  4. Fehler bei Update von vis-icontwo 2.11.6
    2.3k
    4.3k
54 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
    Alero
    schrieb am zuletzt editiert von Alero
    moin,
    hier der diag:
    ```bash
    Script v.2026-06-06
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.12.63+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 3month 1d
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64bit
    System was installed 110 days ago (on 2026-03-13).
    Systemuptime and Load:
     10:19:53 up 21:17,  1 user,  load average: 0.13, 0.21, 0.20
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-07-02 10:19:53 CEST
               Universal time: Thu 2026-07-02 08:19:53 UTC
                     RTC time: Thu 2026-07-02 08:19:53
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    juergen
    HOME=/home/juergen
    GROUPS=juergen adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            8.3G        4.7G        2.7G        4.6M        1.2G        3.6G
    Swap:           5.5G          0B        5.5G
    Total:           13G        4.7G        8.2G
    Active iob-Instances:   36
             7947 M total memory
             4526 M used memory
             4171 M active memory
              786 M inactive memory
             2600 M free memory
              223 M buffer memory
              873 M swap cache
             5237 M total swap
                0 M used swap
             5237 M free swap
    top - 10:19:54 up 21:17,  1 user,  load average: 0.13, 0.21, 0.20
    Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 92.9 id,  0.0 wa,  0.0 hi,  2.4 si,  0.0 st
    MiB Mem :   7947.3 total,   2600.3 free,   4527.1 used,   1096.8 buff/cache
    MiB Swap:   5238.0 total,   5238.0 free,      0.0 used.   3420.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  496K  795M   1% /run
    /dev/sda1      ext4       93G  6.0G   83G   7% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  3.9M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Wed Jul  1 13:02:50 2026] EXT4-fs (sda1): orphan cleanup on readonly fs
    [Wed Jul  1 13:02:50 2026] EXT4-fs (sda1): mounted filesystem ad7cb7c3-87c0-4151-8142-0f5900745d4e ro with ordered data mode. Quota mode: none.
    [Wed Jul  1 13:02:51 2026] EXT4-fs (sda1): re-mounted ad7cb7c3-87c0-4151-8142-0f5900745d4e r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    666M    /var/
    333M    /var/cache
    325M    /var/cache/apt
    235M    /var/cache/apt/archives
    174M    /var/lib
    Archived and active journals take up 143.2M in the file system.
    /opt/iobroker/backups:
    16M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    798M    /opt/iobroker/iobroker-data/
    587M    /opt/iobroker/iobroker-data/files
    129M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    59M     /opt/iobroker/iobroker-data/files/vis
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    19M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.23.1
    /usr/bin/node           v22.23.1
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.1-1nodesource1
      Candidate: 22.23.1-1nodesource1
      Version table:
     *** 22.23.1-1nodesource1 1001
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 76626)
    Core adapters versions
    js-controller:  7.2.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
    + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.email.0                  : email                 : iobroker                                 - disabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.42.15
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.42.15
    + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.42.15
    + system.adapter.mqtt.4                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.42.15
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 192.168.42.15
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 192.168.42.15
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.42.15, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1883, bind: 192.168.42.15
      system.adapter.sonoff.1                 : sonoff                : iobroker                                 - disabled, port: 1884, bind: 192.168.42.15
      system.adapter.sonoff.2                 : sonoff                : iobroker                                 - disabled, port: 1888, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5001
    + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
      system.adapter.text2command.1           : text2command          : iobroker                                 - disabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
      system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                           │ name                          │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17' │ 'none'         │
    │ 2       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '5.0.0'  │ 'none'         │
    │ 3       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
    │ 4       │ 'system.adapter.device-reminder'             │ 'device-reminder'             │ '3.1.2'  │ 'none'         │
    │ 5       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
    │ 6       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
    │ 7       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
    │ 8       │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
    │ 9       │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'  │ 'none'         │
    │ 10      │ 'system.adapter.fb-checkpresence'            │ 'fb-checkpresence'            │ '1.4.2'  │ 'none'         │
    │ 11      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
    │ 12      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
    │ 13      │ 'system.adapter.fritzbox'                    │ 'fritzbox'                    │ '0.7.0'  │ 'none'         │
    │ 14      │ 'system.adapter.fritzdect'                   │ 'fritzdect'                   │ '2.6.2'  │ 'none'         │
    │ 15      │ 'system.adapter.fullcalendar'                │ 'fullcalendar'                │ '2.4.5'  │ 'none'         │
    │ 16      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
    │ 17      │ 'system.adapter.hm-rega'                     │ 'hm-rega'                     │ '5.1.0'  │ 'none'         │
    │ 18      │ 'system.adapter.hm-rpc'                      │ 'hm-rpc'                      │ '3.0.1'  │ 'none'         │
    │ 19      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.1' │ 'none'         │
    │ 20      │ 'system.adapter.icons-fatcow-hosting'        │ 'icons-fatcow-hosting'        │ '0.1.0'  │ 'none'         │
    │ 21      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
    │ 22      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
    │ 23      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
    │ 24      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
    │ 25      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
    │ 26      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
    │ 27      │ 'system.adapter.info'                        │ 'info'                        │ '2.0.0'  │ 'none'         │
    │ 28      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
    │ 29      │ 'system.adapter.melcloud'                    │ 'melcloud'                    │ '3.0.4'  │ 'none'         │
    │ 30      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'  │ 'none'         │
    │ 31      │ 'system.adapter.node-red'                    │ 'node-red'                    │ '6.0.7'  │ 'none'         │
    │ 32      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.6.1'  │ 'none'         │
    │ 33      │ 'system.adapter.pvforecast'                  │ 'pvforecast'                  │ '6.1.0'  │ 'none'         │
    │ 34      │ 'system.adapter.radar2'                      │ 'radar2'                      │ '2.4.0'  │ 'none'         │
    │ 35      │ 'system.adapter.rpi2'                        │ 'rpi2'                        │ '2.4.0'  │ 'none'         │
    │ 36      │ 'system.adapter.sayit'                       │ 'sayit'                       │ '5.1.0'  │ 'none'         │
    │ 37      │ 'system.adapter.scenes'                      │ 'scenes'                      │ '4.0.4'  │ 'none'         │
    │ 38      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
    │ 39      │ 'system.adapter.shuttercontrol'              │ 'shuttercontrol'              │ '2.0.12' │ 'none'         │
    │ 40      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
    │ 41      │ 'system.adapter.snmp'                        │ 'snmp'                        │ '3.4.0'  │ 'none'         │
    │ 42      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
    │ 43      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'  │ 'none'         │
    │ 44      │ 'system.adapter.sonos'                       │ 'sonos'                       │ '3.0.0'  │ 'none'         │
    │ 45      │ 'system.adapter.sourceanalytix'              │ 'sourceanalytix'              │ '0.4.14' │ 'none'         │
    │ 46      │ 'system.adapter.synology'                    │ 'synology'                    │ '3.1.0'  │ 'none'         │
    │ 47      │ 'system.adapter.systeminfo'                  │ 'systeminfo'                  │ '1.3.0'  │ 'none'         │
    │ 48      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
    │ 49      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '4.1.0'  │ 'none'         │
    │ 50      │ 'system.adapter.text2command'                │ 'text2command'                │ '4.0.0'  │ 'none'         │
    │ 51      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
    │ 52      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
    │ 53      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
    │ 54      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
    │ 55      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
    │ 56      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'  │ 'none'         │
    │ 57      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
    │ 58      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.6' │ 'none'         │
    │ 59      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'  │ 'none'         │
    │ 60      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
    │ 61      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
    │ 62      │ 'system.adapter.vis-material'                │ 'vis-material'                │ '0.2.0'  │ 'none'         │
    │ 63      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
    │ 64      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
    │ 65      │ 'system.adapter.vis-metro'                   │ 'vis-metro'                   │ '1.2.0'  │ 'none'         │
    │ 66      │ 'system.adapter.vis-players'                 │ 'vis-players'                 │ '0.1.6'  │ 'none'         │
    │ 67      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
    │ 68      │ 'system.adapter.vis-weather'                 │ 'vis-weather'                 │ '2.5.13' │ 'none'         │
    │ 69      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
    │ 70      │ 'system.adapter.whatsapp-cmb'                │ 'whatsapp-cmb'                │ '0.3.0'  │ 'none'         │
    │ 71      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
    Adapter    "fritzbox"     : 0.7.0    , installed 0.7.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "melcloud"     : 3.0.4    , installed 3.0.4
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
    Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "sayit"        : 5.1.0    , installed 5.1.0
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "snmp"         : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
    Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        23068
    States:         22190
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 0s (31.6 kB/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
    udp   UNCONN 0      0      192.168.42.15:mdns        0.0.0.0:*    users:(("io.tr-064.0",pid=2125,fd=71))
    udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=517,fd=5),("systemd",pid=1,fd=45))
    udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=517,fd=7),("systemd",pid=1,fd=47))
    tcp   LISTEN 0      511    192.168.42.15:8084        0.0.0.0:*    users:(("io.socketio.0",pid=2447,fd=34))
    tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=687,fd=6))
    tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=517,fd=4),("systemd",pid=1,fd=44))
    tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=677,fd=29))
    tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=677,fd=23))
    tcp   LISTEN 0      511    192.168.42.15:1888        0.0.0.0:*    users:(("io.mqtt.4",pid=1969,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:1881        0.0.0.0:*    users:(("io.shelly.0",pid=1986,fd=36))
    tcp   LISTEN 0      511    192.168.42.15:1880        0.0.0.0:*    users:(("node-red",pid=1231,fd=23))
    tcp   LISTEN 0      511    192.168.42.15:1883        0.0.0.0:*    users:(("io.mqtt.3",pid=1877,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:1884        0.0.0.0:*    users:(("io.mqtt.1",pid=1806,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:1886        0.0.0.0:*    users:(("io.mqtt.2",pid=39829,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:42001       0.0.0.0:*    users:(("io.hm-rpc.0",pid=1705,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:42010       0.0.0.0:*    users:(("io.hm-rpc.1",pid=1722,fd=35))
    tcp   LISTEN 0      511    192.168.42.15:8701        0.0.0.0:*    users:(("io.hm-rpc.2",pid=1739,fd=35))
    tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=687,fd=7))
    tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=517,fd=6),("systemd",pid=1,fd=46))
    tcp   LISTEN 0      511                *:8087              *:*    users:(("io.simple-api.0",pid=2424,fd=35))
    tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=2260,fd=35))
    tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.1",pid=718,fd=40))
    tcp   LISTEN 0      511                *:3500              *:*    users:(("io.sonos.0",pid=2020,fd=31))
    2026-07-02 10:20:04.859  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_relative"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_relative/
    2026-07-02 10:20:04.891  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_persistent_absolute/
    2026-07-02 10:20:04.891  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_persistent_absolute"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_persistent_absolute/
    2026-07-02 10:20:04.908  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_relative/
    2026-07-02 10:20:04.909  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_relative"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_relative/
    2026-07-02 10:20:04.913  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute" with regex /solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/
    2026-07-02 10:20:04.914  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/limit_nonpersistent_absolute"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.limit_nonpersistent_absolute/
    2026-07-02 10:20:04.923  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power" with regex /solar\.[^.]*\.cmd\.power/
    2026-07-02 10:20:04.923  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/power"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.power/
    2026-07-02 10:20:04.941  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart" with regex /solar\.[^.]*\.cmd\.restart/
    2026-07-02 10:20:04.941  - info: mqtt.2 (39829) Client [OpenDTU-4876280] subscribes on "solar/+/cmd/restart"  with regex /mqtt\.2\.solar\.[^.]*\.cmd\.restart/
    2026-07-02 10:20:05.059  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:05.091  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:05.109  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:05.115  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:05.123  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:05.141  - info: mqtt.2 (39829) Client [OpenDTU-4876280] publishOnSubscribe send all known states
    2026-07-02 10:20:10.977  - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching CheckDeadBatt()
    2026-07-02 10:20:10.978  - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching MakeTable
    2026-07-02 10:20:10.980  - info: javascript.0 (767) script.js.common.BattUeberwachung: Reaching MakeJSONTable
    2026-07-02 10:20:11.083  - info: javascript.0 (767) script.js.common.FensterUeberwachung: setForeignState(id=javascript.0.FensterUeberwachung.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Büro<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 20 Std. 37 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Flur<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 18 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gäste Wc<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 21 Std. 55 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Gästezimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1007 Tage 21 Std. 55 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Garage<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 20 Std. 49 Min.</div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Küche<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1001 Tage 23 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style='margin: auto; display: block; filter: invert(1); height: 40px;' src='/icons-mfd-svg/fts_door.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0</td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Wohnzimmer<br><div style='font-size:12px; font-weight:normal;'>Tür geschlossen: 1001 Tage 20 Std. 50 Min.</div></td></tr></tbody></table>","ack":true,"ts":1782980411083,"q":0,"from":"system.adapter.javascript.0","lc":1782980411083,"c":"script.js.common.FensterUeberwachung"})
    2026-07-02 10:20:17.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 39966
    2026-07-02 10:20:19.030  - info: dwd.0 (39966) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.23.1, js-controller: 7.2.2
    2026-07-02 10:20:19.294  - info: dwd.0 (39966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-07-02 10:20:19.812  - info: host.iobroker instance system.adapter.dwd.0 having pid 39966 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    ============= Mark until here for C&P =============
    • A Alero
      moin,
      hier der diag:
      ```bash
      Script v.2026-06-06
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64bit
      CPU threads     : 4
                    NTP service: active
                RTC in local TZ: no
      juergen
      HOME=/home/juergen
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           5.5G          0B        5.5G
               7947 M total memory
               4526 M used memory
               2600 M free memory
                223 M buffer memory
                873 M swap cache
               5237 M total swap
                  0 M used swap
               5237 M free swap
      *** FILESYSTEM ***
      /var:
      666M    /var/
      333M    /var/cache
      325M    /var/cache/apt
      174M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.8.23
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        23068
      States:         22190
      @Alero
      Jetzt schaut es gut aus. Um ganz sicher zu gehen, schau dir den npm tree an:
      cd /opt/iobroker && npm ls
        @Alero
        Alero
        @Thomas-Braun sagte:
        permitted by applicable law.
        Last login: Thu Jul  2 10:18:10 2026 from 192.168.42.13
        juergen@iobroker:~$ cd /opt/iobroker && npm ls
        [sudo] password for juergen:
        iobroker.inst@3.0.0 /opt/iobroker
        ├── @stoprocent/bluetooth-hci-socket@1.5.2 extraneous
        ├── @types/w3c-web-usb@1.0.13 extraneous
        ├── @yarnpkg/lockfile@1.1.0 extraneous
        ├── find-yarn-workspace-root@2.0.0 extraneous
        ├── iobroker.admin@7.8.23
        ├── iobroker.backitup@3.3.17
        ├── iobroker.birthdays@5.0.0
        ├── iobroker.daswetter@4.5.3
        ├── iobroker.device-reminder@3.1.2
        ├── iobroker.discovery@5.0.0
        ├── iobroker.dwd@2.8.5
        ├── iobroker.echarts@3.1.0
        ├── iobroker.email@2.0.4
        ├── iobroker.energiefluss@3.6.2
        ├── iobroker.fb-checkpresence@1.4.2
        ├── iobroker.feiertage@1.4.0
        ├── iobroker.flot@1.12.0
        ├── iobroker.fritzbox@0.7.0
        ├── iobroker.fritzdect@2.6.2
        ├── iobroker.fullcalendar@2.4.5
        ├── iobroker.history@4.0.0
        ├── iobroker.hm-rega@5.1.0
        ├── iobroker.hm-rpc@3.0.1
        ├── iobroker.ical@1.20.1
        ├── iobroker.icons-fatcow-hosting@0.1.0
        ├── iobroker.icons-icons8@0.0.1
        ├── iobroker.icons-material-png@0.1.0
        ├── iobroker.icons-mfd-png@1.2.1
        ├── iobroker.icons-mfd-svg@1.2.0
        ├── iobroker.icons-open-icon-library-png@0.1.2
        ├── iobroker.influxdb@4.0.2
        ├── iobroker.javascript@9.0.18
        ├── iobroker.js-controller@7.2.2
        ├── iobroker.melcloud@3.0.4
        ├── iobroker.mqtt@6.1.4
        ├── iobroker.node-red@6.0.7
        ├── iobroker.proxmox@2.6.1
        ├── iobroker.pvforecast@6.1.0
        ├── iobroker.radar2@2.4.0
        ├── iobroker.sayit@5.1.0
        ├── iobroker.scenes@4.0.4
        ├── iobroker.shelly@10.6.1
        ├── iobroker.shuttercontrol@2.0.12
        ├── iobroker.simple-api@3.0.7
        ├── iobroker.snmp@3.4.0
        ├── iobroker.socketio@7.1.3
        ├── iobroker.sonoff@3.3.0
        ├── iobroker.sonos@3.0.0
        ├── iobroker.synology@3.1.0
        ├── iobroker.systeminfo@1.3.0
        ├── iobroker.tankerkoenig@3.4.0
        ├── iobroker.telegram@4.1.0
        ├── iobroker.text2command@4.0.0
        ├── iobroker.tr-064@4.3.0
        ├── iobroker.upnp@1.1.0
        ├── iobroker.vis-bars@0.1.4
        ├── iobroker.vis-canvas-gauges@1.0.1
        ├── iobroker.vis-history@1.0.0
        ├── iobroker.vis-hqwidgets@1.6.1
        ├── iobroker.vis-icontwo@2.11.6
        ├── iobroker.vis-inventwo@4.1.1
        ├── iobroker.vis-jqui-mfd@1.1.3
        ├── iobroker.vis-justgage@2.1.7
        ├── iobroker.vis-material-advanced@1.7.4
        ├── iobroker.vis-material@0.2.0
        ├── iobroker.vis-materialdesign@0.5.9
        ├── iobroker.vis-metro@1.2.0
        ├── iobroker.vis-players@0.1.6
        ├── iobroker.vis-timeandweather@1.2.2
        ├── iobroker.vis-weather@2.5.13
        ├── iobroker.vis@1.5.6
        ├── iobroker.web@8.0.0
        ├── iobroker.whatsapp-cmb@0.3.0
        ├── iobroker.ws@4.1.0
        ├── is-docker@2.2.1 extraneous
        ├── is-wsl@2.2.0 extraneous
        ├── json-stable-stringify@1.3.0 extraneous
        ├── jsonify@0.0.1 extraneous
        ├── klaw-sync@6.0.0 extraneous
        ├── micromatch@4.0.8 extraneous
        ├── node-gyp-build@4.8.4 extraneous
        ├── open@7.4.2 extraneous
        ├── patch-package@8.0.1 extraneous
        ├── slash@2.0.0 extraneous
        ├── tmp@0.2.5 extraneous
        ├── usb@2.17.0 extraneous
        └── yaml@2.8.2 extraneous
        • A Alero
          @Alero
          In der ersten Ebene liegen eigentlich nur Module, die iobroker.XYZ heißen. Also alles, was da auch als 'extraneous' gekennzeichnet ist ist auch genau das: Überflüssig.
          Versuch mal per
          cd /opt/iobroker && npm prune
          da Ordnung reinzubringen.
            @Alero
            Versuch mal per
            Alero
            @Thomas-Braun
            juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm prune
            npm warn deprecated npmlog@4.1.2: This package is no longer supported.
            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
            npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
            npm warn deprecated glob@7.2.3: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.me
            npm warn deprecated gauge@2.7.4: This package is no longer supported.
            up to date in 4s
            214 packages are looking for funding
              run `npm fund` for details
              Alero
              juergen@iobroker:/opt/iobroker$ npm fund
              iobroker.inst@3.0.0
              ├── https://github.com/sponsors/epoberezkin
              │   └── ajv@6.14.0
              ├─┬ https://opencollective.com/express
              │ │ └── body-parser@2.2.2, http-errors@2.0.1, iconv-lite@0.7.2, mime-types@3.0.2, express@4.22.1, express-session@1.19.0, cors@2.8.6, multer@2.1.1
              │ └── https://github.com/sponsors/ljharb
              │     └── qs@6.15.0, side-channel@1.1.0, object-inspect@1.13.4, side-channel-list@1.0.0, side-channel-map@1.0.1, call-bound@1.0.4, side-channel-weakmap@1.0.2, get-intrinsic@1.3.0, function-bind@1.1.2, gopd@1.2.0, has-symbols@1.1.0, has-tostringtag@1.0.2, minimist@0.2.4, qs@6.14.2, call-bind@1.0.8, define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1.2.1, es-abstract@1.24.1, array-buffer-byte-length@1.0.2, arraybuffer.prototype.slice@1.0.4, available-typed-arrays@1.0.7, data-view-buffer@1.0.2, data-view-byte-offset@1.0.1, es-to-primitive@1.3.0, is-date-object@1.1.0, is-symbol@1.1.1, function.prototype.name@1.1.8, functions-have-names@1.2.3, get-symbol-description@1.1.0, globalthis@1.0.4, has-proto@1.2.0, is-array-buffer@3.0.5, is-callable@1.2.7, is-data-view@1.0.2, is-negative-zero@2.0.3, is-regex@1.2.1, is-set@2.0.3, is-shared-array-buffer@1.0.4, is-string@1.1.1, is-typed-array@1.1.15, is-weakref@1.1.1, object.assign@4.1.7, own-keys@1.0.1, regexp.prototype.flags@1.5.4, safe-array-concat@1.1.3, safe-push-apply@1.0.0, safe-regex-test@1.1.0, string.prototype.trim@1.2.10, string.prototype.trimend@1.0.9, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.3, for-each@0.3.5, typed-array-byte-offset@1.0.4, reflect.getprototypeof@1.0.10, which-builtin-type@1.2.1, is-async-function@2.1.1, is-finalizationregistry@1.1.1, is-generator-function@1.1.2, which-boxed-primitive@1.1.1, is-bigint@1.1.0, has-bigints@1.1.0, is-boolean-object@1.2.2, is-number-object@1.1.1, which-collection@1.0.2, is-map@2.0.3, is-weakmap@2.0.2, is-weakset@2.0.4, typed-array-length@1.0.7, unbox-primitive@1.1.0, which-typed-array@1.1.20
              ├── https://github.com/sponsors/broofa
              │   └── uuid@9.0.1
              ├── https://opencollective.com/js-sdsl
              │   └── @js-sdsl/ordered-map@4.4.2, js-sdsl@4.3.0
              ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
              │ │ └── wrap-ansi@7.0.0, wrap-ansi@8.1.0
              │ └── https://github.com/chalk/ansi-styles?sponsor=1
              │     └── ansi-styles@4.3.0, ansi-styles@6.2.3
              ├── https://github.com/sponsors/feross
              │   └── safe-buffer@5.2.1, buffer@6.0.3, simple-get@4.0.1, simple-concat@1.0.1
              ├── https://github.com/sponsors/jaredhanson
              │   └── passport@0.7.0, oauth2orize@1.12.0
              ├── https://github.com/sponsors/RubenVerborgh
              │   └── follow-redirects@1.16.0
              ├── https://github.com/sponsors/panva
              │   └── jose@4.15.9
              ├── https://github.com/sponsors/isaacs
              │   └── glob@10.5.0, foreground-child@3.3.1, signal-exit@4.1.0, jackspeak@3.4.3, minimatch@9.0.9, path-scurry@1.11.1, rimraf@3.0.2, glob@7.2.3
              ├── https://github.com/sponsors/AlCalzone
              │   └── @esm2cjs/got@13.0.0, @esm2cjs/cacheable-lookup@7.0.0, @esm2cjs/cacheable-request@10.2.12, @esm2cjs/mimic-response@4.0.0, @esm2cjs/normalize-url@8.0.0, @esm2cjs/responselike@3.0.0, @esm2cjs/form-data-encoder@2.1.4, @esm2cjs/http-timer@5.0.1, @esm2cjs/is@5.6.0, @esm2cjs/lowercase-keys@3.0.0, @esm2cjs/p-cancelable@3.0.0
              ├─┬ https://opencollective.com/node-fetch
              │ │ └── node-fetch@3.3.2
              │ └── https://github.com/sponsors/jimmywarting
              │     └── fetch-blob@3.2.0, node-domexception@1.0.0
              ├── https://github.com/sponsors/lupomontero
              │   └── psl@1.15.0
              ├── https://github.com/fb55/entities?sponsor=1
              │   └── entities@6.0.1, entities@2.2.0, entities@4.5.0
              ├── https://github.com/sponsors/NaturalIntelligence
              │   └── fast-xml-parser@5.4.1
              ├── https://opencollective.com/serialport/donate
              │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
              ├── https://github.com/inikulin/parse5?sponsor=1
              │   └── parse5@8.0.0
              ├── https://github.com/sponsors/csstools
              │   └── @csstools/css-syntax-patches-for-csstree@1.1.2, @csstools/css-calc@3.1.1, @csstools/css-color-parser@4.0.2, @csstools/color-helpers@6.0.2, @csstools/css-parser-algorithms@4.0.0, @csstools/css-tokenizer@4.0.0
              ├─┬ https://github.com/chalk/chalk-template?sponsor=1
              │ │ └── chalk-template@0.4.0
              │ └── https://github.com/chalk/chalk?sponsor=1
              │     └── chalk@4.1.2
              ├── https://github.com/prettier/prettier?sponsor=1
              │   └── prettier@3.8.1
              ├── https://opencollective.com/ioredis
              │   └── ioredis@4.31.0
              ├── https://github.com/sindresorhus/execa?sponsor=1
              │   └── execa@5.0.1
              ├─┬ https://paulmillr.com/funding/
              │ │ └── chokidar@3.6.0
              │ └── https://github.com/sponsors/jonschlinkert
              │     └── picomatch@2.3.1
              ├── https://github.com/sponsors/sibiraj-s
              │   └── ci-info@3.9.0
              ├── https://github.com/sponsors/Brooooooklyn
              │   └── @node-rs/bcrypt@1.10.7
              ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
              │ │ └── cheerio@1.0.0-rc.10
              │ ├─┬ https://github.com/sponsors/fb55
              │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.2.2, domelementtype@2.3.0
              │ │ └── https://github.com/fb55/domutils?sponsor=1
              │ │     └── domutils@2.8.0, domutils@3.2.2
              │ ├── https://github.com/cheeriojs/dom-serializer?sponsor=1
              │ │   └── dom-serializer@1.4.1, dom-serializer@2.0.0
              │ ├── https://github.com/fb55/domhandler?sponsor=1
              │ │   └── domhandler@4.3.1, domhandler@5.0.3
              │ └── https://github.com/fb55/htmlparser2?sponsor=1
              │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
              ├─┬ https://github.com/sindresorhus/got?sponsor=1
              │ │ └── got@12.6.1
              │ └── https://github.com/sindresorhus/is?sponsor=1
              │     └── @sindresorhus/is@5.6.0
              ├── https://locize.com
              │   └── i18next@25.8.14
              ├── https://ko-fi.com/killymxi
              │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
              ├── https://ko-fi.com/intcreator
              │   └── cron@4.4.0
              ├── https://github.com/sponsors/chrvadala
              │   └── node-ble@1.13.0
              └── https://www.buymeacoffee.com/systeminfo
                  └── systeminformation@5.31.4
              • A Alero
                iobroker.inst@3.0.0
                │   └── ajv@6.14.0
                │   └── uuid@9.0.1
                │   └── jose@4.15.9
                │   └── psl@1.15.0
                │   └── parse5@8.0.0
                │     └── chalk@4.1.2
                │   └── execa@5.0.1
                │   └── ci-info@3.9.0
                │ │ └── got@12.6.1
                │   └── cron@4.4.0
                @Alero
                npm fund ist uninteressant.
                Wie schaut der Baum denn nun nach dem prune aus?
                  @Alero
                  Alero
                  @Thomas-Braun
                  hi, siehe #17
                  up to date in 3s
                  • A Alero
                    @Thomas-Braun
                    hi, siehe #17
                    up to date in 3s
                    @Alero
                    anschauen und gucken ob die extraneous Dinger jetzt weg sind.
                      Alero
                      sind nicht weg
                      juergen@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
                      • A Alero
                        sind nicht weg
                        @Alero Also noch Chaos drin.
                        Ich weiß aber nicht wo da der Hase im Pfeffer liegt.
                          Alero
                          was ist wenn ich die pakete von hand deinstalliere?
                          z.B. npm uninstall json-stable-stringify
                          • A Alero
                            @Alero
                            Schau zuerst mal wo die Doubletten liegen.
                            cd /opt/iobroker && npm ls slash
                            zum Beispiel.
                              Alero
                              juergen@iobroker:~$ cd /opt/iobroker && npm ls slash
                              ├─┬ patch-package@8.0.1 extraneous
                              │ └── slash@2.0.0 deduped
                              └── slash@2.0.0 extraneous
                              • A Alero
                                @Alero
                                Ich würde behaupten, das braucht keiner mehr.
                                Aber wie hast du die Dinger überhaupt in das System reingehievt? Unorthodoxe Installation von irgendwas via github oder direkt per npm?
                                  Alero
                                  i.d.R eigentlich nur über iobroker.
                                    Alero
                                    und wie bekomme ich die jetzt weg?
                                    • A Alero
                                      @Alero
                                      Mit einem
                                      npm uninstall PAKETNAME
                                      in dem entsprechenden Verzeichnis.
                                      Kann aber sein, dass du dir damit dann andere Baustellen aufreißt.
                                        Alero
                                        habe es mit slash versucht. ist immer noch da
                                        npm uninstall slash
                                          Alero
                                          klappt bei anderen auch nicht
