  4. Gelöst - BLE-Adapter startet nicht
24 Beiträge 5 Kommentatoren 6.4k Aufrufe
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    Hast du einen Log der Installation? Meine Glaskugel ist leider kaputt
    • I Offline
      I Offline
      Ingo
      Guten Morgen,
      hier das Log der Installation, ich hoffe, ich habe es richtig aus dem Konsolenfenster herausbekommen.
      root@Brix:/opt/iobroker# sudo npm i iobroker.ble --production --unsafe-perm
      npm WARN addRemoteGit Error: not found: git
      npm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
      npm WARN addRemoteGit  git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
      npm WARN addRemoteGit  git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
      npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
      npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
      > mdns@2.4.0 install /opt/iobroker/node_modules/mdns
      > node-gyp rebuild
      gyp ERR! build error
      gyp ERR! stack Error: not found: make
      gyp ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:123:15)
      gyp ERR! System Linux 4.9.0-6-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/mdns
      gyp ERR! node -v v6.14.2
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! not ok
      > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
      > node-gyp rebuild
      gyp ERR! cwd /opt/iobroker/node_modules/ursa
      gyp ERR! not ok
      > usb@1.3.1 install /opt/iobroker/node_modules/usb
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.3.1/usb_bindings-v1.3.1-node-v48-linux-x64.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.14.2 (node-v48 ABI) (falling back to source compile with node-gyp)
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
      gyp ERR! cwd /opt/iobroker/node_modules/usb
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
      node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      node-pre-gyp ERR! System Linux 4.9.0-6-amd64
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v6.14.2
      node-pre-gyp ERR! node-pre-gyp -v v0.6.36
      node-pre-gyp ERR! not ok
      > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/bluetooth-hci-socket
      > node-gyp rebuild
      gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
      gyp ERR! not ok
      iobroker.inst@1.0.8 /opt/iobroker
      ├── awty@0.1.0  extraneous
      ├── chip.avr.avr109@1.1.1  extraneous
      ├── iobroker.ble@0.5.2
      └── stk500-v2@1.0.2  extraneous
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/avrgirl-arduino/node_modules/stk500):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules/ursa):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: `node-pre-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/bluetooth-hci-socket):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
      root@Brix:/opt/iobroker#</anonymous>
      mit solchen Sachen bin ich total überfordert. Möchte mit meinem Halbwissen natürlich auch nicht meine Installation zerschießen.
      Danke und Grüße Ingo
      Brix 3150, Debian, IoBroker
      RPi3 Raspberrymatic, Arduino Mega mit RF-Link 433 MHz, Echo Dot,
      RPi3 Magic Mirror mit View-Wechsel
      Xiaomi Gateway mit div. Sensoren
      • wendy2702W Online
        wendy2702W Online
        Hi Ingo,
        dir fehlt scheinbar das Paket "Git" –>````
        bzw. er kann es nicht finden.
        Muss mal dumm fragen: Ist das eine Windows oder Linux installation?
        Wenn Linux kannst du mal versuchen das zu installieren:
        sudo apt-get install git
          AlCalzoneA Offline
          AlCalzone
          make fehlt auch, ich würde sagen, du solltest die build-essentials installieren:
          sudo apt-get install -y build-essential
          • I Offline
            I Offline
            Ingo
            Hallo, es ist zum verzweifeln.
            Beide Tipps haben nix gebracht.
            Der Host ist ein Gigabyte Brix 3150 mit Debian 9.3.0 amd64-netinst.
            node.js 6.14.2
            npm 3.10.10
            Eigentlich geht es mir nur um 2 Xiaomi-Sensoren Temp / Hum (die runden mit Display), diese kommen über den Mihome-Adapter nicht mit rüber.
            Ich hatte diese schon mal eingebunden über ein Script hier aus dem Forum, bis ich vor ein paar Tagen feststellen mußte, letzte Aktualisierung
            war vor 2 Wochen.
            Also den ble-Adapter auf dem Test-Raspi nochmal gestartet - wunderbar. Und dann ging das Drama mit dem Brix los…....
            Danke und Grüße
            Ingo
            • wendy2702W Online
              wendy2702W Online
              @Ingo:
              Beide Tipps haben nix gebracht. `
              Bedeutet genau was ?
              GIT und/oder Make konnte nicht installiert werden?
              BLE konnte nicht installiert werden?
              Gab es fehler bei der Installation von GIT/Make bzw. Build-Essentials ?
              Logs?
              Hast du bisher immer alles als "root" installiert oder auch mal einen anderen User verwendet?
              • I Offline
                I Offline
                Ingo
                GIT / Make / Build-Essentials - Installationen liefen fehlerfrei durch.
                Immer als root, im Hauptverzeichnis, oder muß ich vorher in das /opt/ioBroker - Verzeichnis wechseln ????
                Auch der BLE-Adapter wurde fehlerfrei installiert, nur bleibt er gelb, zusammen mit der Fehlermeldung
                Cannot find module 'bluetooth-hci-socket'
                  AlCalzoneA Offline
                  AlCalzone
                  @Ingo:
                  Cannot find module 'bluetooth-hci-socket' `
                  Dann musst du das Modul mal suchen und manuell neu installieren.
                  Laut deinem Log müsste es in /opt/iobroker/node_modules/bluetooth-hci-socket liegen. Darin
                  npm install --production
                  ausführen.
                  • wendy2702W Online
                    wendy2702W Online
                    Linux ist aktuell?
                    apt update && apt upgrade
                    Dann hat er das Modul, aus welchem Grund auch immer, bei dir nicht mit installiert.
                    npm install bluetooth-hci-socket
                    Würde ich jetzt mal machen.
                    Edit: war zu langsam ;)
                    • I Offline
                      I Offline
                      Ingo
                      Alles grün !!!!
                      Danke für eure Hilfe.
                      5 gelbe Daumen an euch.
                      Grüße Ingo
                      • wendy2702W Online
                        wendy2702W Online
                        Schön…
                        Was genau hat jetzt zum Erfolg geführt?
                        • I Offline
                          I Offline
                          Ingo
                          ich muß zwischendurch immer mal was am neuen Gewächshaus meiner besseren Hälfte bauen, sonst gibt's heute Abend Mecker……
                          habe
                          ausgeführt, ist aber kaum was nachinstalliert worden, ging ganz fix.
                          danach ging es.
                          Adapter sofort grün, kurz danach waren die Werte von den beiden Xiaomi-Sensoren da.
                          An Werten battery, humidity, rssi und temperature - perfekt.
                          nun schnell was essen, dann wieder ans Gewächshaus.
                          Danke nochmals für eure geduldige Hilfe
                          Grüße Ingo
                            swordfisch
                            Hi habe auch das Problem das ich den BLE Adapter nicht auf grün bekomme
                            sudo npm i iobroker.ble –production --unsafe-perm
                            habe ich eben ausgeführt
                            > node-gyp rebuild
                            make: Verzeichnis â/opt/iobroker/node_modules/bluetooth-hci-socket/buildâ wird betreten
                              CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
                            ../src/BluetoothHciSocket.cpp: In member function âvoid BluetoothHciSocket::poll()â:
                            ../src/BluetoothHciSocket.cpp:251:95: warning: âv8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)â is deprecated [-Wdeprecated-declarations]
                                 Nan::MakeCallback(Nan::New<object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                            In file included from ../src/BluetoothHciSocket.cpp:8:0:
                            ../../nan/nan.h:950:46: note: declared here
                               NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
                            ../src/BluetoothHciSocket.cpp: In member function âvoid BluetoothHciSocket::emitErrnoError()â:
                            ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to âv8::Function::NewInstance(int, v8::Local <v8::value>[1])â
                               Local <value>error = errorConstructor->NewInstance(1, constructorArgs);
                            In file included from /root/.node-gyp/10.4.0/include/node/node.h:63:0,
                                             from /root/.node-gyp/10.4.0/include/node/node_buffer.h:25,
                                             from ../src/BluetoothHciSocket.cpp:7:
                            /root/.node-gyp/10.4.0/include/node/v8.h:3905:44: note: candidate: v8::MaybeLocal <v8::object>v8::Function::NewInstance(v8::Local<v8::context>, int, v8::Local<v8::value>*) const
                               V8_WARN_UNUSED_RESULT MaybeLocal <object>NewInstance(
                            /root/.node-gyp/10.4.0/include/node/v8.h:3905:44: note:   candidate expects 3 arguments, 2 provided
                            /root/.node-gyp/10.4.0/include/node/v8.h:3908:44: note: candidate: v8::MaybeLocal <v8::object>v8::Function::NewInstance(v8::Local<v8::context>) const
                            /root/.node-gyp/10.4.0/include/node/v8.h:3908:44: note:   candidate expects 1 argument, 2 provided
                            ../src/BluetoothHciSocket.cpp:282:93: warning: âv8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)â is deprecated [-Wdeprecated-declarations]
                            binding.target.mk:93: die Regel für Ziel âRelease/obj.target/binding/src/BluetoothHciSocket.oâ scheiterte
                            make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
                            make: Verzeichnis â/opt/iobroker/node_modules/bluetooth-hci-socket/buildâ wird verlassen
                            gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:258:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
                            gyp ERR! System Linux 4.14.50-v7+
                            gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp ERR! node -v v10.4.0
                            gyp ERR! node-gyp -v v3.6.2
                            gyp ERR! not ok
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            + iobroker.ble@0.5.2
                            updated 1 package and audited 2751 packages in 29.352s
                            found 84 vulnerabilities (46 low, 27 moderate, 11 high)
                              run `npm audit fix` to fix them, or `npm audit` for details</v8::value></object></v8::value></v8::string></v8::object></v8::value></object></v8::context></v8::object></object></v8::value></v8::context></v8::object></value></v8::value></v8::value></object></v8::value></v8::string></v8::object></v8::value>
                              AlCalzoneA Offline
                              AlCalzone
                              Das scheint eine Inkompatibilität zwischen dem bluetooth-hci-socket und Node 10 zu sein. Am besten mal in deren Repo ein Issue aufmachen.
                              Edit: Scheint bekannt zu sein: https://github.com/noble/node-bluetooth … /issues/84
                              • C Offline
                                chka
                                so richtig schlau werde ich aus der Lösung die dort geschrieben ist aber leider nicht
                                INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
                                Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
                                RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @chka:
                                  so richtig schlau werde ich aus der Lösung die dort geschrieben ist aber leider nicht `
                                  Die Quintessenz ist: Warten, bis die Macher von bluetooth-hci-socket das Problem behoben und eine neue Version veröffentlicht haben, oder zurück auf NodeJS 8.
                                  • C Offline
                                    chka
                                    ok danke
                                    node 8 lief bei mir nicht dann muss ich warten.
                                    • C Offline
                                      chka
                                      habe es mit dem downgread auf die 8.11.3 genhaft, ble läuft
