Abfrage des users beim Ausführen des Fix´s
scheinbar habe ich ein Berechtigung Problem.
wenn ich folgendes ausführe kommt das:
sudo iob stop
Sudo curl -sL https://iobroker.net/fix.sh | bash -
dann kommt bei punkt 5 die Abfrage des users und des Passworts.juergen@iobroker:~$ curl -sL https://iobroker.net/fix.sh | bash - library: loaded Library version=2026-04-11 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2025-09-18 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org/debian-security trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Get:5 https://repos.influxdata.com/debian stable InRelease [6,922 B] Fetched 6,922 B in 0s (26.2 kB/s) Reading package lists... Done ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ACL enabled: true ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ==== Authentication is required to stop 'iobroker.service'. Multiple identities can be used for authentication: 1. juergen,,, (juergen) 2. ioadmin Choose identity to authenticate as (1-2):Bei iob Diag sagt er mir ich soll den Fix ausführen:
Temp directories causing deletion problem: 1 Some problems detected, please run 'iob fix'Alles andere im Diag ist grün. Ich kann auch keine Pakete mehr über iobroker aktualisieren. Nur noch über Puttyy und dann
iob update iob upgradejemand eine Idee?
System ist auf dem aktuellen Stand.
npm 10.9.8
Node.js 22.23.2 -
Ein Problem gelöst wenn ich "sudo" vor den curl -sL https://iobroker.net/fix.sh | bash -
fehl curl -sL https://iobroker.net/fix.sh | bash -
dann klappt es einmal . danach wieder die Abfrage nach user und Passwort -
dann klappt es einmal . danach wieder die Abfrage nach user und PasswortNie, nie, nie iob mit sudo anpacken. Nie!
sudo iob stop
npm 10.9.8
Node.js 22.23.2dann kommt bei punkt 5 die Abfrage des users und des Passworts.
Nein, da kommt zunächst mal die Anfrage, welcher user denn dazu verwendet werden soll:
Multiple identities can be used for authentication:- juergen,,, (juergen)
- ioadmin
Offenbar hast du also mehrere user angelegt. Welche Rechte haben die im Einzelnen?
sudo iob stop
npm 10.9.8
Node.js 22.23.2 -
Zeig mal den vollständigen Output von
iob diagdann.
========== Start marking the full check here =========== ```bash Script v.2026-06-06 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.63+deb13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 4month 2w 3d OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64bit System was installed 157 days ago (on 2026-03-13). Systemuptime and Load: 12:19:07 up 1:39, 1 user, load average: 0.51, 0.32, 0.43 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-08-18 12:19:07 CEST Universal time: Tue 2026-08-18 10:19:07 UTC RTC time: Tue 2026-08-18 10:19:07 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': juergen HOME=/home/juergen GROUPS=juergen adm cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.3G 4.6G 2.7G 7.7M 1.4G 3.8G Swap: 5.5G 0B 5.5G Total: 13G 4.6G 8.2G Active iob-Instances: 35 7947 M total memory 4363 M used memory 3838 M active memory 1006 M inactive memory 2574 M free memory 153 M buffer memory 1206 M swap cache 5237 M total swap 0 M used swap 5237 M free swap *** top - Table Of Processes *** top - 12:19:08 up 1:39, 1 user, load average: 0.51, 0.32, 0.43 Tasks: 164 total, 1 running, 163 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.8 us, 2.4 sy, 0.0 ni, 92.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7947.3 total, 2573.5 free, 4364.0 used, 1359.4 buff/cache MiB Swap: 5238.0 total, 5238.0 free, 0.0 used. 3583.3 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 795M 496K 795M 1% /run /dev/sda1 ext4 93G 6.9G 82G 8% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service tmpfs tmpfs 3.9G 6.9M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 795M 8.0K 795M 1% /run/user/1000 Messages concerning filesystems in dmesg: [Tue Aug 18 10:39:41 2026] EXT4-fs (sda1): orphan cleanup on readonly fs [Tue Aug 18 10:39:41 2026] EXT4-fs (sda1): mounted filesystem ad7cb7c3-87c0-4151-8142-0f5900745d4e ro with ordered data mode. Quota mode: none. [Tue Aug 18 10:39:42 2026] EXT4-fs (sda1): re-mounted ad7cb7c3-87c0-4151-8142-0f5900745d4e r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 745M /var/ 376M /var/cache 368M /var/cache/apt 277M /var/cache/apt/archives 192M /var/log Archived and active journals take up 177M in the file system. /opt/iobroker/backups: 16M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 859M /opt/iobroker/iobroker-data/ 602M /opt/iobroker/iobroker-data/files 135M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 68M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 46M /opt/iobroker/iobroker-data/states.jsonl 31M /opt/iobroker/iobroker-data/objects.jsonl 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 20M /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.23.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.23.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.2, hostname: iobroker , alive, uptime: 3842) Core adapters versions js-controller: 7.2.2 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 1 | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) Adapter State + system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.birthdays.0 : birthdays : iobroker - enabled + system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - disabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled system.adapter.echarts.0 : echarts : iobroker - disabled system.adapter.email.0 : email : iobroker - disabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - enabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - disabled system.adapter.feiertage.0 : feiertage : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled + system.adapter.fritzbox.0 : fritzbox : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled system.adapter.fullcalendar.0 : fullcalendar : iobroker - disabled system.adapter.history.0 : history : iobroker - disabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : iobroker - disabled system.adapter.icons-icons8.0 : icons-icons8 : iobroker - disabled system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - disabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.melcloud.0 : melcloud : iobroker - enabled + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1884, bind: 192.168.42.15 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1886, bind: 192.168.42.15 + system.adapter.mqtt.3 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.42.15 + system.adapter.mqtt.4 : mqtt : iobroker - enabled, port: 1888, bind: 192.168.42.15 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 192.168.42.15 system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.radar2.0 : radar2 : iobroker - disabled + system.adapter.rpi2.0 : rpi2 : iobroker - disabled system.adapter.sayit.0 : sayit : iobroker - disabled, port: 0 + system.adapter.scenes.0 : scenes : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 192.168.42.15 + system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - enabled + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.snmp.0 : snmp : iobroker - disabled system.adapter.socketio.0 : socketio : iobroker - disabled, port: 8084, bind: 192.168.42.15, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - disabled, port: 1883, bind: 192.168.42.15 system.adapter.sonoff.1 : sonoff : iobroker - disabled, port: 1884, bind: 192.168.42.15 system.adapter.sonoff.2 : sonoff : iobroker - disabled, port: 1888, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : iobroker - enabled system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - disabled system.adapter.synology.0 : synology : iobroker - disabled, port: 5001 + system.adapter.systeminfo.0 : systeminfo : iobroker - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.2 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : iobroker - disabled system.adapter.text2command.1 : text2command : iobroker - disabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.upnp.0 : upnp : iobroker - disabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-history.0 : vis-history : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - disabled system.adapter.vis-material.0 : vis-material : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-players.0 : vis-players : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - disabled system.adapter.whatsapp-cmb.1 : whatsapp-cmb : iobroker - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1884, bind: 192.168.42.15 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1886, bind: 192.168.42.15 + system.adapter.mqtt.3 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.42.15 + system.adapter.mqtt.4 : mqtt : iobroker - enabled, port: 1888, bind: 192.168.42.15 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 192.168.42.15 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 192.168.42.15 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.2 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '7.8.23' │ 'none' │ │ 1 │ 'system.adapter.backitup' │ 'backitup' │ '3.3.17' │ 'none' │ │ 2 │ 'system.adapter.birthdays' │ 'birthdays' │ '6.1.0' │ 'none' │ │ 3 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.3' │ 'none' │ │ 4 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 5 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 6 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 7 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 8 │ 'system.adapter.email' │ 'email' │ '2.0.4' │ 'none' │ │ 9 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 10 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 11 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 12 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 13 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 14 │ 'system.adapter.fritzbox' │ 'fritzbox' │ '0.7.0' │ 'none' │ │ 15 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 16 │ 'system.adapter.fullcalendar' │ 'fullcalendar' │ '2.4.5' │ 'none' │ │ 17 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 18 │ 'system.adapter.hm-rega' │ 'hm-rega' │ '5.1.0' │ 'none' │ │ 19 │ 'system.adapter.hm-rpc' │ 'hm-rpc' │ '3.0.1' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 21 │ 'system.adapter.icons-fatcow-hosting' │ 'icons-fatcow-hosting' │ '0.1.0' │ 'none' │ │ 22 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 23 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 24 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 25 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 26 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2' │ 'none' │ │ 27 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 28 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 29 │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none' │ │ 30 │ 'system.adapter.melcloud' │ 'melcloud' │ '3.0.4' │ 'none' │ │ 31 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 32 │ 'system.adapter.node-red' │ 'node-red' │ '6.0.7' │ 'none' │ │ 33 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.1' │ 'none' │ │ 34 │ 'system.adapter.pvforecast' │ 'pvforecast' │ '6.1.0' │ 'none' │ │ 35 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 36 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 37 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 38 │ 'system.adapter.scenes' │ 'scenes' │ '4.0.4' │ 'none' │ │ 39 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 40 │ 'system.adapter.shuttercontrol' │ 'shuttercontrol' │ '2.0.12' │ 'none' │ │ 41 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 42 │ 'system.adapter.snmp' │ 'snmp' │ '3.4.0' │ 'none' │ │ 43 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 44 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 45 │ 'system.adapter.sonos' │ 'sonos' │ '3.0.0' │ 'none' │ │ 46 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 47 │ 'system.adapter.synology' │ 'synology' │ '3.1.0' │ 'none' │ │ 48 │ 'system.adapter.systeminfo' │ 'systeminfo' │ '1.3.0' │ 'none' │ │ 49 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 50 │ 'system.adapter.telegram' │ 'telegram' │ '4.1.0' │ 'none' │ │ 51 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 52 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 53 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 54 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 55 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 56 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 57 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 58 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 59 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 60 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 61 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 62 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 63 │ 'system.adapter.vis-material' │ 'vis-material' │ '0.2.0' │ 'none' │ │ 64 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 65 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 66 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 67 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 68 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 69 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 70 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 71 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 72 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: Stable (default) Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "backitup" : 3.3.17 , installed 3.3.17 Adapter "birthdays" : 6.1.0 , installed 6.1.0 Adapter "daswetter" : 4.5.3 , installed 4.5.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 2.0.4 , installed 2.0.4 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "feiertage" : 1.4.0 , installed 1.4.0 Adapter "fritzbox" : 0.7.0 , installed 0.7.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullcalendar" : 2.4.5 , installed 2.4.5 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "melcloud" : 3.0.4 , installed 3.0.4 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "node-red" : 6.0.7 , installed 6.0.7 Adapter "proxmox" : 2.6.1 , installed 2.6.1 Adapter "pvforecast" : 6.1.0 , installed 6.1.0 Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "scenes" : 4.0.4 , installed 4.0.4 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "shuttercontrol": 2.0.12 , installed 2.0.12 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "snmp" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "systeminfo" : 1.3.0 , installed 1.3.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material" : 0.2.0 , installed 0.2.0 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.13 , installed 2.5.13 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Objects and States Please stand by - This may take a while Objects: 22757 States: 21925 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://security.debian.org/debian-security trixie-security InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B] Fetched 6922 B in 0s (28.3 kB/s) Reading package lists... Pending systemupdates: 2 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.42.15:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=14298,fd=70)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=524,fd=5),("systemd",pid=1,fd=96)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=524,fd=7),("systemd",pid=1,fd=98)) tcp LISTEN 0 511 192.168.42.15:1888 0.0.0.0:* users:(("io.mqtt.4",pid=14066,fd=35)) tcp LISTEN 0 511 192.168.42.15:1884 0.0.0.0:* users:(("io.mqtt.1",pid=14014,fd=35)) tcp LISTEN 0 511 192.168.42.15:1886 0.0.0.0:* users:(("io.mqtt.2",pid=16722,fd=35)) tcp LISTEN 0 511 192.168.42.15:1880 0.0.0.0:* users:(("node-red",pid=13140,fd=23)) tcp LISTEN 0 511 192.168.42.15:1881 0.0.0.0:* users:(("io.shelly.0",pid=14083,fd=37)) tcp LISTEN 0 511 192.168.42.15:1883 0.0.0.0:* users:(("io.mqtt.3",pid=14049,fd=35)) tcp LISTEN 0 511 192.168.42.15:42001 0.0.0.0:* users:(("io.hm-rpc.0",pid=13776,fd=35)) tcp LISTEN 0 511 192.168.42.15:42010 0.0.0.0:* users:(("io.hm-rpc.1",pid=13823,fd=35)) tcp LISTEN 0 511 192.168.42.15:8701 0.0.0.0:* users:(("io.hm-rpc.2",pid=13946,fd=35)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=685,fd=6)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=524,fd=4),("systemd",pid=1,fd=95)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=12838,fd=23)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=12838,fd=29)) tcp LISTEN 0 511 *:3500 *:* users:(("io.sonos.0",pid=14117,fd=31)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.1",pid=12866,fd=40)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=15930,fd=35)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=14469,fd=35)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=685,fd=7)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=524,fd=6),("systemd",pid=1,fd=97)) *** Log File - Last 25 Lines *** 2026-08-18 12:19:04.736 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/ 2026-08-18 12:19:04.736 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/ 2026-08-18 12:19:04.739 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_relative/ 2026-08-18 12:19:04.739 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_relative/ 2026-08-18 12:19:04.745 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_persistent_absolute/ 2026-08-18 12:19:04.745 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_absolute/ 2026-08-18 12:19:04.765 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative" with regex /solar\.[^.]*\.cmd\.limit_persistent_relative/ 2026-08-18 12:19:04.765 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_relative/ 2026-08-18 12:19:04.767 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /solar\.[^.]*\.cmd\.power/ 2026-08-18 12:19:04.767 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.power/ 2026-08-18 12:19:04.767 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/reset_rf_stats" with regex /solar\.[^.]*\.cmd\.reset_rf_stats/ 2026-08-18 12:19:04.767 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/reset_rf_stats" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.reset_rf_stats/ 2026-08-18 12:19:04.768 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /solar\.[^.]*\.cmd\.restart/ 2026-08-18 12:19:04.768 - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.restart/ 2026-08-18 12:19:04.937 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.940 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.946 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.964 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.967 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.967 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:04.968 - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-08-18 12:19:26.054 - info: javascript.0 (12977) script.js.common.FensterUeberwachung: setForeignState(id=javascript.0.FensterUeberwachung.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1048 Tage 2 Std. 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Büro<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1054 Tage 22 Std. 36 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Flur<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1048 Tage 2 Std. 18 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gäste Wc<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1054 Tage 23 Std. 54 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gästezimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1054 Tage 23 Std. 54 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Garage<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1048 Tage 22 Std. 48 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Küche<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1048 Tage 2 Std. 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1048 Tage 2 Std. 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Wohnzimmer<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1048 Tage 22 Std. 49 Min.</div></td></tr></tbody></table>","ack":true,"ts":1787048366054,"q":0,"from":"system.adapter.javascript.0","lc":1787048366054,"c":"script.js.common.FensterUeberwachung"}) 2026-08-18 12:19:26.215 - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching CheckDeadBatt() 2026-08-18 12:19:26.220 - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching MakeTable 2026-08-18 12:19:26.224 - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching MakeJSONTable============= Mark until here for C&P =============
iob diag has finished.
Pakete lassen sich jetzt wieder über die vis laden /Installieren.
Habe folgendes gemacht:
Mit diesem Befehl habe ich die verzeichnise die ich umbenennen sollte gelöscht. Hat auch geklappt.
for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/};gefunden im iobroker forum
https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2> -
hi, ich denke ich habe ein Berechtigungsproblem. Es ist doch nicht normal das beim fix eine userabfrage kommt oder?
Da war im Grunde nur der Punkt:
anzugehen. Wenn da jetzt 0 steht, alles i. O.
Und lass halt die Finger von sudo in Verbindung mit dem ioBroker.
