  4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
    6.7k
343 Beiträge 55 Kommentatoren 117.7k Aufrufe 14 Beobachtet
    Kueppert
    #88
    hab mich auch mal gewagt zu testen (nutze die Version 0.4.1 vom Adapter).
    Installieren wollte ich folgendes Plugin: homebridge-mi-aqara-2
    Ich nutze folgenden json-Code aktuell (MAC-Adresse und PW gemäß Anleitung gefunden und eingetragen, hier ausge-x-t):
    "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
    "accessories": [
    "accessory": "WeMo",
    "name": "Coffee Maker"
    "platforms": [
    "platform": "MiAqaraPlatform",
    "gateways": {
    "34xxxxxxxxxx": "ecxxxxxxxxxxxxxx"
    Ich erhalte folgende Fehlermeldung beim Starten der ham-Instanz:
    host.iobrokerNUC	2018-06-23 14:18:54.653	error	instance system.adapter.ham.0 terminated with code 0 (OK)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:228:35)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:190:17)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:86:38)
    Caught	2018-06-23 14:18:54.653	error	by controller[2]: at Server._loadAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:284:42)
    Caught	2018-06-23 14:18:54.652	error	by controller[2]: at API.accessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/api.js:64:13)
    Caught	2018-06-23 14:18:54.652	error	by controller[2]: Error: The requested accessory 'WeMo' was not registered by any plugin.
    Caught	2018-06-23 14:18:54.652	error	by controller[1]: [2018-6-23 14:18:54] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
    Caught	2018-06-23 14:18:54.652	error	by controller[0]: [2018-6-23 14:18:54] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
    ham.0	2018-06-23 14:18:54.615	warn	Exception: Error: The requested accessory 'WeMo' was not registered by any plugin.
    ham.0	2018-06-23 14:18:54.611	info	cleaned everything up...
    ham.0	2018-06-23 14:18:54.611	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
    ham.0	2018-06-23 14:18:54.611	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
    ham.0	2018-06-23 14:18:54.611	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
    ham.0	2018-06-23 14:18:54.611	error	at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
    ham.0	2018-06-23 14:18:54.611	error	at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:228:35)
    ham.0	2018-06-23 14:18:54.611	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
    ham.0	2018-06-23 14:18:54.611	error	at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:190:17)
    ham.0	2018-06-23 14:18:54.611	error	at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:86:38)
    ham.0	2018-06-23 14:18:54.611	error	at Server._loadAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:284:42)
    ham.0	2018-06-23 14:18:54.611	error	at API.accessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/api.js:64:13)
    ham.0	2018-06-23 14:18:54.611	error	Error: The requested accessory 'WeMo' was not registered by any plugin.
    ham.0	2018-06-23 14:18:54.610	error	uncaught exception: The requested accessory 'WeMo' was not registered by any plugin.
    ham.0	2018-06-23 14:18:53.503	info	starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.2
    host.iobrokerNUC	2018-06-23 14:18:52.924	info	instance system.adapter.ham.0 started with pid 1019</anonymous></anonymous>
    Schon jmd versucht, das plugin ans Laufen zu bekommen oder einer einen Tip, was ich noch versuchen kann?
    Danke und Grüße, Thorsten
    PS: Hab vorher nen Snapshot in proxmox gemacht ;)
    • apollon77A Online
      apollon77A Online
      #89
      Fehler sagt das Wemo von keinem Plugin registriert ist. Wenn du Wemo nicht willst dann raus damit. Das war ggf vom Beispiel vorab noch drin? ;-)
      Gesendet vom Handy …
        Kueppert
        #90
        Ach,
        jau, das war es. Jetzt habe ich nach dem Laden (hab mal nachträglich auf debug gestellt) festgestellt, dass ein gelöschter Adapter trotzdem nachwievor geladen wird…der devolo-Adapter...
        ham.0 2018-06-24 12:30:34.165 debug system.adapter.admin.0: logging true
        ham.0 2018-06-24 12:30:30.288 debug system.adapter.admin.0: logging false
        ham.0 2018-06-24 12:30:29.408 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO]server is listening on port 9898.
        ham.0 2018-06-24 12:30:29.392 debug Homebridge Wrapper Bridge publish {"username":"FF:FF:FF:FF:FF:FF","port":0,"pincode":"0","category":2}
        ham.0 2018-06-24 12:30:29.390 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO]start success...
        ham.0 2018-06-24 12:30:29.389 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO]**************************************************************
        ham.0 2018-06-24 12:30:29.389 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO] QQ Group: 107927710
        ham.0 2018-06-24 12:30:29.389 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO] GitHub: https://github.com/YinHangCode/homebridge-mi-aqara
        ham.0 2018-06-24 12:30:29.389 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO] MiAqaraPlatform v1.0.2 By YinHang
        ham.0 2018-06-24 12:30:29.386 debug [2018-6-24 12:30:29] [MiAqaraPlatform] [INFO]**************************************************************
        ham.0 2018-06-24 12:30:29.376 debug [2018-6-24 12:30:29] [MiAqaraPlatform] Initializing MiAqaraPlatform platform...
        ham.0 2018-06-24 12:30:29.375 debug [2018-6-24 12:30:29] Loading 1 platforms...
        ham.0 2018-06-24 12:30:29.366 debug [2018-6-24 12:30:29] ---
        ham.0 2018-06-24 12:30:29.366 debug [2018-6-24 12:30:29] Registering platform 'homebridge-mi-aqara.MiAqaraPlatform'
        ham.0 2018-06-24 12:30:29.365 debug [2018-6-24 12:30:29] Loaded plugin: homebridge-mi-aqara-2
        ham.0 2018-06-24 12:30:29.303 debug [2018-6-24 12:30:29] ---
        ham.0 2018-06-24 12:30:29.303 debug [2018-6-24 12:30:29] Registering platform 'homebridge-devolo.Devolo'
        ham.0 2018-06-24 12:30:29.301 debug [2018-6-24 12:30:29] Loaded plugin: homebridge-devolo
        ham.0 2018-06-24 12:30:28.290 info starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.2
        ham.0 2018-06-24 12:30:28.183 debug statesDB connected
        ham.0 2018-06-24 12:30:28.152 debug objectDB connected
        ham.0 2018-06-24 12:30:25.242 info terminating
        ham.0 2018-06-24 12:30:25.217 info cleaned everything up...
        ham.0 2018-06-24 12:28:45.198 info starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.2
        der steht aber in der Instanz schon garnicht mehr drin - auch in der json steht nix (stand auch vorher nie was von devolo):
         ![2700_ham_1.png](/assets/uploads/files/2700_ham_1.png)
         ![2700_ham_2.png](/assets/uploads/files/2700_ham_2.png)
        Und dann noch eine Frage: wo sollten denn die Objekte jetzt auftauchen? Entweder ich bin blind - oder da sind keine?
         ![2700_ham_3.png](/assets/uploads/files/2700_ham_3.png)
        Danke euch und Grüße, Thorsten
        • apollon77A Online
          apollon77A Online
          #91
          Ja wenn du homebridge Plugins installierst bleiben die da und homebridge findet sie. Ist aber nicht schlimm.
          Wegbekommen: im Verzeichnis /opt/iobroker/node_modules/iobroker.ham
          Ein
          npm uninstall homebridge-Name
          Machen.
          Die datenpunkte sollten intern ham.0 auftauchen. Mal Seite bzw Objekte neu geladen? Sagt das log irgendwas?
            Kueppert
            #92
            Hallo Apo,
            hab gerade den Adapter nochmal neu gestartet, Log auf debug. Nutze gerade einen anderen Rechner. Auch hier taucht unter Objekte kein ham.0 auf…
            Das log sagt folgendes (in meinen Augen nix ungewöhnliches, bin aber auch eher unwissend...):
            ham.0 2018-06-24 20:58:46.977 debug system.adapter.admin.0: logging true
            ham.0 2018-06-24 20:58:10.988 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO]server is listening on port 9898.
            ham.0 2018-06-24 20:58:10.972 debug Homebridge Wrapper Bridge publish {"username":"FF:FF:FF:FF:FF:FF","port":0,"pincode":"0","category":2}
            ham.0 2018-06-24 20:58:10.969 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO]start success...
            ham.0 2018-06-24 20:58:10.969 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO]**************************************************************
            ham.0 2018-06-24 20:58:10.969 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO] QQ Group: 107927710
            ham.0 2018-06-24 20:58:10.969 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO] GitHub: https://github.com/YinHangCode/homebridge-mi-aqara
            ham.0 2018-06-24 20:58:10.968 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO] MiAqaraPlatform v1.0.2 By YinHang
            ham.0 2018-06-24 20:58:10.966 debug [2018-6-24 20:58:10] [MiAqaraPlatform] [INFO]**************************************************************
            ham.0 2018-06-24 20:58:10.956 debug [2018-6-24 20:58:10] [MiAqaraPlatform] Initializing MiAqaraPlatform platform...
            ham.0 2018-06-24 20:58:10.955 debug [2018-6-24 20:58:10] Loading 1 platforms...
            ham.0 2018-06-24 20:58:10.946 debug [2018-6-24 20:58:10] ---
            ham.0 2018-06-24 20:58:10.946 debug [2018-6-24 20:58:10] Registering platform 'homebridge-mi-aqara.MiAqaraPlatform'
            ham.0 2018-06-24 20:58:10.945 debug [2018-6-24 20:58:10] Loaded plugin: homebridge-mi-aqara-2
            ham.0 2018-06-24 20:58:10.883 debug [2018-6-24 20:58:10] ---
            ham.0 2018-06-24 20:58:10.882 debug [2018-6-24 20:58:10] Registering platform 'homebridge-devolo.Devolo'
            ham.0 2018-06-24 20:58:10.881 debug [2018-6-24 20:58:10] Loaded plugin: homebridge-devolo
            ham.0 2018-06-24 20:58:09.885 info starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.2
            ham.0 2018-06-24 20:58:09.776 debug statesDB connected
            ham.0 2018-06-24 20:58:09.735 debug objectDB connected
            ham.0 2018-06-24 20:58:06.827 info terminating
            ham.0 2018-06-24 20:58:06.799 info cleaned everything up...
            ham.0 2018-06-24 12:37:11.796 debug system.adapter.admin.0: logging false
            ham.0 2018-06-24 12:35:44.260 debug system.adapter.admin.0: logging true
            ham.0 2018-06-24 12:32:41.744 debug system.adapter.admin.0: logging false
            PS: Habe auf meinem PI3 (nicht hier auf meinem NUC) n MI-Home-Adapter laufen. Kann es evtl. daran liegen, dass ich keine Objekte bekomme? Ich glaube zwar nicht, dass das Gateway nur einen Zugriff zulässt, bin aber nicht sicher…
            • apollon77A Online
              apollon77A Online
              #93
              Naja dann liegt es daran das das mi-aquara Plugin wohl keine Objekte kennt und anlegt.
              Schau mal ob da alles korrekt ist. Sonst müsste dein debug log eindeutig zeigen das was angelegt wird.
              Ingo
              • Alex1808A Offline
                Alex1808A Offline
                Alex1808
                #94
                Habe einen Plugin gefunden der sich ganz komisch verhält.. das ist der homebridge-http-switch Plugin.
                1. Im Global modus kommen lauter Fehler im Log. Wird kurz Grün, anlegt Objekte und dann wieder Rot
                ost.buanet 2018-06-25 15:39:44.193 error instance system.adapter.ham.0 terminated with code 0 (OK)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at emitOne (events.js:116:13)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/request/request.js:1157:10)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at Request.emit (events.js:214:7)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at emitTwo (events.js:126:13)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.ham/node_modules/request/request.js:185:22)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at Request._callback (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-http-switch/index.js:284:17)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at HTTP_SWITCH. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-http-switch/index.js:127:25)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at /usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:16:19
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at Characteristic.On. <anonymous>(/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Characteristic.js:167:23)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: at char.getValue (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:96:32)
                Caught 2018-06-25 15:39:44.193 error by controller[2]: TypeError: logger.warn is not a function
                Caught 2018-06-25 15:39:44.193 error by controller[1]: [2018-6-25 13:39:44] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-http-switch' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobrok
                Caught 2018-06-25 15:39:44.193 error by controller[0]: [2018-6-25 13:39:43] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                ham.0 2018-06-25 15:39:44.188 info stateChange ham.0.Knopka-2.Accessory-Information.Hardware-Revision {"val":"","ack":true,"ts":1529933984181,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0 2018-06-25 15:39:44.188 warn Exception: TypeError: logger.warn is not a function
                ham.0 2018-06-25 15:39:44.186 info cleaned everything up...
                ham.0 2018-06-25 15:39:44.185 error at emitOne (events.js:116:13)
                ham.0 2018-06-25 15:39:44.185 error at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/request/request.js:1157:10)
                ham.0 2018-06-25 15:39:44.185 error at Request.emit (events.js:214:7)
                ham.0 2018-06-25 15:39:44.185 error at emitTwo (events.js:126:13)
                ham.0 2018-06-25 15:39:44.185 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.ham/node_modules/request/request.js:185:22)
                ham.0 2018-06-25 15:39:44.185 error at Request._callback (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-http-switch/index.js:284:17)
                ham.0 2018-06-25 15:39:44.185 error at HTTP_SWITCH. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-http-switch/index.js:127:25)
                ham.0 2018-06-25 15:39:44.185 error at /usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:16:19
                ham.0 2018-06-25 15:39:44.185 error at Characteristic.On. <anonymous>(/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Characteristic.js:167:23)
                ham.0 2018-06-25 15:39:44.185 error at char.getValue (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:96:32)
                ham.0 2018-06-25 15:39:44.185 error TypeError: logger.warn is not a function
                ham.0 2018-06-25 15:39:44.185 error uncaught exception: logger.warn is not a function
                ham.0 2018-06-25 15:39:44.181 info stateChange ham.0.Knopka-2.Accessory-Information.Firmware-Revision {"val":"0.4.9","ack":true,"ts":1529933984178,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0 2018-06-25 15:39:44.180 info stateChange ham.0.Knopka-2.Accessory-Information.Serial-Number {"val":"SW01","ack":true,"ts":1529933984178,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0 2018-06-25 15:39:44.180 info stateChange ham.0.Knopka-2.Accessory-Information.Name {"val":"Knopka-2","ack":true,"ts":1529933984178,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                2\. Im config modus wird sofort Grün und im Log gibst keine Fehler
                ham.0	2018-06-25 15:43:58.093	info	stateChange ham.0.Knopka-1.Knopka-1.On {"val":true,"ack":true,"ts":1529934238092,"q":0,"from":"system.adapter.ham.0","lc":1529925873505}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Knopka-2.Name {"val":"","ack":true,"ts":1529934238072,"q":0,"from":"system.adapter.ham.0","lc":1529934238072}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Knopka-2.On {"val":true,"ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302473}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Knopka-2.Name {"val":"Knopka-2","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529934238071}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Accessory-Flags {"val":0,"ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Hardware-Revision {"val":"","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Firmware-Revision {"val":"0.4.9","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Serial-Number {"val":"SW01","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Name {"val":"Knopka-2","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302472}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Model {"val":"HTTP Switch","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Manufacturer {"val":"Andreas Bauer","ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-2.Accessory-Information.Identify {"val":false,"ack":true,"ts":1529934238071,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-1.Knopka-1.Name {"val":"","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529934238070}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-1.Knopka-1.Name {"val":"Knopka-1","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529934238070}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-1.Accessory-Information.Accessory-Flags {"val":0,"ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-1.Accessory-Information.Hardware-Revision {"val":"","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.087	info	stateChange ham.0.Knopka-1.Accessory-Information.Firmware-Revision {"val":"0.4.9","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.086	info	stateChange ham.0.Knopka-1.Accessory-Information.Serial-Number {"val":"SW01","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302469}
                ham.0	2018-06-25 15:43:58.086	info	stateChange ham.0.Knopka-1.Accessory-Information.Name {"val":"Knopka-1","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302462}
                ham.0	2018-06-25 15:43:58.086	info	stateChange ham.0.Knopka-1.Accessory-Information.Model {"val":"HTTP Switch","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302462}
                ham.0	2018-06-25 15:43:58.086	info	stateChange ham.0.Knopka-1.Accessory-Information.Manufacturer {"val":"Andreas Bauer","ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302462}
                ham.0	2018-06-25 15:43:58.086	info	stateChange ham.0.Knopka-1.Accessory-Information.Identify {"val":false,"ack":true,"ts":1529934238070,"q":0,"from":"system.adapter.ham.0","lc":1529925302462}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Knopka-2.Name: value = /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Knopka-2.On: value = true /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Knopka-2.Name: value = Knopka-2 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateChannel Knopka-2.Knopka-2: name = Knopka-2
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Accessory-Flags: value = 0 /common= {"type":"number","min":0,"max":4294967295,"read":true,"write":false,"role":"value","name":"Accessory Flags","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Hardware-Revision: value = /common= {"type":"string","read":true,"write":false,"role":"state","name":"Hardware Revision","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Firmware-Revision: value = 0.4.9 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Firmware Revision","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Serial-Number: value = SW01 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Serial Number","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Name: value = Knopka-2 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Model: value = HTTP Switch /common= {"type":"string","read":true,"write":false,"role":"state","name":"Model","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Manufacturer: value = Andreas Bauer /common= {"type":"string","read":true,"write":false,"role":"state","name":"Manufacturer","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateState Knopka-2.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                ham.0	2018-06-25 15:43:58.063	info	updateChannel Knopka-2.Accessory-Information: name = undefined
                ham.0	2018-06-25 15:43:58.063	info	updateDev Knopka-2: name = Knopka-2 /type= 1
                ham.0	2018-06-25 15:43:58.057	info	updateState Knopka-1.Knopka-1.Name: value = /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.057	info	updateState Knopka-1.Knopka-1.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Knopka-1.Name: value = Knopka-1 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateChannel Knopka-1.Knopka-1: name = Knopka-1
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Accessory-Information.Accessory-Flags: value = 0 /common= {"type":"number","min":0,"max":4294967295,"read":true,"write":false,"role":"value","name":"Accessory Flags","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Accessory-Information.Hardware-Revision: value = /common= {"type":"string","read":true,"write":false,"role":"state","name":"Hardware Revision","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Accessory-Information.Firmware-Revision: value = 0.4.9 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Firmware Revision","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Accessory-Information.Serial-Number: value = SW01 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Serial Number","unit":""}
                ham.0	2018-06-25 15:43:58.056	info	updateState Knopka-1.Accessory-Information.Name: value = Knopka-1 /common= {"type":"string","read":true,"write":false,"role":"state","name":"Name","unit":""}
                ham.0	2018-06-25 15:43:58.055	info	updateState Knopka-1.Accessory-Information.Model: value = HTTP Switch /common= {"type":"string","read":true,"write":false,"role":"state","name":"Model","unit":""}
                ham.0	2018-06-25 15:43:58.055	info	updateState Knopka-1.Accessory-Information.Manufacturer: value = Andreas Bauer /common= {"type":"string","read":true,"write":false,"role":"state","name":"Manufacturer","unit":""}
                ham.0	2018-06-25 15:43:58.055	info	updateState Knopka-1.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                ham.0	2018-06-25 15:43:58.055	info	updateChannel Knopka-1.Accessory-Information: name = undefined
                ham.0	2018-06-25 15:43:58.054	info	updateDev Knopka-1: name = Knopka-1 /type= 1
                ham.0	2018-06-25 15:43:57.687	info	starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.ham, node: v8.11.3
                yahka.0	2018-06-25 15:43:57.446	info	objectChange system.adapter.ham.0 {"_id":"system.adapter.ham.0","type":"instance","common":{"name":"ham","version":"0.4.1","news":{"0.4.1":{"en":"option to poll values from the plugins added and othe
                host.buanet	2018-06-25 15:43:57.445	info	instance system.adapter.ham.0 started with pid 4302
                host.buanet	2018-06-25 15:43:57.442	info	"system.adapter.ham.0" enabled
                host.buanet	2018-06-25 15:43:57.442	info	object change system.adapter.ham.0
                yahka.0	2018-06-25 15:43:55.538	info	objectChange system.adapter.ham.0 {"_id":"system.adapter.ham.0","type":"instance","common":{"name":"ham","version":"0.4.1","news":{"0.4.1":{"en":"option to poll values from the plugins added and othe
                host.buanet	2018-06-25 15:43:55.536	info	object change system.adapter.ham.0
                3. Beim starten Homebridge (ohne ham adapter) geht auch alles ohne Problemen und keine Fehler im Log
                Objekte
                  Kueppert
                  #95
                  Kurze Frage: ich muss dich nur den ham-Adapter installieren um die Plugins für Homebridge nutzen zu können, korrekt? Oder muss ich separat auch den/einen Homebridge Adapter installieren??
                  VG Thorsten
                  Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #96
                    @Kueppert:
                    VG Thorsten
                    Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk `
                    Du musst :
                    • den HAM Adapter installieren
                    • die gewünschten Plugins in der Adapter Konfiguration eintragen (diese werden dann bei Adapter start installiert)
                    • die Konfiguration des betreffenden Plugins im HAM Adapter eintragen
                    Greetz
                    Dutch
                    • apollon77A Online
                      apollon77A Online
                      #97
                      @Alex1808:
                      1. Im Global modus kommen lauter Fehler im Log. Wird kurz Grün, anlegt Objekte und dann wieder Rot `
                      Gratuliere, Bug gefunden!
                      Bitte Github version versuchen. Geht es damit auch im Global-Mode?
                      Dann release ich das nach deinem Check. Danke!
                      • Alex1808A Offline
                        Alex1808A Offline
                        Alex1808
                        #98
                        @apollon77:
                        Dann release ich das nach deinem Check. Danke! `
                        Ja, Geht!
                        habe nur ein kurze Warnung > ham.0 2018-06-25 17:14:37.234 warn Error while getting current value: Error: Got html error code 404
                        aber ich glaube das ist weil ich noch keine richtige URLs eingetragen habe.
                          Kueppert
                          #99
                          @Dutchman:
                          @Kueppert:
                          VG Thorsten
                          Du musst :
                          Greetz
                          Dutch
                          Sent from my iPhone using Tapatalk ` Super danke, also alles richtig gemacht ;)
                          • Alex1808A Offline
                            Alex1808A Offline
                            Alex1808
                            #100
                            @apollon77:
                            Habe richtige URLs eingetragen, funktioniert sehr gut! (Warnung ist auch weg) Danke!
                            Kurze frage habe ich noch, was muss ich eintragen um status vom "State" rauszulesen? Habe jetzt mit prettyPrint und getPlainValue versucht, ohne erfolg. (es geht um simple-api Adapter)
                            Mein config
                            "accessories": [
                            "accessory": "HTTP-SWITCH",
                            "name": "Knopka-1",
                            "switchType": "stateful",
                            "httpMethod": "GET",
                            "onUrl": "http://192.168.2.88:8087/set/javascript.0.Test.Knopka-1?value=true",
                            "offUrl": "http://192.168.2.88:8087/set/javascript.0.Test.Knopka-1?value=false",
                            "statusUrl": "http://192.168.2.88:8087/getPlainValue/javascript.0.Test.Knopka-1"
                            "name": "Knopka-2",
                            "switchType": "stateless-reverse",
                            "timeout": 1000,
                            "offUrl": "http://192.168.2.88:8087/set/javascript.0.Test.Knopka-2?value=false"
                            Update:
                            Habe nachgelesen, es muss noch ein homebridge-http-notification-server laufen und eingerichtet werden..
                            • apollon77A Online
                              apollon77A Online
                              #101
                              Die Frage ist aber ziemlich Plugin-Spezifisch und wäre in einem eigenen Thread besser aufgehoben ;-)
                              Tip: Ruf direkt auf und schau ob der Wert rauskommt. Was das Plugin mit dem Wert wie macht und erwartet weiss ich aber nicht.
                              • Alex1808A Offline
                                Alex1808A Offline
                                Alex1808
                                #102
                                @apollon77:
                                Tip: Ruf direkt auf und schau ob der Wert rauskommt. Was das Plugin mit dem Wert wie macht und erwartet weiss ich aber nicht. `
                                ok.
                                Bei "Funktionierende Plugins und Beispiele" hinzugefügt.
                                viewtopic.php?f=20&t=15021&p=158013#p158013
                                P.S. Habe mit Dev. vom homebridge-iobroker gesprochen wird eventuell ein Fortsetzung geben :)
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #103
                                  @Alex1808:
                                  P.S. Habe mit Dev. vom homebridge-iobroker gesprochen wird eventuell ein Fortsetzung geben :) `
                                  Interesting! Was genau?
                                  • Alex1808A Offline
                                    Alex1808A Offline
                                    Alex1808
                                    #104
                                    @Dutchman:
                                    Interesting! Was genau? `
                                    Native Verbindung zwischen iobroker und Homebridge (ohne yahka adapter)
                                    "platforms": [
                                                "platform" : "homebridge-iobroker.iobroker",
                                                "name" : "iobroker",
                                                "host": "http://localhost:8084",
                                                "filter": "*",
                                                "switches": [
                                                    "adapter.0.object_1",
                                                    "adapter.0.object_2",
                                                    "adapter.0.object_3",
                                    https://github.com/Haba1234/homebridge-iobroker
                                    • R Offline
                                      rudiraz
                                      #105
                                      mich interessiert der Adapter sehr.
                                      Leider bekomme ich beim Start folgende Meldung:
                                      ` > ham.0 2018-06-26 10:48:38.034 info terminating
                                      ham.0 2018-06-26 10:48:37.946 warn Exception: TypeError: Cannot read property 'indexOf' of undefined
                                      ham.0 2018-06-26 10:48:37.938 info cleaned everything up…
                                      ham.0 2018-06-26 10:48:37.936 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                      ham.0 2018-06-26 10:48:37.936 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                      ham.0 2018-06-26 10:48:37.936 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2249:25)
                                      ham.0 2018-06-26 10:48:37.936 error at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
                                      ham.0 2018-06-26 10:48:37.936 error at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:229:35)
                                      ham.0 2018-06-26 10:48:37.936 error at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
                                      ham.0 2018-06-26 10:48:37.936 error at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:190:17)
                                      ham.0 2018-06-26 10:48:37.936 error at Server.run (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:85:36)
                                      ham.0 2018-06-26 10:48:37.936 error at Server._loadPlatforms (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:314:45)
                                      ham.0 2018-06-26 10:48:37.936 error at API.platform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js:108:11)
                                      ham.0 2018-06-26 10:48:37.936 error TypeError: Cannot read property 'indexOf' of undefined
                                      ham.0 2018-06-26 10:48:37.936 error uncaught exception: Cannot read property 'indexOf' of undefined</anonymous> `
                                      Nodejs 6 ist installiert
                                      Woran kann das liegen?
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        #106
                                        Zeig Mal deine config
                                        • R Offline
                                          rudiraz
                                          #107
                                          Plugin erstmal nur zum Test drin:
