  4. Fehler bei Update von vis-icontwo 2.11.6
    2.3k
    4.3k
54 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • A Alero
    juergen@iobroker:/opt/iobroker$ npm fund
    iobroker.inst@3.0.0
    ├── https://github.com/sponsors/epoberezkin
    │   └── ajv@6.14.0
    ├─┬ https://opencollective.com/express
    │ │ └── body-parser@2.2.2, http-errors@2.0.1, iconv-lite@0.7.2, mime-types@3.0.2, express@4.22.1, express-session@1.19.0, cors@2.8.6, multer@2.1.1
    │ └── https://github.com/sponsors/ljharb
    │     └── qs@6.15.0, side-channel@1.1.0, object-inspect@1.13.4, side-channel-list@1.0.0, side-channel-map@1.0.1, call-bound@1.0.4, side-channel-weakmap@1.0.2, get-intrinsic@1.3.0, function-bind@1.1.2, gopd@1.2.0, has-symbols@1.1.0, has-tostringtag@1.0.2, minimist@0.2.4, qs@6.14.2, call-bind@1.0.8, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1.2.1, es-abstract@1.24.1, array-buffer-byte-length@1.0.2, arraybuffer.prototype.slice@1.0.4, available-typed-arrays@1.0.7, data-view-buffer@1.0.2, data-view-byte-offset@1.0.1, es-to-primitive@1.3.0, is-date-object@1.1.0, is-symbol@1.1.1, function.prototype.name@1.1.8, functions-have-names@1.2.3, get-symbol-description@1.1.0, globalthis@1.0.4, has-proto@1.2.0, is-array-buffer@3.0.5, is-callable@1.2.7, is-data-view@1.0.2, is-negative-zero@2.0.3, is-regex@1.2.1, is-set@2.0.3, is-shared-array-buffer@1.0.4, is-string@1.1.1, is-typed-array@1.1.15, is-weakref@1.1.1, object.assign@4.1.7, own-keys@1.0.1, regexp.prototype.flags@1.5.4, safe-array-concat@1.1.3, safe-push-apply@1.0.0, safe-regex-test@1.1.0, string.prototype.trim@1.2.10, string.prototype.trimend@1.0.9, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.3, for-each@0.3.5, typed-array-byte-offset@1.0.4, reflect.getprototypeof@1.0.10, which-builtin-type@1.2.1, is-async-function@2.1.1, is-finalizationregistry@1.1.1, is-generator-function@1.1.2, which-boxed-primitive@1.1.1, is-bigint@1.1.0, has-bigints@1.1.0, is-boolean-object@1.2.2, is-number-object@1.1.1, which-collection@1.0.2, is-map@2.0.3, is-weakmap@2.0.2, is-weakset@2.0.4, typed-array-length@1.0.7, unbox-primitive@1.1.0, which-typed-array@1.1.20
    ├── https://github.com/sponsors/broofa
    │   └── uuid@9.0.1
    ├── https://opencollective.com/js-sdsl
    │   └── @js-sdsl/ordered-map@4.4.2, js-sdsl@4.3.0
    ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
    │ │ └── wrap-ansi@7.0.0, wrap-ansi@8.1.0
    │ └── https://github.com/chalk/ansi-styles?sponsor=1
    │     └── ansi-styles@4.3.0, ansi-styles@6.2.3
    ├── https://github.com/sponsors/feross
    │   └── safe-buffer@5.2.1, buffer@6.0.3, simple-get@4.0.1, simple-concat@1.0.1
    ├── https://github.com/sponsors/jaredhanson
    │   └── passport@0.7.0, oauth2orize@1.12.0
    ├── https://github.com/sponsors/RubenVerborgh
    │   └── follow-redirects@1.16.0
    ├── https://github.com/sponsors/panva
    │   └── jose@4.15.9
    ├── https://github.com/sponsors/isaacs
    │   └── glob@10.5.0, foreground-child@3.3.1, signal-exit@4.1.0, jackspeak@3.4.3, minimatch@9.0.9, path-scurry@1.11.1, rimraf@3.0.2, glob@7.2.3
    ├── https://github.com/sponsors/AlCalzone
    │   └── @esm2cjs/got@13.0.0, @esm2cjs/cacheable-lookup@7.0.0, @esm2cjs/cacheable-request@10.2.12, @esm2cjs/mimic-response@4.0.0, @esm2cjs/normalize-url@8.0.0, @esm2cjs/responselike@3.0.0, @esm2cjs/form-data-encoder@2.1.4, @esm2cjs/http-timer@5.0.1, @esm2cjs/is@5.6.0, @esm2cjs/lowercase-keys@3.0.0, @esm2cjs/p-cancelable@3.0.0
    ├─┬ https://opencollective.com/node-fetch
    │ │ └── node-fetch@3.3.2
    │ └── https://github.com/sponsors/jimmywarting
    │     └── fetch-blob@3.2.0, node-domexception@1.0.0
    ├── https://github.com/sponsors/lupomontero
    │   └── psl@1.15.0
    ├── https://github.com/fb55/entities?sponsor=1
    │   └── entities@6.0.1, entities@2.2.0, entities@4.5.0
    ├── https://github.com/sponsors/NaturalIntelligence
    │   └── fast-xml-parser@5.4.1
    ├── https://opencollective.com/serialport/donate
    │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
    ├── https://github.com/inikulin/parse5?sponsor=1
    │   └── parse5@8.0.0
    ├── https://github.com/sponsors/csstools
    │   └── @csstools/css-syntax-patches-for-csstree@1.1.2, @csstools/css-calc@3.1.1, @csstools/css-color-parser@4.0.2, @csstools/color-helpers@6.0.2, @csstools/css-parser-algorithms@4.0.0, @csstools/css-tokenizer@4.0.0
    ├─┬ https://github.com/chalk/chalk-template?sponsor=1
    │ │ └── chalk-template@0.4.0
    │ └── https://github.com/chalk/chalk?sponsor=1
    │     └── chalk@4.1.2
    ├── https://github.com/prettier/prettier?sponsor=1
    │   └── prettier@3.8.1
    ├── https://opencollective.com/ioredis
    │   └── ioredis@4.31.0
    ├── https://github.com/sindresorhus/execa?sponsor=1
    │   └── execa@5.0.1
    ├─┬ https://paulmillr.com/funding/
    │ │ └── chokidar@3.6.0
    │ └── https://github.com/sponsors/jonschlinkert
    │     └── picomatch@2.3.1
    ├── https://github.com/sponsors/sibiraj-s
    │   └── ci-info@3.9.0
    ├── https://github.com/sponsors/Brooooooklyn
    │   └── @node-rs/bcrypt@1.10.7
    ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
    │ │ └── cheerio@1.0.0-rc.10
    │ ├─┬ https://github.com/sponsors/fb55
    │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.2.2, domelementtype@2.3.0
    │ │ └── https://github.com/fb55/domutils?sponsor=1
    │ │     └── domutils@2.8.0, domutils@3.2.2
    │ ├── https://github.com/cheeriojs/dom-serializer?sponsor=1
    │ │   └── dom-serializer@1.4.1, dom-serializer@2.0.0
    │ ├── https://github.com/fb55/domhandler?sponsor=1
    │ │   └── domhandler@4.3.1, domhandler@5.0.3
    │ └── https://github.com/fb55/htmlparser2?sponsor=1
    │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
    ├─┬ https://github.com/sindresorhus/got?sponsor=1
    │ │ └── got@12.6.1
    │ └── https://github.com/sindresorhus/is?sponsor=1
    │     └── @sindresorhus/is@5.6.0
    ├── https://locize.com
    │   └── i18next@25.8.14
    ├── https://ko-fi.com/killymxi
    │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
    ├── https://ko-fi.com/intcreator
    │   └── cron@4.4.0
    ├── https://github.com/sponsors/chrvadala
    │   └── node-ble@1.13.0
    └── https://www.buymeacoffee.com/systeminfo
        └── systeminformation@5.31.4
    @Alero
    npm fund ist uninteressant.
    Wie schaut der Baum denn nun nach dem prune aus?
      @Alero
      Alero
      @Thomas-Braun
      hi, siehe #17
      juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm prune
      npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      npm warn deprecated glob@7.2.3: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.me
      npm warn deprecated gauge@2.7.4: This package is no longer supported.
      up to date in 3s
      214 packages are looking for funding
        run `npm fund` for details
      • A Alero
        @Thomas-Braun
        hi, siehe #17
        up to date in 3s
        @Alero
        cd /opt/iobroker && npm ls
        anschauen und gucken ob die extraneous Dinger jetzt weg sind.
          Alero
          @Thomas-Braun sagte:
          sind nicht weg
          juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
          [sudo] password for juergen:
          iobroker.inst@3.0.0 /opt/iobroker
          ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous
          ├── @types/w3c-web-usb@1.0.13 extraneous
          ├── @yarnpkg/lockfile@1.1.0 extraneous
          ├── find-yarn-workspace-root@2.0.0 extraneous
          ├── iobroker.admin@7.8.23
          ├── iobroker.backitup@3.3.17
          ├── iobroker.birthdays@5.0.0
          ├── iobroker.daswetter@4.5.3
          ├── iobroker.device-reminder@3.1.2
          ├── iobroker.discovery@5.0.0
          ├── iobroker.dwd@2.8.5
          ├── iobroker.echarts@3.1.0
          ├── iobroker.email@2.0.4
          ├── iobroker.energiefluss@3.6.2
          ├── iobroker.fb-checkpresence@1.4.2
          ├── iobroker.feiertage@1.4.0
          ├── iobroker.flot@1.12.0
          ├── iobroker.fritzbox@0.7.0
          ├── iobroker.fritzdect@2.6.2
          ├── iobroker.fullcalendar@2.4.5
          ├── iobroker.history@4.0.0
          ├── iobroker.hm-rega@5.1.0
          ├── iobroker.hm-rpc@3.0.1
          ├── iobroker.ical@1.20.1
          ├── iobroker.icons-fatcow-hosting@0.1.0
          ├── iobroker.icons-icons8@0.0.1
          ├── iobroker.icons-material-png@0.1.0
          ├── iobroker.icons-mfd-png@1.2.1
          ├── iobroker.icons-mfd-svg@1.2.0
          ├── iobroker.icons-open-icon-library-png@0.1.2
          ├── iobroker.influxdb@4.0.2
          ├── iobroker.javascript@9.0.18
          ├── iobroker.js-controller@7.2.2
          ├── iobroker.melcloud@3.0.4
          ├── iobroker.mqtt@6.1.4
          ├── iobroker.node-red@6.0.7
          ├── iobroker.proxmox@2.6.1
          ├── iobroker.pvforecast@6.1.0
          ├── iobroker.radar2@2.4.0
          ├── iobroker.sayit@5.1.0
          ├── iobroker.scenes@4.0.4
          ├── iobroker.shelly@10.6.1
          ├── iobroker.shuttercontrol@2.0.12
          ├── iobroker.simple-api@3.0.7
          ├── iobroker.snmp@3.4.0
          ├── iobroker.socketio@7.1.3
          ├── iobroker.sonoff@3.3.0
          ├── iobroker.sonos@3.0.0
          ├── iobroker.synology@3.1.0
          ├── iobroker.systeminfo@1.3.0
          ├── iobroker.tankerkoenig@3.4.0
          ├── iobroker.telegram@4.1.0
          ├── iobroker.text2command@4.0.0
          ├── iobroker.tr-064@4.3.0
          ├── iobroker.upnp@1.1.0
          ├── iobroker.vis-bars@0.1.4
          ├── iobroker.vis-canvas-gauges@1.0.1
          ├── iobroker.vis-history@1.0.0
          ├── iobroker.vis-hqwidgets@1.6.1
          ├── iobroker.vis-icontwo@2.11.6
          ├── iobroker.vis-inventwo@4.1.1
          ├── iobroker.vis-jqui-mfd@1.1.3
          ├── iobroker.vis-justgage@2.1.7
          ├── iobroker.vis-material-advanced@1.7.4
          ├── iobroker.vis-material@0.2.0
          ├── iobroker.vis-materialdesign@0.5.9
          ├── iobroker.vis-metro@1.2.0
          ├── iobroker.vis-players@0.1.6
          ├── iobroker.vis-timeandweather@1.2.2
          ├── iobroker.vis-weather@2.5.13
          ├── iobroker.vis@1.5.6
          ├── iobroker.web@8.0.0
          ├── iobroker.whatsapp-cmb@0.3.0
          ├── iobroker.ws@4.1.0
          ├── is-docker@2.2.1 extraneous
          ├── is-wsl@2.2.0 extraneous
          ├── json-stable-stringify@1.3.0 extraneous
          ├── jsonify@0.0.1 extraneous
          ├── klaw-sync@6.0.0 extraneous
          ├── micromatch@4.0.8 extraneous
          ├── node-gyp-build@4.8.4 extraneous
          ├── open@7.4.2 extraneous
          ├── patch-package@8.0.1 extraneous
          ├── slash@2.0.0 extraneous
          ├── tmp@0.2.5 extraneous
          ├── usb@2.17.0 extraneous
          └── yaml@2.8.2 extraneous
          • A Alero
            sind nicht weg
            @Alero Also noch Chaos drin.
            Ich weiß aber nicht wo da der Hase im Pfeffer liegt.
              Alero
              schrieb am zuletzt editiert von Alero
              was ist wenn ich die pakete von hand deinstalliere?
              z.B. npm uninstall json-stable-stringify
              • A Alero
                @Alero
                Schau zuerst mal wo die Doubletten liegen.
                cd /opt/iobroker && npm ls slash
                zum Beispiel.
                  Alero
                  juergen@iobroker:~$ cd /opt/iobroker && npm ls slash
                  ├─┬ patch-package@8.0.1 extraneous
                  │ └── slash@2.0.0 deduped
                  └── slash@2.0.0 extraneous
                  • A Alero
                    @Alero
                    Ich würde behaupten, das braucht keiner mehr.
                    Aber wie hast du die Dinger überhaupt in das System reingehievt? Unorthodoxe Installation von irgendwas via github oder direkt per npm?
                      Alero
                      i.d.R eigentlich nur über iobroker.
                        Alero
                        und wie bekomme ich die jetzt weg?
                        • A Alero
                          @Alero
                          Mit einem
                          npm uninstall PAKETNAME
                          in dem entsprechenden Verzeichnis.
                          Kann aber sein, dass du dir damit dann andere Baustellen aufreißt.
                            Alero
                            habe es mit slash versucht. ist immer noch da
                            npm uninstall slash
                              Alero
                              klappt bei anderen auch nicht
                                Alero
                                was ist mit dem Befahl yarn? wenn ich ihn nutzen will muss ich ihn erst installieren, oder?
                                Wenn das Paket weiterhin als extraneous oder Warnung auftaucht, nutzen Sie den Aufräum-Befehl von Yarn, um veraltete oder ungenutzte Verknüpfungen zu entfernen:
                                yarn cache clean
                                yarn clean
                                  Alero
                                  oder das hier?
                                  rm -rf node_modules package-lock.json
                                  npm cache clean --force
                                  npm install
                                    Alero
                                    Hi, habe von den oben genannten Sachen nichts ausgeführt, nur im internet gelesen.
                                    Meine Vis startet nicht mehr. auch nicht nach einem Reboot
                                    • A Alero
                                      oder das hier?
                                      npm install
                                      @Alero
                                      So tief stecke ich in yarn und npm nicht drin.
                                      Aber ganz grundsätzlich ist --force und 'wildes' Löschen von Dingen im npm tree mit Vorsicht zu genießen.
                                        Alero
                                        hi,
                                        ich habe ja noch nichts gelöscht
                                        das einzige war slash von hand
                                          Alero
                                          Bein reboot kommt im Protokoll u.a. folgendes:
                                          iobroker npm-install: npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error (node:887) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:186:23)npm error gyp ERR! System Linux 6.12.63+deb13-amd64npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v22.23.1npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-07-03T09_14_17_962Z-debug-0.loghost.iobroker Cannot install iobroker.rpi2@2.4.0: 7
