  4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
    6.7k
343 Beiträge 55 Kommentatoren 117.7k Aufrufe 14 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #106
    Zeig Mal deine config
    • R Offline
      rudiraz
      #107
      Plugin erstmal nur zum Test drin:
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #108
        Nimm Mal {} bij Platforms Weck wenn nichts eingefüllt reicht []
        • R Offline
          rudiraz
          #109
          Ahh ok, das war der Fehler.
          Dann kann ich mal testen jetzt :-)
          Danke und Grüße
          • MeistertrM Offline
            MeistertrM Offline
            Meistertr
            #110
            wollte es auch gerade testen leider ohne erfolg, er kann die config.json nicht finden.
            host.devbroker	2018-06-26 21:59:40.320	info	Restart adapter system.adapter.ham.0 because enabled
            host.devbroker	2018-06-26 21:59:40.320	error	instance system.adapter.ham.0 terminated with code 0 (OK)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: path: '/opt/iobroker/iobroker-data/ham_0/config.json' }
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: syscall: 'open',
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: code: 'ENOENT',
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: errno: -2,
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Array.forEach (<anonymous>)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.readFileSync (fs.js:551:33)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.openSync (fs.js:646:18)
            Caught	2018-06-26 21:59:40.320	error	by controller[1]: { Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
            Caught	2018-06-26 21:59:40.319	error	by controller[0]: [2018-6-26 21:59:40] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            ham.0	2018-06-26 21:59:40.314	warn	Exception: Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
            ham.0	2018-06-26 21:59:40.314	info	cleaned everything up...
            ham.0	2018-06-26 21:59:40.314	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
            ham.0	2018-06-26 21:59:40.314	error	at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
            ham.0	2018-06-26 21:59:40.314	error	at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
            ham.0	2018-06-26 21:59:40.314	error	at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
            ham.0	2018-06-26 21:59:40.314	error	at Array.forEach (<anonymous>)
            ham.0	2018-06-26 21:59:40.314	error	at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
            ham.0	2018-06-26 21:59:40.314	error	at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
            ham.0	2018-06-26 21:59:40.314	error	at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
            ham.0	2018-06-26 21:59:40.314	error	at Object.fs.readFileSync (fs.js:551:33)
            ham.0	2018-06-26 21:59:40.314	error	at Object.fs.openSync (fs.js:646:18)
            ham.0	2018-06-26 21:59:40.314	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
            ham.0	2018-06-26 21:59:40.314	error	uncaught exception: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
            ham.0	2018-06-26 21:59:40.311	debug	[2018-6-26 21:59:40] Loaded plugin: homebridge-mi-philips-light</anonymous></anonymous></anonymous></anonymous>
            das modul habe ich eigentlich schon gelöscht.. screenshot der Config im Anhang
            • apollon77A Online
              apollon77A Online
              #111
              Oooohje diese Plugin-Entwickler … warum auch immer die das Configfile lesen ...
              Bitte 0.4.3 vom GitHub versuchen. geht es damit? Er schreibt jetzt die Konfig ins Konfigverzeichnis zusätzlich.
              Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst.
              • Alex1808A Offline
                Alex1808A Offline
                Alex1808
                #112
                @apollon77:
                Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst. `
                Am besten aus dem Grund-config diese Beispiele löschen, es verwirrt nur.
                • apollon77A Online
                  apollon77A Online
                  #113
                  0.4.3 macht genau das ;)
                  Gesendet vom Handy …
                  • Z Offline
                    Z Offline
                    zahnheinrich
                    #114
                    Hallo in die Runde,
                    Mein System:
                    ioBroker auf Synology buanet-Docker
                    node v6.14.3
                    npm 4.6.1
                    Installation des Adpters ohne Besonderheiten.
                    Habe das homebridge-ikea-tradfri-gateway installiert, die config, wie von Alex1808 für ein funktionierendes Plugin beschrieben, eingestellt.
                    Gateway ist online.
                    Der Adapter zeigt kurz grün, dann bleibt er rot, das log zeigt folgende Fehler:
                    ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error instance system.adapter.ham.0 terminated with code 0 (OK)
                    ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error Caught by controller[2]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/index.js:4:15)
                    ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require/index.js:29:22)
                    ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: { Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
                    ! host.iobrokerBosaca 2018-06-27 15:02:53.790 error Caught by controller[0]: [2018-6-27 13:02:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                    ! host.iobrokerBosaca 2018-06-27 15:02:50.474 info instance system.adapter.ham.0 started with pid 7291
                    ! host.iobrokerBosaca 2018-06-27 15:02:20.449 info Restart adapter system.adapter.ham.0 because enabled</anonymous>
                    die config:
                    ! "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
                    ! "accessories": [],
                    ! "platforms": [
                    ! "platform": "Ikea Trådfri Gateway",
                    ! "name": "Ikea Trådfri Gateway",
                    ! "host": "192.168.7.106", // IP des Tradfry Gateways
                    ! "securityCode": "XXXXXXXXXX" // hier unkenntlich gemacht
                    MfG Ulrich
                    • apollon77A Online
                      apollon77A Online
                      #115
                      Zeig mal den Log-Teil von der Installation des gewählten Plugins … In meinen Augen passt da was nicht:
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #116
                        Warum Bindest du Ikea per Homebridge ein anstatt des tradifi Adapters ?
                        Der Adapter kan mehr als Homebridge!
                        Beides gleichzeitig geht nicht wegen besetzten ports
                        • Z Offline
                          Z Offline
                          zahnheinrich
                          #117
                          @apollon77
                          Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll:
                          @Dutchman
                          ...weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                          Es ging schon mal einwandfrei, nach Docker update, Adapter update auf 2.0 auf einmal nicht mehr, trotz stundenlangen Suchens.
                          Auch zurück auf v1.4.1 beim Tradfri ging nicht mehr.
                          Dacht nun, wenn mit dem homebridge plugin einfach ginge....
                          MfG Ulrich
                          • apollon77A Online
                            apollon77A Online
                            #118
                            @zahnheinrich:
                            @apollon77
                            Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll: `
                            Also du den Namen des Plugins in die Konfig eingetragen und gespeichert hast. Da würde das NPM paket installiert. Den Teil aus dem ioBroker-Log meine ich.
                            @zahnheinrich:
                            @Dutchman
                            …weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                            Dacht nun, wenn mit dem homebridge plugin einfach ginge.... `
                            Dann mache lieber einen Thread auf wo es darum geht den Adapter wieder zum laufen zu bekommen! :-)
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #119
                              Nö lieber troubleshooten warum tradifi nicht mehr läuft Homebridge wird dir weniger Möglichkeiten geben als der Adapter.
                              Mja, jedenfalls würde ich es so machen gut gemeinter tip
                                schroedinger
                                #120
                                ich finde diesen adapter absolut toll , allerdings habe ich ein Problem, das ich einfach nicht selber lösen kann:
                                Ich schaffe es nicht zwei "platforms" in die Konfigurationsdatei zu geben – denn ich erhalte immer eine Fehlermeldung und kann die Konfirguration nicht abspeichern.
                                Hier die Konfirgurationsdatei - mit 2 "platforms", für dich ich die Fehlermeldung "expected ',' instead od '{' ferhalte -> und nicht abspeichern kann.
                                (die Fehlermeldung steht übrigens über der Zeile mit "platform": "Info",
                                ! "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                                ! "accessories": [
                                ! "accessory": "RaspberryPiTemperature",
                                ! "name": "RaspberryPi CPU Temperature",
                                ! "updateInterval": 1000
                                ! "platforms": [
                                ! "platform": "Seasons",
                                ! "name": "Seasons",
                                ! "calendar": "meteorologic",
                                ! "hemisphere": "north",
                                ! "display": "both"
                                ! "platform": "Info",
                                ! "port": 9876,
                                ! "name": "Homebridge Info Server",
                                ! "updateFrequency": 10000,
                                ! "updateCheckFrequency": 86400
                                Was an meiner Konfiguration ist falsch bzw. wie kann man mehrere "platforms" in der Konfigurationsdatei eintragen.
                                Danke bereits jetzt für eure Tipps.
                                schroedinger
                                • Alex1808A Offline
                                  Alex1808A Offline
                                  Alex1808
                                  #121
                                  @schroedinger:
                                  "platforms": [ `
                                  es fehlt eine Komma
                                  "name": "Seasons",
                                  "display": "both"
                                  "platform": "Info",
                                  "port": 9876,
                                  • apollon77A Online
                                    apollon77A Online
                                    #122
                                    Nach der ersten Plattform und der schliessenden geschweiften Klammer ein Komma bitte weil Du ja noch einen Eintrag angibst.
                                    Die Fehlermeldung sagt das doch … "erwarte ein Komma anstelle der nächsten öffnenden Klammer ...
                                    Edit: Alex war schneller ;-)
                                      schroedinger
                                      #123
                                      danke euch beiden.
                                      Ich habe immer noch Probleme mit der Syntax von Konfigurationsdateien - aber auch wieder was gelernt.
                                      Falls ich noch ein paar interessante hmebridge-adapter zum Laufen bringen, poste ich das hier. Mein Favorit wäre fakegato-history
                                      Wenn das funktioniert, könnte man in der Elgato Eve app Graphen anzeigen lassen.
                                      Sollte ich es hinbekommen, poste ich es hier.
                                      danke
                                      schroedinger
                                      • apollon77A Online
                                        apollon77A Online
                                        #124
                                        Dann sag doch welche Probleme du hast, dann finden wir eine Lösung.
                                        • apollon77A Online
                                          apollon77A Online
                                          #125
                                          Ps: dir ist aber schon klar das fakegato-History kein homebridge Plugin ist. Das ist eine Library die andere Plugin Provider einbauen können um für ihre Plugins in eve histories anzuzeigen.
                                          Also du kannst da gar nichts tun. Das müssen die Plugin devs machen. Also wenn du es willst musst du bei denen isues aufmachen.
                                          Auch dann wäre das hier nur für den globalen Modus interessant!! Für den wrapper Modus nimm History in iobroker oder so.
