ioBroker ohne Zugriff auf Weboberflächen Admin & Visu
Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: rpi-iobroker Icon name: computer Kernel: Linux 6.18.50+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 99 days ago (on 2026-06-18). Systemuptime and Load: 18:53:42 up 3 min, 2 users, load average: 0.89, 0.61, 0.26 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Fri 2026-09-25 18:53:42 CEST Universal time: Fri 2026-09-25 16:53:42 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input lpadmin iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 1.4G 6.2G 9.8M 717M 6.8G Swap: 2.1G 0B 2.1G Total: 10G 1.4G 8.4G Active iob-Instances: 3 7818 M total memory 1294 M used memory 1382 M active memory 337 M inactive memory 5938 M free memory 55 M buffer memory 628 M swap cache 2047 M total swap 0 M used swap 2047 M free swap *** top - Table Of Processes *** top - 18:53:42 up 3 min, 2 users, load average: 0.89, 0.61, 0.26 Tasks: 189 total, 1 running, 188 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.1 us, 2.1 sy, 0.0 ni, 93.6 id, 2.1 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7818.7 total, 5935.9 free, 1296.4 used, 684.9 buff/cache MiB Swap: 2048.0 total, 2048.0 free, 0.0 used. 6522.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 1.6G 9.0M 1.6G 1% /run /dev/sda2 ext4 117G 17G 96G 15% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/sda1 vfat 505M 67M 439M 14% /boot/firmware tmpfs tmpfs 3.9G 400K 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 782M 8.0K 782M 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Fri Sep 25 18:50:33 2026] EXT4-fs (sda2): orphan cleanup on readonly fs [Fri Sep 25 18:50:33 2026] EXT4-fs (sda2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Qu ota mode: none. [Fri Sep 25 18:50:35 2026] EXT4-fs (sda2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount- ro Files in neuralgic directories: /var: 2.5G /var/ 232M /var/cache 226M /var/cache/apt 185M /var/lib 148M /var/lib/apt/lists Archived and active journals take up 8M in the file system. /opt/iobroker/backups: 3.5G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 6.5G /opt/iobroker/iobroker-data/ 6.2G /opt/iobroker/iobroker-data/backup-objects 229M /opt/iobroker/iobroker-data/files 47M /opt/iobroker/iobroker-data/files/admin.admin 46M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets The five largest files in iobroker-data are: 373M /opt/iobroker/iobroker-data/backup-objects/2026-09-19_19-05_states.jsonl.gz 358M /opt/iobroker/iobroker-data/backup-objects/2026-09-19_17-05_states.jsonl.gz 342M /opt/iobroker/iobroker-data/backup-objects/2026-09-19_15-05_states.jsonl.gz 333M /opt/iobroker/iobroker-data/backup-objects/2026-09-19_13-05_states.jsonl.gz 323M /opt/iobroker/iobroker-data/backup-objects/2026-09-19_11-05_states.jsonl.gz USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.23.3 /usr/bin/node v22.23.3 /usr/bin/npm 10.9.9 /usr/bin/npx 10.9.9 ✓ Node.js installation is correct nodejs: Installed: 22.23.3-1nodesource1 Candidate: 22.23.3-1nodesource1 Version table: *** 22.23.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.23.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.23.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.23.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main arm64 Packages 500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: rpi-iobroker rpi-iobroker (version: 7.2.2, hostname: rpi-iobroker , alive, uptime: 200) Core adapters versions js-controller: 7.2.2 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : rpi-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : rpi-iobroker - disabled + system.adapter.backitup.0 : backitup : rpi-iobroker - enabled system.adapter.discovery.0 : discovery : rpi-iobroker - disabled system.adapter.echarts.0 : echarts : rpi-iobroker - disabled system.adapter.govee-local.0 : govee-local : rpi-iobroker - disabled system.adapter.habpanel.0 : habpanel : rpi-iobroker - disabled system.adapter.history.0 : history : rpi-iobroker - disabled system.adapter.homeconnect.0 : homeconnect : rpi-iobroker - disabled system.adapter.ical.0 : ical : rpi-iobroker - disabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: rpi-iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : rpi-iobroker - disabled system.adapter.iot.0 : iot : rpi-iobroker - disabled system.adapter.iqontrol.0 : iqontrol : rpi-iobroker - disabled system.adapter.javascript.0 : javascript : rpi-iobroker - disabled system.adapter.openknx.0 : openknx : rpi-iobroker - disabled system.adapter.proxmox.0 : proxmox : rpi-iobroker - disabled, port: 8006 system.adapter.pushover.0 : pushover : rpi-iobroker - disabled system.adapter.rpi2.0 : rpi2 : rpi-iobroker - disabled system.adapter.shelly.0 : shelly : rpi-iobroker - disabled, port: 1882, bind: 0.0.0.0 system.adapter.squeezeboxrpc.0 : squeezeboxrpc : rpi-iobroker - disabled, port: 9000 system.adapter.trashschedule.1 : trashschedule : rpi-iobroker - disabled system.adapter.unifi-network.0 : unifi-network : rpi-iobroker - disabled, port: 8443 system.adapter.unifi-protect.0 : unifi-protect : rpi-iobroker - disabled system.adapter.unifi.0 : unifi : rpi-iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : rpi-iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : rpi-iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : rpi-iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : rpi-iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : rpi-iobroker - disabled system.adapter.vis-material.0 : vis-material : rpi-iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : rpi-iobroker - disabled system.adapter.vis-players.0 : vis-players : rpi-iobroker - disabled system.adapter.vis-plumb.0 : vis-plumb : rpi-iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : rpi-iobroker - disabled system.adapter.vis.0 : vis : rpi-iobroker - disabled system.adapter.web.0 : web : rpi-iobroker - disabled, port: 8082, bind: 192.168.100.2, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : rpi-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '7.8.23' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.backitup' │ 'backitup' │ '3.3.17' │ 'none' │ │ 3 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 4 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 5 │ 'system.adapter.govee-local' │ 'govee-local' │ '0.4.7' │ 'none' │ │ 6 │ 'system.adapter.habpanel' │ 'habpanel' │ '0.5.0' │ 'none' │ │ 7 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 8 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 9 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 10 │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0' │ 'none' │ │ 11 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 12 │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1' │ 'none' │ │ 13 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 14 │ 'system.adapter.iqontrol' │ 'iqontrol' │ '3.0.0' │ 'none' │ │ 15 │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none' │ │ 16 │ 'system.adapter.knx' │ 'knx' │ '2.0.30' │ 'none' │ │ 17 │ 'system.adapter.openknx' │ 'openknx' │ '1.2.0' │ 'none' │ │ 18 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.1' │ 'none' │ │ 19 │ 'system.adapter.pushover' │ 'pushover' │ '5.0.0' │ 'none' │ │ 20 │ 'system.adapter.rpi2' │ 'rpi2' │ '3.0.2' │ 'none' │ │ 21 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 22 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 23 │ 'system.adapter.socketio' │ 'socketio' │ '7.0.8' │ 'none' │ │ 24 │ 'system.adapter.squeezeboxrpc' │ 'squeezeboxrpc' │ '1.6.4' │ 'none' │ │ 25 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 26 │ 'system.adapter.unifi' │ 'unifi' │ '0.7.0' │ 'none' │ │ 27 │ 'system.adapter.unifi-network' │ 'unifi-network' │ '1.4.0' │ 'none' │ │ 28 │ 'system.adapter.unifi-protect' │ 'unifi-protect' │ '1.0.1' │ 'none' │ │ 29 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 30 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 31 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 32 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 33 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 34 │ 'system.adapter.vis-material' │ 'vis-material' │ '0.2.0' │ 'none' │ │ 35 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 36 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 37 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 38 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 39 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 40 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 41 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.11 , installed 7.8.23 [Updatable] Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 3.3.17 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "govee-local" : 0.4.7 , installed 0.4.7 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "iqontrol" : 3.0.0 , installed 3.0.0 Adapter "javascript" : 10.1.3 , installed 9.0.18 [Updatable] Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "openknx" : 1.2.0 , installed 1.2.0 Adapter "proxmox" : 2.6.3 , installed 2.6.1 [Updatable] Adapter "pushover" : 5.0.0 , installed 5.0.0 Adapter "rpi2" : 3.0.2 , installed 3.0.2 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "squeezeboxrpc": 1.6.4 , installed 1.6.4 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "unifi-network": 1.4.0 , installed 1.4.0 Adapter "unifi-protect": 1.0.1 , installed 1.0.1 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-material" : 0.2.0 , installed 0.2.0 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 3.0.19 [Updatable] Objects and States Please stand by - This may take a while Objects: 12525 States: 11938 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://deb.debian.org/debian-security trixie-security InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Hit:5 http://archive.raspberrypi.com/debian trixie InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=615,fd=12)) udp UNCONN 0 0 0.0.0.0:46844 0.0.0.0:* users:(("avahi-daemon",pid=615,fd=14)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=588,fd=5),("systemd",pid=1,fd=177)) udp UNCONN 0 0 *:58535 *:* users:(("avahi-daemon",pid=615,fd=15)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=615,fd=13)) udp UNCONN 0 0 *:sunrpc *:* users:(("rpcbind",pid=588,fd=7),("systemd",pid=1,fd=179)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=825,fd=23)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=825,fd=29)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=588,fd=4),("systemd",pid=1,fd=176)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=837,fd=6)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.0",pid=860,fd=37)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=588,fd=6),("systemd",pid=1,fd=178)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=837,fd=7)) *** Log File - Last 25 Lines *** 2026-09-25 18:50:52.040 - info: admin.0 (860) received all objects 2026-09-25 18:50:52.440 - info: admin.0 (860) socket.io server listening on port 8081 2026-09-25 18:50:52.443 - info: admin.0 (860) http server listening on port 8081 2026-09-25 18:50:52.444 - info: admin.0 (860) Use link "http://127.0.0.1:8081" to configure. 2026-09-25 18:50:52.526 - warn: admin.0 (860) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net 2026-09-25 18:51:00.723 - info: host.rpi-iobroker instance system.adapter.backitup.0 scheduled normal terminated and will be restarted on schedule. 2026-09-25 18:51:00.724 - info: host.rpi-iobroker Restart adapter system.adapter.backitup.0 because enabled 2026-09-25 18:51:02.347 - info: host.rpi-iobroker instance system.adapter.backitup.0 in version "3.3.17" started with pid 943 2026-09-25 18:51:08.416 - error: backitup.0 (943) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,domain=WORKGROUP,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.100.10/media/Backups/ioBroker /opt/iobroker/backups mount error: Server abruptly closed the connection. This can happen if the server does not support the SMB version you are trying to use. The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0. mount error(112): Host is down Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg) 2026-09-25 18:51:44.638 - info: admin.0 (860) ==> Connected system.user.admin from ::ffff:192.168.10.246 2026-09-25 18:52:13.181 - info: host.rpi-iobroker instance system.adapter.backitup.0 scheduled normal terminated and will be restarted on schedule. 2026-09-25 18:52:13.182 - info: host.rpi-iobroker Restart adapter system.adapter.backitup.0 because enabled 2026-09-25 18:52:14.960 - info: host.rpi-iobroker instance system.adapter.backitup.0 in version "3.3.17" started with pid 1101 2026-09-25 18:53:00.672 - info: host.rpi-iobroker instance system.adapter.backitup.0 scheduled normal terminated and will be restarted on schedule. 2026-09-25 18:53:00.673 - info: host.rpi-iobroker Restart adapter system.adapter.backitup.0 because enabled 2026-09-25 18:53:02.379 - info: host.rpi-iobroker instance system.adapter.backitup.0 in version "3.3.17" started with pid 1158 2026-09-25 18:54:00.708 - info: host.rpi-iobroker instance system.adapter.backitup.0 scheduled normal terminated and will be restarted on schedule. 2026-09-25 18:54:00.708 - info: host.rpi-iobroker Restart adapter system.adapter.backitup.0 because enabled 2026-09-25 18:54:02.413 - info: host.rpi-iobroker instance system.adapter.backitup.0 in version "3.3.17" started with pid 1582============= Mark until here for C&P =============
iob diag has finished.
Aktualisieren "backitup" auf v4.0.3
Integrated token encryption
With this release, even greater attention has been paid to data security, and the values for the Dropbox access token, the Grafana API key, and the InfluxDB token have been encrypted. After the update, these tokens must be re-entered in the Backitup configuration!!
Änderungen4.0.3(stable)(a month ago)
• Fix signed FTP Certificates
• Fix Backup Timeout
• Fix lint check4.0.2
• Fix Backitup Tab
• dependencies updated4.0.1
• Fix Backitup Tab4.0.0
• Fix Translation
• small Fixes
• Integrated token encryption
• Fix Yahka Backup
• Updated GUI packages und removed linter errors
• Update Node Engine
• Migrated to Admin 8
• Redesign Backitup TabSchreit das danach?
AI API keys must be re-entered
Aktualisieren "javascript" auf v10.1.3
liegt hier evtl eine Verschlüsselung vor?
Da stimmt auch was mit deinem SMB-Server nicht:
2026-09-25 18:51:08.416 - error: backitup.0 (943) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,domain=WORKGROUP,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.100.10/media/Backups/ioBroker /opt/iobroker/backups mount error: Server abruptly closed the connection. This can happen if the server does not support the SMB version you are trying to use. The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0. mount error(112): Host is down -
Interessant ist ja nur, das er die letzen Backups immer auf die SSD des Systems geschrieben hat
Wenn dann schon jede States gefühlt 500MB hat dann wird das eng
Also erstmal wirklich ein Danke an alle Teilnehmer für die Hilfestellung hier. Ich werde am heutigen Abend noch den Umzug auf das neue NAS System durchführen und mit dem BackItUp update erstmal warten.
Am Rande einmal eine Frage an erfahrenere Nutzer von ioBroker. Hat wer von euch ioBroker schon effektiv in Betrieben eingesetzt? Mir liegt viel an diesem PRojket und würde das gerne durchgesetzt bekommen, dass dieses System bei mir auf der Arbeit auch zum Einsatz kommt. Haben wir hierfür Ansprechpartner ?
