Fehler bei Update von vis-icontwo 2.11.6
moin,
hier der diag:========== Start marking the full check here =========== ```bash Script v.2026-06-06 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iobroker Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.63+deb13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 3month 1d OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64bit System was installed 110 days ago (on 2026-03-13). Systemuptime and Load: 10:19:53 up 21:17, 1 user, load average: 0.13, 0.21, 0.20 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Thu 2026-07-02 10:19:53 CEST Universal time: Thu 2026-07-02 08:19:53 UTC RTC time: Thu 2026-07-02 08:19:53 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': juergen HOME=/home/juergen GROUPS=juergen adm cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.3G 4.7G 2.7G 4.6M 1.2G 3.6G Swap: 5.5G 0B 5.5G Total: 13G 4.7G 8.2G Active iob-Instances: 36 7947 M total memory 4526 M used memory 4171 M active memory 786 M inactive memory 2600 M free memory 223 M buffer memory 873 M swap cache 5237 M total swap 0 M used swap 5237 M free swap *** top - Table Of Processes *** top - 10:19:54 up 21:17, 1 user, load average: 0.13, 0.21, 0.20 Tasks: 165 total, 1 running, 164 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.8 us, 0.0 sy, 0.0 ni, 92.9 id, 0.0 wa, 0.0 hi, 2.4 si, 0.0 st MiB Mem : 7947.3 total, 2600.3 free, 4527.1 used, 1096.8 buff/cache MiB Swap: 5238.0 total, 5238.0 free, 0.0 used. 3420.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 795M 496K 795M 1% /run /dev/sda1 ext4 93G 6.0G 83G 7% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service tmpfs tmpfs 3.9G 3.9M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 795M 8.0K 795M 1% /run/user/1000 Messages concerning filesystems in dmesg: [Wed Jul 1 13:02:50 2026] EXT4-fs (sda1): orphan cleanup on readonly fs [Wed Jul 1 13:02:50 2026] EXT4-fs (sda1): mounted filesystem ad7cb7c3-87c0-4151-8142-0f5900745d4e ro with ordered data mode. Quota mode: none. [Wed Jul 1 13:02:51 2026] EXT4-fs (sda1): re-mounted ad7cb7c3-87c0-4151-8142-0f5900745d4e r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 666M /var/ 333M /var/cache 325M /var/cache/apt 235M /var/cache/apt/archives 174M /var/lib Archived and active journals take up 143.2M in the file system. /opt/iobroker/backups: 16M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 798M /opt/iobroker/iobroker-data/ 587M /opt/iobroker/iobroker-data/files 129M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 59M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 30M /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map 27M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 20M /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map 19M /opt/iobroker/iobroker-data/states.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.23.1 /usr/bin/node v22.23.1 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.1-1nodesource1 Candidate: 22.23.1-1nodesource1 Version table: *** 22.23.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.23.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.2.2, hostname: iobroker , alive, uptime: 76626) Core adapters versions js-controller: 7.2.2 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 1 | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) Adapter State + system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.birthdays.0 : birthdays : iobroker - enabled + system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - disabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled + system.adapter.echarts.0 : echarts : iobroker - enabled system.adapter.email.0 : email : iobroker - disabled system.adapter.energiefluss.0 : energiefluss : iobroker - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - disabled system.adapter.feiertage.0 : feiertage : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled + system.adapter.fritzbox.0 : fritzbox : iobroker - enabled system.adapter.fritzdect.0 : fritzdect : iobroker - disabled + system.adapter.fullcalendar.0 : fullcalendar : iobroker - enabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : iobroker - disabled system.adapter.icons-icons8.0 : icons-icons8 : iobroker - disabled system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - disabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.melcloud.0 : melcloud : iobroker - enabled + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1884, bind: 192.168.42.15 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1886, bind: 192.168.42.15 + system.adapter.mqtt.3 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.42.15 + system.adapter.mqtt.4 : mqtt : iobroker - enabled, port: 1888, bind: 192.168.42.15 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 192.168.42.15 system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.radar2.0 : radar2 : iobroker - disabled system.adapter.rpi2.0 : rpi2 : iobroker - disabled system.adapter.sayit.0 : sayit : iobroker - disabled, port: 0 + system.adapter.scenes.0 : scenes : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 192.168.42.15 + system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - enabled + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.snmp.0 : snmp : iobroker - disabled + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 192.168.42.15, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - disabled, port: 1883, bind: 192.168.42.15 system.adapter.sonoff.1 : sonoff : iobroker - disabled, port: 1884, bind: 192.168.42.15 system.adapter.sonoff.2 : sonoff : iobroker - disabled, port: 1888, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : iobroker - enabled system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - disabled system.adapter.synology.0 : synology : iobroker - disabled, port: 5001 + system.adapter.systeminfo.0 : systeminfo : iobroker - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.2 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : iobroker - disabled system.adapter.text2command.1 : text2command : iobroker - disabled + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.upnp.0 : upnp : iobroker - disabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-history.0 : vis-history : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - disabled system.adapter.vis-material.0 : vis-material : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-players.0 : vis-players : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - disabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - disabled system.adapter.whatsapp-cmb.1 : whatsapp-cmb : iobroker - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1884, bind: 192.168.42.15 + system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1886, bind: 192.168.42.15 + system.adapter.mqtt.3 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.42.15 + system.adapter.mqtt.4 : mqtt : iobroker - enabled, port: 1888, bind: 192.168.42.15 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 192.168.42.15 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 192.168.42.15 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 192.168.42.15, run as: admin + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.2 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '7.8.23' │ 'none' │ │ 1 │ 'system.adapter.backitup' │ 'backitup' │ '3.3.17' │ 'none' │ │ 2 │ 'system.adapter.birthdays' │ 'birthdays' │ '5.0.0' │ 'none' │ │ 3 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.3' │ 'none' │ │ 4 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 5 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 6 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 7 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 8 │ 'system.adapter.email' │ 'email' │ '2.0.4' │ 'none' │ │ 9 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 10 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 11 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 12 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 13 │ 'system.adapter.fritzbox' │ 'fritzbox' │ '0.7.0' │ 'none' │ │ 14 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 15 │ 'system.adapter.fullcalendar' │ 'fullcalendar' │ '2.4.5' │ 'none' │ │ 16 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 17 │ 'system.adapter.hm-rega' │ 'hm-rega' │ '5.1.0' │ 'none' │ │ 18 │ 'system.adapter.hm-rpc' │ 'hm-rpc' │ '3.0.1' │ 'none' │ │ 19 │ 'system.adapter.ical' │ 'ical' │ '1.20.1' │ 'none' │ │ 20 │ 'system.adapter.icons-fatcow-hosting' │ 'icons-fatcow-hosting' │ '0.1.0' │ 'none' │ │ 21 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 22 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 23 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 24 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 25 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2' │ 'none' │ │ 26 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 27 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 28 │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none' │ │ 29 │ 'system.adapter.melcloud' │ 'melcloud' │ '3.0.4' │ 'none' │ │ 30 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 31 │ 'system.adapter.node-red' │ 'node-red' │ '6.0.7' │ 'none' │ │ 32 │ 'system.adapter.proxmox' │ 'proxmox' │ '2.6.1' │ 'none' │ │ 33 │ 'system.adapter.pvforecast' │ 'pvforecast' │ '6.1.0' │ 'none' │ │ 34 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 35 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 36 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 37 │ 'system.adapter.scenes' │ 'scenes' │ '4.0.4' │ 'none' │ │ 38 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 39 │ 'system.adapter.shuttercontrol' │ 'shuttercontrol' │ '2.0.12' │ 'none' │ │ 40 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 41 │ 'system.adapter.snmp' │ 'snmp' │ '3.4.0' │ 'none' │ │ 42 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 43 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 44 │ 'system.adapter.sonos' │ 'sonos' │ '3.0.0' │ 'none' │ │ 45 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 46 │ 'system.adapter.synology' │ 'synology' │ '3.1.0' │ 'none' │ │ 47 │ 'system.adapter.systeminfo' │ 'systeminfo' │ '1.3.0' │ 'none' │ │ 48 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 49 │ 'system.adapter.telegram' │ 'telegram' │ '4.1.0' │ 'none' │ │ 50 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 51 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 52 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 53 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 54 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 55 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 56 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 57 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 58 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 59 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 60 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 61 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 62 │ 'system.adapter.vis-material' │ 'vis-material' │ '0.2.0' │ 'none' │ │ 63 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 64 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 65 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 66 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 67 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 68 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 69 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 70 │ 'system.adapter.whatsapp-cmb' │ 'whatsapp-cmb' │ '0.3.0' │ 'none' │ │ 71 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: Stable (default) Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "backitup" : 3.3.17 , installed 3.3.17 Adapter "birthdays" : 5.0.0 , installed 5.0.0 Adapter "daswetter" : 4.5.3 , installed 4.5.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 2.0.4 , installed 2.0.4 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "feiertage" : 1.4.0 , installed 1.4.0 Adapter "fritzbox" : 0.7.0 , installed 0.7.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullcalendar" : 2.4.5 , installed 2.4.5 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.20.1 , installed 1.20.1 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "melcloud" : 3.0.4 , installed 3.0.4 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "node-red" : 6.0.7 , installed 6.0.7 Adapter "proxmox" : 2.6.1 , installed 2.6.1 Adapter "pvforecast" : 6.1.0 , installed 6.1.0 Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "scenes" : 4.0.4 , installed 4.0.4 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "shuttercontrol": 2.0.12 , installed 2.0.12 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "snmp" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "systeminfo" : 1.3.0 , installed 1.3.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material" : 0.2.0 , installed 0.2.0 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.13 , installed 2.5.13 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Objects and States Please stand by - This may take a while Objects: 23068 States: 22190 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B] Fetched 6922 B in 0s (31.6 kB/s) Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.42.15:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=2125,fd=71)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=517,fd=5),("systemd",pid=1,fd=45)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=517,fd=7),("systemd",pid=1,fd=47)) tcp LISTEN 0 511 192.168.42.15:8084 0.0.0.0:* users:(("io.socketio.0",pid=2447,fd=34)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=687,fd=6)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=517,fd=4),("systemd",pid=1,fd=44)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=677,fd=29)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=677,fd=23)) tcp LISTEN 0 511 192.168.42.15:1888 0.0.0.0:* users:(("io.mqtt.4",pid=1969,fd=35)) tcp LISTEN 0 511 192.168.42.15:1881 0.0.0.0:* users:(("io.shelly.0",pid=1986,fd=36)) tcp LISTEN 0 511 192.168.42.15:1880 0.0.0.0:* users:(("node-red",pid=1231,fd=23)) tcp LISTEN 0 511 192.168.42.15:1883 0.0.0.0:* users:(("io.mqtt.3",pid=1877,fd=35)) tcp LISTEN 0 511 192.168.42.15:1884 0.0.0.0:* users:(("io.mqtt.1",pid=1806,fd=35)) tcp LISTEN 0 511 192.168.42.15:1886 0.0.0.0:* users:(("io.mqtt.2",pid=39829,fd=35)) tcp LISTEN 0 511 192.168.42.15:42001 0.0.0.0:* users:(("io.hm-rpc.0",pid=1705,fd=35)) tcp LISTEN 0 511 192.168.42.15:42010 0.0.0.0:* users:(("io.hm-rpc.1",pid=1722,fd=35)) tcp LISTEN 0 511 192.168.42.15:8701 0.0.0.0:* users:(("io.hm-rpc.2",pid=1739,fd=35)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=687,fd=7)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=517,fd=6),("systemd",pid=1,fd=46)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=2424,fd=35)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=2260,fd=35)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.1",pid=718,fd=40)) tcp LISTEN 0 511 *:3500 *:* users:(("io.sonos.0",pid=2020,fd=31)) *** Log File - Last 25 Lines *** 2026-07-02 10:20:04.859 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_relative/ 2026-07-02 10:20:04.891 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_persistent_absolute/ 2026-07-02 10:20:04.891 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_absolute/ 2026-07-02 10:20:04.908 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_relative/ 2026-07-02 10:20:04.909 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_relative/ 2026-07-02 10:20:04.913 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/ 2026-07-02 10:20:04.914 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/ 2026-07-02 10:20:04.923 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /solar\.[^.]*\.cmd\.power/ 2026-07-02 10:20:04.923 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.power/ 2026-07-02 10:20:04.941 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /solar\.[^.]*\.cmd\.restart/ 2026-07-02 10:20:04.941 - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /mqtt\.2\.solar\.[^.]*\.cmd\.restart/ 2026-07-02 10:20:05.059 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:05.091 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:05.109 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:05.115 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:05.123 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:05.141 - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states 2026-07-02 10:20:10.977 - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching CheckDeadBatt() 2026-07-02 10:20:10.978 - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching MakeTable 2026-07-02 10:20:10.980 - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching MakeJSONTable 2026-07-02 10:20:11.083 - info: javascript.0 (767) script.js.common.FensterUeberwachung: setForeignState(id=javascript.0.FensterUeberwachung.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Büro<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 20 Std. 37 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Flur<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 18 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gäste Wc<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 21 Std. 55 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gästezimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 21 Std. 55 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Garage<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 20 Std. 49 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Küche<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Wohnzimmer<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 20 Std. 50 Min.</div></td></tr></tbody></table>","ack":true,"ts":1782980411083,"q":0,"from":"system.adapter.javascript.0","lc":1782980411083,"c":"script.js.common.FensterUeberwachung"}) 2026-07-02 10:20:17.007 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 39966 2026-07-02 10:20:19.030 - info: dwd.0 (39966) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.23.1, js-controller: 7.2.2 2026-07-02 10:20:19.294 - info: dwd.0 (39966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-07-02 10:20:19.812 - info: host.iobroker instance system.adapter.dwd.0 having pid 39966 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)============= Mark until here for C&P =============
Jetzt schaut es gut aus. Um ganz sicher zu gehen, schau dir den npm tree an:
cd /opt/iobroker && npm ls -
cd /opt/iobroker && npm lscd /opt/iobroker && npm ls
The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Jul 2 10:18:10 2026 from 192.168.42.13 juergen@iobroker:~$ cd /opt/iobroker && npm ls [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous ├── @types/w3c-web-usb@1.0.13 extraneous ├── @yarnpkg/lockfile@1.1.0 extraneous ├── find-yarn-workspace-root@2.0.0 extraneous ├── iobroker.admin@7.8.23 ├── iobroker.backitup@3.3.17 ├── iobroker.birthdays@5.0.0 ├── iobroker.daswetter@4.5.3 ├── iobroker.device-reminder@3.1.2 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@2.0.4 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.feiertage@1.4.0 ├── iobroker.flot@1.12.0 ├── iobroker.fritzbox@0.7.0 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullcalendar@2.4.5 ├── iobroker.history@4.0.0 ├── iobroker.hm-rega@5.1.0 ├── iobroker.hm-rpc@3.0.1 ├── iobroker.ical@1.20.1 ├── iobroker.icons-fatcow-hosting@0.1.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.javascript@9.0.18 ├── iobroker.js-controller@7.2.2 ├── iobroker.melcloud@3.0.4 ├── iobroker.mqtt@6.1.4 ├── iobroker.node-red@6.0.7 ├── iobroker.proxmox@2.6.1 ├── iobroker.pvforecast@6.1.0 ├── iobroker.radar2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.scenes@4.0.4 ├── iobroker.shelly@10.6.1 ├── iobroker.shuttercontrol@2.0.12 ├── iobroker.simple-api@3.0.7 ├── iobroker.snmp@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sonos@3.0.0 ├── iobroker.synology@3.1.0 ├── iobroker.systeminfo@1.3.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@4.1.0 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-material-advanced@1.7.4 ├── iobroker.vis-material@0.2.0 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis-weather@2.5.13 ├── iobroker.vis@1.5.6 ├── iobroker.web@8.0.0 ├── iobroker.whatsapp-cmb@0.3.0 ├── iobroker.ws@4.1.0 ├── is-docker@2.2.1 extraneous ├── is-wsl@2.2.0 extraneous ├── json-stable-stringify@1.3.0 extraneous ├── jsonify@0.0.1 extraneous ├── klaw-sync@6.0.0 extraneous ├── micromatch@4.0.8 extraneous ├── node-gyp-build@4.8.4 extraneous ├── open@7.4.2 extraneous ├── patch-package@8.0.1 extraneous ├── slash@2.0.0 extraneous ├── tmp@0.2.5 extraneous ├── usb@2.17.0 extraneous └── yaml@2.8.2 extraneous -
The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Jul 2 10:18:10 2026 from 192.168.42.13 juergen@iobroker:~$ cd /opt/iobroker && npm ls [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous ├── @types/w3c-web-usb@1.0.13 extraneous ├── @yarnpkg/lockfile@1.1.0 extraneous ├── find-yarn-workspace-root@2.0.0 extraneous ├── iobroker.admin@7.8.23 ├── iobroker.backitup@3.3.17 ├── iobroker.birthdays@5.0.0 ├── iobroker.daswetter@4.5.3 ├── iobroker.device-reminder@3.1.2 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@2.0.4 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.feiertage@1.4.0 ├── iobroker.flot@1.12.0 ├── iobroker.fritzbox@0.7.0 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullcalendar@2.4.5 ├── iobroker.history@4.0.0 ├── iobroker.hm-rega@5.1.0 ├── iobroker.hm-rpc@3.0.1 ├── iobroker.ical@1.20.1 ├── iobroker.icons-fatcow-hosting@0.1.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.javascript@9.0.18 ├── iobroker.js-controller@7.2.2 ├── iobroker.melcloud@3.0.4 ├── iobroker.mqtt@6.1.4 ├── iobroker.node-red@6.0.7 ├── iobroker.proxmox@2.6.1 ├── iobroker.pvforecast@6.1.0 ├── iobroker.radar2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.scenes@4.0.4 ├── iobroker.shelly@10.6.1 ├── iobroker.shuttercontrol@2.0.12 ├── iobroker.simple-api@3.0.7 ├── iobroker.snmp@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sonos@3.0.0 ├── iobroker.synology@3.1.0 ├── iobroker.systeminfo@1.3.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@4.1.0 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-material-advanced@1.7.4 ├── iobroker.vis-material@0.2.0 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis-weather@2.5.13 ├── iobroker.vis@1.5.6 ├── iobroker.web@8.0.0 ├── iobroker.whatsapp-cmb@0.3.0 ├── iobroker.ws@4.1.0 ├── is-docker@2.2.1 extraneous ├── is-wsl@2.2.0 extraneous ├── json-stable-stringify@1.3.0 extraneous ├── jsonify@0.0.1 extraneous ├── klaw-sync@6.0.0 extraneous ├── micromatch@4.0.8 extraneous ├── node-gyp-build@4.8.4 extraneous ├── open@7.4.2 extraneous ├── patch-package@8.0.1 extraneous ├── slash@2.0.0 extraneous ├── tmp@0.2.5 extraneous ├── usb@2.17.0 extraneous └── yaml@2.8.2 extraneousIn der ersten Ebene liegen eigentlich nur Module, die iobroker.XYZ heißen. Also alles, was da auch als 'extraneous' gekennzeichnet ist ist auch genau das: Überflüssig.
Versuch mal per
cd /opt/iobroker && npm pruneda Ordnung reinzubringen.
Versuch mal per
juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm prune npm warn deprecated npmlog@4.1.2: This package is no longer supported. npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported. npm warn deprecated glob@7.2.3: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.me npm warn deprecated gauge@2.7.4: This package is no longer supported. up to date in 4s 214 packages are looking for funding run `npm fund` for details -
juergen@iobroker:/opt/iobroker$ npm fund iobroker.inst@3.0.0 ├── https://github.com/sponsors/epoberezkin │ └── ajv@6.14.0 ├─┬ https://opencollective.com/express │ │ └── body-parser@2.2.2, http-errors@2.0.1, iconv-lite@0.7.2, mime-types@3.0.2, express@4.22.1, express-session@1.19.0, cors@2.8.6, multer@2.1.1 │ └── https://github.com/sponsors/ljharb │ └── qs@6.15.0, side-channel@1.1.0, object-inspect@1.13.4, side-channel-list@1.0.0, side-channel-map@1.0.1, call-bound@1.0.4, side-channel-weakmap@1.0.2, get-intrinsic@1.3.0, function-bind@1.1.2, gopd@1.2.0, has-symbols@1.1.0, has-tostringtag@1.0.2, minimist@0.2.4, qs@6.14.2, call-bind@1.0.8, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1.2.1, es-abstract@1.24.1, array-buffer-byte-length@1.0.2, arraybuffer.prototype.slice@1.0.4, available-typed-arrays@1.0.7, data-view-buffer@1.0.2, data-view-byte-offset@1.0.1, es-to-primitive@1.3.0, is-date-object@1.1.0, is-symbol@1.1.1, function.prototype.name@1.1.8, functions-have-names@1.2.3, get-symbol-description@1.1.0, globalthis@1.0.4, has-proto@1.2.0, is-array-buffer@3.0.5, is-callable@1.2.7, is-data-view@1.0.2, is-negative-zero@2.0.3, is-regex@1.2.1, is-set@2.0.3, is-shared-array-buffer@1.0.4, is-string@1.1.1, is-typed-array@1.1.15, is-weakref@1.1.1, object.assign@4.1.7, own-keys@1.0.1, regexp.prototype.flags@1.5.4, safe-array-concat@1.1.3, safe-push-apply@1.0.0, safe-regex-test@1.1.0, string.prototype.trim@1.2.10, string.prototype.trimend@1.0.9, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.3, for-each@0.3.5, typed-array-byte-offset@1.0.4, reflect.getprototypeof@1.0.10, which-builtin-type@1.2.1, is-async-function@2.1.1, is-finalizationregistry@1.1.1, is-generator-function@1.1.2, which-boxed-primitive@1.1.1, is-bigint@1.1.0, has-bigints@1.1.0, is-boolean-object@1.2.2, is-number-object@1.1.1, which-collection@1.0.2, is-map@2.0.3, is-weakmap@2.0.2, is-weakset@2.0.4, typed-array-length@1.0.7, unbox-primitive@1.1.0, which-typed-array@1.1.20 ├── https://github.com/sponsors/broofa │ └── uuid@9.0.1 ├── https://opencollective.com/js-sdsl │ └── @js-sdsl/ordered-map@4.4.2, js-sdsl@4.3.0 ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1 │ │ └── wrap-ansi@7.0.0, wrap-ansi@8.1.0 │ └── https://github.com/chalk/ansi-styles?sponsor=1 │ └── ansi-styles@4.3.0, ansi-styles@6.2.3 ├── https://github.com/sponsors/feross │ └── safe-buffer@5.2.1, buffer@6.0.3, simple-get@4.0.1, simple-concat@1.0.1 ├── https://github.com/sponsors/jaredhanson │ └── passport@0.7.0, oauth2orize@1.12.0 ├── https://github.com/sponsors/RubenVerborgh │ └── follow-redirects@1.16.0 ├── https://github.com/sponsors/panva │ └── jose@4.15.9 ├── https://github.com/sponsors/isaacs │ └── glob@10.5.0, foreground-child@3.3.1, signal-exit@4.1.0, jackspeak@3.4.3, minimatch@9.0.9, path-scurry@1.11.1, rimraf@3.0.2, glob@7.2.3 ├── https://github.com/sponsors/AlCalzone │ └── @esm2cjs/got@13.0.0, @esm2cjs/cacheable-lookup@7.0.0, @esm2cjs/cacheable-request@10.2.12, @esm2cjs/mimic-response@4.0.0, @esm2cjs/normalize-url@8.0.0, @esm2cjs/responselike@3.0.0, @esm2cjs/form-data-encoder@2.1.4, @esm2cjs/http-timer@5.0.1, @esm2cjs/is@5.6.0, @esm2cjs/lowercase-keys@3.0.0, @esm2cjs/p-cancelable@3.0.0 ├─┬ https://opencollective.com/node-fetch │ │ └── node-fetch@3.3.2 │ └── https://github.com/sponsors/jimmywarting │ └── fetch-blob@3.2.0, node-domexception@1.0.0 ├── https://github.com/sponsors/lupomontero │ └── psl@1.15.0 ├── https://github.com/fb55/entities?sponsor=1 │ └── entities@6.0.1, entities@2.2.0, entities@4.5.0 ├── https://github.com/sponsors/NaturalIntelligence │ └── fast-xml-parser@5.4.1 ├── https://opencollective.com/serialport/donate │ └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0 ├── https://github.com/inikulin/parse5?sponsor=1 │ └── parse5@8.0.0 ├── https://github.com/sponsors/csstools │ └── @csstools/css-syntax-patches-for-csstree@1.1.2, @csstools/css-calc@3.1.1, @csstools/css-color-parser@4.0.2, @csstools/color-helpers@6.0.2, @csstools/css-parser-algorithms@4.0.0, @csstools/css-tokenizer@4.0.0 ├─┬ https://github.com/chalk/chalk-template?sponsor=1 │ │ └── chalk-template@0.4.0 │ └── https://github.com/chalk/chalk?sponsor=1 │ └── chalk@4.1.2 ├── https://github.com/prettier/prettier?sponsor=1 │ └── prettier@3.8.1 ├── https://opencollective.com/ioredis │ └── ioredis@4.31.0 ├── https://github.com/sindresorhus/execa?sponsor=1 │ └── execa@5.0.1 ├─┬ https://paulmillr.com/funding/ │ │ └── chokidar@3.6.0 │ └── https://github.com/sponsors/jonschlinkert │ └── picomatch@2.3.1 ├── https://github.com/sponsors/sibiraj-s │ └── ci-info@3.9.0 ├── https://github.com/sponsors/Brooooooklyn │ └── @node-rs/bcrypt@1.10.7 ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1 │ │ └── cheerio@1.0.0-rc.10 │ ├─┬ https://github.com/sponsors/fb55 │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.2.2, domelementtype@2.3.0 │ │ └── https://github.com/fb55/domutils?sponsor=1 │ │ └── domutils@2.8.0, domutils@3.2.2 │ ├── https://github.com/cheeriojs/dom-serializer?sponsor=1 │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0 │ ├── https://github.com/fb55/domhandler?sponsor=1 │ │ └── domhandler@4.3.1, domhandler@5.0.3 │ └── https://github.com/fb55/htmlparser2?sponsor=1 │ └── htmlparser2@6.1.0, htmlparser2@8.0.2 ├─┬ https://github.com/sindresorhus/got?sponsor=1 │ │ └── got@12.6.1 │ └── https://github.com/sindresorhus/is?sponsor=1 │ └── @sindresorhus/is@5.6.0 ├── https://locize.com │ └── i18next@25.8.14 ├── https://ko-fi.com/killymxi │ └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0 ├── https://ko-fi.com/intcreator │ └── cron@4.4.0 ├── https://github.com/sponsors/chrvadala │ └── node-ble@1.13.0 └── https://www.buymeacoffee.com/systeminfo └── systeminformation@5.31.4 -
juergen@iobroker:/opt/iobroker$ npm fund iobroker.inst@3.0.0 ├── https://github.com/sponsors/epoberezkin │ └── ajv@6.14.0 ├─┬ https://opencollective.com/express │ │ └── body-parser@2.2.2, http-errors@2.0.1, iconv-lite@0.7.2, mime-types@3.0.2, express@4.22.1, express-session@1.19.0, cors@2.8.6, multer@2.1.1 │ └── https://github.com/sponsors/ljharb │ └── qs@6.15.0, side-channel@1.1.0, object-inspect@1.13.4, side-channel-list@1.0.0, side-channel-map@1.0.1, call-bound@1.0.4, side-channel-weakmap@1.0.2, get-intrinsic@1.3.0, function-bind@1.1.2, gopd@1.2.0, has-symbols@1.1.0, has-tostringtag@1.0.2, minimist@0.2.4, qs@6.14.2, call-bind@1.0.8, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1.2.1, es-abstract@1.24.1, array-buffer-byte-length@1.0.2, arraybuffer.prototype.slice@1.0.4, available-typed-arrays@1.0.7, data-view-buffer@1.0.2, data-view-byte-offset@1.0.1, es-to-primitive@1.3.0, is-date-object@1.1.0, is-symbol@1.1.1, function.prototype.name@1.1.8, functions-have-names@1.2.3, get-symbol-description@1.1.0, globalthis@1.0.4, has-proto@1.2.0, is-array-buffer@3.0.5, is-callable@1.2.7, is-data-view@1.0.2, is-negative-zero@2.0.3, is-regex@1.2.1, is-set@2.0.3, is-shared-array-buffer@1.0.4, is-string@1.1.1, is-typed-array@1.1.15, is-weakref@1.1.1, object.assign@4.1.7, own-keys@1.0.1, regexp.prototype.flags@1.5.4, safe-array-concat@1.1.3, safe-push-apply@1.0.0, safe-regex-test@1.1.0, string.prototype.trim@1.2.10, string.prototype.trimend@1.0.9, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.3, for-each@0.3.5, typed-array-byte-offset@1.0.4, reflect.getprototypeof@1.0.10, which-builtin-type@1.2.1, is-async-function@2.1.1, is-finalizationregistry@1.1.1, is-generator-function@1.1.2, which-boxed-primitive@1.1.1, is-bigint@1.1.0, has-bigints@1.1.0, is-boolean-object@1.2.2, is-number-object@1.1.1, which-collection@1.0.2, is-map@2.0.3, is-weakmap@2.0.2, is-weakset@2.0.4, typed-array-length@1.0.7, unbox-primitive@1.1.0, which-typed-array@1.1.20 ├── https://github.com/sponsors/broofa │ └── uuid@9.0.1 ├── https://opencollective.com/js-sdsl │ └── @js-sdsl/ordered-map@4.4.2, js-sdsl@4.3.0 ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1 │ │ └── wrap-ansi@7.0.0, wrap-ansi@8.1.0 │ └── https://github.com/chalk/ansi-styles?sponsor=1 │ └── ansi-styles@4.3.0, ansi-styles@6.2.3 ├── https://github.com/sponsors/feross │ └── safe-buffer@5.2.1, buffer@6.0.3, simple-get@4.0.1, simple-concat@1.0.1 ├── https://github.com/sponsors/jaredhanson │ └── passport@0.7.0, oauth2orize@1.12.0 ├── https://github.com/sponsors/RubenVerborgh │ └── follow-redirects@1.16.0 ├── https://github.com/sponsors/panva │ └── jose@4.15.9 ├── https://github.com/sponsors/isaacs │ └── glob@10.5.0, foreground-child@3.3.1, signal-exit@4.1.0, jackspeak@3.4.3, minimatch@9.0.9, path-scurry@1.11.1, rimraf@3.0.2, glob@7.2.3 ├── https://github.com/sponsors/AlCalzone │ └── @esm2cjs/got@13.0.0, @esm2cjs/cacheable-lookup@7.0.0, @esm2cjs/cacheable-request@10.2.12, @esm2cjs/mimic-response@4.0.0, @esm2cjs/normalize-url@8.0.0, @esm2cjs/responselike@3.0.0, @esm2cjs/form-data-encoder@2.1.4, @esm2cjs/http-timer@5.0.1, @esm2cjs/is@5.6.0, @esm2cjs/lowercase-keys@3.0.0, @esm2cjs/p-cancelable@3.0.0 ├─┬ https://opencollective.com/node-fetch │ │ └── node-fetch@3.3.2 │ └── https://github.com/sponsors/jimmywarting │ └── fetch-blob@3.2.0, node-domexception@1.0.0 ├── https://github.com/sponsors/lupomontero │ └── psl@1.15.0 ├── https://github.com/fb55/entities?sponsor=1 │ └── entities@6.0.1, entities@2.2.0, entities@4.5.0 ├── https://github.com/sponsors/NaturalIntelligence │ └── fast-xml-parser@5.4.1 ├── https://opencollective.com/serialport/donate │ └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0 ├── https://github.com/inikulin/parse5?sponsor=1 │ └── parse5@8.0.0 ├── https://github.com/sponsors/csstools │ └── @csstools/css-syntax-patches-for-csstree@1.1.2, @csstools/css-calc@3.1.1, @csstools/css-color-parser@4.0.2, @csstools/color-helpers@6.0.2, @csstools/css-parser-algorithms@4.0.0, @csstools/css-tokenizer@4.0.0 ├─┬ https://github.com/chalk/chalk-template?sponsor=1 │ │ └── chalk-template@0.4.0 │ └── https://github.com/chalk/chalk?sponsor=1 │ └── chalk@4.1.2 ├── https://github.com/prettier/prettier?sponsor=1 │ └── prettier@3.8.1 ├── https://opencollective.com/ioredis │ └── ioredis@4.31.0 ├── https://github.com/sindresorhus/execa?sponsor=1 │ └── execa@5.0.1 ├─┬ https://paulmillr.com/funding/ │ │ └── chokidar@3.6.0 │ └── https://github.com/sponsors/jonschlinkert │ └── picomatch@2.3.1 ├── https://github.com/sponsors/sibiraj-s │ └── ci-info@3.9.0 ├── https://github.com/sponsors/Brooooooklyn │ └── @node-rs/bcrypt@1.10.7 ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1 │ │ └── cheerio@1.0.0-rc.10 │ ├─┬ https://github.com/sponsors/fb55 │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.2.2, domelementtype@2.3.0 │ │ └── https://github.com/fb55/domutils?sponsor=1 │ │ └── domutils@2.8.0, domutils@3.2.2 │ ├── https://github.com/cheeriojs/dom-serializer?sponsor=1 │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0 │ ├── https://github.com/fb55/domhandler?sponsor=1 │ │ └── domhandler@4.3.1, domhandler@5.0.3 │ └── https://github.com/fb55/htmlparser2?sponsor=1 │ └── htmlparser2@6.1.0, htmlparser2@8.0.2 ├─┬ https://github.com/sindresorhus/got?sponsor=1 │ │ └── got@12.6.1 │ └── https://github.com/sindresorhus/is?sponsor=1 │ └── @sindresorhus/is@5.6.0 ├── https://locize.com │ └── i18next@25.8.14 ├── https://ko-fi.com/killymxi │ └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0 ├── https://ko-fi.com/intcreator │ └── cron@4.4.0 ├── https://github.com/sponsors/chrvadala │ └── node-ble@1.13.0 └── https://www.buymeacoffee.com/systeminfo └── systeminformation@5.31.4npm fund ist uninteressant.
Wie schaut der Baum denn nun nach dem prune aus? -
Wie schaut der Baum denn nun nach dem prune aus?@Thomas-Braun
hi, siehe #17juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm prune npm warn deprecated npmlog@4.1.2: This package is no longer supported. npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported. npm warn deprecated glob@7.2.3: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.me npm warn deprecated gauge@2.7.4: This package is no longer supported. up to date in 3s 214 packages are looking for funding run `npm fund` for details -
@Thomas-Braun
sind nicht wegjuergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous ├── @types/w3c-web-usb@1.0.13 extraneous ├── @yarnpkg/lockfile@1.1.0 extraneous ├── find-yarn-workspace-root@2.0.0 extraneous ├── iobroker.admin@7.8.23 ├── iobroker.backitup@3.3.17 ├── iobroker.birthdays@5.0.0 ├── iobroker.daswetter@4.5.3 ├── iobroker.device-reminder@3.1.2 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@2.0.4 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.feiertage@1.4.0 ├── iobroker.flot@1.12.0 ├── iobroker.fritzbox@0.7.0 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullcalendar@2.4.5 ├── iobroker.history@4.0.0 ├── iobroker.hm-rega@5.1.0 ├── iobroker.hm-rpc@3.0.1 ├── iobroker.ical@1.20.1 ├── iobroker.icons-fatcow-hosting@0.1.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.javascript@9.0.18 ├── iobroker.js-controller@7.2.2 ├── iobroker.melcloud@3.0.4 ├── iobroker.mqtt@6.1.4 ├── iobroker.node-red@6.0.7 ├── iobroker.proxmox@2.6.1 ├── iobroker.pvforecast@6.1.0 ├── iobroker.radar2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.scenes@4.0.4 ├── iobroker.shelly@10.6.1 ├── iobroker.shuttercontrol@2.0.12 ├── iobroker.simple-api@3.0.7 ├── iobroker.snmp@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sonos@3.0.0 ├── iobroker.synology@3.1.0 ├── iobroker.systeminfo@1.3.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@4.1.0 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-material-advanced@1.7.4 ├── iobroker.vis-material@0.2.0 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis-weather@2.5.13 ├── iobroker.vis@1.5.6 ├── iobroker.web@8.0.0 ├── iobroker.whatsapp-cmb@0.3.0 ├── iobroker.ws@4.1.0 ├── is-docker@2.2.1 extraneous ├── is-wsl@2.2.0 extraneous ├── json-stable-stringify@1.3.0 extraneous ├── jsonify@0.0.1 extraneous ├── klaw-sync@6.0.0 extraneous ├── micromatch@4.0.8 extraneous ├── node-gyp-build@4.8.4 extraneous ├── open@7.4.2 extraneous ├── patch-package@8.0.1 extraneous ├── slash@2.0.0 extraneous ├── tmp@0.2.5 extraneous ├── usb@2.17.0 extraneous └── yaml@2.8.2 extraneous -
sind nicht wegjuergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous ├── @types/w3c-web-usb@1.0.13 extraneous ├── @yarnpkg/lockfile@1.1.0 extraneous ├── find-yarn-workspace-root@2.0.0 extraneous ├── iobroker.admin@7.8.23 ├── iobroker.backitup@3.3.17 ├── iobroker.birthdays@5.0.0 ├── iobroker.daswetter@4.5.3 ├── iobroker.device-reminder@3.1.2 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@2.0.4 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.feiertage@1.4.0 ├── iobroker.flot@1.12.0 ├── iobroker.fritzbox@0.7.0 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullcalendar@2.4.5 ├── iobroker.history@4.0.0 ├── iobroker.hm-rega@5.1.0 ├── iobroker.hm-rpc@3.0.1 ├── iobroker.ical@1.20.1 ├── iobroker.icons-fatcow-hosting@0.1.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.javascript@9.0.18 ├── iobroker.js-controller@7.2.2 ├── iobroker.melcloud@3.0.4 ├── iobroker.mqtt@6.1.4 ├── iobroker.node-red@6.0.7 ├── iobroker.proxmox@2.6.1 ├── iobroker.pvforecast@6.1.0 ├── iobroker.radar2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.scenes@4.0.4 ├── iobroker.shelly@10.6.1 ├── iobroker.shuttercontrol@2.0.12 ├── iobroker.simple-api@3.0.7 ├── iobroker.snmp@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sonos@3.0.0 ├── iobroker.synology@3.1.0 ├── iobroker.systeminfo@1.3.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@4.1.0 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-material-advanced@1.7.4 ├── iobroker.vis-material@0.2.0 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis-weather@2.5.13 ├── iobroker.vis@1.5.6 ├── iobroker.web@8.0.0 ├── iobroker.whatsapp-cmb@0.3.0 ├── iobroker.ws@4.1.0 ├── is-docker@2.2.1 extraneous ├── is-wsl@2.2.0 extraneous ├── json-stable-stringify@1.3.0 extraneous ├── jsonify@0.0.1 extraneous ├── klaw-sync@6.0.0 extraneous ├── micromatch@4.0.8 extraneous ├── node-gyp-build@4.8.4 extraneous ├── open@7.4.2 extraneous ├── patch-package@8.0.1 extraneous ├── slash@2.0.0 extraneous ├── tmp@0.2.5 extraneous ├── usb@2.17.0 extraneous └── yaml@2.8.2 extraneous@Alero Also noch Chaos drin.
Ich weiß aber nicht wo da der Hase im Pfeffer liegt. -
was ist wenn ich die pakete von hand deinstalliere?
z.B. npm uninstall json-stable-stringify -
cd /opt/iobroker && npm ls slash
juergen@iobroker:~$ cd /opt/iobroker && npm ls slash [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├─┬ patch-package@8.0.1 extraneous │ └── slash@2.0.0 deduped └── slash@2.0.0 extraneous -
juergen@iobroker:~$ cd /opt/iobroker && npm ls slash [sudo] password for juergen: iobroker.inst@3.0.0 /opt/iobroker ├─┬ patch-package@8.0.1 extraneous │ └── slash@2.0.0 deduped └── slash@2.0.0 extraneousIch würde behaupten, das braucht keiner mehr.
Aber wie hast du die Dinger überhaupt in das System reingehievt? Unorthodoxe Installation von irgendwas via github oder direkt per npm? -
Mit einem
npm uninstall PAKETNAMEin dem entsprechenden Verzeichnis.
Kann aber sein, dass du dir damit dann andere Baustellen aufreißt. -
was ist mit dem Befahl yarn? wenn ich ihn nutzen will muss ich ihn erst installieren, oder?
Wenn das Paket weiterhin als extraneous oder Warnung auftaucht, nutzen Sie den Aufräum-Befehl von Yarn, um veraltete oder ungenutzte Verknüpfungen zu entfernen:yarn cache clean yarn clean
