  4. {Gelöst] Fehler in iobroker Status Anzeige
25 Beiträge 12 Kommentatoren 4.0k Aufrufe
  • ElzersharkE Offline
    ElzersharkE Offline
    Elzershark
    Wenn ich bei Putty "iobroker status" Eingebe , wird das angezeigt:
    Hab ich grade durch Zufall gesehen.
    Nach Neustart das selbe (iobroker u. Raspy neugestartet)
    iobroker läuft aber normal. (Denke ich…Im Log wird nichts angezeigt)
    Mehr komm ich nicht dazu. Muss los...
    Status:
    Admin: 3.4.2
    Rest der Adapter up do Date.
    npm = 3.10.10.
    node = 6.14.2.
    root@Elzershark:/opt/iobroker# iobroker status
    iobroker is running
     Ready check failed: Connection forcefully ended and command aborted. It might have been processed.
     AbortError: Ready check failed: Connection forcefully ended and command aborted. It might have been processed.
        at RedisClient.flush_and_error (/opt/iobroker/node_modules/redis/index.js:362:23)
        at RedisClient.end (/opt/iobroker/node_modules/redis/lib/extendedApi.js:52:14)
        at StateRedis.destroy (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:272:20)
        at processExit (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2820:44)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:312:25
        at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3124:70)
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemClient.js:120:68)
        at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
        at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
        at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:332:8                     )
    ]</anonymous>
    https://www.youtube.com/c/Elzershark
    https://t.me/joinchat/BD87n3xMU0QzYmUy
    https://www.facebook.com/elzershark
    • wendy2702W Offline
      wendy2702W Offline
      Gerade mal an 3 Installationen getestet:
      pi@pi-iobroker:~$ iobroker status
      iobroker is running
      pi@pi-iobroker:~$
      pi@iobroker-garage-gross:~$ iobroker status
      iobroker is running
      pi@pi_piVCCU:~$ iobroker status
      iobroker is running
      pi@pi_piVCCU:~$
      Würde mal vermuten das Problem liegt an deiner Installation.
      • arteckA Offline
        arteckA Offline
        arteck
        check mal redis
        • BluefoxB Offline
          BluefoxB Offline
          Fixed auf github
            ElzersharkE Offline
            Elzershark
            Ich denke mal, Multihost heißt, mehrere "ioBroker" laufen nebeneinander oder?
            Ich hab 1 Raspy + 1 ioBroker.
            Werd mal weiter gucken…
            Laufen tut ioBroker ganz normal. Zeigt keinerlei Fehler an.
            hm...
            root@Elzershark:/opt/iobroker# ls -la
            insgesamt 68
            drwxrwxrwx   6 root root  4096 Mai  7 12:16 .
            drwxr-xr-x   4 root root  4096 Apr 18 20:30 ..
            drwxrwxrwx   2 root root  4096 Nov 22 17:35 etc
            -rwxrwxrwx   1 root root   297 Nov 22 17:48 install.sh
            -rwxrwxrwx   1 root root    67 Nov 22 17:48 iobroker
            drwxrwxrwx   6 root root  4096 Apr  4 02:31 iobroker-data
            -rwxrwxrwx   1 root root    92 Apr 13 11:43 killall.sh
            drwxrwxrwx   2 root root  4096 Mai  8 18:57 log
            drwxrwxrwx 678 root root 28672 Mai  7 12:16 node_modules
            -rwxrwxrwx   1 root root   765 Mai  7 12:16 package.json
            -rwxrwxrwx   1 root root   709 Apr 13 11:43 reinstall.sh
            root@Elzershark:/opt/iobroker# iobroker multihost disable
            Nothing changed.
            Miltihost:      disabled
            Authentication: enabled
            Objects:        file on 127.0.0.1
            States:         redis on 127.0.0.1
            • HomoranH Offline
              HomoranH Offline
              @Elzershark:
              Ich denke mal, Multihost heißt, mehrere "ioBroker" laufen nebeneinander oder? `
              Worauf beziehst du diese Aussage?
              Ich finde bisher in dem Threads keinen Bezug darauf.
              Artecks und Bluefox's Hinweise hast du aber gelesen?
                ElzersharkE Offline
                Elzershark
                Erics und Bluefox's Hinweise hast du aber gelesen?
                Da ich nichts mit diesen Aussagen anfangen konnte, habe ich nach den Fehler in Github gesucht. Es ist ja kein Link bei um was es sich handelt. Dort habe ich nur Sachen gefunden die was mit Multihost zu tun haben. (Wenn man nach redis guckt. Was immer auch redis ist… Bei Redis steht das man die ip anpassen muss. Ich denke, das ich sie nicht anpassen muss, da ich nur 1 Host habe und in der Config 127.0.0.1 drin steht. Habe aber es aber trotzdem auch mit 0.0.0.0 versucht, aber das bringt nichts.
                Bei Fixed hab ich keine Ahnung wo man da suchen soll nach diesem Fehler. Es gibt etliche Eintragungen..
                Ich bin so vorgegangen.. Erst mal geguckt nach "redis" das verweißt sofort da hin = http://www.iobroker.net/docu/?page_id=3 ... _mit_redis
                Bei issues und fixes finde ich nur immer so ungefähr die selben Sachen.
                • HomoranH Offline
                  HomoranH Offline
                  Bitte keine unnötigen Fullquotes.
                  Bluefox hat einen Fehler im Code beseitigt. Um das Testen zu können musst du den Adapter von GitHub installieren.
                  Arteck hatte auf Redis hingewiesen. Das ist eine Datenbank in der die States gespeichert werden können. Dies ist in nahezu allen Images installiert und eingestellt.
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    @Elzershark:
                    Da ich nichts mit diesen Aussagen anfangen konnte, habe ich nach den Fehler in Github gesucht. `
                    da Du den neuen Admin in der 3er-Version hast, gehe ich davon aus, das Du in ioBroker von Stable- auf Latest-Repository umgestellt hast. Und damit testest Du Adapter, bevor sie endgültig für alle freigegeben werden (eben ins Stable-Repository). Dann dürfte „Fixed auf Github“ eigentlich nichts unbekanntes sein. :-)
                    Installiere den Adapter mal über den Admin von Github.
                    Dann bekommst Du die gefixte Version.
                    Weitere Infos hier in der Doku (http://www.iobroker.net/docu/?page_id=5379&lang=de#Die_Titelzeile), Absatz 3.
                    Die Screenshots passen zwar nicht so ganz, aber die Icons sind die gleichen und die restliche Erklärung passt auch.
                    Gruß,
                    Eric
                    Von unterwegs getippert
                      ElzersharkE Offline
                      Elzershark
                      Ist auch egal. Ich hab einfach diese "redis" deinstalliert und fertig :D
                      pi@Elzershark:~ $ sudo iobroker status
                      iobroker is running
                      pi@Elzershark:~ $
                      • HomoranH Offline
                        HomoranH Offline
                        Danach aber hoffentlich die Konfiguration zur Speicherung der States auch wieder umgestellt.
                          ElzersharkE Offline
                          Elzershark
                          @Homoran:
                          Rainer `
                          Auch damit kann ich nichts Anfangen. Ich installiere einfach immer nur die Adapter wenn sie neu kommen.
                          Warum da was mit diesem redis war, keine Ahnung. Im Moment wird der Fehler nicht mehr angezeigt und alles läuft wie immer..
                          Was ich da machen muss mit States.. k.a… hab ja nichts geändert.. denke ich.. ;)
                          • HomoranH Offline
                            HomoranH Offline
                            Nochmals:
                            Keine Fullquotes vom Post vorher!
                            Hast du jetzt Redis deinstalliert?
                            Und die iobroker Konfiguration nicht geändert?
                              ElzersharkE Offline
                              Elzershark
                              Nein, nichts geändert. Habe nur redis deinstalliert
                              sudo apt-get purge --auto-remove redis-server
                              Raspi neugestartet und weg war der fehler
                              Ehrlich gesagt wüsste ich auch nicht was ich ändern soll im admin adapter. Ist da eine besondere Einstellung?
                              Dachte hab was mit Admin Adapter gelesen… Welche Einstellung meinst Du?
                              • HomoranH Offline
                                HomoranH Offline
                                Ich zitiere dich Mal aus einem anderen Thread
                                @Elzershark:
                                Da kann ich dich beruhigen. Von ioBroker hab ich sehr viel Ahnung und Wissen. `
                                von sudo iobroker setup custom hast du daher sicher schon etwas gehört.
                                  ElzersharkE Offline
                                  Elzershark
                                  Doch. Reichlich gelesen wo man sudo iobroker setup custom anwendet. Wie ich schon geschrieben habe, hab ich kein Multihost system
                                    ElzersharkE Offline
                                    Elzershark
                                    Ich glaube, wir beenden hier das Thema. Ist für mich ja gelöst. thx… sozusagen..
                                    • BreisgauerB Offline
                                      BreisgauerB Offline
                                      Breisgauer
                                      @Homoran:
                                      … von sudo iobroker setup custom hast du daher sicher schon etwas gehört.... `
                                      In https://github.com/ioBroker/ioBroker.js-controller#using-redis-as-states-db ist beschrieben was mit/ohne installiertem REDIS für ioBroker konfiguriert werden muss.
                                      Wird REDIS deinstalliert oder deaktiviert, verschwindet zwar die im ersten Post genannte Fehlermeldung, der Fehler im Zusammenspiel mit REDIS ist jedoch nicht beseitigt. Ich kann den Fehler noch auf meinem Testsystem reproduzieren: js-controller 1.4.2, admin 3.4.7
                                      ` > iouser@ioBroker-VM:~$ sudo iobroker status
                                      iobroker is running
                                      at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:138:10)
                                      at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:335:8)</anonymous> `
                                      Auffällig ist, dass ich zuvor ein restore von meinem produktiven System gemacht hatte. Auf beiden Systemen ist REDIS installiert und in ioBroker aktiviert.
                                      Produktiv: iobroker in Docker; latest stable versions for adapters. ETS 5 (aktuelle Version)
                                      • Alex1808A Offline
                                        Alex1808A Offline
                                        Alex1808
                                        Bei mir spukt "iobroker status" genau das Gleiche Zeilen wie bei TS aus..
                                        root@iobroker2:/opt/iobroker# iobroker status
                                        iobroker is running
                                        at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                        at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:332:8)</anonymous>
                                        Redis ist installiert und am laufen.. (Redis server v=3.2.6)
                                        Admin 3.4.7
                                        Host 1.4.2
                                        Node v8.11.3
                                        NPM v6.1.0
                                          martinschm
                                          Bei mir leider auch das gleiche. Dazu ist der Admin via Browser nicht erreichbar :-(
                                          ! AbortError: Ready check failed: Connection forcefully ended and command aborted. It might have been processed.
                                          ! at RedisClient.flush_and_error (/opt/iobroker/node_modules/redis/index.js:362:23)
                                          ! at RedisClient.end (/opt/iobroker/node_modules/redis/lib/extendedApi.js:52:14)
                                          ! at StateRedis.destroy (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:275:24)
                                          ! at processExit (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2854:44)
                                          ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:314:25
                                          ! at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3157:70)
                                          ! at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemClient.js:120:68)
                                          ! at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                          ! at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:138:10)
                                          ! at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:335:8)</anonymous>
                                          Das komische ist, das es gestern noch ging. Hab mir über das latest Repo den Alexa2 Adapter installiert und dann wieder auf stable umgestellt. Anschließend mit ein paar Blockly Skripten experimentiert.
