Nodejs-Update funktioniert nicht
Hast du denn den Befehl jetzt nochmal aufgerufen?
@Thomas-Braun
Welchen?
nodejs-update?
jaAnbei nochmals alles, gerade eben ausgeführt:
pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ curl https://github.com -o /dev/null % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 524k 0 524k 0 0 100k 0 --:--:-- 0:00:05 --:--:-- 119k pi@raspberrypi:~ $ cat /etc/resolv.conf # Generated by resolvconf nameserver 192.168.1.1 pi@raspberrypi:~ $ curl https://github.com -o /dev/null % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 524k 0 524k 0 0 100k 0 --:--:-- 0:00:05 --:--:-- 108k pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ -
@Thomas-Braun
Welchen?
nodejs-update?
pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $ curl https://github.com -o /dev/null % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 524k 0 524k 0 0 100k 0 --:--:-- 0:00:05 --:--:-- 119k pi@raspberrypi:~ $ cat /etc/resolv.conf # Generated by resolvconf nameserver 192.168.1.1 pi@raspberrypi:~ $ curl https://github.com -o /dev/null % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 524k 0 524k 0 0 100k 0 --:--:-- 0:00:05 --:--:-- 108k pi@raspberrypi:~ $ iobroker nodejs-update [ERROR] No internet connection. Cannot fetch Node.js version. [INFO] Cleaning up temporary files... pi@raspberrypi:~ $Dload 100k ist auch zu wenig. Keine Ahnung was dein Netz da treibt.
@Thomas-Braun
Speedtest schaut recht gut aus
Kein Plan was ich da noch prüfen könnte
@Thomas-Braun
pi@raspberrypi:~ $ curl -sL --connect-timeout 5 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" DNS: 0.000000s TCP: 0.000000s TLS: 0.000000s Gesamt: 5.018451s HTTP: 000 Exit-Code: 28 -
pi@raspberrypi:~ $ curl -sL --connect-timeout 5 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" DNS: 0.000000s TCP: 0.000000s TLS: 0.000000s Gesamt: 5.018451s HTTP: 000 Exit-Code: 28nochmal mit längerem Timeout
curl -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" -
Mal ne einfache Frage: was ist das für eine HW und vor allem wie angebunden an dein Netzwerk
@wendy2702
ein Pi4 mit 8GB - via LANpi@raspberrypi:~ $ curl -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" DNS: 5.013556s TCP: 5.032272s TLS: 5.120822s Gesamt: 5.228453s HTTP: 200 Exit-Code: 0 -
@wendy2702
@wendy2702
ein Pi4 mit 8GB - via LANpi@raspberrypi:~ $ curl -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" DNS: 5.013556s TCP: 5.032272s TLS: 5.120822s Gesamt: 5.228453s HTTP: 200 Exit-Code: 0@igor123
Könnte IPv6 vs. IPv4 sein. Erzwing mal beides:curl -4 -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?"curl -6 -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?"ip -6 addr show; ip -6 route showtime getent ahosts github.comiw dev wlan0 link 2>/dev/null || iwconfig 2>/dev/nulltimeout 10 bash -c 'cat < /dev/null > /dev/tcp/140.82.121.4/443' && echo "TCP OK" || echo "TCP TIMEOUT"Gut, ist wohl DNS-Timing. Dann mal damit schauen:
Wie schnell ist der Router-DNS wirklich? Mehrfach messen:
time getent ahosts github.comRouter gegen öffentlichen DNS vergleichen:
time dig github.com @192.168.1.1 time dig github.com @1.1.1.1 -
@Marc-Berg
Ich hab da keinen Zugang vom Provider erhalten
aber ich hab wohl das Thema gefunden...im "sudo nano /etc/network/interfaces" war kein DNS eingetragen
spannend!
Hab nun 192.168.1.1 eingetragen und es flutscht:pi@raspberrypi:~ $ curl -sL --connect-timeout 15 -o /dev/null -w 'DNS: %{time_namelookup}s TCP: %{time_connect}s TLS: %{time_appconnect}s Gesamt: %{time_total}s HTTP: %{http_code}\n' https://github.com; echo "Exit-Code: $?" DNS: 0.011343s TCP: 0.029940s TLS: 0.079021s Gesamt: 0.188663s HTTP: 200 Exit-Code: 0Aber:
Ich hab gerade bemerkt dass ich noch 32bit hab - und Node.js 22.15.0 scheint die zuletzt unterstützte zu sein
verdammt
Ich muss wohl alles auf 64bit lite migrieren
@Marc-Berg
spannend!
verdammt
@Thomas-Braun
Gibt es da irgendein trick wie man alles "einfach so" auf 64 bit migrieren kann?
Ich hab da auch piVCCU drauf und hab da etwas schiss das ich mir da nicht etwas zerschisse -
@Thomas-Braun
Ich hab da auch piVCCU drauf und hab da etwas schiss das ich mir da nicht etwas zerschisse@igor123
Nix migrieren. Backups ziehen, aktuelles RaspberryOS komplett neu installieren, Backup einspielen. Bei 32 -> 64Bit funktioniert kein In-Place-Upgrade.Damit wird sich auch dein DNS-Problem erledigen, das funktioniert nämlich mittlerweile anders.
@igor123
@Thomas-Braun
Alles klar, dachte da gibt es irgendwas einfaches..
das DNS-Thema ist nun erledigt. zumindest flutscht esDa gibt es wohl noch eine Möglichkeit für ein neueres Nodejs (erstmal bis ich mir die Zeit nehme auf 64 Bit umzusteigen), nur eben manuell
https://nodejs.org/en/blog/release/v22.23.0
ARMv7 32-bit Binary: https://nodejs.org/dist/v22.23.0/node-v22.23.0-linux-armv7l.tar.xzIch bin mir nicht sicher wie gescheit es ist es auszuprobieren..
@Thomas-Braun
@Thomas-Braun
War eher gedacht damit ich etwas "zeit gewinne" bis ich Zeit und Lust auf ein "Update-Abend" habe
@Thomas-Braun
Die Zeit kannst du nicht mehr gewinnen, du steht mit dem Setup komplett in der Sackgasse.
@Thomas-Braun ich habs mal riskiert
pi@raspberrypi:~ $ node -v v22.23.5 -
pi@raspberrypi:~ $ node -v v22.23.5Bringt dir nur nichts wirklich.
Du gewinnst keine Zeit. Der Umzug ist der ohnehin anstehende Endpunkt. Der manuelle Node-Build ist pure Zusatzarbeit mit Halbwertszeit null, inklusive Risiko, dass die ioBroker-Installation durch den manuellen Installationspfad (um die Paketverwaltung herum) aus den Fugen gerät, falls ihn ein Adapter-Update später wieder erwartet.
Dein ursprüngliches Ziel funktioniert danach immer noch nicht. Du wolltest den Node-Update-Weg ja nur gehen, weil ein Adapter eine neuere Version verlangt. Adapter, die Node 24 fordern, bleiben auch mit 22.23 gesperrt. Du schafft es also mit nodejs=22.23.5 nicht einmal bis zu dem Adapter, der das ganze ausgelöst hat.
Der Aufwand wird falsch eingeschätzt. Pi 4 neu aufsetzen, ioBroker-Skript, iob restore, piVCCU neu installieren: Das ist ein Abend mit zwei, drei Stunden, weil Backups das Risiko rausnehmen. „Keine Zeit“ heißt in Wahrheit: Der Umzug ist fällig, gerade weil du keine Zeit hat, sich um dein auslaufendes 32-Bit-System zu kümmern.
