<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Abfrage des users beim Ausführen des Fix´s]]></title><description><![CDATA[<p dir="auto">Hi,<br />
scheinbar habe ich ein Berechtigung Problem.<br />
wenn ich folgendes ausführe kommt das:<br />
sudo iob stop<br />
Sudo curl -sL <a href="https://iobroker.net/fix.sh" rel="nofollow ugc">https://iobroker.net/fix.sh</a> | bash -<br />
dann kommt bei punkt 5 die Abfrage des users und des Passworts.</p>
<pre><code>juergen@iobroker:~$ curl -sL https://iobroker.net/fix.sh | bash -
library: loaded
Library version=2026-04-11
    Welcome to the ioBroker installation fixer!
    Script version: 2025-09-18
    You might need to enter your password a couple of times.
    Installing prerequisites (1/5)
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://security.debian.org/debian-security trixie-security InRelease
Hit:3 http://deb.debian.org/debian trixie-updates InRelease
Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
Get:5 https://repos.influxdata.com/debian stable InRelease [6,922 B]
Fetched 6,922 B in 0s (26.2 kB/s)
Reading package lists... Done
    Checking ioBroker user and directory permissions (2/5)
Created /etc/sudoers.d/iobroker
ACL enabled: true
    Check and cleanup npm temporary directories (3/5)
Done.
    Database maintenance (4/5)
Checking for uncompressed JSONL databases... This might take a while!
Compressing /opt/iobroker/iobroker-data/states.jsonl
Compressing /opt/iobroker/iobroker-data/objects.jsonl
Compressed 2 JSONL files. Done
    Checking autostart (5/5)
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
Authentication is required to stop 'iobroker.service'.
Multiple identities can be used for authentication:
 1.  juergen,,, (juergen)
 2.  ioadmin
Choose identity to authenticate as (1-2):
</code></pre>
<p dir="auto">Bei iob Diag sagt er mir ich soll den Fix ausführen:</p>
<pre><code>Temp directories causing deletion problem: 1
Some problems detected, please run 'iob fix'
</code></pre>
<p dir="auto">Alles andere im Diag ist grün. Ich kann auch keine Pakete mehr über iobroker aktualisieren. Nur noch über Puttyy und dann</p>
<pre><code>iob update
iob upgrade
</code></pre>
<p dir="auto">jemand eine Idee?<br />
System ist auf dem aktuellen Stand.<br />
npm 10.9.8<br />
Node.js 22.23.2</p>
]]></description><link>https://forum.iobroker.net/topic/85189/abfrage-des-users-beim-ausführen-des-fix-s</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 17:29:07 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85189.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Aug 2026 08:36:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 11:43:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alero" aria-label="Profile: Alero">@<bdi>Alero</bdi></a></p>
<p dir="auto">Da war im Grunde nur der Punkt:</p>
<blockquote>
<p dir="auto">Pending systemupdates: 2</p>
</blockquote>
<p dir="auto">anzugehen. Wenn da jetzt 0 steht, alles i. O.</p>
<p dir="auto">Und lass halt die Finger von sudo in Verbindung mit dem ioBroker.</p>
]]></description><link>https://forum.iobroker.net/post/1351845</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351845</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 11:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 11:34:10 GMT]]></title><description><![CDATA[<p dir="auto">hi, iob diag ausgeführt . alles grün.<br />
Bei bedarf poste ich auch gerne auch den code</p>
]]></description><link>https://forum.iobroker.net/post/1351844</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351844</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 11:34:10 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 11:34:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alero" aria-label="Profile: Alero">@<bdi>Alero</bdi></a> <a href="/post/1351835">sagte</a>:</p>
<p dir="auto">Es ist doch nicht normal das beim fix eine userabfrage kommt oder?</p>
</blockquote>
<p dir="auto">Natürlich.</p>
]]></description><link>https://forum.iobroker.net/post/1351843</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351843</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 11:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 11:30:50 GMT]]></title><description><![CDATA[<p dir="auto">iob fix ausgeführt . immer noch die Abfrage nach user und passwort</p>
]]></description><link>https://forum.iobroker.net/post/1351842</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351842</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 11:30:50 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 10:56:04 GMT]]></title><description><![CDATA[<p dir="auto">updates ausgeführt</p>
]]></description><link>https://forum.iobroker.net/post/1351836</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351836</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 10:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 10:55:54 GMT]]></title><description><![CDATA[<p dir="auto">hi, ich denke ich habe ein Berechtigungsproblem.  Es ist doch nicht normal das beim fix eine userabfrage kommt oder?</p>
]]></description><link>https://forum.iobroker.net/post/1351835</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351835</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 10:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 10:31:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alero" aria-label="Profile: Alero">@<bdi>Alero</bdi></a> <a href="/post/1351830">sagte</a>:</p>
<p dir="auto">Habe folgendes gemacht:<br />
Mit diesem Befehl habe ich die verzeichnise die ich umbenennen sollte gelöscht. Hat auch geklappt.</p>
</blockquote>
<p dir="auto">Das gleiche Kommando ist auch im</p>
<pre><code>iob fix
</code></pre>
<p dir="auto">enthalten.</p>
<blockquote>
</blockquote>
<p dir="auto">Installier die beiden Updates.</p>
]]></description><link>https://forum.iobroker.net/post/1351831</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351831</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 10:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 10:22:54 GMT]]></title><description><![CDATA[<p dir="auto">Pakete lassen sich jetzt wieder über die vis laden /Installieren.<br />
Mit diesem Befehl habe ich die verzeichnise die ich umbenennen sollte gelöscht. Hat auch geklappt.<br />
for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/};</p>
<p dir="auto">gefunden im iobroker forum<br />
<a href="https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2">https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2</a>&gt;</p>
]]></description><link>https://forum.iobroker.net/post/1351830</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351830</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 10:22:54 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 10:20:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> <a href="/post/1351827">sagte</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alero" aria-label="Profile: Alero">@<bdi>Alero</bdi></a> <a href="/post/1351815">sagte</a>:</p>
<p dir="auto">Alles andere im Diag ist grün.</p>
</blockquote>
<p dir="auto">Zeig mal den vollständigen Output von</p>
<pre><code>iob diag
</code></pre>
<p dir="auto">dann.</p>
</blockquote>
<pre><code>========== Start marking the full check here ===========
```bash
Script v.2026-06-06
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: iobroker
       Icon name: computer-vm
         Chassis: vm 🖴
  Virtualization: kvm
          Kernel: Linux 6.12.63+deb13-amd64
    Architecture: x86-64
 Hardware Vendor: QEMU
  Hardware Model: Standard PC _i440FX + PIIX, 1996_
Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
   Firmware Date: Tue 2014-04-01
    Firmware Age: 12y 4month 2w 3d
OS is similar to:
model name      : QEMU Virtual CPU version 2.5+
Docker          : false
Virtualization  : kvm
Kernel          : x86_64
Userland        : 64bit
System was installed 157 days ago (on 2026-03-13).
Systemuptime and Load:
 12:19:07 up  1:39,  1 user,  load average: 0.51, 0.32, 0.43
CPU threads     : 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** TIME AND TIMEZONES ***
               Local time: Tue 2026-08-18 12:19:07 CEST
           Universal time: Tue 2026-08-18 10:19:07 UTC
                 RTC time: Tue 2026-08-18 10:19:07
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
juergen
HOME=/home/juergen
GROUPS=juergen adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
iobroker
HOME=/home/iobroker
GROUPS=iobroker tty dialout audio video plugdev
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:                tty
Boot Target:            multi-user.target
*** MEMORY ***
Mem:            8.3G        4.6G        2.7G        7.7M        1.4G        3.8G
Swap:           5.5G          0B        5.5G
Total:           13G        4.6G        8.2G
Active iob-Instances:   35
         7947 M total memory
         4363 M used memory
         3838 M active memory
         1006 M inactive memory
         2574 M free memory
          153 M buffer memory
         1206 M swap cache
         5237 M total swap
            0 M used swap
         5237 M free swap
top - 12:19:08 up  1:39,  1 user,  load average: 0.51, 0.32, 0.43
Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
%Cpu(s):  4.8 us,  2.4 sy,  0.0 ni, 92.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7947.3 total,   2573.5 free,   4364.0 used,   1359.4 buff/cache
MiB Swap:   5238.0 total,   5238.0 free,      0.0 used.   3583.3 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  3.9G     0  3.9G   0% /dev
tmpfs          tmpfs     795M  496K  795M   1% /run
/dev/sda1      ext4       93G  6.9G   82G   8% /
tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs          tmpfs     3.9G  6.9M  3.9G   1% /tmp
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1000
Messages concerning filesystems in dmesg:
[Tue Aug 18 10:39:41 2026] EXT4-fs (sda1): orphan cleanup on readonly fs
[Tue Aug 18 10:39:41 2026] EXT4-fs (sda1): mounted filesystem ad7cb7c3-87c0-4151-8142-0f5900745d4e ro with ordered data mode. Quota mode: none.
[Tue Aug 18 10:39:42 2026] EXT4-fs (sda1): re-mounted ad7cb7c3-87c0-4151-8142-0f5900745d4e r/w.
Show mounted filesystems:
TARGET SOURCE    FSTYPE OPTIONS
/      /dev/sda1 ext4   rw,relatime,errors=remount-ro
/var:
745M    /var/
376M    /var/cache
368M    /var/cache/apt
277M    /var/cache/apt/archives
192M    /var/log
Archived and active journals take up 177M in the file system.
/opt/iobroker/backups:
16M     /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
859M    /opt/iobroker/iobroker-data/
602M    /opt/iobroker/iobroker-data/files
135M    /opt/iobroker/iobroker-data/backup-objects
78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
68M     /opt/iobroker/iobroker-data/files/vis
46M     /opt/iobroker/iobroker-data/states.jsonl
31M     /opt/iobroker/iobroker-data/objects.jsonl
30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
No Devices found 'by-id'
No nvbackup.json found.
*** NodeJS-Installation ***
/usr/bin/nodejs         v22.23.2
/usr/bin/node           v22.23.2
/usr/bin/npm            10.9.8
/usr/bin/npx            10.9.8
✓ Node.js installation is correct
nodejs:
  Installed: 22.23.2-1nodesource1
  Candidate: 22.23.2-1nodesource1
  Version table:
 *** 22.23.2-1nodesource1 1001
        500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
        100 /var/lib/dpkg/status
     22.23.1-1nodesource1 1001
     22.23.0-1nodesource1 1001
     22.22.3-1nodesource1 1001
     22.22.2-1nodesource1 1001
     22.22.1-1nodesource1 1001
     22.22.0-1nodesource1 1001
     22.21.0-1nodesource1 1001
     22.20.0-1nodesource1 1001
     22.19.0-1nodesource1 1001
     22.18.0-1nodesource1 1001
     22.17.1-1nodesource1 1001
     22.17.0-1nodesource1 1001
     22.16.0-1nodesource1 1001
     22.15.1-1nodesource1 1001
     22.15.0-1nodesource1 1001
     22.14.0-1nodesource1 1001
     22.13.1-1nodesource1 1001
     22.13.0-1nodesource1 1001
     22.12.0-1nodesource1 1001
     22.11.0-1nodesource1 1001
     22.10.0-1nodesource1 1001
     22.9.0-1nodesource1 1001
     22.8.0-1nodesource1 1001
     22.7.0-1nodesource1 1001
     22.6.0-1nodesource1 1001
     22.5.1-1nodesource1 1001
     22.5.0-1nodesource1 1001
     22.4.1-1nodesource1 1001
     22.4.0-1nodesource1 1001
     22.3.0-1nodesource1 1001
     22.2.0-1nodesource1 1001
     22.1.0-1nodesource1 1001
     22.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian trixie/main amd64 Packages
        500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
No problems detected
Errors in npm tree: 0
No known Vulnerabilities detected!
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 3842)
Core adapters versions
js-controller:  7.2.2
admin:          7.8.23
javascript:     9.0.18
nodejs modules from github:     1
| +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
Adapter State
+ system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
  system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
+ system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
  system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
+ system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
  system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
  system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
  system.adapter.email.0                  : email                 : iobroker                                 - disabled
+ system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
+ system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
  system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
+ system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
+ system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
  system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 - disabled
  system.adapter.history.0                : history               : iobroker                                 - disabled
+ system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
+ system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
+ system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
+ system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
  system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
  system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
+ system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
+ system.adapter.info.0                   : info                  : iobroker                                 - disabled
+ system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
+ system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
+ system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.42.15
+ system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.42.15
+ system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.42.15
+ system.adapter.mqtt.4                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.42.15
+ system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 192.168.42.15
  system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
+ system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
  system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
+ system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
  system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
+ system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
+ system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 192.168.42.15
+ system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
+ system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
  system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
  system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 192.168.42.15, run as: admin
  system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1883, bind: 192.168.42.15
  system.adapter.sonoff.1                 : sonoff                : iobroker                                 - disabled, port: 1884, bind: 192.168.42.15
  system.adapter.sonoff.2                 : sonoff                : iobroker                                 - disabled, port: 1888, bind: 0.0.0.0
+ system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
  system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5001
+ system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
+ system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
+ system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
  system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
  system.adapter.text2command.1           : text2command          : iobroker                                 - disabled
+ system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
  system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
  system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
  system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
  system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
  system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
  system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
  system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
+ system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
  system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
+ instance is alive
ioBroker-Repositories
│ (index) │ name               │ url                                                     │ auto upgrade │
│ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
│ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                           │ name                          │ version  │ upgrade policy │
│ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
│ 1       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17' │ 'none'         │
│ 2       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '6.1.0'  │ 'none'         │
│ 3       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
│ 4       │ 'system.adapter.device-reminder'             │ 'device-reminder'             │ '3.1.2'  │ 'none'         │
│ 5       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
│ 6       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
│ 7       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
│ 8       │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
│ 9       │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'  │ 'none'         │
│ 10      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.1'  │ 'none'         │
│ 11      │ 'system.adapter.fb-checkpresence'            │ 'fb-checkpresence'            │ '1.4.2'  │ 'none'         │
│ 12      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
│ 13      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
│ 14      │ 'system.adapter.fritzbox'                    │ 'fritzbox'                    │ '0.7.0'  │ 'none'         │
│ 15      │ 'system.adapter.fritzdect'                   │ 'fritzdect'                   │ '2.6.2'  │ 'none'         │
│ 16      │ 'system.adapter.fullcalendar'                │ 'fullcalendar'                │ '2.4.5'  │ 'none'         │
│ 17      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
│ 18      │ 'system.adapter.hm-rega'                     │ 'hm-rega'                     │ '5.1.0'  │ 'none'         │
│ 19      │ 'system.adapter.hm-rpc'                      │ 'hm-rpc'                      │ '3.0.1'  │ 'none'         │
│ 20      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.21.0' │ 'none'         │
│ 21      │ 'system.adapter.icons-fatcow-hosting'        │ 'icons-fatcow-hosting'        │ '0.1.0'  │ 'none'         │
│ 22      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
│ 23      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
│ 24      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
│ 25      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
│ 26      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
│ 27      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
│ 28      │ 'system.adapter.info'                        │ 'info'                        │ '2.0.0'  │ 'none'         │
│ 29      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
│ 30      │ 'system.adapter.melcloud'                    │ 'melcloud'                    │ '3.0.4'  │ 'none'         │
│ 31      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'  │ 'none'         │
│ 32      │ 'system.adapter.node-red'                    │ 'node-red'                    │ '6.0.7'  │ 'none'         │
│ 33      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.6.1'  │ 'none'         │
│ 34      │ 'system.adapter.pvforecast'                  │ 'pvforecast'                  │ '6.1.0'  │ 'none'         │
│ 35      │ 'system.adapter.radar2'                      │ 'radar2'                      │ '2.4.0'  │ 'none'         │
│ 36      │ 'system.adapter.rpi2'                        │ 'rpi2'                        │ '2.4.0'  │ 'none'         │
│ 37      │ 'system.adapter.sayit'                       │ 'sayit'                       │ '5.1.0'  │ 'none'         │
│ 38      │ 'system.adapter.scenes'                      │ 'scenes'                      │ '4.0.4'  │ 'none'         │
│ 39      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
│ 40      │ 'system.adapter.shuttercontrol'              │ 'shuttercontrol'              │ '2.0.12' │ 'none'         │
│ 41      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
│ 42      │ 'system.adapter.snmp'                        │ 'snmp'                        │ '3.4.0'  │ 'none'         │
│ 43      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
│ 44      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'  │ 'none'         │
│ 45      │ 'system.adapter.sonos'                       │ 'sonos'                       │ '3.0.0'  │ 'none'         │
│ 46      │ 'system.adapter.sourceanalytix'              │ 'sourceanalytix'              │ '0.4.14' │ 'none'         │
│ 47      │ 'system.adapter.synology'                    │ 'synology'                    │ '3.1.0'  │ 'none'         │
│ 48      │ 'system.adapter.systeminfo'                  │ 'systeminfo'                  │ '1.3.0'  │ 'none'         │
│ 49      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
│ 50      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '4.1.0'  │ 'none'         │
│ 51      │ 'system.adapter.text2command'                │ 'text2command'                │ '4.0.0'  │ 'none'         │
│ 52      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
│ 53      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
│ 54      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
│ 55      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
│ 56      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
│ 57      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'  │ 'none'         │
│ 58      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
│ 59      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.6' │ 'none'         │
│ 60      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'  │ 'none'         │
│ 61      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
│ 62      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
│ 63      │ 'system.adapter.vis-material'                │ 'vis-material'                │ '0.2.0'  │ 'none'         │
│ 64      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
│ 65      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
│ 66      │ 'system.adapter.vis-metro'                   │ 'vis-metro'                   │ '1.2.0'  │ 'none'         │
│ 67      │ 'system.adapter.vis-players'                 │ 'vis-players'                 │ '0.1.6'  │ 'none'         │
│ 68      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
│ 69      │ 'system.adapter.vis-weather'                 │ 'vis-weather'                 │ '2.5.13' │ 'none'         │
│ 70      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
│ 71      │ 'system.adapter.whatsapp-cmb'                │ 'whatsapp-cmb'                │ '0.3.0'  │ 'none'         │
│ 72      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
ioBroker-Adapter Versions and update status
Adapter    "admin"        : 7.8.23   , installed 7.8.23
Adapter    "backitup"     : 3.3.17   , installed 3.3.17
Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
Adapter    "device-reminder": 3.1.2  , installed 3.1.2
Adapter    "echarts"      : 3.1.0    , installed 3.1.0
Adapter    "email"        : 2.0.4    , installed 2.0.4
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
Adapter    "fritzbox"     : 0.7.0    , installed 0.7.0
Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
Adapter    "history"      : 4.0.0    , installed 4.0.0
Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
Adapter    "ical"         : 1.21.0   , installed 1.21.0
Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
Adapter    "javascript"   : 9.0.18   , installed 9.0.18
Controller "js-controller": 7.2.2    , installed 7.2.2
Adapter    "melcloud"     : 3.0.4    , installed 3.0.4
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "node-red"     : 6.0.7    , installed 6.0.7
Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
Adapter    "radar2"       : 2.4.0    , installed 2.4.0
Adapter    "sayit"        : 5.1.0    , installed 5.1.0
Adapter    "scenes"       : 4.0.4    , installed 4.0.4
Adapter    "shelly"       : 10.6.1   , installed 10.6.1
Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "snmp"         : 3.4.0    , installed 3.4.0
Adapter    "socketio"     : 7.1.3    , installed 7.1.3
Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
Adapter    "sonos"        : 3.0.0    , installed 3.0.0
Adapter    "synology"     : 3.1.0    , installed 3.1.0
Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
Adapter    "text2command" : 4.0.0    , installed 4.0.0
Adapter    "upnp"         : 1.1.0    , installed 1.1.0
Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
Adapter    "vis-material" : 0.2.0    , installed 0.2.0
Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Objects and States
Objects:        22757
States:         21925
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://security.debian.org/debian-security trixie-security InRelease
Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B]
Fetched 6922 B in 0s (28.3 kB/s)
*** Listening Ports ***
Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
udp   UNCONN 0      0      192.168.42.15:mdns        0.0.0.0:*    users:(("io.tr-064.0",pid=14298,fd=70))
udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=524,fd=5),("systemd",pid=1,fd=96))
udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=524,fd=7),("systemd",pid=1,fd=98))
tcp   LISTEN 0      511    192.168.42.15:1888        0.0.0.0:*    users:(("io.mqtt.4",pid=14066,fd=35))
tcp   LISTEN 0      511    192.168.42.15:1884        0.0.0.0:*    users:(("io.mqtt.1",pid=14014,fd=35))
tcp   LISTEN 0      511    192.168.42.15:1886        0.0.0.0:*    users:(("io.mqtt.2",pid=16722,fd=35))
tcp   LISTEN 0      511    192.168.42.15:1880        0.0.0.0:*    users:(("node-red",pid=13140,fd=23))
tcp   LISTEN 0      511    192.168.42.15:1881        0.0.0.0:*    users:(("io.shelly.0",pid=14083,fd=37))
tcp   LISTEN 0      511    192.168.42.15:1883        0.0.0.0:*    users:(("io.mqtt.3",pid=14049,fd=35))
tcp   LISTEN 0      511    192.168.42.15:42001       0.0.0.0:*    users:(("io.hm-rpc.0",pid=13776,fd=35))
tcp   LISTEN 0      511    192.168.42.15:42010       0.0.0.0:*    users:(("io.hm-rpc.1",pid=13823,fd=35))
tcp   LISTEN 0      511    192.168.42.15:8701        0.0.0.0:*    users:(("io.hm-rpc.2",pid=13946,fd=35))
tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=685,fd=6))
tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=524,fd=4),("systemd",pid=1,fd=95))
tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=12838,fd=23))
tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=12838,fd=29))
tcp   LISTEN 0      511                *:3500              *:*    users:(("io.sonos.0",pid=14117,fd=31))
tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.1",pid=12866,fd=40))
tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=15930,fd=35))
tcp   LISTEN 0      511                *:8087              *:*    users:(("io.simple-api.0",pid=14469,fd=35))
tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=685,fd=7))
tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=524,fd=6),("systemd",pid=1,fd=97))
2026-08-18 12:19:04.736  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/
2026-08-18 12:19:04.736  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/
2026-08-18 12:19:04.739  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_relative/
2026-08-18 12:19:04.739  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_relative/
2026-08-18 12:19:04.745  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_persistent_absolute/
2026-08-18 12:19:04.745  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_absolute/
2026-08-18 12:19:04.765  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative" with regex /solar\.[^.]*\.cmd\.limit_persistent_relative/
2026-08-18 12:19:04.765  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_relative/
2026-08-18 12:19:04.767  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /solar\.[^.]*\.cmd\.power/
2026-08-18 12:19:04.767  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.power/
2026-08-18 12:19:04.767  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/reset_rf_stats" with regex /solar\.[^.]*\.cmd\.reset_rf_stats/
2026-08-18 12:19:04.767  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/reset_rf_stats"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.reset_rf_stats/
2026-08-18 12:19:04.768  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /solar\.[^.]*\.cmd\.restart/
2026-08-18 12:19:04.768  - info: mqtt.2 (16722) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.restart/
2026-08-18 12:19:04.937  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:04.940  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:04.946  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:04.964  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:04.967  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:04.968  - info: mqtt.2 (16722) Client [OpenDTU-4876280] publishOnSubscribe send all known states
2026-08-18 12:19:26.054  - info: javascript.0 (12977) script.js.common.FensterUeberwachung: setForeignState(id=javascript.0.FensterUeberwachung.OverviewTable, state={"val":"&lt;table style='width:100%; border-collapse: collapse; border: 0px solid black;'&gt;&lt;tr&gt;&lt;td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;table style='width:100%; border-collapse: collapse;'&gt;&lt;thead&gt;&lt;tr&gt;&lt;th width='40px' style='text-align:left;'&lt;/th&gt;&lt;th width='40px' style='text-align:left;'&lt;/th&gt;&lt;th width='20px' style='text-align:center;'&gt;&lt;/th&gt;&lt;th style='text-align:left;'&gt;&lt;/th&gt;&lt;/tr&gt;&lt;/thead&gt;&lt;tbody&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Bad&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1048 Tage 2 Std. 23 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Büro&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1054 Tage 22 Std. 36 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Flur&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Tür geschlossen: 1048 Tage 2 Std. 18 Min.&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Gäste Wc&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1054 Tage 23 Std. 54 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Gästezimmer&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1054 Tage 23 Std. 54 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Garage&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Tür geschlossen: 1048 Tage 22 Std. 48 Min.&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Küche&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1048 Tage 2 Std. 23 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;br&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Schlafzimmer&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Fenster geschlossen: 1048 Tage 2 Std. 23 Min.&lt;br&gt;&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td colspan='2' style='border: 1px solid black; background-color:#4caf50;'&gt;&lt;img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'&gt;&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'&gt;0&lt;/td&gt;&lt;td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'&gt;Wohnzimmer&lt;br&gt;&lt;div style='font-size:12px; font-weight:normal;'&gt;Tür geschlossen: 1048 Tage 22 Std. 49 Min.&lt;/div&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/tbody&gt;&lt;/table&gt;","ack":true,"ts":1787048366054,"q":0,"from":"system.adapter.javascript.0","lc":1787048366054,"c":"script.js.common.FensterUeberwachung"})
2026-08-18 12:19:26.215  - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching CheckDeadBatt()
2026-08-18 12:19:26.220  - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching MakeTable
2026-08-18 12:19:26.224  - info: javascript.0 (12977) script.js.common.BatterieUeberwachung_1_8_7: Reaching MakeJSONTable
</code></pre>
<p dir="auto">============= Mark until here for C&amp;P =============</p>
<p dir="auto">iob diag has finished.</p>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/post/1351829</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351829</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 10:20:08 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 09:58:34 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<pre><code>iob diag
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1351827</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351827</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 09:58:34 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 09:57:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dann kommt bei punkt 5 die Abfrage des users und des Passworts.</p>
</blockquote>
<p dir="auto">Nein, da kommt zunächst mal die Anfrage, welcher user denn dazu verwendet werden soll:</p>
<blockquote>
<p dir="auto">==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====<br />
Authentication is required to stop 'iobroker.service'.<br />
Multiple identities can be used for authentication:</p>
<ol>
<li>juergen,,, (juergen)</li>
<li>ioadmin<br />
Choose identity to authenticate as (1-2):</li>
</ol>
</blockquote>
<p dir="auto">Offenbar hast du also mehrere user angelegt. Welche Rechte haben die im Einzelnen?</p>
]]></description><link>https://forum.iobroker.net/post/1351825</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351825</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 09:57:26 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 09:42:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alero" aria-label="Profile: Alero">@<bdi>Alero</bdi></a></p>
<p dir="auto">Nie, nie, nie iob mit sudo anpacken. Nie!</p>
]]></description><link>https://forum.iobroker.net/post/1351824</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351824</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Aug 2026 09:42:03 GMT</pubDate></item><item><title><![CDATA[Reply to Abfrage des users beim Ausführen des Fix´s on Tue, 18 Aug 2026 09:07:26 GMT]]></title><description><![CDATA[<p dir="auto">Ein Problem gelöst wenn ich "sudo" vor den curl -sL <a href="https://iobroker.net/fix.sh" rel="nofollow ugc">https://iobroker.net/fix.sh</a> | bash -<br />
fehl curl -sL <a href="https://iobroker.net/fix.sh" rel="nofollow ugc">https://iobroker.net/fix.sh</a> | bash -<br />
dann klappt es einmal . danach wieder die Abfrage nach user und Passwort</p>
]]></description><link>https://forum.iobroker.net/post/1351817</link><guid isPermaLink="true">https://forum.iobroker.net/post/1351817</guid><dc:creator><![CDATA[Alero]]></dc:creator><pubDate>Tue, 18 Aug 2026 09:07:26 GMT</pubDate></item></channel></rss>
