  4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
    6.7k
343 Beiträge 55 Kommentatoren 117.7k Aufrufe 14 Beobachtet
  • Z Offline
    Z Offline
    zahnheinrich
    #114
    Hallo in die Runde,
    Mein System:
    ioBroker auf Synology buanet-Docker
    node v6.14.3
    npm 4.6.1
    Installation des Adpters ohne Besonderheiten.
    Habe das homebridge-ikea-tradfri-gateway installiert, die config, wie von Alex1808 für ein funktionierendes Plugin beschrieben, eingestellt.
    Gateway ist online.
    Der Adapter zeigt kurz grün, dann bleibt er rot, das log zeigt folgende Fehler:
    ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error instance system.adapter.ham.0 terminated with code 0 (OK)
    ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error Caught by controller[2]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/index.js:4:15)
    ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require/index.js:29:22)
    ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: { Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
    ! host.iobrokerBosaca 2018-06-27 15:02:53.790 error Caught by controller[0]: [2018-6-27 13:02:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
    ! host.iobrokerBosaca 2018-06-27 15:02:50.474 info instance system.adapter.ham.0 started with pid 7291
    ! host.iobrokerBosaca 2018-06-27 15:02:20.449 info Restart adapter system.adapter.ham.0 because enabled</anonymous>
    die config:
    ! "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
    ! "accessories": [],
    ! "platforms": [
    ! "platform": "Ikea Trådfri Gateway",
    ! "name": "Ikea Trådfri Gateway",
    ! "host": "192.168.7.106", // IP des Tradfry Gateways
    ! "securityCode": "XXXXXXXXXX" // hier unkenntlich gemacht
    MfG Ulrich
    • apollon77A Online
      apollon77A Online
      #115
      Zeig mal den Log-Teil von der Installation des gewählten Plugins … In meinen Augen passt da was nicht:
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #116
        Warum Bindest du Ikea per Homebridge ein anstatt des tradifi Adapters ?
        Der Adapter kan mehr als Homebridge!
        Beides gleichzeitig geht nicht wegen besetzten ports
        • Z Offline
          Z Offline
          zahnheinrich
          #117
          @apollon77
          Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll:
          @Dutchman
          ...weil ich das Ding nicht mehr zum Laufen kriege... :oops:
          Es ging schon mal einwandfrei, nach Docker update, Adapter update auf 2.0 auf einmal nicht mehr, trotz stundenlangen Suchens.
          Auch zurück auf v1.4.1 beim Tradfri ging nicht mehr.
          Dacht nun, wenn mit dem homebridge plugin einfach ginge....
          MfG Ulrich
          • apollon77A Online
            apollon77A Online
            #118
            @zahnheinrich:
            @apollon77
            Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll: `
            Also du den Namen des Plugins in die Konfig eingetragen und gespeichert hast. Da würde das NPM paket installiert. Den Teil aus dem ioBroker-Log meine ich.
            @zahnheinrich:
            @Dutchman
            …weil ich das Ding nicht mehr zum Laufen kriege... :oops:
            Dacht nun, wenn mit dem homebridge plugin einfach ginge.... `
            Dann mache lieber einen Thread auf wo es darum geht den Adapter wieder zum laufen zu bekommen! :-)
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #119
              Nö lieber troubleshooten warum tradifi nicht mehr läuft Homebridge wird dir weniger Möglichkeiten geben als der Adapter.
              Mja, jedenfalls würde ich es so machen gut gemeinter tip
                schroedinger
                #120
                ich finde diesen adapter absolut toll , allerdings habe ich ein Problem, das ich einfach nicht selber lösen kann:
                Ich schaffe es nicht zwei "platforms" in die Konfigurationsdatei zu geben – denn ich erhalte immer eine Fehlermeldung und kann die Konfirguration nicht abspeichern.
                Hier die Konfirgurationsdatei - mit 2 "platforms", für dich ich die Fehlermeldung "expected ',' instead od '{' ferhalte -> und nicht abspeichern kann.
                (die Fehlermeldung steht übrigens über der Zeile mit "platform": "Info",
                ! "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                ! "accessories": [
                ! "accessory": "RaspberryPiTemperature",
                ! "name": "RaspberryPi CPU Temperature",
                ! "updateInterval": 1000
                ! "platforms": [
                ! "platform": "Seasons",
                ! "name": "Seasons",
                ! "calendar": "meteorologic",
                ! "hemisphere": "north",
                ! "display": "both"
                ! "platform": "Info",
                ! "port": 9876,
                ! "name": "Homebridge Info Server",
                ! "updateFrequency": 10000,
                ! "updateCheckFrequency": 86400
                Was an meiner Konfiguration ist falsch bzw. wie kann man mehrere "platforms" in der Konfigurationsdatei eintragen.
                Danke bereits jetzt für eure Tipps.
                schroedinger
                • Alex1808A Offline
                  Alex1808A Offline
                  Alex1808
                  #121
                  @schroedinger:
                  "platforms": [ `
                  es fehlt eine Komma
                  "name": "Seasons",
                  "display": "both"
                  "platform": "Info",
                  "port": 9876,
                  • apollon77A Online
                    apollon77A Online
                    #122
                    Nach der ersten Plattform und der schliessenden geschweiften Klammer ein Komma bitte weil Du ja noch einen Eintrag angibst.
                    Die Fehlermeldung sagt das doch … "erwarte ein Komma anstelle der nächsten öffnenden Klammer ...
                    Edit: Alex war schneller ;-)
                      schroedinger
                      #123
                      danke euch beiden.
                      Ich habe immer noch Probleme mit der Syntax von Konfigurationsdateien - aber auch wieder was gelernt.
                      Falls ich noch ein paar interessante hmebridge-adapter zum Laufen bringen, poste ich das hier. Mein Favorit wäre fakegato-history
                      Wenn das funktioniert, könnte man in der Elgato Eve app Graphen anzeigen lassen.
                      Sollte ich es hinbekommen, poste ich es hier.
                      danke
                      schroedinger
                      • apollon77A Online
                        apollon77A Online
                        #124
                        Dann sag doch welche Probleme du hast, dann finden wir eine Lösung.
                        Gesendet vom Handy …
                        • apollon77A Online
                          apollon77A Online
                          #125
                          Ps: dir ist aber schon klar das fakegato-History kein homebridge Plugin ist. Das ist eine Library die andere Plugin Provider einbauen können um für ihre Plugins in eve histories anzuzeigen.
                          Also du kannst da gar nichts tun. Das müssen die Plugin devs machen. Also wenn du es willst musst du bei denen isues aufmachen.
                          Auch dann wäre das hier nur für den globalen Modus interessant!! Für den wrapper Modus nimm History in iobroker oder so.
                            schroedinger
                            #126
                            hi @appolon77
                            Ich hatte mich schlecht ausgedrückt , als ich sagte, die Syntax macht mir immer noch Probleme. Ich meinte dies generell.
                            Aber mein oben erwähntes Problem hast du doch deine Post gelöst. Ich werde dies als "gelöst" markieren.
                            Bezüglich > fakegato-History kein homebridge Plugin
                            Zumindest hier steht, dass es ein homebridge-plugin wäre.
                            https://www.npmjs.com/search?q=homebrid … popularity
                            cu
                            • apollon77A Online
                              apollon77A Online
                              #127
                              Dann lies mal was auf der readme von dem Projekt steht.
                              • apollon77A Online
                                apollon77A Online
                                #128
                                Ps: das wäre eher ein issue für yahka in meinen Augen sowas mit einzubauen auch wenn nicht diese lib genutzt werden kann
                                  Kueppert
                                  #129
                                  Hi Gemeinde,
                                  hab mal wieder versucht, das plugin````
                                  [b]homebridge-mi-aqara[/b]
                                  (bedeutet: Daten eingetragen, gem. log wurde das plugin gestartet, die Mac-Adresse vom Gateway aufgerufen…und das wars. Keine Objekte erstellt. Testweise habe ich das Luftdaten-plugin ausprobiert - funktioniert. An einer Verbindung sollte es also nicht liegen)
                                  Ich würde gern den Aquara-Würfel nutzen können, der derzeit vom MiHome-Adapter (noch) nicht unterstützt wird.
                                  Frage: hat den Adapter schon jemand ausprobiert? Und ans Laufen bekommen?
                                  Link: [https://github.com/YinHangCode/homebridge-mi-aqara](https://github.com/YinHangCode/homebridge-mi-aqara)
                                  Danke und viele Grüße, Thorsten
                                  • smartboartS Offline
                                    smartboartS Offline
                                    smartboart
                                    #130
                                    hallo, cooles projekt…. mache mal mit und fange klein mit dem plugin an...
                                    bekomme diese Meldung...
                                    Jemand ne idee? wie ich das beheben kann?
                                    ham.0 2018-07-18 20:15:24.691 warn Error writing /opt/iobroker/iobroker-data/ham_0/config.json - Some Plugins may need that
                                    • apollon77A Online
                                      apollon77A Online
                                      #131
                                      Dann schau mal das der User unter dem ioBroker läuft da ein Verzeichnis anlegen und schreiben darf.
                                      Ob das ein Problem ist hängt davon ab ob die homebridge Plugins die du nutzen willst da config file brauchen. Einige lesen es
                                        smartboartS Offline
                                        smartboart
                                        #132
                                        ok war mein Fehler, hab eben erst kapiert, das der Name des plugin richtig eingetragen werden muss und mit Adapterneustart installiert wird.. :shock:
                                        probiere mal das plugginn hombridge-foscamcamera aus.habe sie zwar schon in vis eingebunden aber mal sehen was noch so geht damit
                                          smartboartS Offline
                                          smartboart
                                          #133
                                          hallo versuche die foscam instanz zum laufen zu bringen… Scheitere schon an der konfigurationsdatei...wie muss ich die anpassen, damit ich keine roten x Hinweise bekomme?
                                          "platforms": [
                                                "platform": "FoscamCamera",
                                                "name": "Foscam",
                                                "cameras": [
                                                    "username": "admin",
                                                    "password": "xxxxxxx",
                                                    "host": "192.168.xxx",
                                                    "port": 80,
                                                    "stay": 13,
                                                    "away": 15,
                                                    "night": 14
                                                    "password": "xxxxxxxx",
                                                    "host": "192.168.1xxx",
                                                    "port": 80,
                                                    "stay": 0,
                                                    "away": 14,
                                                    "night": 13,
                                                    "sensitivity": 2,
                                                    "triggerInterval": 5,
                                                    "gain": 6,
                                                    "spkrEnable": true,
                                                    "spkrCompression": true,
                                                    "spkrGain": 1
                                          Hier der log
                                          host.tinkerboard	2018-07-19 23:19:27.378	info	Restart adapter system.adapter.ham.0 because enabled
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:229:35)
                                          host.tinkerboard	2018-07-19 23:19:27.378	error	Caught by controller[5]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[5]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:199:17)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[5]: at Server.run (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:85:36)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[5]: at Server._loadPlatforms (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:314:45)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[5]: at API.platform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js:122:13)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[5]: Error: The requested platform 'FoscamCamera' was not registered by any plugin.
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[4]: [7/19/2018, 11:19:27 PM] ====================
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[3]: at tryModuleLoad (module.js:453:12)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[3]: at Module.load (module.js:494:32)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[3]: at Object.Module._extensions..js (module.js:586:10)
                                          host.tinkerboard	2018-07-19 23:19:27.377	error	Caught by controller[3]: at Module._compile (module.js:577:32)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/foscam-binary-client/lib/FoscamStreamLayer.js:5:20)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at require (internal/module.js:20:19)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at Module.require (module.js:504:17)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:29:22)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at Function.Module._load (module.js:424:25)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: at Function.Module._resolveFilename (module.js:476:15)
                                          host.tinkerboard	2018-07-19 23:19:27.376	error	Caught by controller[3]: [7/19/2018, 11:19:27 PM] Error: Cannot find module '../build/Release/FoscamG726'
                                          host.tinkerboard	2018-07-19 23:19:27.375	error	Caught by controller[2]: [7/19/2018, 11:19:27 PM] ERROR LOADING PLUGIN homebridge-foscamcamera:
                                          host.tinkerboard	2018-07-19 23:19:27.375	error	Caught by controller[1]: [7/19/2018, 11:19:27 PM] ====================
                                          host.tinkerboard	2018-07-19 23:19:27.375	error	Caught by controller[0]: [7/19/2018, 11:19:26 PM] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-seasons' since we already loaded the same plugin from '/opt/iobroker/node_mod
                                          host.tinkerboard	2018-07-19 23:19:27.375	error	Caught by controller[0]: [7/19/2018, 11:19:26 PM] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                          host.tinkerboard	2018-07-19 23:19:27.374	error	Caught by controller[0]: [7/19/2018, 11:19:26 PM] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-foscam-stream package.json does not contain the keyword 'homebridge-plugin'.
                                          ham.0	2018-07-19 23:19:27.313	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.3
                                          ham.0	2018-07-19 23:19:24.689	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.3</anonymous></anonymous>
