  4. Downgrade node, Nodejs, npm
32 Beiträge 8 Kommentatoren 13.7k Aufrufe
  • U Offline
    U Offline
    UweS
    @paul53:
    @UweS:
    NODECMD=/usr/local/bin/node `
    Dann startet ioBroker beim Systemstart mit der Version /usr/local/bin/node. Ist das die Version 9.8.x ? Was ergibt ?
    /usr/local/bin/node -v
    /usr/bin/node -v
    /usr/bin/nodejs -v
    echo $PATH
    Hi
    /usr/local/bin/node -v -> 6.12.3
    /usr/bin/node -v -> 6.12.3
    /usr/bin/nodejs -v -> 6.12.3
    iobroker gibt aber nach einem reboot wieder den Fehler mit node.js 9.4.0 aus
    bei find -name node kommt folgendes
    ! ./home/uwe/.nvm/versions/node
    ! ./home/uwe/.nvm/versions/node/v6.12.3/include/node
    ! ./home/uwe/.nvm/versions/node/v6.12.3/bin/node
    ! ./home/uwe/.nvm/versions/node/v6.12.3/share/doc/node
    ! ./home/uwe/.nvm/versions/node/v8.9.4/include/node
    ! ./home/uwe/.nvm/versions/node/v8.9.4/bin/node
    ! ./home/uwe/.nvm/versions/node/v8.9.4/share/doc/node
    ! ./home/uwe/.node-gyp/6.12.3/include/node
    ! ./proc/irq/0/node
    ! ./proc/irq/1/node
    ! ./proc/irq/2/node
    ! ./proc/irq/3/node
    ! ./proc/irq/4/node
    ! ./proc/irq/5/node
    ! ./proc/irq/6/node
    ! ./proc/irq/7/node
    ! ./proc/irq/8/node
    ! ./proc/irq/9/node
    ! ./proc/irq/10/node
    ! ./proc/irq/11/node
    ! ./proc/irq/12/node
    ! ./proc/irq/13/node
    ! ./proc/irq/14/node
    ! ./proc/irq/15/node
    ! ./proc/irq/18/node
    ! ./proc/irq/23/node
    ! ./proc/irq/40/node
    ! ./proc/irq/41/node
    ! ./proc/irq/42/node
    ! ./proc/irq/43/node
    ! ./proc/irq/44/node
    ! ./proc/irq/45/node
    ! ./proc/irq/46/node
    ! ./usr/include/node
    ! ./usr/bin/node
    ! ./usr/share/doc/node
    ! ./usr/local/n/versions/node
    ! ./usr/local/n/versions/node/9.4.0/include/node
    ! ./usr/local/n/versions/node/9.4.0/bin/node
    ! ./usr/local/n/versions/node/9.4.0/share/doc/node
    ! ./usr/local/include/node
    ! ./usr/local/bin/node
    ! ./usr/local/share/doc/node
    ! ./opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    ! ./opt/iobroker/node_modules/@types/node
    ! ./opt/iobroker/node_modules/base64url/typings/globals/node
    ! ./opt/iobroker/node_modules/iobroker.vis/node_modules/base64url/typings/globals/node
    ! ./root/.npm/@types/node
    ! ./root/.nvm/versions/node
    ! ./root/.nvm/versions/node/v6.12.2/include/node
    ! ./root/.nvm/versions/node/v6.12.2/bin/node
    ! ./root/.nvm/versions/node/v6.12.2/share/doc/node
    ! ./root/.nvm/versions/node/v6.12.3/include/node
    ! ./root/.nvm/versions/node/v6.12.3/bin/node
    ! ./root/.nvm/versions/node/v6.12.3/share/doc/node
    ! ./root/.node-gyp/9.4.0/include/node
    ! ./root/.node-gyp/6.12.2/include/node
    ! ./root/.node-gyp/6.12.3/include/node
      knopers1
      mach mal so:
      sudo cat /etc/init.d/iobroker.sh
      ändere
      in
      NODECMD=/usr/bin/node
      danach noch ein restart und berichten.
      • paul53P Offline
        Du verwendest n. Dann kannst Du damit auch die störende Version löschen:
        n rm 9.4.0
        n use 6.12.3
        • paul53P Offline
          @UweS:
          Ich verwende dan nvm use 6.12.2 und restarte iobroker `
          Das ist dann sicherlich das Ergebnis:
          @UweS:
          /usr/bin/nodejs -v -> 6.12.3 `
          • wendy2702W Online
            wendy2702W Online
            @UweS:
            -rwxr-xr-x 1 root root 24209080 Jän 2 20:26 /usr/bin/node
            lrwxrwxrwx 1 root root 24 Jän 25 00:21 /usr/bin/nodejs -> /etc/alternatives/nodejs
            -rwxr-xr-x 1 root staff 33163507 Jän 25 00:09 /usr/local/bin/node `
            Hat nix mit Node zu tun aber was ist das für eine Datums ausgabe?
            Jän
            • U Offline
              U Offline
              UweS
              Hi, hat nicht funktioniert der Fehler ist noch immer da.
              lg
              • paul53P Offline
                Anscheinend hast Du mal nvm und mal n verwendet. Die Version 9.4.0 ist offenbar mit n installiert worden. Dann versuche es mal so:
                n 6.13.1
                n use 6.13.1
                n rm 9.4.0
                node -v
                  @wendy2702:
                  CODE: ALLES AUSWÄHLEN
                  Jän `
                  Das müsste der Alpenjanuar (=Jänner) sein :-)
                  • U Offline
                    U Offline
                    UweS
                    hi
                    bei node -v kommt v 6.12.2
                    bei nodejs -v kommt v 6.12.3
                    im iobroker log steht aber
                    starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v6.13.1
                    mit warning:
                    radar.1
                    2018-03-13 19:35:30.998
                    warn
                    Noble not available, Error: Error: Module version mismatch. Expected 48, got 59. at Error (native) at Object.Module._extensions..node (module.js:604:18) at Module.load (module.js:494:32)
                    bin schon etwas verwirrt.
                    • wendy2702W Online
                      wendy2702W Online
                      @Homoran:
                      @wendy2702:
                      Jän `
                      Rainer `
                      Wusste nicht das man das Einstellen kann.
                        Vielleicht mit den Spracheinstellungen DE-AT
                        • paul53P Offline
                          @UweS:
                          bin schon etwas verwirrt. `
                          Das wäre ich auch. n und nvm scheinen sich in die Quere zu kommen ?
                          Vielleicht hilft es, die NVM-Version von node gleich zu ziehen ?
                          nvm install 6.13.1
                          nvm use 6.13.1
                          node -v
                          • U Offline
                            U Offline
                            UweS
                            Hi
                            schaur schon etwas besser aus
                            bei nodejs -v kommt noch immer 6.12.3
                            und jetzt noch folgender Fehler von 2 Adaptern
                            ! radar.1
                            ! 2018-03-13 20:19:06.064
                            ! warn
                            ! Noble not available, Error: Error: Module version mismatch. Expected 48, got 59. at Error (native) at Object.Module._extensions..node (module.js:604:18) at Module.load (module.js:494:32)
                            ! radar.1
                            ! 2018-03-13 20:19:06.063
                            ! info
                            ! starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v6.13.1
                            ! host.fhem
                            ! 2018-03-13 20:19:05.492
                            ! info
                            ! instance system.adapter.radar.1 started with pid 1323
                            ! ble.0
                            ! 2018-03-13 20:19:01.957
                            ! error
                            ! unhandled promise rejection: Error: Module version mismatch. Expected 48, got 59.
                            Ich weiß leider nicht mehr wie ich das in den adaptern updaten kann.
                            LG
                            Uwe
                            • wendy2702W Online
                              wendy2702W Online
                              Was es alles gibt :P
                              • paul53P Offline
                                Für das Problem mit nicht passender node-Version soll es reinstall geben.
                                cd /opt/iobroker
                                sudo ./reinstall.sh
                                iobroker start
                                Es kann einige Zeit dauern, bis reinstall fertig ist.
                                • U Offline
                                  U Offline
                                  UweS
                                  Hi
                                  Da bekomme ich folgenden Fehler:
                                  sudo: unable to execute ./reinstall.sh: No such file or directory
                                  reinstall.sh ist aber im verzeichniss
                                  LG
                                    knopers1
                                    Datei bitte mit filezilla o.ä herunterladen, mit notepad++ bearbeiten und den Typ des Zeilenumbruchs von Windows in Unix ändern:
                                    Dateittribut auf 755 setzen, dann geht es mit dem Script!
                                    • U Offline
                                      U Offline
                                      UweS
                                      Hi
                                      gemacht kommt aber der gleiche Fehler.
                                      LG
                                        knopers1
                                        Hast Du auf Unix gestellt und dateiattributte 755 geändert?
                                        Versuche ein sudo vor dem````
                                        ./reinstall.sh
                                        [1526__593_3.gif](/assets/uploads/files/1526__593_3.gif)
                                        • U Offline
                                          U Offline
                                          UweS
                                          hi
                                          das mit dem sudo wars, jetzt läufts mal.
                                          danke
