  4. Absturz des javascript Adapters Version 10.1.3
    1.5k
15 Beiträge 3 Kommentatoren 263 Aufrufe 3 Beobachtet
  • hsteinmeH
    hsteinmeH
    hsteinme
    schrieb am zuletzt editiert von hsteinme
    Bitte schaut Euch mal das Issue https://github.com/ioBroker/ioBroker.javascript/issues/2379 an, das einen Absturz des javascript Adapters behandelt, der womöglich in Zusammenhang zur Version 10.1.3 steht. Dazu drei Fragen in die Runde:
    • Gibt es denn außer den im Issue erwähnten Usern weitere User hier, die von diesem Problem betroffen sind?
    • Wie kann ich das Problem weiter eingrenzen?
    • Wie kann ich mit den mir als User verfügbaren Mitteln das Problem lösen oder zumindest umgehen?
    • mcm1957M
      mcm1957M
      mcm1957
      Zur schnelleren Info hier der wichtigste Issue Inhalt:
      Since updating to JavaScript 10.1.3 yesterday, I have been experiencing the same issues:
      • The JavaScript adapter cannot be started.
      • The logfile is cluttered with host.IOBROKER entries of the type mentioned above .
      • All adapters are in debug mode. Any attempted changes are rejected.
      • In the web view, the ‘head’ for switching to expert mode is missing.
      • Attempts to downgrade the javascript adapter via command-line interface to a 9.x version are rejected with a message stating that only an upgrade to a newer version is possible.
      … and many, many functions implemented via javascripts, which are essential in day-to-day use, no longer work.
      The problem
      host.IOBROKER | 2026-09-12 11:59:45.764 | info | Restart adapter system.adapter.javascript.0 because enabled
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: Node.js v22.21.1
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: }
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24) {
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1192:37)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at Function._resolveFilename (node:internal/modules/cjs/loader:1369:27)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at Function._findPath (node:internal/modules/cjs/loader:717:31)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:650:36)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:660:9)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: at exportsNotFound (node:internal/modules/esm/resolve:313:10)
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './credentials' is not defined by "exports" in d:\ioBroker2\node_modules@iobroker\adapter-core\package.json
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: ^
      host.IOBROKER | 2026-09-12 11:59:45.764 | error | Caught by controller[0]: throw e;
      host.IOBROKER | 2026-09-12 11:59:45.763 | error | Caught by controller[0]: node:internal/modules/cjs/loader:657
      host.IOBROKER | 2026-09-12 11:59:45.057 | info | instance system.adapter.javascript.0 in version "10.1.3" started with pid 6560
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • AsgothianA
        AsgothianA
        Asgothian
        Es gibt einen issue (https://github.com/ioBroker/ioBroker.javascript/issues/2371 ) das der Adapter eine Bibliothek in einer Version benötigt die mit JS-Controller 7.1 nicht installiert ist, sich aber trotzdem installieren lässt.
        Zumindest sieht der log Auszug gleich aus.
        Ein Update auf JS-Controller 7.2.2 sollte das Problem lösen.
        A.
        • hsteinmeH
          hsteinmeH
          hsteinme
          Danke!
          Parallel zu Euren Antworten hatte ich bereitszwischenzeitlich über npm Downgrades auf javascripz 9.2.4 (wegen der Abstürze) und auf admin 7.8.23 (wegen der Ungereimtheiten in der Web-Oberfläche) vorgenommen, um Druck vom Kessel zu nehmen. Jetzt "darf" ich noch meine dreistellige Anzahl von Skripten wieder starten 😠
          • AsgothianA Asgothian
            A.
            mcm1957M
            mcm1957M
            mcm1957
            A.
            FYI:
            Hab Bluefox explizit getriggert ...
            • mcm1957M mcm1957
              A.
              FYI:
              AsgothianA
              AsgothianA
              Asgothian
              @mcm1957 sagte:
              FYI:
              Danke.
              Der Bug wegen der Installation ist lt. Kommentar von Bluefox seit 2 Tagen gefixed - allerdings gibt es da wohl noch keine neue Version, nur den Fix selber.
              A.
                @mcm1957 sagte:
                FYI:
                Danke.
                A.
                mcm1957M
                mcm1957M
                mcm1957
                @Asgothian
                Javascript hat die neueste Version ca 16h alt ...
                • mcm1957M
                  mcm1957M
                  mcm1957
                  Aber ja js-controller 7.1.x sollte soweiso NIEMAND mehr nutzen:
                  https://forum.iobroker.net/topic/84818/wichtiges-update-für-controller-7.2.2-im-stable
                  • mcm1957M mcm1957
                    @Asgothian
                    AsgothianA
                    AsgothianA
                    Asgothian
                    @mcm1957 hmm.. die war bei mir nichr verfügbar.
                    Ist fein.
                    Und ja, es gibt wenig gründe nicht auf JS-Controller 7.2 hoch zu gehen.
                    A.
                    • mcm1957M
                      mcm1957M
                      mcm1957
                      schrieb zuletzt editiert von mcm1957
                      Damit die Info auch hier ankommt:
                      Ursache war der veraltete js-controller 7.1.x
                      https://github.com/ioBroker/ioBroker.javascript/issues/2379#issuecomment-5655109232
                      hsteinmeH 1 Antwort Letzte Antwort
                      • mcm1957M mcm1957
                        hsteinmeH
                        hsteinmeH
                        hsteinme
                        @mcm1957 sagte:
                        Hmmmm, oder war die Ursache die fehlende Überprüfung der Dependency auf den js-Controller 🤔
                        • mcm1957M
                          mcm1957M
                          mcm1957
                          Nö, das war definitiv nicht du Ursache des Absturzes. Sonst würde der das Adapter nach einem Update des js-controlelrs auch nicht laufen Dabei wird nämlich die Dependencyprüfung nicht korrigiert. Eine Dependencyprüfung hätte dich nur dran erinnert dein veraltetes System zu aktualisisern. :-)
                          Und ganz generell für jene die auch noch zu alte js-controller Versionen fahren nochmal die Info bezüglich Updatebedarf für frühe 7.x.x Versionen:
                          🚨 Dringendes Update: js-controller 7.2.2
                          Der js-controller 7.2.2 ist jetzt im STABLE-Repository verfügbar.
                          Nutzer der Versionen 7.1.x, 7.2.0 und 7.2.1 sollten bitte schnellstmöglich aktualisieren.
                          Die älteren Versionen erzeugen aktuell sehr viele zentrale Fehlerprotokolle. Dadurch werden die ioBroker-Server stark belastet und die Funktionalität kann für alle Nutzer beeinträchtigt werden.
                          Das Update enthält außerdem wichtige Anpassungen für zukünftige Adapter-Versionen.
                          ⚠️ Bitte wundert euch nicht, wenn ihr die Admin-Information auch nach einem bereits durchgeführten Update angezeigt bekommt.
                          Die Nachricht kann technisch nicht auf bestimmte js-controller-Versionen begrenzt werden und wird daher an alle Nutzer verteilt.
                          Bitte prüft eure Version und aktualisiert euer System bei Bedarf zeitnah. Vielen Dank! 🙏
                          • mcm1957M mcm1957
                            hsteinmeH
                            hsteinmeH
                            hsteinme
                            @mcm1957 sagte:
                            Ich bleibe dabei: Hätte ioBroker mit Hinweis auf den js-controller-Stand das Update auf jvascript 10 nicht zugelassen, wäre kein Absturz aufgetreten.
                            • mcm1957M
                              mcm1957M
                              mcm1957
                              Ja, aber das hätte nicht die URSACHE behoben sondern nur das AUFTRETEN verhindert :-)
                              Und ich bleibe auch dabei:
                              Hättest du dein System wie per Announcemnet (im Forum und auch als Admin Announcement) aktualisiert bräuchten wir hier nicht zu diskutieren. :-)
                              • mcm1957M mcm1957
                                hsteinmeH
                                hsteinmeH
                                hsteinme
                                @mcm1957 sagte:
                                Jetzt sind wir beieiander 😊
                                83.8k
