  4. Load average am Anschlag -> Neustart
52 Beiträge 8 Kommentatoren 548 Aufrufe 6 Beobachtet
    @Thomas-Braun sagte:
    dmesg -T
    Das was ich gesucht hatte ist drin:
    [Thu Aug 27 15:40:15 2026] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0-7,global_oom,task_memcg=/,task=iobroker.js-con,pid=533421,uid=1001
    [Thu Aug 27 15:40:15 2026] Out of memory: Killed process 533421 (iobroker.js-con) total-vm:12096752kB, anon-rss:150480kB, file-rss:0kB, shmem-rss:0kB, UID:1001 pgtables:28000kB oom_score_adj:0
    [Thu Aug 27 15:40:17 2026] oom_reaper: reaped process 533421 (iobroker.js-con), now anon-rss:768kB, file-rss:0kB, shmem-rss:0kB
    puh@BrokerRaspi:~ $
    journalctl
    Alles?
    lines 5575-5627/5656 100%
    Oder nur das rote
    Aug 25 14:14:05 BrokerRaspi systemd-udevd[381]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
    Aug 25 14:14:05 BrokerRaspi systemd-udevd[381]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 The line has no effect any more, dropping.
    Aug 25 14:14:05 BrokerRaspi systemd-udevd[381]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
    Aug 25 14:14:05 BrokerRaspi systemd-udevd[381]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 The line has no effect any more, dropping.
    Aug 25 14:14:07 BrokerRaspi systemd[1]: Reached target remote-fs-pre.target - Preparation for Remote File Systems.
    Aug 25 14:14:07 BrokerRaspi systemd[1]: Reached target remote-fs.target - Remote File Systems.
    Aug 25 14:14:07 BrokerRaspi blkmapd[766]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
    Aug 25 14:14:07 BrokerRaspi systemd[1]: Started nfs-blkmap.service - pNFS block layout mapping daemon.
    Aug 27 15:27:33 BrokerRaspi kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0-7,global_oom,task_memcg=/,task=iobroker.js-con,pid=1191,uid=1001
    Aug 27 15:27:33 BrokerRaspi kernel: Out of memory: Killed process 1191 (iobroker.js-con) total-vm:12474624kB, anon-rss:335120kB, file-rss:0kB, shmem-rss:0kB, UID:1001 pgtables:32976kB oom_score_adj:0
    Aug 27 15:28:34 BrokerRaspi kernel: cron invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
    Aug 27 15:28:36 BrokerRaspi kernel: [ 531576]  1001 531576     6381        6        0        6         0    98304        0             0 node
    Aug 27 15:28:36 BrokerRaspi kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0-7,global_oom,task_memcg=/,task=io.javascript.1,pid=1474,uid=1001
    Aug 27 15:28:36 BrokerRaspi kernel: Out of memory: Killed process 1474 (io.javascript.1) total-vm:12129424kB, anon-rss:205536kB, file-rss:256kB, shmem-rss:0kB, UID:1001 pgtables:22080kB oom_score_adj:0
    Aug 27 15:28:36 BrokerRaspi systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
    Aug 27 15:40:16 BrokerRaspi kernel: [ 538774]  1001 538774     6712       12        0       12         0    98304        0             0 node
    Aug 27 15:40:16 BrokerRaspi kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0-7,global_oom,task_memcg=/,task=iobroker.js-con,pid=533421,uid=1001
    Aug 27 15:40:16 BrokerRaspi kernel: Out of memory: Killed process 533421 (iobroker.js-con) total-vm:12096752kB, anon-rss:150480kB, file-rss:0kB, shmem-rss:0kB, UID:1001 pgtables:28000kB oom_score_adj:0
    Aug 27 15:40:16 BrokerRaspi kernel: oom_reaper: reaped process 533421 (iobroker.js-con), now anon-rss:768kB, file-rss:0kB, shmem-rss:0kB
    @Homoran sagte:
    Alles?
    Man kann das ganz wunderbar auf bestimmte Betrachtungszeiträume beschränken. Steht alles im Schnubbibuntu-Wiki drin, aus dem Kopf weiß ich die genaue Syntax auch nicht.
      @Homoran sagte:
      Alles?
      @Thomas-Braun Danke.
      Such ich mir gerne nachher raus
      Die roten zeilen hab ich alle gezeigt
      Dass es schlussendlich out of memory war, hab ich ja aus den charts vermutet, aber warum?
      Hilft das letzte aus dem output
      Aug 27 18:01:37 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      Aug 27 18:02:41 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      Aug 27 18:03:51 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      Aug 27 18:04:28 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      Aug 27 18:04:46 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      Aug 27 18:05:11 BrokerRaspi bash[539235]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      • MartinPM Online
        MartinPM Online
        MartinP
        Wer Speicher frisst, kann man sich auch anzeigen lassen...
        Die Prozesse, sortiert von oben nach unten nach dem Speicherverbrauch.
        Kann aber langweilig werden, wenn man davor sitzen muss ...
        Wenn es Vorzeichen gibt, kann man sich ja über iobroker alarmieren lassen, wenn es spannend wird ...
        Linux Console
        top -o %MEM - echtzeit-Anzeige
        top -o %MEM -n 1 - ein Durchlauf, kann man auch in Datei umleiten lassen (ggfs mit linux-control sogar von iobroker starten lassen)
        top - 18:36:03 up 1 day,  2:03,  0 users,  load average: 3.43, 3.57, 3.73
        Tasks:  66 total,   1 running,  65 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 27.5 us, 25.5 sy,  0.0 ni, 43.8 id,  0.5 wa,  0.0 hi,  2.7 si,  0.0 st
        MiB Mem :   6144.0 total,   2979.2 free,   2562.4 used,    602.5 buff/cache
        MiB Swap:   6144.0 total,   4956.9 free,   1187.1 used.   3581.6 avail Mem
            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
            410 iobroker  20   0   12.1g 247056  29684 S   9.4   3.9 205:08.33 iobroker.js-con
            354 grafana   20   0 2147780 216260  81568 S   2.6   3.4  36:43.40 grafana
            106 influxdb  20   0 4706888 192716  31064 S   4.9   3.1 198:46.98 influxd
            498 iobroker  20   0   22.0g 189992  42472 S   0.0   3.0   2:23.22 io.admin.0
            522 iobroker  20   0   12.0g 181988  39140 S   2.9   2.9  96:19.18 io.influxdb.0
            554 iobroker  20   0   12.0g 181164  41612 S   2.3   2.9  62:00.97 io.javascript.0
            570 iobroker  20   0   11.8g 145544  39192 S   2.3   2.3  44:19.36 io.javascript.1
            601 iobroker  20   0   11.8g 124428  42428 S   0.3   2.0   9:39.54 io.mqtt.0
            590 iobroker  20   0   11.7g 121228  40660 S   0.0   1.9   1:43.94 io.mqtt-client.
            571 iobroker  20   0   11.9g 117876  41844 S   0.0   1.9   6:32.65 io.backitup.0
            639 iobroker  20   0   11.7g 117788  41660 S   2.9   1.9  61:25.18 io.sonoff.0
            816 iobroker  20   0   11.7g 116152  41380 S   0.3   1.8   2:15.27 io.simple-api.0
            670 iobroker  20   0   11.9g 115492  42396 S   0.0   1.8   8:11.39 io.tr-064.0
             51 root      20   0  233784 115160 114676 S   0.0   1.8   0:20.48 systemd-journal
            646 iobroker  20   0   11.9g 113644  42556 S   0.0   1.8   4:27.48 io.meross.0
            837 iobroker  20   0   21.7g 105520  41872 S   0.0   1.7   2:36.18 io.linux-contro
            723 iobroker  20   0   11.9g 103152  42328 S   0.0   1.6   2:31.00 io.hm-rpc.0
            801 iobroker  20   0   11.8g 103052  42320 S   0.0   1.6   1:44.38 io.web.0
            773 iobroker  20   0   11.7g  99972  42172 S   0.0   1.6   2:40.04 io.hm-rega.0
            534 iobroker  20   0   11.7g  97704  41924 S   0.0   1.6   1:39.59 io.email.0
            659 iobroker  20   0   11.7g  97036  41252 S   0.0   1.5   1:52.47 io.snmp.0
            795 iobroker  20   0   11.8g  96892  42248 S   0.0   1.5   1:32.61 io.vis-2.0
            722 iobroker  20   0   11.7g  96848  41132 S   0.0   1.5   1:30.10 io.discovery.0
        • MartinPM Online
          MartinPM Online
          MartinP
          Nachtrag Bei meiner "top" - Version gibt es noch einem Parameter, den aber nicht alle bieten
          top -o %MEM -n 1 --scale-task-mem=m
          Damit wird der Speicherbedarf in Megabyte ausgegeben...
          %Cpu(s): 17.4 us, 21.7 sy,  0.0 ni, 60.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   6144.0 total,   2991.9 free,   2563.1 used,    589.1 buff/cache
          MiB Swap:   6144.0 total,   4956.9 free,   1187.1 used.   3580.9 avail Mem
              410 iobroker  20   0   12.1g 275.0m  29.0m S   0.0   4.5 206:46.87 iobroker.js-con
              354 grafana   20   0 2097.7m 211.4m  79.7m S   0.0   3.4  37:01.41 grafana
              498 iobroker  20   0   22.0g 185.5m  41.5m S   0.0   3.0   2:23.85 io.admin.0
              106 influxdb  20   0 4596.6m 178.2m  30.3m S   0.0   2.9 200:17.88 influxd
              522 iobroker  20   0   12.0g 171.6m  38.2m S   0.0   2.8  97:05.90 io.influxdb.0
              554 iobroker  20   0   12.0g 160.4m  40.6m S   0.0   2.6  62:31.28 io.javascript.0
              570 iobroker  20   0   11.8g 142.1m  38.3m S   0.0   2.3  44:40.54 io.javascript.1
              601 iobroker  20   0   11.8g 121.5m  41.4m S   0.0   2.0   9:44.16 io.mqtt.0
              590 iobroker  20   0   11.7g 118.5m  39.7m S   0.0   1.9   1:44.71 io.mqtt-client.
              571 iobroker  20   0   11.9g 115.1m  40.9m S   0.0   1.9   6:33.21 io.backitup.0
              639 iobroker  20   0   11.7g 114.4m  40.7m S   0.0   1.9  61:56.16 io.sonoff.0
              816 iobroker  20   0   11.7g 113.4m  40.4m S   0.0   1.8   2:16.30 io.simple-api.0
               51 root      20   0  228.3m 112.9m 112.4m S   0.0   1.8   0:20.61 systemd-journal
              670 iobroker  20   0   11.9g 112.8m  41.4m S   0.0   1.8   8:14.95 io.tr-064.0
              646 iobroker  20   0   11.9g 110.9m  41.6m S   8.3   1.8   4:29.42 io.meross.0
              837 iobroker  20   0   21.7g 103.4m  40.9m S   0.0   1.7   2:37.33 io.linux-contro
              723 iobroker  20   0   11.9g 100.8m  41.3m S   0.0   1.6   2:32.01 io.hm-rpc.0
              801 iobroker  20   0   11.8g 100.6m  41.3m S   0.0   1.6   1:45.00 io.web.0
              773 iobroker  20   0   11.7g  98.4m  41.2m S   0.0   1.6   2:41.13 io.hm-rega.0
              659 iobroker  20   0   11.7g  94.8m  40.3m S   0.0   1.5   1:53.36 io.snmp.0
              795 iobroker  20   0   11.8g  94.6m  41.3m S   0.0   1.5   1:33.15 io.vis-2.0
              722 iobroker  20   0   11.7g  94.6m  40.2m S   0.0   1.5   1:30.81 io.discovery.0
              534 iobroker  20   0   11.7g  93.6m  40.9m S   0.0   1.5   1:40.26 io.email.0
              772 iobroker  20   0   11.7g  92.7m  40.3m S   0.0   1.5   3:50.66 io.ping.0
              808 iobroker  20   0   11.1g  80.9m  33.4m S   0.0   1.3  13:48.18 io.reolink.0
              710 iobroker  20   0   11.1g  80.3m  32.7m S   0.0   1.3  11:14.24 io.ems-esp.0
              830 iobroker  20   0   11.1g  78.8m  33.4m S   0.0   1.3  13:31.45 io.reolink.1
              822 iobroker  20   0   11.2g  77.5m  33.2m S   0.0   1.3  18:38.57 io.fb-checkpres
              737 iobroker  20   0   11.1g  76.8m  33.1m S   0.0   1.3   2:45.78 io.fritzdect.0
              793 iobroker  20   0   11.1g  74.6m  32.7m S   0.0   1.2   2:06.69 io.tradfri.0
              716 iobroker  20   0   11.1g  74.2m  32.9m S   0.0   1.2   8:15.38 io.zigbee2mqtt.
              640 iobroker  20   0   11.1g  73.3m  32.5m S   0.0   1.2   5:48.54 io.operating-ho
              438 grafana   20   0 1259.6m  21.1m  14.9m S   0.0   0.3   0:05.54 gpx_grafana_inf
              458 grafana   20   0 1269.8m  13.9m   8.3m S   0.0   0.2   0:05.69 gpx_grafana-lok
              391 grafana   20   0 1265.2m  13.1m   8.5m S   0.0   0.2   0:04.94 gpx_grafana_ela
                1 root      20   0   23.0m  11.5m   9.2m S   0.0   0.2   1:17.94 systemd
              403 grafana   20   0 1254.5m  11.2m  10.0m S   0.0   0.2   0:00.37 gpx_dash_linux_
              101 root      20   0   18.7m   7.6m   6.9m S   0.0   0.1   0:12.04 systemd-logind
            35315 postfix   20   0   43.5m   7.3m   6.6m S   0.0   0.1   0:00.02 pickup
              329 postfix   20   0   43.5m   6.2m   6.1m S   0.0   0.1   0:00.16 qmgr
          martin@iobroker-test-sicher:~$ top -o %MEM -n 1 --scale-task-mem=m
            @Homoran sagte:
            Das kann dir zugegebenermaßen auch journalctl nicht beantworten. Sind ja offenbar keine Vorgänge im OS sondern im ioBroker.
            • MartinPM MartinP
              Linux Console
              @MartinP sagte:
              Ach was!
              Da ist aber nix
              Auch nicht in der nach Mem sortierten json Tabelle
              Der Speicher bricht ja erst in den letzten Millisekunden weg...siehe chart
                schrieb zuletzt editiert von Homoran
                Leider ist der Controller heute nacht kurz nach Mitternacht wieder abgeschossen worden. (Sourceanalytix??)
                Daraufhin hab ich heute morgen einiges probiert.
                Was mir dabei aufgefallen ist:
                • Seit dem vorigen kill reagierte der scaling governor deutlich langsamer
                  Die CPU-Frequenz lieb deutlich länger auf 2400MHz, was ich erst als gutes Zeichen gesehen hatte.
                • die Werte unter system.host.xyz.load passen nicht wirklich zu load average 1min aus ̀top
                  • sie wechseln viel zu schnell und stark, als dass es 1min floating average sein könnten
                  • der Wert ist auch deutlich höher
                • das Ansteigen der Load konnte ich (meistens 😞) reproduzieren durch
                  • zoomen in einem Flot chart
                  • arbeiten im admin an Instanzeneinstellungen
                • Wenn es zu (geregelten (0-4)) load Anstiegen kam, dauerten diese meistens ca. 30 Minuten
                • zusätzlich stieg der Speicherverbrauch im Heap des admins (leicht) an.
                • Ansonsten war weder die CPU Last noch der Speicher der Prozesse in top irgendwie auffällig.
                Daraufhin habe ich mir angesehen ob ich einige Instanzen pausieren, oder unnötige Adapter deinstallieren könnte um die Ursache einzugrenzen.
                • simple api hatte ich mWn nie installiert, im Gegenteil ich hatte es nach dem Umzug bewusst deinstalliert, was zu einer deutlich niedrigeren load führte. Jetzt war es wieder da.
                • native web sockets war updatefähig, was ich gemacht habe. Auch hier hatte ich es nie installiert.
                  • hier habe ich eine -bisher nicht existierende- Instanz angelegt, was zu einem Portkonflikt führte, da 8084 bereits vergeben war, geändert auf 8087
                Anschließend ein iob upload all und ein reboot
                Jetzt reagiert auch der governor wieder wie vorher und die anderen Werte im chart verhielten sich wie früher
                Ab kurz nach 08:00
                Den go-e Adapter hab ich jetzt deaktiviert.
                Er war bei den zuletzt upgedateten dabei und wurde wegen restart loops schon mal abgeschaltet (muss kein Zusammenhang bestehen)
                • Ro75R Online
                  Ro75R Online
                  Ro75
                  Hast du den PI5 in einem speziellen Gehäuse? Ich hatte meinen PI4 mal in ein Alu-Gehäuse gepckt und dann zeigte der die selben Sympthome.
                  Ro75.
                  • Ro75R Ro75
                    Ro75.
                    @Ro75 sagte:
                    Ja, in einem Argon mit NVMe Zusatz.
                    https://www.welectron.com/Raspberry-Pi-5-8-GB-Argon-Neo-Kit
                    @Ro75 sagte:
                    🤔 die Symptome traten ja bereits vorher auf, als es noch auf einem anderen Pi5 lief, plötzlich auf, nachdem es dort ca. 2 Jahre problemlos in einem anderen Alu Gehäuse lief.
                    https://www.welectron.com/Raspberry-Pi-5-8-GB-Flirc-Kit
                    • Ro75R Online
                      Ro75R Online
                      Ro75
                      Das erste hatte ich für einen PI4. Der lief 2 Jahre ohne Probleme. In das Gehäuse und dann fingen die Probleme an. Vielleicht kannst du den PI5 mal ohne dem Gehäuse laufen lassen. Mein PI5 für OMV läuft in einem Plastegehäuse - bisher ohne Probleme. Manchmal ist es sehr komisch.
                      Ro75.
                      • Ro75R Ro75
                        Ro75.
                          Ab kurz nach 08:00
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @Homoran
                          https://forum.iobroker.net/topic/85231/unregelmäßig-unmotivierter-neustart-aller-instanzen/26?_=1787912224912
                          Hier auch so eine Nachricht zum abfragen der repos und dann Absturz
                          Meine Adapter und Widgets
                          Links im Profil
                          • OliverIOO OliverIO
                            @Homoran
                            @OliverIO sagte:
                            Sag ich doch 😉
                            Homoran sagte:
                            @oliverio
                            Ich hab da noch was gefunden
                            2026-08-23 08:58:42.519 - info: admin.0 (1197) Adapter rating updated
                            Das kommt mir aber bekannt vor.
                            Und
                            Homoran sagte:
                            EDIT:
                            Hab seitenweise EPIPE, ECONNRESET 9000 und 9001 im log!
                            Ist das etwa dasselbe hier?
                            Aber auch da gibt es keinerlei greifbare Ergebnisse.
                            @Ro75 sagte:
                            Ganz abgesehen davon, dass die Probleme bereits im Flirc Gehäuse begannen, bin ich ja danach auf Argon umgestiegen, da dort die NVMe und ein geregelter Lüfter drin sind.
                            Wäre aber jetzt nicht normal, wenn möglicherweise ausgerechnet der Lüfter due Störungen verursacht bzw. verschlimmert
                            OliverIOO Ro75R 2 Antworten Letzte Antwort
                              @OliverIO sagte:
                              Sag ich doch 😉
                              Homoran sagte:
                              @oliverio
                              Und
                              Homoran sagte:
                              EDIT:
                              @Ro75 sagte:
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @Homoran
                              Ich denke es ist nur ein Symptom bei dem ein Absturz auftritt.
                              Wenn an der Funktion etwas problematisch wäre, wären hier viel mehr Nachrichten, da jeder iobroker das täglich mehrfach macht
                              Links im Profil
                                @OliverIO sagte:
                                Sag ich doch 😉
                                Homoran sagte:
                                @oliverio
                                Und
                                Homoran sagte:
                                EDIT:
                                @Ro75 sagte:
                                Ro75R Online
                                Ro75R Online
                                Ro75
                                @Homoran sagte:
                                Ich gebe dir da völlig recht. Ich hatte meinen PI4 dann wieder aus dem Gehäue genommen und der lief wieder - kein Problem mehr.
                                Möglicherweise eine andere Wärmeverteilung, vielleicht auch ungewollt ein Stromfluss der nicht sein darf - keine Ahnung.
                                Es war nur eine Idee, da ja wenn es was "globales" wäre hier viel mehr Berichte in gleicher Form auftauchen müssten. Deswegen denke ich, es ist etwas sehr spezielles und "unerfahren" bist du ja nun auch nicht. Deswegen, manchmal läuft es wirklich komisch.
                                Ro75.
                                • Ro75R Ro75
                                  @Homoran sagte:
                                  Ro75.
                                  @Ro75 ich logge jetzt auch noch die CPU Temp.
                                  Hab leider auf die Schnelle keine Möglichkeit gefu den die Lüfteraktivität zu tracken.
                                  Nur ein Addon für HA 😂
                                    @OliverIO sagte:
                                    da könntest du mal auf input counts/output counts des javascript adapters tracken, ob das zu diesen ereignissen extrem ansteigt
                                    Ooh, nicht korrekt gelesen 😳
                                    Hab nur die input counts 😞
                                    Was mich allerdings wundert ist, dass js.0 und js.1 etwa gleiche Werte (ca.1400) haben, obwohl in js.0 keine Skripte laufen
                                    edit:
                                    Jetzt aber
                                    Input counts sind 10x so hoch wie die output counts
                                    @Homoran [sagte]: obwohl in js.0 keine Skripte laufen
                                    Weshalb ist dann die Instanz aktiv? Das frisst nur eine Menge RAM.
                                    In deinen Ausgaben von "top" vermisse ich "admin.0".
                                      @paul53 Danke!!
                                      @paul53 sagte:
                                      War mir gar nicht aufgefallen!
                                      Nach der Tabelle (nach mem sortiert)
                                      Hat der admin.0 im Moment gerade mal 0.4% cpu last
                                      Kann es sein dass bei top (nach cpu last sortiert) der admin ganz weit unten ist?
                                      Sehe ich gleich mal nach
                                      EDIT:
                                      Sehr strange!
                                      Ich musste auch nach mem sortieren
                                      0% CPU ist aber nicht glaubwürdig
                                      Dito bei matter!
                                      Matter war auch beim letzten update dabei, admin weiss ich leider nicht mehr.
                                      @paul53 sagte:
                                      Muss ich auch mal nachsehen. Ich glaube da ist irgendwann ein Skript irrtümlich rein gerutscht. Müsste ich dann verschieben
                                        @paul53 Danke!!
                                        @paul53 sagte:
                                        EDIT:
                                        Sehr strange!
                                        Dito bei matter!
                                        @paul53 sagte:
                                        schrieb zuletzt editiert von paul53
                                        @Homoran [sagte]:
                                        Ist bei mir auch so (nach mem sortiert)
                                        top - 13:09:00 up 2 days, 33 min,  1 user,  load average: 0,00, 0,00, 0,00
                                        Tasks: 117 total,   1 running, 116 sleeping,   0 stopped,   0 zombie
                                        %CPU(s):  1,1 us,  0,2 sy,  0,0 ni, 98,7 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
                                        MiB Spch:   3921,5 total,   1521,2 free,   1627,0 used,   1008,1 buff/cache
                                        MiB Swap:   1722,0 total,   1722,0 free,      0,0 used.   2294,6 avail Spch
                                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                                            834 iobroker  20   0   11,4g 334252  57164 S   0,3   8,3   9:41.52 io.javascript.0
                                            684 iobroker  20   0   11,4g 271536  56504 S   3,0   6,8  22:29.85 iobroker.js-con
                                            787 iobroker  20   0   21,4g 229116  58980 S   0,0   5,7   1:22.79 io.admin.0
                                            989 iobroker  20   0   11,2g 156692  57136 S   0,0   3,9   0:49.84 io.echarts.0
                                           1155 iobroker  20   0   11,3g 118316  52700 S   0,0   2,9   0:57.19 io.web.0
                                            861 iobroker  20   0   11,1g 117368  53084 S   0,0   2,9   5:26.78 io.history.0
                                           1005 iobroker  20   0   11,1g 105764  51116 S   0,0   2,6   0:46.24 io.simple-api.0
                                            877 iobroker  20   0   11,1g 105132  51528 S   0,0   2,6   1:17.45 io.hm-rpc.0
                                           1037 iobroker  20   0   11,1g 104676  52120 S   0,0   2,6   1:42.39 io.midea.0
                                            925 iobroker  20   0   11,3g 102428  51924 S   0,0   2,6   7:46.15 io.proxmox.0
                                            941 iobroker  20   0   11,1g 101392  52180 S   0,0   2,5   0:46.29 io.email.0
                                           1021 iobroker  20   0   11,1g 100148  51672 S   0,0   2,5   5:09.31 io.fritzdect.0
                                            909 iobroker  20   0   11,1g  98092  51164 S   0,0   2,4   1:05.72 io.hm-rega.0
                                        Ausgabe von "top -u iobroker".
                                          Danke!
                                          Das beruhigt mich
