  4. ESP Home Fehlermeldung
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
86 Beiträge 7 Kommentatoren 4.9k Aufrufe 4 Beobachtet
    SuFra
    schrieb am zuletzt editiert von SuFra
    • Adaptername: esphome
    • Link zu Adapterrepository: https://github.com/DrozmotiX/ioBroker.esphome
    • Adapterversion: v0.7.0
    • js-controller Version: 7.2.2
    • Admin Version: 7.8.23
    PlatformBetriebssystem:linux
    Architektur:x64
    CPUs:4
    Geschwindigkeit:0 MHz
    Modell:QEMU Virtual CPU version 2.5+
    RAM:11.6 GB
    System-Betriebszeit:1 T. 17:24:46
    Node.js:v22.23.1
    Zeit:1783248700130
    Zeitversatz:-120
    NPM:10.9.8
    Adapter-Anzahl:624
    Datenträgergröße:27.7 GB
    Freier Festplattenspeicher:20.3 GB
    Aktive Instanzen:29
    Pfad:/opt/iobroker/
    Betriebszeit:1 T. 17:24:39
    aktiv:true
    _nodeCurrent:22.23.1
    _npmCurrent:10.9.8
    Linux User bitte hier den Output von iob diag einfügen.
    bash
    Script v.2026-06-06
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iob
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.12.94+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 3month 4d
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64bit
    System was installed 588 days ago (on 2024-11-23).
    Systemuptime and Load:
     13:00:08 up 1 day, 17:33,  1 user,  load average: 0.16, 0.11, 0.10
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-07-05 13:00:08 CEST
               Universal time: Sun 2026-07-05 11:00:08 UTC
                     RTC time: Sun 2026-07-05 11:00:08
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    frank
    HOME=/home/frank
    GROUPS=frank adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:             12G        4.5G        7.4G        3.2M        924M        8.1G
    Swap:           4.0G          0B        4.0G
    Total:           16G        4.5G         11G
    Active iob-Instances:   30
            11967 M total memory
             4264 M used memory
             3929 M active memory
              617 M inactive memory
             7082 M free memory
              166 M buffer memory
              715 M swap cache
             3813 M total swap
                0 M used swap
             3813 M free swap
    top - 13:00:08 up 1 day, 17:33,  1 user,  load average: 0.15, 0.11, 0.09
    Tasks: 150 total,   1 running, 149 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.2 sy,  0.0 ni, 95.6 id,  2.2 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11967.3 total,   7079.3 free,   4267.7 used,    882.6 buff/cache
    MiB Swap:   3814.0 total,   3814.0 free,      0.0 used.   7699.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.9G     0  5.9G   0% /dev
    tmpfs          tmpfs     1.2G  504K  1.2G   1% /run
    /dev/sda2      ext4       28G  7.4G   19G  28% /
    tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     5.9G  2.6M  5.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.2G  8.0K  1.2G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Fri Jul  3 19:26:55 2026] EXT4-fs (sda2): mounted filesystem e6aca371-219c-419f-8f50-48cdcc9f5c97 ro with ordered data mode. Quota mode: none.
    [Fri Jul  3 19:26:56 2026] EXT4-fs (sda2): re-mounted e6aca371-219c-419f-8f50-48cdcc9f5c97 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda2 ext4   rw,relatime,errors=remount-ro
    /var:
    926M    /var/
    490M    /var/log
    475M    /var/log/journal/c8098ef4e0db45229e11085705e90f90
    245M    /var/cache
    Archived and active journals take up 474.3M in the file system.
    /opt/iobroker/backups:
    148M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    527M    /opt/iobroker/iobroker-data/
    306M    /opt/iobroker/iobroker-data/files
    172M    /opt/iobroker/iobroker-data/backup-objects
    82M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/states.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        tcp://10.10.20.225:6638             -                                   tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.23.1
    /usr/bin/node           v22.23.1
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.1-1nodesource1
      Candidate: 22.23.1-1nodesource1
      Version table:
     *** 22.23.1-1nodesource1 1001
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iob                 iob (version: 7.2.2, hostname: iob           , alive, uptime: 149602)
    Core adapters versions
    js-controller:  7.2.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : iob                                      -  enabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iob                                      -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iob                                      - disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iob                                      -  enabled
    + system.adapter.backitup.0               : backitup              : iob                                      -  enabled
    + system.adapter.brightsky.0              : brightsky             : iob                                      -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : iob                                      -  enabled
      system.adapter.devices.0                : devices               : iob                                      - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob                                      -  enabled
    + system.adapter.esphome.0                : esphome               : iob                                      -  enabled
      system.adapter.flot.0                   : flot                  : iob                                      - disabled
      system.adapter.frigate.0                : frigate               : iob                                      - disabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iob                                      -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob                                      -  enabled
    + system.adapter.iot.0                    : iot                   : iob                                      -  enabled
    + system.adapter.javascript.0             : javascript            : iob                                      -  enabled
      system.adapter.linktap.0                : linktap               : iob                                      - disabled
    + system.adapter.modbus.0                 : modbus                : iob                                      -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iob                                      -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iob                                      -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iob                                      -  enabled
    + system.adapter.nut.0                    : nut                   : iob                                      -  enabled
    + system.adapter.nut.1                    : nut                   : iob                                      -  enabled
    + system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarwetter.0            : solarwetter           : iob                                      -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iob                                      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : iob                                      -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iob                                      -  enabled, port: 3306
    + system.adapter.sql.2                    : sql                   : iob                                      -  enabled, port: 3306
    + system.adapter.sql.3                    : sql                   : iob                                      -  enabled, port: 3306
    + system.adapter.statistics.0             : statistics            : iob                                      -  enabled
    + system.adapter.tahoma.0                 : tahoma                : iob                                      -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iob                                      -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iob                                      -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iob                                      -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iob                                      -  enabled
      system.adapter.vis.0                    : vis                   : iob                                      -  enabled
    + system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iob                                      -  enabled, port: tcp://10.10.20.225:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                        │ name                       │ version   │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                    │ 'admin'                    │ '7.8.23'  │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'                   │ 'alexa2'                   │ '3.27.4'  │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'            │ 'alias-manager'            │ '2.1.0'   │ 'none'         │
    │ 3       │ 'system.adapter.awtrix-light'             │ 'awtrix-light'             │ '3.0.0'   │ 'none'         │
    │ 4       │ 'system.adapter.backitup'                 │ 'backitup'                 │ '3.3.17'  │ 'none'         │
    │ 5       │ 'system.adapter.brightsky'                │ 'brightsky'                │ '1.0.1'   │ 'none'         │
    │ 6       │ 'system.adapter.chromecast'               │ 'chromecast'               │ '4.0.0'   │ 'none'         │
    │ 7       │ 'system.adapter.daikin-cloud'             │ 'daikin-cloud'             │ '0.4.12'  │ 'none'         │
    │ 8       │ 'system.adapter.devices'                  │ 'devices'                  │ '1.2.14'  │ 'none'         │
    │ 9       │ 'system.adapter.energiefluss-erweitert'   │ 'energiefluss-erweitert'   │ '0.8.1'   │ 'none'         │
    │ 10      │ 'system.adapter.esphome'                  │ 'esphome'                  │ '0.6.3'   │ 'none'         │
    │ 11      │ 'system.adapter.flot'                     │ 'flot'                     │ '1.12.0'  │ 'none'         │
    │ 12      │ 'system.adapter.frigate'                  │ 'frigate'                  │ '1.4.0'   │ 'none'         │
    │ 13      │ 'system.adapter.heatingcontrol'           │ 'heatingcontrol'           │ '2.12.19' │ 'none'         │
    │ 14      │ 'system.adapter.icons-mfd-png'            │ 'icons-mfd-png'            │ '1.2.1'   │ 'none'         │
    │ 15      │ 'system.adapter.iot'                      │ 'iot'                      │ '6.0.3'   │ 'none'         │
    │ 16      │ 'system.adapter.javascript'               │ 'javascript'               │ '9.0.18'  │ 'none'         │
    │ 17      │ 'system.adapter.linktap'                  │ 'linktap'                  │ '1.0.3'   │ 'none'         │
    │ 18      │ 'system.adapter.modbus'                   │ 'modbus'                   │ '8.0.3'   │ 'none'         │
    │ 19      │ 'system.adapter.mqtt'                     │ 'mqtt'                     │ '6.1.4'   │ 'none'         │
    │ 20      │ 'system.adapter.nspanel-lovelace-ui'      │ 'nspanel-lovelace-ui'      │ '0.16.2'  │ 'none'         │
    │ 21      │ 'system.adapter.nut'                      │ 'nut'                      │ '1.7.0'   │ 'none'         │
    │ 22      │ 'system.adapter.shelly'                   │ 'shelly'                   │ '10.6.1'  │ 'none'         │
    │ 23      │ 'system.adapter.simple-api'               │ 'simple-api'               │ '2.8.0'   │ 'none'         │
    │ 24      │ 'system.adapter.socketio'                 │ 'socketio'                 │ '7.1.3'   │ 'none'         │
    │ 25      │ 'system.adapter.solarwetter'              │ 'solarwetter'              │ '1.2.0'   │ 'none'         │
    │ 26      │ 'system.adapter.sonoff'                   │ 'sonoff'                   │ '3.3.0'   │ 'none'         │
    │ 27      │ 'system.adapter.sql'                      │ 'sql'                      │ '3.0.1'   │ 'none'         │
    │ 28      │ 'system.adapter.statistics'               │ 'statistics'               │ '4.0.0'   │ 'none'         │
    │ 29      │ 'system.adapter.tahoma'                   │ 'tahoma'                   │ '0.10.4'  │ 'none'         │
    │ 30      │ 'system.adapter.tr-064'                   │ 'tr-064'                   │ '4.3.0'   │ 'none'         │
    │ 31      │ 'system.adapter.vis'                      │ 'vis'                      │ '1.5.6'   │ 'none'         │
    │ 32      │ 'system.adapter.vis-2'                    │ 'vis-2'                    │ '2.13.8'  │ 'none'         │
    │ 33      │ 'system.adapter.vis-2-widgets-collection' │ 'vis-2-widgets-collection' │ '1.8.1'   │ 'none'         │
    │ 34      │ 'system.adapter.vis-2-widgets-inventwo'   │ 'vis-2-widgets-inventwo'   │ '1.4.0'   │ 'none'         │
    │ 35      │ 'system.adapter.vis-2-widgets-material'   │ 'vis-2-widgets-material'   │ '1.6.1'   │ 'none'         │
    │ 36      │ 'system.adapter.web'                      │ 'web'                      │ '8.0.0'   │ 'none'         │
    │ 37      │ 'system.adapter.ws'                       │ 'ws'                       │ '4.1.0'   │ 'none'         │
    │ 38      │ 'system.adapter.zigbee'                   │ 'zigbee'                   │ '3.3.5'   │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "frigate"      : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 3.1.4   , installed 2.12.19 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "linktap"      : 1.0.3    , installed 1.0.3
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "nspanel-lovelace-ui": 0.16.2, installed 0.16.2
    Adapter    "nut"          : 1.7.0    , installed 1.7.0
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "statistics"   : 4.0.0    , installed 4.0.0
    Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-inventwo": 1.4.0, installed 1.4.0
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        12891
    States:         10145
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 1
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("io.esphome.0",pid=3019,fd=37))
    udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=510,fd=5),("systemd",pid=1,fd=45))
    udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=510,fd=7),("systemd",pid=1,fd=47))
    tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=674,fd=28))
    tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=674,fd=23))
    tcp   LISTEN 0      20         127.0.0.1:smtp        0.0.0.0:*    users:(("exim4",pid=933,fd=5))
    tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=803,fd=6))
    tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=510,fd=4),("systemd",pid=1,fd=44))
    tcp   LISTEN 0      511          0.0.0.0:1882        0.0.0.0:*    users:(("io.shelly.0",pid=1299,fd=46))
    tcp   LISTEN 0      511          0.0.0.0:1883        0.0.0.0:*    users:(("io.sonoff.0",pid=1316,fd=37))
    tcp   LISTEN 0      511          0.0.0.0:1884        0.0.0.0:*    users:(("io.mqtt.0",pid=1282,fd=35))
    tcp   LISTEN 0      511          0.0.0.0:1885        0.0.0.0:*    users:(("io.mqtt.0",pid=1282,fd=36))
    tcp   LISTEN 0      511          0.0.0.0:1886        0.0.0.0:*    users:(("io.mqtt.1",pid=1449,fd=35))
    tcp   LISTEN 0      511          0.0.0.0:1887        0.0.0.0:*    users:(("io.mqtt.1",pid=1449,fd=36))
    tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=957,fd=40))
    tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=1516,fd=34))
    tcp   LISTEN 0      511                *:8083              *:*    users:(("io.admin.1",pid=977,fd=40))
    tcp   LISTEN 0      20             [::1]:smtp           [::]:*    users:(("exim4",pid=933,fd=6))
    tcp   LISTEN 0      511                *:8883              *:*    users:(("io.nspanel-love",pid=1583,fd=35))
    tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=803,fd=7))
    tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=510,fd=6),("systemd",pid=1,fd=46))
    2026-07-05 12:55:00.007  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Drucker steht
    2026-07-05 12:55:03.715  - info: esphome.0 (3019) ESPHome client 10.10.50.42 connected
    2026-07-05 12:55:03.716  - info: esphome.0 (3019) ESPHome Device info received for sensor-balkon
    2026-07-05 12:55:03.782  - warn: esphome.0 (3019) Object 500291C24B11.info.area is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, json This will throw an error up from js-controller version 7.0.0!
    2026-07-05 12:55:03.873  - info: esphome.0 (3019) sensor-balkon announced temperature "Temperatur Balkon"
    2026-07-05 12:55:03.873  - info: esphome.0 (3019) sensor-balkon announced humidity "Luftfeuchtigkeit Balkon"
    2026-07-05 12:55:03.874  - info: esphome.0 (3019) sensor-balkon announced Sensor "Taupunkt Balkon"
    2026-07-05 12:55:03.874  - info: esphome.0 (3019) sensor-balkon announced temperature "BME280 Temperatur"
    2026-07-05 12:55:03.874  - info: esphome.0 (3019) sensor-balkon announced pressure "Luftdruck Balkon"
    2026-07-05 12:55:03.874  - info: esphome.0 (3019) sensor-balkon announced humidity "BME280 Luftfeuchtigkeit"
    2026-07-05 12:55:03.874  - info: esphome.0 (3019) ESPHome  client sensor-balkon on ip 10.10.50.42 initialized
    2026-07-05 12:55:07.789  - info: esphome.0 (3019) New ESPHome Device discovered: sensor-balkon on undefined
    2026-07-05 12:56:00.002  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: --------
    2026-07-05 12:56:00.002  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Countdown läuft
    2026-07-05 12:56:00.002  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Drucker steht
    2026-07-05 12:57:00.010  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: --------
    2026-07-05 12:57:00.010  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Countdown läuft
    2026-07-05 12:57:00.011  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Drucker steht
    2026-07-05 12:57:41.128  - info: sql.1 (1162) Do not store value "NULL" for Thermostat SchlafZi VentilStellung because no number
    2026-07-05 12:58:00.003  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: --------
    2026-07-05 12:58:00.003  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Countdown läuft
    2026-07-05 12:58:00.003  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Drucker steht
    2026-07-05 12:59:00.004  - info: javascript.0 (1080) script.js.sonst_Steuerung.MK4s: Drucker ausschalten
    2026-07-05 12:59:18.330  - info: sql.1 (1162) Do not store value "NULL" for Thermostat EssZi Ventilstellung because no number
    2026-07-05 12:59:27.553  - info: sql.1 (1162) Do not store value "NULL" for Thermostat Küche VentilStellung because no number'
    Beim Editieren in den Einstellungen von ESP Home erscheint dieser Bildschirm:
    Cannot read properties of undefined (reading 'toLowerCase')
    TypeError: Cannot read properties of undefined (reading 'toLowerCase')
        at http://10.10.30.110:8081/assets/index-5jYqkyLZ.js:2:39057
        at Array.filter (<anonymous>)
        at filterOptions (http://10.10.30.110:8081/assets/index-5jYqkyLZ.js:2:38958)
        at xi (http://10.10.30.110:8081/assets/index-D2TbHchB.js:3:23740)
        at http://10.10.30.110:8081/assets/index-D2TbHchB.js:3:42140
        at ei (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:6:16976)
        at oo (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:1576)
        at ya (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:45990)
        at va (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:39731)
        at kc (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:39662)
        at Qr (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:39521)
        at xu (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:35909)
        at wo (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:36719)
        at dn (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:6:3258)
        at Nn (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:8:37157)
        at Ho (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:5:9039)
        at Cl (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:5:33166)
        at Iu (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:5:17384)
        at uf (http://10.10.30.110:8081/assets/index-D2Em8S_O.js:5:17172)
        at HTMLDivElement.s (http://10.10.30.110:8081/assets/sdk-CcUbytYT.js:15:6192)
    Hoffe mir kann jemand helfen.
    Grüße Frank
    HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
    LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
    VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
    simonf04S 1 Antwort Letzte Antwort
    • S SuFra
      @simonf04 : Ich habe die 0.7.0 beta installiert.
      Das gleiche Verhalten, gleiche Meldungen.
      Sowohl mit Edge als auch Brave Browser.
      Sobald ich die IP Nummer versuche zu ändern kommt die Meldung.
      SuFra
      @simonf04 : Ich habe die Instanz einmal gelöscht und neu hinzugefügt.
      Jetzt funktioniert alles wieder und ich kann neue IPs eingeben.
      • S SuFra
        Architektur:x64
        CPUs:4
        RAM:11.6 GB
        Node.js:v22.23.1
        Zeit:1783248700130
        Zeitversatz:-120
        NPM:10.9.8
        Adapter-Anzahl:624
        Aktive Instanzen:29
        Pfad:/opt/iobroker/
        aktiv:true
        _npmCurrent:10.9.8
        bash
        Script v.2026-06-06
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64bit
        CPU threads     : 4
                      NTP service: active
                  RTC in local TZ: no
        frank
        HOME=/home/frank
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           4.0G          0B        4.0G
        Total:           16G        4.5G         11G
                 4264 M used memory
                 7082 M free memory
                  166 M buffer memory
                  715 M swap cache
                 3813 M total swap
                    0 M used swap
                 3813 M free swap
        *** FILESYSTEM ***
        /var:
        926M    /var/
        490M    /var/log
        245M    /var/cache
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.8
        /usr/bin/npx            10.9.8
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.8.23
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12891
        States:         10145
        Grüße Frank
        simonf04S Offline
        simonf04S Offline
        simonf04
        @SuFra sagte:
        Was hast du versucht zu editieren?
          SuFra
          @simonf04
          Die IP Nummer um ein neues Gerät hinzu zu fügen.
          • simonf04S Offline
            simonf04S Offline
            simonf04
            bitte mal 0.7.0 beta testen
            S D 2 Antworten Letzte Antwort
            • simonf04S simonf04
              SuFra
              @simonf04 mach ich heute Abend.
              • S SuFra
                SuFra
                • S SuFra
                  SuFra
                  • S SuFra has marked this topic as solved on
                  • S SuFra
                    SuFra
                    @simonf04 hatte leider doch nicht den gewünschten Erfolg, die Fehlermeldung ist wieder da.
                    Hast du einen Tipp was ich machen kann?
                    Wie kann ich das Thema wieder als "ungelöst" taggen?
                    • S SuFra
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @SuFra sagte:
                      installier den adapter komplett neu..
                      also alle instanzen löschen
                      adapter löschen
                      neu hinzufügen
                      neue instanz hinzufügen
                      • arteckA arteck
                        @SuFra sagte:
                        adapter löschen
                        neu hinzufügen
                        SuFra
                        @arteck : Habe ich gemacht.
                        Wenn ich dort die IP Nummer eingeben will crashed die GUI.
                        • S SuFra
                          andibr
                          schrieb am zuletzt editiert von andibr
                          Hallo zusammen
                          Nach bald 1 1/2 Tagen suchen und versuchen gebe ich die Hoffnung bald auf, den ESPhome Adapter wieder zum laufen zu bringen. Bei mir erscheint vielfach der Errorcode 25 aber zusätzliche eben noch
                          npm error code EALLOWGIT
                          npm error Fetching packages of type "git" have been disabled
                          npm error Refusing to fetch "github:DrozmotiX/ioBroker.esphome#...........
                          unterdessen habe ich es soweit gebracht, das ich auch keine anderen Adapter mehr installieren kann. Leider hilft auch ein "iob fix" nicht mehr. Ich wüsste aktuell nicht, dass ich irgendwo und irgendwie verboten hätte auf Git Daten zu holen, da es aber bei allen Adaptern nicht mehr funktioniert, weiss ich echt nicht mehr weiter.
                          Proxmox LXC 8Kerne 12GB Ram
                          andi@iobroker:~$ npm -v
                          12.0.1
                          andi@iobroker:~$ node -v
                          v22.23.1
                          andi@iobroker:~$ iob -v
                          7.2.2
                          python3 is already the newest version (3.13.5-1)
                          Eigentlich wollte ich ja nur rasch bei einem D1 Mini ein paar ds18B20 Sensoren dazu hängen. nicht das ich es jetzt gemusst hätte, aber ich wollte einfach die 0.7.0 mal probieren
                          Danke für eure Tips
                          Andi
                          Nachtrag:
                          noch das iob diag
                          ```bash
                          Script v.2026-06-06
                          *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer-container
                                   Chassis: container ☐
                            Virtualization: lxc
                                    Kernel: Linux 7.0.14-6-pve
                          OS is similar to:
                          model name      : 12th Gen Intel(R) Core(TM) i5-12400
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : 64bit
                          System was installed 631 days ago (on 2024-10-31).
                           15:38:37 up  1:45,  0 users,  load average: 0.10, 0.13, 0.14
                          CPU threads     : 8
                                         Local time: Sat 2026-07-25 15:38:37 CEST
                                     Universal time: Sat 2026-07-25 13:38:37 UTC
                                           RTC time: n/a
                                          Time zone: Europe/Zurich (CEST, +0200)
                                        NTP service: active
                                    RTC in local TZ: no
                          andi
                          HOME=/home/andi
                          GROUPS=andi sudo users iobroker
                          js-controller is not running
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Mem:             12G        686M         10G        5.7M        1.3G         11G
                          Swap:           8.6G          0B        8.6G
                          Total:           21G        686M         19G
                          Active iob-Instances:   1
                                  12000 M total memory
                                    655 M used memory
                                    855 M active memory
                                    799 M inactive memory
                                  10085 M free memory
                                      0 M buffer memory
                                   1264 M swap cache
                                   8191 M total swap
                                      0 M used swap
                                   8191 M free swap
                          top - 15:38:37 up  1:45,  0 users,  load average: 0.10, 0.13, 0.14
                          Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  12000.0 total,  10085.2 free,    655.5 used,   1264.7 buff/cache
                          MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  11344.5 avail Mem
                            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                          * iobroker.service        loaded failed failed ioBroker Server
                          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                  SUB    -> The low-level unit activation state, values depend on unit type.
                          3 loaded units listed.
                          dmesg: read kernel buffer failed: Operation not permitted
                          *** FILESYSTEM ***
                          Filesystem                       Type      Size  Used Avail Use% Mounted on
                          /dev/mapper/pve-vm--110--disk--0 ext4      196G   34G  153G  19% /
                          none                             tmpfs     492K  4.0K  488K   1% /dev
                          udev                             devtmpfs   15G     0   15G   0% /dev/tty
                          tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                          tmpfs                            tmpfs     6.2G  132K  6.2G   1% /run
                          tmpfs                            tmpfs      16G  5.3M   16G   1% /tmp
                          /      /dev/mapper/pve-vm--110--disk--0 ext4   rw,relatime,stripe=16
                          /var:
                          4.1G    /var/
                          3.4G    /var/lib
                          3.0G    /var/lib/mysql
                          2.8G    /var/lib/mysql/iobroker
                          465M    /var/log
                          Archived and active journals take up 50.3M in the file system.
                          9.8G    /opt/iobroker/backups/
                          8.2G    /opt/iobroker/iobroker-data/
                          5.6G    /opt/iobroker/iobroker-data/history
                          1.3G    /opt/iobroker/iobroker-data/files
                          999M    /opt/iobroker/iobroker-data/esphome.0/.esphome
                          92M     /opt/iobroker/iobroker-data/objects.json.broken
                          87M     /opt/iobroker/iobroker-data/objects.jsonl
                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          32M     /opt/iobroker/iobroker-data/states.jsonl
                          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                          USB-Devices by-id:
                          No nvbackup.json found.
                          /usr/bin/npm            12.0.1
                          /usr/bin/npx            12.0.1
                          nodejs:
                            Version table:
                                  500 http://security.debian.org trixie-security/main amd64 Packages
                          ioBroker Status
                          iobroker is not running on this host.
                          No iobroker host is running.
                          Objects type: redis
                          States  type: redis
                          Hosts:
                          iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 3795)
                          admin:          7.8.23
                          javascript:     9.0.18
                          nodejs modules from github:     4
                          +-- iobroker.enocean@0.9.4 (git+ssh://git@github.com/jey-cee/ioBroker.enocean.git#7a623c622a67ec6f723822940570dc0b36883ab2)
                          +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                          +-- iobroker.timer-switch@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.timer-switch.git#f38b114f0ed2d399b3f2665ea92a8f841727e0e5)
                          +-- iobroker.windows-control@0.1.5 (git+ssh://git@github.com/Mic-M/ioBroker.windows-control.git#8a45eabb71aa481793b24b47af456b4b17bc0447)
                          Adapter State
                            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            system.adapter.bestway.0                : bestway               : iobroker                                 -  enabled
                            system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                            system.adapter.devices.0                : devices               : iobroker                                 - disabled
                            system.adapter.discord.0                : discord               : iobroker                                 -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                            system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                            system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                            system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                            system.adapter.history.0                : history               : iobroker                                 -  enabled
                            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                            system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            system.adapter.matrix-org.0             : matrix-org            : iobroker                                 - disabled
                            system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                            system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
                            system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
                            system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
                            system.adapter.modbus.6                 : modbus                : iobroker                                 -  enabled
                            system.adapter.modbus.7                 : modbus                : iobroker                                 -  enabled
                            system.adapter.modbus.8                 : modbus                : iobroker                                 - disabled
                            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                            system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                            system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                            system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
                            system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                            system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                            system.adapter.pid.0                    : pid                   : iobroker                                 - disabled
                            system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                            system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.shelly.2                 : shelly                : iobroker                                 - disabled, port: 1888, bind: 0.0.0.0
                            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                            system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                            system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                            system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                            system.adapter.timer-switch.0           : timer-switch          : iobroker                                 -  enabled
                            system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, port: 5000
                            system.adapter.wireless-mbus.1          : wireless-mbus         : iobroker                                 -  enabled
                            system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                            system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                          + instance is alive
                          │ (index) │ name               │ url                                                     │ auto upgrade │
                          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                          │ 1       │ 'system.adapter.alias-manager'          │ 'alias-manager'          │ '2.1.0'  │ 'none'         │
                          │ 2       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17' │ 'none'         │
                          │ 3       │ 'system.adapter.bestway'                │ 'bestway'                │ '0.0.5'  │ 'none'         │
                          │ 4       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.0.1'  │ 'none'         │
                          │ 5       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.0.0'  │ 'none'         │
                          │ 6       │ 'system.adapter.devices'                │ 'devices'                │ '1.2.14' │ 'none'         │
                          │ 7       │ 'system.adapter.discord'                │ 'discord'                │ '2.6.1'  │ 'none'         │
                          │ 8       │ 'system.adapter.discovery'              │ 'discovery'              │ '5.0.0'  │ 'none'         │
                          │ 9       │ 'system.adapter.echarts'                │ 'echarts'                │ '3.1.0'  │ 'none'         │
                          │ 10      │ 'system.adapter.email'                  │ 'email'                  │ '2.0.4'  │ 'none'         │
                          │ 11      │ 'system.adapter.enocean'                │ 'enocean'                │ '0.9.4'  │ 'none'         │
                          │ 12      │ 'system.adapter.flot'                   │ 'flot'                   │ '1.12.0' │ 'none'         │
                          │ 13      │ 'system.adapter.fronius'                │ 'fronius'                │ '2.2.0'  │ 'none'         │
                          │ 14      │ 'system.adapter.history'                │ 'history'                │ '4.0.0'  │ 'none'         │
                          │ 15      │ 'system.adapter.icons-material-png'     │ 'icons-material-png'     │ '0.1.0'  │ 'none'         │
                          │ 16      │ 'system.adapter.icons-mfd-svg'          │ 'icons-mfd-svg'          │ '1.2.0'  │ 'none'         │
                          │ 17      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.0.18' │ 'none'         │
                          │ 18      │ 'system.adapter.matrix-org'             │ 'matrix-org'             │ '1.2.2'  │ 'none'         │
                          │ 19      │ 'system.adapter.modbus'                 │ 'modbus'                 │ '8.0.3'  │ 'none'         │
                          │ 20      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'  │ 'none'         │
                          │ 21      │ 'system.adapter.node-red'               │ 'node-red'               │ '6.0.7'  │ 'none'         │
                          │ 22      │ 'system.adapter.octoprint'              │ 'octoprint'              │ '5.1.0'  │ 'none'         │
                          │ 23      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'  │ 'none'         │
                          │ 24      │ 'system.adapter.pid'                    │ 'pid'                    │ '1.1.3'  │ 'none'         │
                          │ 25      │ 'system.adapter.proxmox'                │ 'proxmox'                │ '2.6.1'  │ 'none'         │
                          │ 26      │ 'system.adapter.pvforecast'             │ 'pvforecast'             │ '6.1.0'  │ 'none'         │
                          │ 27      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1' │ 'none'         │
                          │ 28      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'  │ 'none'         │
                          │ 29      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14' │ 'none'         │
                          │ 30      │ 'system.adapter.sql'                    │ 'sql'                    │ '3.0.1'  │ 'none'         │
                          │ 31      │ 'system.adapter.statistics'             │ 'statistics'             │ '5.0.0'  │ 'none'         │
                          │ 32      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'  │ 'none'         │
                          │ 33      │ 'system.adapter.time-switch'            │ 'time-switch'            │ '2.2.2'  │ 'none'         │
                          │ 34      │ 'system.adapter.timer-switch'           │ 'timer-switch'           │ '0.0.1'  │ 'none'         │
                          │ 35      │ 'system.adapter.unifi'                  │ 'unifi'                  │ '0.7.0'  │ 'none'         │
                          │ 36      │ 'system.adapter.vis'                    │ 'vis'                    │ '1.5.6'  │ 'none'         │
                          │ 37      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.8' │ 'none'         │
                          │ 38      │ 'system.adapter.vis-2-widgets-energy'   │ 'vis-2-widgets-energy'   │ '1.0.2'  │ 'none'         │
                          │ 39      │ 'system.adapter.vis-2-widgets-gauges'   │ 'vis-2-widgets-gauges'   │ '2.0.2'  │ 'none'         │
                          │ 40      │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1'  │ 'none'         │
                          │ 41      │ 'system.adapter.vis-colorpicker'        │ 'vis-colorpicker'        │ '2.1.0'  │ 'none'         │
                          │ 42      │ 'system.adapter.vis-hqwidgets'          │ 'vis-hqwidgets'          │ '1.6.1'  │ 'none'         │
                          │ 43      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.6' │ 'none'         │
                          │ 44      │ 'system.adapter.vis-inventwo'           │ 'vis-inventwo'           │ '4.1.1'  │ 'none'         │
                          │ 45      │ 'system.adapter.vis-justgage'           │ 'vis-justgage'           │ '2.1.7'  │ 'none'         │
                          │ 46      │ 'system.adapter.vis-materialdesign'     │ 'vis-materialdesign'     │ '0.5.9'  │ 'none'         │
                          │ 47      │ 'system.adapter.vis-players'            │ 'vis-players'            │ '0.1.6'  │ 'none'         │
                          │ 48      │ 'system.adapter.vis-timeandweather'     │ 'vis-timeandweather'     │ '1.2.2'  │ 'none'         │
                          │ 49      │ 'system.adapter.vis-weather'            │ 'vis-weather'            │ '2.5.13' │ 'none'         │
                          │ 50      │ 'system.adapter.web'                    │ 'web'                    │ '8.0.0'  │ 'none'         │
                          │ 51      │ 'system.adapter.windows-control'        │ 'windows-control'        │ '0.1.5'  │ 'none'         │
                          │ 52      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'  │ 'none'         │
                          │ 53      │ 'system.adapter.wireless-mbus'          │ 'wireless-mbus'          │ '0.10.2' │ 'none'         │
                          │ 54      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.7.3'  │ 'none'         │
                          │ 55      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'  │ 'none'         │
                          │ 56      │ 'system.adapter.yr'                     │ 'yr'                     │ '5.3.0'  │ 'none'         │
                          Adapter    "bestway"      : 0.0.4    , installed 0.0.5
                          Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                          Adapter    "device-reminder": 3.1.2  , installed 3.0.0  [Updatable]
                          Adapter    "discord"      : 2.6.1    , installed 2.6.1
                          Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                          Adapter    "email"        : 2.0.4    , installed 2.0.4
                          Adapter    "fronius"      : 2.2.0    , installed 2.2.0
                          Adapter    "history"      : 4.0.0    , installed 4.0.0
                          Adapter    "matrix-org"   : 1.2.2    , installed 1.2.2
                          Adapter    "node-red"     : 6.0.7    , installed 6.0.7
                          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                          Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                          Adapter    "pid"          : 1.1.3    , installed 1.1.3
                          Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
                          Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
                          Adapter    "statistics"   : 5.0.0    , installed 5.0.0
                          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                          Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
                          Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                          Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                          Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
                          Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
                          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                          Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                          Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
                          Adapter    "wled"         : 0.7.3    , installed 0.7.3
                          Adapter    "yr"           : 5.3.0    , installed 5.3.0
                          Objects and States
                          Objects:        17204
                          States:         59762
                          Hit:1 http://deb.debian.org/debian trixie InRelease
                          Hit:2 http://security.debian.org trixie-security InRelease
                          Pending systemupdates: 0
                          udp   UNCONN 0      0                               0.0.0.0:bootpc      0.0.0.0:*    users:(("dhclient",pid=114,fd=7))
                          udp   UNCONN 0      0                               0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=132,fd=5),("systemd",pid=1,fd=119))
                          udp   UNCONN 0      0                        192.168.130.10:ntp         0.0.0.0:*    users:(("ntpd",pid=246,fd=19))
                          udp   UNCONN 0      0                             127.0.0.1:ntp         0.0.0.0:*    users:(("ntpd",pid=246,fd=18))
                          udp   UNCONN 0      0                               0.0.0.0:ntp         0.0.0.0:*    users:(("ntpd",pid=246,fd=17))
                          udp   UNCONN 0      0                                  [::]:sunrpc         [::]:*    users:(("rpcbind",pid=132,fd=7),("systemd",pid=1,fd=121))
                          udp   UNCONN 0      0      [fe80::be24:11ff:fe09:4aff]%eth0:ntp            [::]:*    users:(("ntpd",pid=246,fd=22))
                          udp   UNCONN 0      0                                 [::1]:ntp            [::]:*    users:(("ntpd",pid=246,fd=20))
                          udp   UNCONN 0      0                                  [::]:ntp            [::]:*    users:(("ntpd",pid=246,fd=16))
                          tcp   LISTEN 0      4096                            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=132,fd=4),("systemd",pid=1,fd=118))
                          tcp   LISTEN 0      511                           127.0.0.1:redis       0.0.0.0:*    users:(("redis-server",pid=224,fd=8))
                          tcp   LISTEN 0      100                           127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=450,fd=13))
                          tcp   LISTEN 0      511                               [::1]:redis          [::]:*    users:(("redis-server",pid=224,fd=9))
                          tcp   LISTEN 0      4096                                  *:mysql             *:*    users:(("mariadbd",pid=321,fd=5),("systemd",pid=1,fd=164))
                          tcp   LISTEN 0      4096                                  *:ssh               *:*    users:(("sshd",pid=255,fd=3),("systemd",pid=1,fd=139))
                          tcp   LISTEN 0      4096                               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=132,fd=6),("systemd",pid=1,fd=120))
                          tcp   LISTEN 0      100                               [::1]:smtp           [::]:*    users:(("master",pid=450,fd=14))
                          2026-07-25 15:38:24.061  - warn: sql.0 (2947) No Connection to database
                          2026-07-25 15:38:24.062  - warn: sql.0 (2947) No Connection to database
                          2026-07-25 15:38:24.076  - info: host.iobroker instance system.adapter.echarts.0 terminated with code 0 (NO_ERROR)
                          2026-07-25 15:38:24.076  - info: host.iobroker stopInstance timeout system.adapter.telegram.0 killing pid 3049
                          2026-07-25 15:38:24.077  - info: host.iobroker stopInstance timeout system.adapter.fronius.0 killing pid 3374
                          2026-07-25 15:38:24.077  - info: host.iobroker stopInstance timeout system.adapter.web.0 killing pid 3472
                          2026-07-25 15:38:24.092  - info: host.iobroker instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                          2026-07-25 15:38:24.092  - info: host.iobroker instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-07-25 15:38:24.096  - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-07-25 15:38:24.102  - info: host.iobroker instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                          2026-07-25 15:38:24.102  - info: host.iobroker All instances are stopped.
                          2026-07-25 15:38:24.269  - info: host.iobroker terminated
                          • A andibr
                            Hallo zusammen
                            12.0.1
                            v22.23.1
                            7.2.2
                            Danke für eure Tips
                            Andi
                            Nachtrag:
                            noch das iob diag
                            ```bash
                            Script v.2026-06-06
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64bit
                            CPU threads     : 8
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            andi
                            HOME=/home/andi
                            Desktop:
                            Session:
                            *** MEMORY ***
                            Swap:           8.6G          0B        8.6G
                            Total:           21G        686M         19G
                                      655 M used memory
                                      855 M active memory
                                    10085 M free memory
                                        0 M buffer memory
                                     1264 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            *** FILESYSTEM ***
                            /var:
                            4.1G    /var/
                            3.4G    /var/lib
                            3.0G    /var/lib/mysql
                            465M    /var/log
                            USB-Devices by-id:
                            /usr/bin/npm            12.0.1
                            /usr/bin/npx            12.0.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            admin:          7.8.23
                            javascript:     9.0.18
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        17204
                            States:         59762
                            @andibr sagte:
                            /usr/bin/npm 12.0.1
                            Ist nicht die vorgesehene Kombination. nodejs 22.23.1 kommt mit npm 10.9.8 daher. Du hast also irgendwas da manuell dran herumgefingert.
                            iob nodejs-update 22
                            sollte zumindest das wieder hinbiegen.
                            Das wird auch mit npm@12 zusammenhängen. Da wird aus Sicherheitsgründen das nachladen von Skripten und aus anderen Quellen als npm erstmal unterbunden.
                              andibr
                              ja, ich habe auf der Linux Konsole eben ein paar mal "npm update -g" durchgeführt, weil ich versucht habe den Fehler 25 irgendwie zu beheben.
                              Huch da kommen aber ganz viele Fehlermeldungen:
                              andi@iobroker:~$ iob nodejs-update 22
                              [sudo] password for andi:
                              [INFO] Custom installation of Node.js v22 requested.
                              [INFO] Current Node.js version: v22.23.1
                              [INFO] Stopping ioBroker with 'iob stop'...
                              [INFO] ioBroker stopped successfully.
                              [INFO] Node.js paths are correct.
                              [INFO] Removing old Node.js versions...
                              (Reading database ... 55161 files and directories currently installed.)
                              Removing nodejs (22.23.1-1nodesource1) ...
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/yallist' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/write-file-atomic' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/walk-up-path/dist' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-name/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/util-deprecate' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tuf-js' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/treeverse' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tinyglobby' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tiny-relative-date/translations' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ssri' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-expression-parse' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks-proxy-agent' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/smart-buffer' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/sigstore' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/signal-exit' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/functions' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safer-buffer' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/qrcode-terminal' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promzard' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-call-limit' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-all-reject-late' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proggy' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proc-log' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/postcss-selector-parser/dist/util' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/path-scurry' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/parse-conflict-json' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/pacote' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-registry-fetch' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-profile' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-pick-manifest' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-packlist' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-package-arg' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-audit-report' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/packaging' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/negotiator' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mute-stream' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ms' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minizlib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-sized' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline/node_modules/yallist' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline/node_modules/minipass' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-flush' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-fetch' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-collect' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/make-fetch-happen' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache/dist/esm' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache/dist/commonjs' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmversion' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmteam' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmsearch' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpublish' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpack' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmorg' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmfund' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmexec/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmdiff' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmaccess' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff-apply' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/jsonparse' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-stringify-nice' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-parse-even-better-errors' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/isexe' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-cidr' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ip-address' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/iconv-lite/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-cache-semantics' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/hosted-git-info' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob/dist/esm' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob/dist/commonjs' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs-minipass' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fastest-levenshtein' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/exponential-backoff' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/diff' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/debug' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cssesc' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/common-ancestor-path' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cidr-regex' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ci-info' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cacache/lib/util' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/brace-expansion' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/bin-links' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/balanced-match' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aproba' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@tufjs/canonical-json' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/verify/dist/tlog' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/tuf' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/sign/dist/external' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/protobuf-specs/dist' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/core' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@sigstore/bundle' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/run-script' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/redact' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/query' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/node-gyp' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/name-from-folder' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/metavuln-calculator' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/map-workspaces' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/installed-package-contents' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/git' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/cp' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/config/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/agent' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/string-locale-compare' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/fs-minipass' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/commands' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/configuring-npm' not empty so not removed
                              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/commands' not empty so not removed
                              Processing triggers for man-db (2.13.1-1) ...
                              [INFO] Setting up NodeSource repository for Node.js 22...
                              [INFO] Downloading NodeSource GPG key...
                              [INFO] Verifying GPG key fingerprint...
                              [ERROR] NodeSource GPG key fingerprint mismatch! Expected: 6F71F525282841EEDAF851B42F59B5F99B1BE0B4, Got: gpg:/root/.gnupg/trustdb.gpg:trustdbcreated
                              [INFO] Cleaning up temporary files..
                              Wobei mich die 2.letzte Zeile am meisten stört
                              • A andibr
                                @andibr sagte:
                                Macht man nicht. Was soll denn 'Fehler 25' deiner Meinung nach besagen?
                                • A andibr
                                  @andibr sagte:
                                  Mach es nochmal.
                                    @andibr sagte:
                                    Mach es nochmal.
                                    andibr
                                    @Thomas-Braun
                                    Habe ich gemacht, es wurden keine roten Zeilen und auch keine Ordner die nicht zu löschen sein sollen angezeigt, aber dafür blieb gleich die ganze Konsole hängen. Sprich der ganze Container hat sich verabschiedet, wieso auch immer.
                                    Mir ist gerade noch in den Sinn gekommen, ich habe vor ca. 2 Monate an meiner neuen Ubiquiti EFG die Sicherheitsfunktion aktiviert, dass er da gewisse Dinge nicht mehr durchlässt. Aber ich habe seither mind. 2x bereits Adapter-Update gemacht. Wäre auch etwas heftig wenn da Github als gesamtes drauf wäre, ich die Webseite aber trotzdem per Browser erreichen kann.
                                    • A andibr
                                      @Thomas-Braun
                                      @andibr
                                      Und
                                      iob diag
                                      sagt nun?
                                        @andibr
                                        Und
                                        iob diag
                                        sagt nun?
                                        andibr
                                        @Thomas-Braun sagte:
                                        @andibr
                                        Und
                                        iob diag
                                        sagt nun?
                                        kommt bald, irgendwas hat da nicht nur den Container gekillt, sondern gleich den ganzen Proxmox abgeschossen. Könnte noch interessant werden nächste Woche bei der erwarteten Wärme, ich mus smir wohl doch noch ein Klimagerät kaufen.
                                        • A andibr
                                          @andibr
                                          Und
                                          iob diag
                                          sagt nun?
                                          @andibr sagte:
                                          Das kann dann aber nicht mit dem nodejs-Update zusammenhängen, das kommt aus dem Container nicht raus.
                                            @andibr sagte:
                                            andibr
                                            @andibr sagte:
                                            nee, dass habe ich auch nicht so gemeint. Da gibt es noch was anderes was mir den ganze Proxmox blokiert, dass muss ich anschliessend noch suchen.
                                            Also:
                                            ```bash
                                            Script v.2026-06-06
                                            *** BASE SYSTEM ***
                                            Operating System: Debian GNU/Linux 13 (trixie)
                                              Virtualization: lxc
                                                Architecture: x86-64
                                            OS is similar to:
                                            Docker          : false
                                            Kernel          : x86_64
                                            Userland        : 64bit
                                            Systemuptime and Load:
                                             17:26:08 up 3 min,  0 users,  load average: 0.60, 0.49, 0.22
                                            CPU threads     : 8
                                            *** LIFE CYCLE STATUS ***
                                            Operating System is the current Debian stable version codenamed 'trixie'!
                                            *** TIME AND TIMEZONES ***
                                                           Local time: Sat 2026-07-25 17:26:08 CEST
                                                       Universal time: Sat 2026-07-25 15:26:08 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** Users and Groups ***
                                            User that called 'iob diag':
                                            andi
                                            HOME=/home/andi
                                            Desktop:
                                            Session:
                                            *** MEMORY ***
                                            Mem:             12G        660M         10G        2.8M        1.2G         11G
                                            Swap:           8.6G          0B        8.6G
                                            Total:           21G        660M         19G
                                                      629 M used memory
                                                      854 M active memory
                                                      864 M inactive memory
                                                    10201 M free memory
                                                        0 M buffer memory
                                                     1171 M swap cache
                                                     8191 M total swap
                                                        0 M used swap
                                                     8191 M free swap
                                            top - 17:26:08 up 3 min,  0 users,  load average: 0.60, 0.49, 0.22
                                            %Cpu(s):  1.2 us,  0.0 sy,  0.0 ni, 98.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :  12000.0 total,  10200.6 free,    630.7 used,   1171.3 buff/cache
                                            MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  11369.3 avail Mem
                                            *** FILESYSTEM ***
                                            /dev/mapper/pve-vm--110--disk--0 ext4      196G   36G  151G  19% /
                                            udev                             devtmpfs   14G     0   14G   0% /dev/tty
                                            tmpfs                            tmpfs      16G  2.6M   16G   1% /tmp
                                            /var:
                                            4.2G    /var/
                                            3.4G    /var/lib
                                            3.0G    /var/lib/mysql
                                            489M    /var/log
                                            Archived and active journals take up 58.3M in the file system.
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.9.8
                                            /usr/bin/npx            10.9.8
                                            nodejs:
                                              Version table:
                                            ioBroker Status
                                            Objects type: redis
                                            States  type: redis
                                            Hosts:
                                            iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 181)
                                            admin:          7.8.23
                                            javascript:     9.0.18
                                            nodejs modules from github:     6
                                            +-- iobroker.esphome@0.7.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#65ee24885cc3bb66cfec885242e31432e3539196)
                                            | `-- autopy@1.1.1 (git+ssh://git@github.com/SimonFischer04/autopy.git#fbe016f35e13e335e1c44783a1e7273bbb2a08c1)
                                            Adapter State
                                            + instance is alive
                                            Objects and States
                                            Objects:        17206
                                            States:         59797
                                            udp   UNCONN 0      0                               0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=149,fd=5),("systemd",pid=1,fd=36))
                                            udp   UNCONN 0      0                        192.168.130.10:ntp         0.0.0.0:*    users:(("ntpd",pid=238,fd=19))
                                            udp   UNCONN 0      0                             127.0.0.1:ntp         0.0.0.0:*    users:(("ntpd",pid=238,fd=18))
                                            udp   UNCONN 0      0                               0.0.0.0:ntp         0.0.0.0:*    users:(("ntpd",pid=238,fd=17))
                                            udp   UNCONN 0      0                                  [::]:sunrpc         [::]:*    users:(("rpcbind",pid=149,fd=7),("systemd",pid=1,fd=38))
                                            udp   UNCONN 0      0      [fe80::be24:11ff:fe09:4aff]%eth0:ntp            [::]:*    users:(("ntpd",pid=238,fd=22))
                                            udp   UNCONN 0      0                                 [::1]:ntp            [::]:*    users:(("ntpd",pid=238,fd=20))
                                            udp   UNCONN 0      0                                  [::]:ntp            [::]:*    users:(("ntpd",pid=238,fd=16))
                                            tcp   LISTEN 0      511                           127.0.0.1:redis       0.0.0.0:*    users:(("redis-server",pid=216,fd=8))
                                            tcp   LISTEN 0      4096                            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=149,fd=4),("systemd",pid=1,fd=35))
                                            tcp   LISTEN 0      100                           127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=433,fd=13))
                                            tcp   LISTEN 0      100                               [::1]:smtp           [::]:*    users:(("master",pid=433,fd=14))
                                            tcp   LISTEN 0      4096                                  *:mysql             *:*    users:(("mariadbd",pid=313,fd=5),("systemd",pid=1,fd=61))
                                            tcp   LISTEN 0      511                               [::1]:redis          [::]:*    users:(("redis-server",pid=216,fd=9))
                                            tcp   LISTEN 0      4096                                  *:ssh               *:*    users:(("sshd",pid=247,fd=3),("systemd",pid=1,fd=67))
                                            tcp   LISTEN 0      4096                               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=149,fd=6),("systemd",pid=1,fd=37))
                                            2026-07-25 17:25:41.074  - warn: sql.0 (562) No Connection to database
                                            2026-07-25 17:25:41.091  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                                            2026-07-25 17:25:41.096  - info: host.iobroker instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                                            2026-07-25 17:25:41.102  - info: host.iobroker instance system.adapter.fronius.0 terminated with code 0 (NO_ERROR)
                                            2026-07-25 17:25:41.108  - info: host.iobroker instance system.adapter.echarts.0 terminated with code 0 (NO_ERROR)
                                            2026-07-25 17:25:41.113  - info: host.iobroker instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                                            2026-07-25 17:25:41.113  - info: host.iobroker All instances are stopped.
                                            2026-07-25 17:25:41.287  - info: host.iobroker terminated
                                            ============= Mark until here for C&P =============
                                            iob diag has finished.
                                            Edit:
                                            - Jetzt geht wenigstens das normale Adapter installieren wieder, ohne das er da irgendwelche Meldungen bringt.
