt habe, aber machbar.
      Ich war so frei den Arbeitsablauf aufzuführen (falls ich das nochmal brauche ;) ) :
      --- VM einrichten ---
      VM starten und installieren
      mit Putty einloggen und Befehle abarbeiten:
      sudo apt update && sudo apt upgrade -y
      sudo reboot
      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      sudo npm install npm@latest -g
      npm - v
      Ergebnis = 6.2.0
      node -v
      Ergebnis =v8.11.3
      sudo reboot
      sudo mkdir /opt/iobroker
      sudo chmod -R 777 /opt/iobroker
      cd /opt/iobroker
      sudo npm install iobroker --unsafe-perm
      sudo reboot
      sudo iobroker stop
      cd /opt/iobroker
      --- Ordner <backups>erstellen und Backup ablegen
      sudo chmod -R 777 /opt/iobroker (wird benötigt um Backup einzuspielen)
      sudo iobroker restore 0
      Sudo reboot
      apt-get install redis-server
      sudo chmod 777 -R /var/lib/redis
      sudo reboot</backups>
      In meinem Fall waren die Adapter zunächst nicht verfügbar. Die werden nachinstalliert wenn aus dem kleinen Backup wiederhergestellt wird. Da ich das nicht wusste habe ich über die vorhandenen Ordner "/opt/iobroker" ein komplettes Backup mit allen Ordnern kopiert.
      Bis auf Redis ist dann alles sofort gelaufen.
      Zusatzarbeiten:
      Im Ordner VIS.0 die eigenen Bilder einspielen
      in allen Sonoffs den MQTT Server neu setzen
      im PAW Adapter den ioBroker neu eintragen
      Scripte auf Funktion prüfen (wegen fehlender Verknüpfungen)
      Bisher ist es so, das scheinbar der ioBroker nicht automatisch startet wenn die VM bootet.
      Da muss ich nochmal nachfragen woran das liegen könnte.
      Der Adapter "Backitup" hat mir sehr gut geholfen beim einfachen erstellen der Backups.
      Aktuell werde ich ihn dann vermutlich nicht mehr benötigen, da ich über Proxmox bequem Abbilder erstellen kann und die schneller zu handhaben sind.
      Wenn mir noch jemand helfen kann bei den beiden Problemen Dash Button und Autostart wäre ich recht dankbar. Ansonsten schon jetzt meinen herzlichsten Dank an alle die mir bisher geholfen haben und ganz besonders an @Dutchman der es geschafft hat mich im richtigen Augenblick davon abzuhalten alles durchs Fenster zu donnern.
      • P Offline
        PrinzEisenherz1
        Mittlerweile bin ich auch stolzer besitzer eines NUCs.
        Jetzt hab ich aber n kleines Problem. Ich habe debian 9.5 als VM installiert mit ioBroker usw.
        Läuft auch super bloß wenn ich in den Optionen der VM "Beim booten starten" aktiviere dann wird die VM nicht mitgestartet.
        Da bekomme ich dann folgende Meldung:
        TASK ERROR: start failed: command '/usr/bin/kvm -id 101 -name Debian9-cli -chardev 'socket,id=qmp,path=/var/run/qemu-server/101.qmp,server,nowait' -mon 'chardev=qmp,mode=control' -pidfile /var/run/qemu-server/101.pid -daemonize -smbios 'type=1,uuid=4716a4ed-a688-43d1-9312-15b660b9d52f' -smp '4,sockets=2,cores=2,maxcpus=4' -nodefaults -boot 'menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg' -vga std -vnc unix:/var/run/qemu-server/101.vnc,x509,password -cpu kvm64,+lahf_lm,+sep,+kvm_pv_unhalt,+kvm_pv_eoi,enforce -m 4096 -device 'pci-bridge,id=pci.1,chassis_nr=1,bus=pci.0,addr=0x1e' -device 'pci-bridge,id=pci.2,chassis_nr=2,bus=pci.0,addr=0x1f' -device 'piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2' -device 'usb-tablet,id=tablet,bus=uhci.0,port=1' -device 'virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3' -iscsi 'initiator-name=iqn.1993-08.org.debian:01:9ae4763a016' -drive 'file=/ISO-files/template/iso/debian-9.5.0-i386-netinst.iso,if=none,id=drive-ide2,media=cdrom,aio=threads' -device 'ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200' -device 'virtio-scsi-pci,id=scsihw0,bus=pci.0,addr=0x5' -drive 'file=/ISO-files/images/101/vm-101-disk-1.qcow2,if=none,id=drive-scsi0,format=qcow2,cache=none,aio=native,detect-zeroes=on' -device 'scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100' -netdev 'type=tap,id=net0,ifname=tap101i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on' -device 'virtio-net-pci,mac=42:84:4B:57:24:8C,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300'' failed: got timeout
        Kann mir da vielleicht jemand weiterhelfen
        Johnny
        Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
        • E Offline
          EVOlutionIX
          Erst mal Danke an @Chaot für die super Anleitung ich wäre sonst total verzweifelt.
          Leider habe ich das Problem das nachdem ich mein Backup einspiele nicht mehr auf ioBroker zugreifen kann obwohl er angeblich läuft, auch ein stoppen ist nicht mehr möglich über putty?
          Ich hab’s mir ja kompliziert vorgestellt weil ich habe überhaupt keine Ahnung von dem was ich da eingebe aber sieht so aus als müsste ich zum dritten Mal alles von vorn machen und dann alles neu einrichten und sämtliche VIS neu machen obwohl ich täglich ein Backup mache.
          Hardware: Raspberry Pi3 (ioBroker reserve) + Intel NUC (ioBroker) mit Ubutu Server 18.04 + CCU 2
          Ausstattung: HM Messdosen, HM Heizungssteuerung, HM Türsensoren, HM Lichtschalter, Sonoff Schalter
          • H Offline
            hb9irn
            Habe ioBroker ebenfalls auf meinem NUC mit Proxmox zum laufen bekommen (Ubuntuserver 18.04 LTS).
            Funktioniert soweit alles, außer der "Auto Start" wie bei PrinzEisenherz1 will noch nicht obwohl in der VM das Häcken gesetzt ist.
            Fehlermeldung:
            TASK ERROR: start failed: command '/usr/bin/kvm -id 100 -name ioBroker -chardev 'socket,id=qmp,path=/var/run/qemu-server/100.qmp,server,nowait' -mon 'chardev=qmp,mode=control' -pidfile /var/run/qemu-server/100.pid -daemonize -smbios 'type=1,uuid=0624c1b7-c3ea-4994-95cd-86760e54687f' -smp '2,sockets=1,cores=2,maxcpus=2' -nodefaults -boot 'menu=on,strict=on,reboot-timeout=1000,splash=/usr/share/qemu-server/bootsplash.jpg' -vga std -vnc unix:/var/run/qemu-server/100.vnc,x509,password -cpu kvm64,+lahf_lm,+sep,+kvm_pv_unhalt,+kvm_pv_eoi,enforce -m 2000 -device 'pci-bridge,id=pci.2,chassis_nr=2,bus=pci.0,addr=0x1f' -device 'pci-bridge,id=pci.1,chassis_nr=1,bus=pci.0,addr=0x1e' -device 'piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2' -device 'usb-tablet,id=tablet,bus=uhci.0,port=1' -device 'virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3' -iscsi 'initiator-name=iqn.1993-08.org.debian:01:2ac21683882f' -drive 'file=/var/lib/vz/template/iso/ubuntu-18.04-live-server-amd64.iso,if=none,id=drive-ide2,media=cdrom,aio=threads' -device 'ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200' -device 'virtio-scsi-pci,id=scsihw0,bus=pci.0,addr=0x5' -drive 'file=/dev/pve/vm-100-disk-1,if=none,id=drive-scsi0,format=raw,cache=none,aio=native,detect-zeroes=on' -device 'scsi-hd,bus=scsihw0.0,channel=0,scsi-id=0,lun=0,drive=drive-scsi0,id=scsi0,bootindex=100' -netdev 'type=tap,id=net0,ifname=tap100i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown,vhost=on' -device 'virtio-net-pci,mac=16:64:B1:31:E4:AB,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300'' failed: got timeout
            Hat jemand eine Idee?
            • HomoranH Offline
              HomoranH Offline
              Zu diesem Thema (ohne Proxmox) gibt es inzwischen einige Threads (mit Lösungen)
              Anscheinend funktioniert das install unter npm 6.x nicht mehr und die Startdatei wird gelöscht.
              rainer
              • Schuko80S Offline
                Schuko80S Offline
                Schuko80
                @Dutchman:
                @Chaot:
                Der NUC ist eingetroffen und fertig zusammengezimmert.
                Proxmox ist installiert und läuft.
                Jetzt die Frage:
                Für den ioBroker einen Container oder eine VM erstellen?
                Welche Linux-Version wäre am Besten geeignet? `
                Für ioBroker würde ich eine VM nehmen, benutze selber Ubuntu 18 LTS läuft sehr gut aber auch Debian ist zu empfehlen
                Sent from my iPhone using Tapatalk `
                Da ich mich aktuell auch mal wieder mit dem Thema Container beschäftige (Proxmox scheint jetzt meinen WLan Treiber zu kennen), darf ich fragen, warum du eine VM empfehlen würdest? Gibt es speziell bei IOBroker Vorteile in einer VM gegenüber einem Container? Snapshots sind ja bei beiden möglich.
                Und nebenbei, welches Dateisystem sollte man bei Proxmox wählen?
                Nuc6cayh + Proxmox / Zigbee (Deconz / Conbee I ) / ZWave / Homematic (CCU2)
                • P Offline
                  PrinzEisenherz1
                  Ich hab da mal kurz ne Verständnisfrage.
                  Sollte man in der selben VM wie ioBroker auch SQL und REDIS installieren oder besser beides auf ne eigene VM?
                  Johnny
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    Moin,
                    @Schuko80:
                    Da ich mich aktuell auch mal wieder mit dem Thema Container beschäftige (Proxmox scheint jetzt meinen WLan Treiber zu kennen), darf ich fragen, warum du eine VM empfehlen würdest? Gibt es speziell bei IOBroker Vorteile in einer VM gegenüber einem Container? Snapshots sind ja bei beiden möglich. `
                    ein Container verwendet quasi das OS der Wirts-/Hostmaschine mit.
                    Bei einer VM bist Du im Prinzip völlig vom Host unabhängig.
                    @Schuko80:
                    Und nebenbei, welches Dateisystem sollte man bei Proxmox wählen? `
                    Schau Dir mal diesen https://pve.proxmox.com/wiki/Qemu/KVM_Virtual_Machines dazu an. Da ist das alles sehr gut erklärt.
                    Gruß,
                    Eric
                    Von unterwegs getippert
                    • eric2905E Offline
                      eric2905E Offline
                      eric2905
                      Moin Johnny,
                      @PrinzEisenherz1:
                      Sollte man in der selben VM wie ioBroker auch SQL und REDIS installieren oder besser beides auf ne eigene VM? `
                      Redis würde ich machen, da es die aktuelle Arbeits-Datenbank von ioBroker ist.
                      SQL würde ich nicht machen, da dort ja die aufgezeichneten Daten liegen und diese bei einem Snapshot-Rollback ja auch auf den alten (gesicherten) Stand zurückgesetzt werden.
                      Gruß,
                      Eric
                      • P Offline
                        PrinzEisenherz1
                        @eric
                        Alles klar. Danke für die Info.
                        Ich hab das mit REDIS auf der selben VM wie ioBroker schon mal probiert gehabt aber da hat es mir dann nach paar mal Snapshot zurücksetzen den REDIS zerlegt.
                        Da ist dann iobroker nicht mehr sauber gelaufen. da kam dann ne Fehlermeldung das irgendwas in REDIS korrupt sei wenn ich````
                        iobroker status
                        Momentan hab ichs auf file gesetzt.
                        Gruß Johnny
                        • Schuko80S Offline
                          Schuko80S Offline
                          Schuko80
                          @eric2905:
                          Moin,
                          @Schuko80:
                          @Schuko80:
                          Gruß,
                          Eric
                          Von unterwegs getippert `
                          Danke für den Link, bzgl. Container und VM war mir das soweit schon klar, ich dachte es gibt evtl einen speziellen Vorteil für IOBroker.
                          • chucky666C Offline
                            chucky666C Offline
                            chucky666
                            @PrinzEisenherz1:
                            Johnny `
                            Klappt das jetzt mit dem Autostart ? Wenn ja wo war das Problem?
                            Gesendet von iPad mit Tapatalk Pro
                            • P Offline
                              PrinzEisenherz1
                              Ja, mittlerweileklappt es. Das Problem war ne defekte msata.
                              Gruß johnny
                                chucky666C Offline
                                chucky666
                                Super Danke
                                  chucky666C Offline
                                  chucky666
                                  Hallo
                                  Proxmox läuft , VM mit Iobroker läuft auch
                                  Der Autostart von Iobroker selber klappt nicht , hat jemand eine Idee ? Iobroker.sh ist da
                                  • H Offline
                                    holgerwolf
                                    @chucky666:
                                    Hallo
                                    Gesendet von iPad mit Tapatalk Pro `
                                    Haste es mal hiermit versucht?
                                    chmod +x /etc/init.d/iobroker.sh
                                    update-rc.d iobroker.sh defaults
                                    reboot
                                    Holger
                                      chucky666C Offline
                                      chucky666
                                      Super Danke jetzt klappt es
                                        chucky666C Offline
                                        chucky666
                                        Neues Problem, Arduino Mega ist per usb angeschlossen
                                        Ist auch schon durchgereicht , RF link findet keinen serial Port
                                        Weiß einer eine Lösung ?
                                        • ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          Nachdem das System jetzt ein paar Tage läuft habe ich versucht ein Update zu machen und bin zunächst an einer Fehlermeldung gescheitert.
                                          "No Subscription"
                                          Das ist zwar in der Beschreimbung recht gut dokumentiert, aber es fehlt dann doch noch ein kleiner Hinweis.
                                          Nach dem Ändern der /etc/apt/sources.list
                                          deb http://ftp.debian.org/debian stretch main contrib
                                          # PVE pve-no-subscription repository provided by proxmox.com,
                                          # NOT recommended for production use
                                          deb http://download.proxmox.com/debian/pve stretch pve-no-subscription
                                          # security updates
                                          deb http://security.debian.org stretch/updates main contrib
                                          Muss unbedingt noch die Enterprise Zuordnung gelöscht werden:
                                          rm /etc/apt/sources.list.d/pve-enterprise.list
                                          Ansonsten bekommt man bei jedem Updateversuch einen Fehler 401.
